on the website of the Icarus a lot of interesting articles, sometimes, to unload the heads from the other work - I read them, mostly because their model is very close to my understanding of the physics of the world (I'm talking about resonance model), because I have reason (very simplistically speaking) to assume that all have a resonance ( and our perception of space and time - in some ways too, but that's much outside of this topic)
Here is an excerpt on the topic of contactless processing:
----The phenomenon of noncontact electrochemical water activation (BAS) was theoretically predicted in 1992 by I. L. Gerlovin is based on the physical theory of the fundamental field [1].. Experimental data on contactless ECHO first published by W. M. Bahir in 1992 [2].
----Hermetic thin-walled closed containers (ampoules or capsules) or tube made of polyvinyl chloride (PVC, diameter 3 mm, wall thickness 1 mm) with saline solution was placed in a working chamber (anodic or cathodic) electrochemical diaphragm activator. Typically, activation of the ampoules was carried out 30 min while the current, or while current is off just before the dive tanks with saline in the ECHO environment.
----After 30 min of contactless activation parameters for the solutions in the vials were as follows [3]:
Table.
The Parameters Of The Outcome.
NAT R-R Anolyte Catholyte D ЛА0
D LAR D СА0
D SAR D ФА0
D LIGHTS D ЛК0
LKR D D SC0
D TFR D ФК0
D FKR
pH 6.7±0.2 1.1 11.5 -0.8±0.1
-1.3±0.1 -0.2±0.1
-0.5±0.1 0.1±0.2
0.2±0.15 0.5±0.2
0.8±0.2 0.2±0.15
0.4±0.2 -0.4±0.1
-0.2±0.1
MV 260±5 1135±15 -845±5 110±10
150±7 31±8
30±5 -80±5
-130±4 -490±7
-560±10 -280±5
-370±6 23±7
30±10
ЛА0 where D = pH(ORP)Lao-pH(ORP)Ref.Phys.R-R; L,, f - the material of the ampoule (polyester, glass, PTFE); And activation in the anolyte To the catholyte, P(O) - activation when the current is turned on (off) immediately before dipping of containers with the physiological solution in the ECHO environment.
----Thus, after exposure of the sealed vials with physiological solution in the anolyte or in the catholyte the pH and ORP of a physiological solution change significantly, which can be considered as a manifestation of contactless ECHO. This effect is qualitatively the same when the electrolyzer and when it is off. Anolyte and catholyte are in a physiological solution through glass, lavsan and fluoroplastic. In addition, for glass and Dacron the direction of changes in pH and ORP corresponds to the sign of the electrochemical treatment (anodic or cathodic), and for fluoropolymer characterized by inversion of the sign of electrochemical machining. After 2 hours, the pH and ORP, changed as a result of contactless ECHO, are relaxation, indicating the absence of penetration of the stable products of eletrolyte inside closed vials. Therefore, non-contact ECHO osushestvlyaetsya on the energy level without the attendant transport (mass exchange) of ions through the ampoules wall [3].
----To clarify the nature of the phenomenon of contactless activation, we conducted additional experiments.
http://www.ikar.udm.ru/sb15-12.htm
ie, the topic started in private conversation with a Zombie to hydrogen it has a very secondary relation
but just in this place is seen a strong intersection with the topic of structuring itself.
another thing is that there are very stable structures (live for years and this is confirmed), and activators usually do not give a stable structure.
Moreover, this effect has a resonant nature. Stable structure in which there are other analogues in the world (nature) that's why I mentioned Vistalizator pomahival and a ban on its screening.
It is also interesting that some (many of my friends) people are not interested in special treatment, was fond of its activation in the field of Tesla coils (more precisely katscher) and talked about the interesting effects that usually people write about-ORP (sea of energy, increase immunity, etc.).
And in most cases the idea of such activation came to mind intuitively.
I haven't tested how changing the characteristics of water next to the Tesla and do change.
But I checked a few other interesting things about electrolysis and came to the conclusion that under pulsed electrolysis (short pulses) (see links in the topic about the book the digital world) one of the electrodes is activated and energy is already being drawn to the land is kind of weak, but a source of energy. (in the biological sense).
Because of this and some other observations, I believe that we need to look wider than just the negative-ORP.
Ideally you need -ORP water with sustainable structures harmonious body(and long gelisimi), which is not the fact that the desired cell, but the fact that the required information (what you write on water).<
