Himself Gura
Has thanked: 478 times
Been thanked: 264 times
Re: Myself Gura
Post by ЛИЛИЯ-Р » Sat Nov 12, 2016 17:47
Чезаре wrote:
нева wrote:
Чезаре wrote:What now with him? Incarnate? Or what?
. it is believed that the development of the person, the less he time (by our standards) you need for the next incarnation, which already happens to some extent consciously, due to the conservation of accumulated personal qualities aligned(designed) with the energies of Earth and Sky. In principle, time(by our standards) had enough, and would come already..)
and I can write. And really?
Neva and I think the more a person is developed , the less he was here on Earth ,the lessons will get the most, and more will be occupied in a different space))) Or not to be embodied and to be rastoplenny Teachers, Mentors and so on. ))
Only those who have not "learned" and not have the experience needed and of consciousness, because in the school the second year and let's learn , ATO once again be a repetition. There is a lot to say on this topic but not in this thread.
Castaneda was fond of many , but you know its all right.? This base so much perelojennoe hex.....passes that's understandable. The book I have Magicheskie passes Castaneda is prakticheskoe described like terms. Too lazy to do it or time more is not enough.
But all sorts of stalking and other fermentation through the maze of Tonally nahalem and so on-everyone will understand through your filters. In General, when there is practice , there is nothing to compare. But...while praktichesski also fails somewhere to go-the reasons vesskie. Yes does not matter.
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Re: Myself Gura
Post by Иван Славов » Sat Nov 12, 2016 17:48
Yes, the theme revealing.
Much better to be your own guru than to wait for external /even the term was, when guru prikosnutsya to you, or you touch with the guru, hehehhe, and you sort of get what does the healing, whether the enlightenment/ "pickup".
p.s. so one well-known example is the Pak Jae Woo - disembodiment, but for many you know, and so manages his Affairs. And the fact that I can't tell where now /what the/ Castaneda - /well, at least I poluchili :lol: / not even worth it to report the obvious conclusions.
кросби
Has thanked: 56 times
Been thanked: 33 times
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 17:50
нева wrote:while expressing some semantic meaning, it probably came from the secret Masonic signs with his fingers. therefore, it is difficult to say what exactly was meant when the folding fingers "goat", which is basically a secret sign conscious "Satanists".).
There is a reason to assume that Castaneda,in addition to the practical use and symbolism in the sequence have invested?
нева
Has thanked: 21 times
Been thanked: 90 times
Re: Myself Gura
Post by нева » Sat Nov 12, 2016 18:02
кросби
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 18:05
Neva
Then there was the hijacking?
нева
Re: Myself Gura
Post by нева » Sat Nov 12, 2016 18:08
Crosby Let's just say...there is nobody not a secret that Milton Erickson, the legend of therapeutic hypnosis, it officially worked in a very major organizations, not himself, He unraveled to the whole world) and this is not to say that Arizonasee hypnosis..this is blasphemy, kakraz Vice versa. As well as NLP.
кросби
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 18:20
Neva
Downloaded Harner-"the way of the shaman"
нева
Re: Myself Gura
Post by нева » Sat Nov 12, 2016 19:06
Crosby
кросби wrote:I Downloaded Harner-"the way of the shaman"
..The way of the shaman..honestly..he didn't read to the end..its good to read for the overall development..or.. to catch what is the difference between Castaneda and Hareram..and what is.. in one case .. a huge popularity, and the other full not popularity. In the case of two friends.
By the way I reserve the right to delete your posts after reading, which I consider unnecessary.)
нева
Re: Myself Gura
Post by нева » Sat Nov 12, 2016 19:12
Crosby actually..here is a shamanic journey purely Garnero. Penguin is the teacher encountered in his unconscious..during the dive, which tells. "GLIDE"
кросби
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 19:38
Neva
What film?
кросби
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 19:42
нева wrote:by the Way I reserve the right to delete your posts after reading, which I consider unnecessary.)
where such impulsivity,to write, and then erase?By the way I because of this, YOU moved on,thought is a form of trolling of the interlocutor,even screenshots do.
нева
Re: Myself Gura
Post by нева » Sat Nov 12, 2016 19:56
Crosby the movie fight club...about "schizophrenia", and deleted reports..this is such information that does not need to Chur was referring to, who should he read it. To post this picture.. "representation of the world picture" that by and large nekchemu..) and "to stir up dirty Laundry" in different directions.. once again, too nekchemu.) Why should for example know how the hare Krishnas, have put Japan for many millions of dollars removed from the country using their skills in "the substitution of internal dialogue as" mahamantras, because the recitation of mantras, it is also a wonderful practice, but it's better to be used for good than to declassify the materials, and to repel asylum.))
кросби
Re: Myself Gura
Post by кросби » Sat Nov 12, 2016 19:58
нева wrote:Crosby movie fight club...about "schizophrenia",
he smiled :)
Has thanked: 5 times
Been thanked: 16 times
Re: Myself Gura
Post by Вячеслав. » Sat Nov 12, 2016 23:54
ОльгаВВ
Has thanked: 60 times
Been thanked: 45 times
Re: Myself Gura
Post by ОльгаВВ » Sun Nov 13, 2016 4:29
! or ... more appropriate, although it can be .
but it vryatli :)
нева
Re: Myself Gura
Post by нева » Sun Nov 13, 2016 21:09
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: Myself Gura
Post by мимоходом » Wed Nov 23, 2016 9:56
And still unanswered question - what is the third attention... Maybe someone will tell? The second note is clear about the opinion is not with intelligence and logic, and subconscious, perception and sensation, where, depending on the neural connections to the subcortical associated with a particular area of the brain (visual, auditory, tactile) - that allows you to directly apply to this zone the raw data flow from the limbic system.
But the third attention is what and how is expressed?
Рита С
Has thanked: 4 times
Been thanked: 30 times
Re: Myself Gura
Post by Рита С » Wed Nov 23, 2016 11:34
Well, it's like, when you're in the first and second attention, flashlight illuminate their perception around the Assembly point, collecting worlds.
And third, it included the light around the cocoon. :)
мимоходом
Re: Myself Gura
Post by мимоходом » Wed Nov 23, 2016 13:29
to leave entirely at the field level, becoming pure unconscious?
аВАЛОН
Re: U-system.
Post by аВАЛОН » Sun Dec 04, 2016 15:30
Андрей Кабанков wrote:http://www.mindmachine.ru/club/u-system.htm
in my understanding, obtained after the scan. this is a common simple device resonant circuit coil capacity, very small compact dimensions, the resonance of which is configured to the natural frequency with the frequency of the Schumann vibrations of the earth mother, what this device has much in common with BRM system expanded a little, effektami infopresse of biological objects, as a result no magic tricks to getting this but you will be under the cocoon people can work as a resonant amplifier resetting the vibration of the people on the range, sort it as the system oscillator in the receiver where tuning a resonant circuit coil, the capacity we tune to the required station with pleasant music :) this around the amplifier then the people themselves on the principle of the effect of 100 monkeys PS did no one out of curiosity get looted and have not looked what's inside? what's up chip, dip, processor, etc. know-how 8) to me it resembles FSC
нева
Re: Myself Gura
Post by нева » Mon Dec 05, 2016 0:08
мимоходом wrote:to leave completely at the field level, becoming pure unconscious?
To go on field level, that is.. the Kingdom of heaven..)
нева
Re: Myself Gura
Post by нева » Mon Dec 05, 2016 0:18
аВАЛОН
Re: U-system.
Post by аВАЛОН » Fri Dec 16, 2016 11:46
Испытатель wrote: What kind of nonsense are you talking about? The Frequency Of The Noise...
This is a common card RFID 13.56 MHz.
On since this is Your first post on the forum in this view of this branch, that's saying a lot :) zaslanets-Kozachok which is specifically registered to protect the authors of the "miracle" of the invention conventional resonant circuit for which people buratinki lay out a bunch of dough, and it is clear who cares that their business was losing customers, of course the truth needs to succumb to lastcol criticism and to omit those who are trying razoblochit mountain magicians :) as always, comrade shouldn't have any appliances to Your friends there is not poisonramune elementary read, And how beautifully painted direct from boots the miracle skarahod painted, and with a piece of cloth painted like a tablecloth Samobranka. well done talent :wiz :wiz really don't make me reveal all info
аВАЛОН
Re: Myself Gura
Post by аВАЛОН » Sun Dec 18, 2016 1:58
good informative technology rfid http://www.alpha1.ru/recomend/rfid_lowcost.pdf
The information field of the Earth and the Internet of things http://grazit.ru/informacionnoe-pole-ze ... eshej.html
http://www.muiv.ru/vestnik/pdf/pp/ot_2014_2_178-182.pdf
Key words. The Internet of things, radio frequency identification, individual frequency of oscillation, the energy field. :) :roll:
Мартин
Been thanked: 58 times
Re: Natural Artifacts
Post by Мартин » Sun Feb 18, 2018 23:02
Martin's expedition to Russia in the framework of the project "Natural artifacts"
Image\
