Appeared in the sale of rims from Andrei Patrushev
Пианистка
Has thanked: 10 times
Post by Пианистка » Sun Jan 20, 2008 0:18
Andrey Kabanov
Hello, Andrey!
Can discs audiostrobe listen through a regular DVD?
If, in principle, Yes, then how many lost?
Thank you.
Been thanked: 182 times
Post by Андрей Кабанков » Sun Jan 20, 2008 13:46
Татьяна_Я wrote:Andrew Kabankov
Hello, Andrey!
Thank you.
Yes,you can listen to the player and no different from the SD player in this case.
Пианистка
Post by Пианистка » Sun Jan 20, 2008 21:44
Andrey Kabanov
Thank You, Andrew!
Today I sent the order on 4 discs.
КАА1970
Post by КАА1970 » Thu Mar 27, 2008 16:47
Question to Andrei Patrushev, and everyone who knows
In the manual for Your drive, the Guide mentioned that scientists have learned how to get in contact with DNA. Could you provide a link to these materials if you have them. It was interesting to read. In Explorer these techniques also apply?
Post by Андрей Патрушев » Thu Mar 27, 2008 17:05
КАА1970 wrote:Question to Andrei Patrushev, and everyone who knows
It is not "material" and very thick book of disciple of the famous hypnotist Milton Erickson - Ernest Rossi, devoted to the so-called "pallavolo the signaling" (in Russian were not translated).
Post by Guest » Thu Mar 27, 2008 17:40
Андрей Патрушев wrote:Is not "material" and very thick book of disciple of the famous hypnotist Milton Erickson - Ernest Rossi, devoted to the so-called "pallavolo the signaling" (in Russian were not translated).
Andrew, please give the title of the book, maybe she translated into German. :)
Post by Андрей Патрушев » Thu Mar 27, 2008 17:46
Okay - at home today.
Post by Guest » Thu Mar 27, 2008 17:47
THANK you!!!!
Post by Guest » Thu Mar 27, 2008 21:15
While Andrew is watching the title of the book, I found one book by Ernest Rossi in Russian "PSICOBIOLOGIA TREATMENT model “BODY-CONSCIOUSNESS”
and immediately in the Preface, the author came across , and I quote
"Example: is There a relationship at the level of the mind (?)? Whether movement of the mind, change of mental state have an impact not only on our emotions or blood pressure, but also on the genes and molecules that are enclosed in microscopic cages of our organism? Are there any real evidence of this? If you push any endocrinologist for the answer to this question, he will say: “Yes it is!” Under the influence of mental stress lymphatic(?)-hypothalamic system will convert nerve impulses in brain neurohormonal - molecules - the carriers of our body. In turn, this process will stimulate the endocrine system to produce steroid hormones that can reach the nucleus of various cells of the body and cause modulation of genes. Then these genes can cause cells the formation of molecules, which will influence metabolism, growth, activity level, sexuality, response of the immune system as the disease and in a healthy condition of the body. Thus, the relationship at the level of consciousness and genetics still exists! And all this affects the formation and composition of the molecules of life!"
Post by Андрей Патрушев » Fri Mar 28, 2008 10:53
Ernest L. Rossi The psychobiology is of Gene Expression: neuroscience and neurogenesis in hypnosis and the healing arts. – W. W. Norton & Company, New York/London, 2002.
ISBN 0-393-70343-6
Post by Guest » Fri Mar 28, 2008 14:19
Andrew, unfortunately the Germans had not had the honor to translate this book. Other on hypnosis a lot. In the English version is on Amazon, but I am not satisfied. If there is text on the computer, then I have it with the translator to manage as well :cry:
Фогель
Post by Фогель » Sun Mar 30, 2008 22:33
Maybe my question sounds strange,but:which of the following CDs you can listen to at night,that is, with the subsequent falling asleep?and then what to do with the rule *of the second glass of water* ? Star traveler, Ultramesh...In the answers was poking around,but it turns out that the night listen to sample of these discs,and which can simply be put to sleep?If not the above,then call ,if not difficult ,other.The aim of the listening,like many,poor sleep,depression,but everything is still the need to learn English.Oh,and here's a second question has arisen:the language is taught on the courses is in the background listening to this CD is not possible,what to do in this case?Thanks in advance for the detailed answer!
Post by Андрей Патрушев » Mon Mar 31, 2008 10:05
Фогель wrote:Maybe my question will sound weird,but:which of the following CDs you can listen to at night,that is, with the subsequent falling asleep?and then what to do with the rule *of the second glass of water* ? Star traveler, Ultramesh...In the answers was poking around,but it turns out that the night listen to sample of these discs,and which can simply be put to sleep?If not the above,then call ,if not difficult ,other.The aim of the listening,like many,poor sleep,depression,but everything is still the need to learn English.Oh,and here's a second question has arisen:the language is taught on the courses is in the background listening to this CD is not possible,what to do in this case?Thanks in advance for the detailed answer!
To put to sleep, perhaps only Healing and if You have a pillow Sleepsonic. Disk space wanderer better to listen to in the morning, and Ultramega necessary to engage with the learning material.
If the head does not hurt, the second Cup can not drink. :)
Post by Guest » Tue Apr 01, 2008 23:31
Thanks for the reply!and just one more question:))))Is a normal computer speakers can give the desired frequency of sound?and another thing:is it possible to listen to CDs in the background?not even the tech:what do you listen to in the background(about Ultramesh clear)?For example Andorfine?
Post by Андрей Патрушев » Thu Apr 03, 2008 9:28
And then the computer speakers?
Yes, actually, everything except Explorer, you can listen in the background - the question of effectiveness.
Михаил 2
Post by Михаил 2 » Thu Apr 17, 2008 5:16
Lord!
Which ROM can be used when working with grief (death of a relative) At the moment is "Explorer", "Ultramesh", "Massage brain", "Endorphins", "Star traveler"?.
In terms of BWG in this case, to generate any waves, or a combination thereof need to focus?
Post by Андрей Патрушев » Thu Apr 17, 2008 8:51
Михаил 2 wrote:gentlemen!
At the first stage - all Star traveler, on the second Conductor.
As always alpha.
Ринат
Post by Ринат » Thu Apr 17, 2008 21:00
Adrey V. when we will enjoy new disks?
Post by Андрей Патрушев » Thu Apr 17, 2008 22:28
Ринат wrote:, Andrei Vadimovich, when we will enjoy new disks?
Perhaps only in the fall...:)
Жека2008
Post by Жека2008 » Mon May 12, 2008 18:13
Purchased the "Explorer" and "Healing." There are a couple of questions at the audition in conjunction with a mind machine.
1. What program include?
2. How to synchronize the time of the session in MM and playing time of the CD? For example Bremse sound of the conductor is 70 minutes. This integrated session, in MM no...
Post by Андрей Патрушев » Mon May 12, 2008 18:22
Жека2008 wrote:Acquired "Explorer" and "Healing." There are a couple of questions at the audition in conjunction with a mind machine.
Please read the instructions to machine on the topic of audiostrobe. :?
Post by Guest » Fri May 16, 2008 2:42
:roll: :roll: :roll: :shock: :shock: guys read all the posts in this thread and honestly :roll: :roll: :roll: if something you can not but really want you so? combine anything you want Because if the medication and this kind of "medicine" to take as a hit and the result can be :cry: because if you drink castor oil with strengthening then who knows what will pardon me for the comparison But the mind is not a toy Andrew please explain what is safer and more effective in terms of use
Post by Guest » Fri May 16, 2008 2:53
I was referring to your drives how to apply if you have manual why everyone asks that when possible and always different for different cases as a doctor at the reception. Can create a separate section-manual TIA then and then this with this and this with that .ATO to begin to do you have to shovel all the posts all the themes to choose fits me well Honestly sit for several months, watching the results but did not understand disks enough to work with me or need a car and glasses .What I mean is that this topic started 2 years ago if not more and the questions are all the same and new people also not clear It would be convenient for you and for us if there were a theme separately How to combine mm and drives when and how and why I'm Sorry if that was wrong, But to read all the posts in order to extract useful information no time, I was trying to figure out to make the conclusions I need mm or discs or not enough and what points is better and why Thanks in advance what Izvinitye
Post by Андрей Патрушев » Fri May 16, 2008 8:43
Well, okay... I will Answer for the hundredth time. :?
Drives and mindmachine is not the pills and not the enema. They do not cure, and is intended for self-improvement. Better health is only a side effect. The effect of both those, and others very soft and unobtrusive, even though this is one of the most important factors in their effectiveness. All the recommendations and instructions written on the basis of the experience and highlight only the most effective (average path) path. But everyone is different, and everyone can certainly find your most effective method of application, since the experiments with discs and mindmachine safe enough.
Post by Guest » Fri May 16, 2008 14:41
Andrew I apologize for the analogy with drugs is a painful topic sitting at the hospital with a pinched lumbar vertebr. cross. Department That's looking for a way out . The old methods already in use by me do not act and live any way I want :cry: normal not to crawl .So I think the machine is no money and the disks even with delivery well,as I live in Moscow. Again for the clueless :o :o :o some drives while you can
