Re: Stream. The basic features and rates.
Post by Михаил_ » Sat Oct 26, 2013 20:44
UI children's peace must take a different crisis-conflict and just hysterical symptoms, excessive moods and stuff... if that is of course not much additional contributing causes in the family or outside thereof.
in short the main trend of it - to help the child with adaptability without conflict, and attempting to bend others after the scandal-scream-tantrum or manipulation.
occupies two slots.
cost - free (need a pre-purchased slots, replaces them with 2.2)
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Sat Oct 26, 2013 21:05
Михаил_ wrote:FE child calm
Interested in age limit (approximately of course)
Макте
Post by Макте » Sat Oct 26, 2013 21:11
There is a perception that women grow up very early (school period or even earlier), but men are, in principle, never grow up, there is need to understand what a "child" need to calm down :)
Post by Михаил_ » Sat Oct 26, 2013 21:14
Yes, to some at any age is useful.... :) in General, no limits of age, just assume that as adults, there should be a kind of mindfulness, although many of the zeros...
алекс.
Has thanked: 4 times
Post by алекс. » Sun Oct 27, 2013 0:52
Михаил_ wrote:not yet had time to answer.... I remember this question, it's just one sentence the answer is no.
OK, I'll wait
ПавелР
Post by ПавелР » Wed Oct 30, 2013 12:34
Hello!
Tell me the product 3.1 OZ and entails the obligation to repurchase as a result of annual subscription?
Thank you!
Post by Михаил_ » Wed Oct 30, 2013 14:28
ПавелР wrote:Hello!
Thank you!
It is obvious that the obligation of a yearly subscription, is a product of the point group (these products are in a tangible medium and high demand).
These products also belong to the basic (see link on the price list on the website), so Yes, entail.
The obligation is due to the fact that You get a more powerful analog products and some it'll catch on in a short time. To create such a price distortion would not be true.
At the same time, small lifetime use of broadcast products can create the illusion that "development completed" when insufficient time broadcast, and we are not interested to stimulate the discrepancy is not fully functional product.
Obviously the monthly rate is actually a product in installments or something so hence the obligation.
This does not apply to IE (see the list of IP) and product group VIP (since they are bought immediately).
Post by Михаил_ » Wed Oct 30, 2013 14:49
алекс. wrote:Michael, please describe in detail the module UI "Integration with the new" in broadcast mode, principle of work and in what situations you can apply; also asked to talk about the principle of operation of the modules "activation of male sexual energy" and "normalization of the urogenital system" is in General terms, the cleaning and washing out of the blocks, or something else here laid?
About the module "Energy for sex," You wrote that triggered the activation of memory and the actual flows and their correct variants of "looping" in time - here, too, can elaborate on what you mean? Smoothing of peaks and failures in the past, future or something else?
.... well, actually, I like to say that as a joke about the set of psychics - "come you know where and when"...
with the UI all wrong... not just that sometimes words are hard to describe.
UI integration with new, stimulating integration processes in cases when a person has no proper experience of, well, just no.... not delivered :) ie, this experience will come faster, more intelligent and harmonious way. Less likely different inconsistencies, misunderstandings, conflicts. When to apply ? always, when integration with the new... work with this IP are also useful, and the situation (the experience from this PI will be grafted in some way, and without situations).
Energy sex - so quoted me like 100% described what. Activated memory and proper flow.
What are the peaks and dips? I do not understand... here literally says that we are talking about the fact that this area is fully or very highly distorted and 99.99% does not work properly in principle. Remember-run... of course not immediately and not momentalno. Also depends on the General znalosti other blocks in the behavior.
Ie in memory rise areas, where there is something about the correct course of the process, and in bodies, in time, run the correct flow of energy, collaboration and not just a primitive blend, as most now. There are a lot of nuances, depending on the PURPOSE of the collective flow.
ie creativity, impact on the world(sub art), conceiving the self healing (including the same memory of the same process) , and other options will cause the ideal different energy configuration and of varying quality, in some cases, there will be an outcome of energy outside, and others will all potrebica inside.
In General of course all do not necessarily know, because in the simplest case, this entrepreneur gradually (someone slow, someone faster) will cause some changes that will accumulate and changes of the above kind. All of this will have a positive impact on all aspects of life.
Something like that.<
ПавелР
Post by ПавелР » Wed Oct 30, 2013 15:27
Everything is clear )
I use wide bracelet 3.0 (only not long ago began to wear it all day until it was enough for an hour or two and not every day was an overload on the mind).
Does it make sense to connect the stream and 3.1 OZ? Or is it sufficient and appropriate that one of the two?
Thank you!
Post by Михаил_ » Wed Oct 30, 2013 15:49
I think it makes sense even with a gap of one month (or more), stream, though, and more powerful, but softer in some way...
интересующийсябж
Post by интересующийсябж » Wed Oct 30, 2013 17:37
Hello Michael,
You make the broadcast or do you prefer BJ to wear, I understand that the right combination of broadcast and BJ will give better results.
Thanks in advance.
Post by Михаил_ » Wed Oct 30, 2013 18:24
1. questions on the bracelets please post in the relevant thread, the discussion is ONLY broadcast on not a hodgepodge of everything, frame issues and write them where they belong. Please.... Then it's a lot of people already read from the archive branches take their time.
2. stream PC+ is a five slots that You have I for your phrase did not understand, and cannot know and do not remember. About PC+ 've been many times already chewed above. What You have connected to either email so that it is clear, or check in the office and ask the question more clearly (I suspect that it will simply cease to exist when you take the time to understand). I guess what is requested and what is - not.
ПавелР
Post by ПавелР » Wed Oct 30, 2013 19:24
If I rent a channel for 6 months, and the stream of IP connect for 1 month., will I be able to connect to the vacant slot any other entrepreneur?
Thank you!
Been thanked: 182 times
Post by Андрей Кабанков » Wed Oct 30, 2013 20:01
ПавелР wrote:If I rent a channel for 6 months, and the stream of IP connect for 1 month., will I be able to connect to the vacant slot any other entrepreneur?
Thank you!
Yes.
Макте
Post by Макте » Thu Oct 31, 2013 19:25
A few days of the broadcast (FRM, Panacea, PC). Cuts in a dream - is simply unrealistic. Today, especially with work early went to sleep. Wake up in a couple of hours eat and go to the website to read MM on a tablet, and I - "Access restricted" ("picture", as usual now sites block the law enforcement officers). After a little "investigation" with the operational staff of the site came to the conclusion that this problem I have only on your tablet (but everything else is working fine :shock: ) as with the laptop everything is OK (I ate probably something wrong).
Even in the last days noticed severe exacerbation of my social ties. People with their claims to me as something very special to became annoying (a small tight family, and quarreled with some colleagues at work with whom a lot of years, "Lisp"), although the situations at all, my irritability is not (or not yet had to deal with this). Even notice when you talk, I act and say, not as I would like (as would parallel the observer appeared, who wants something different and to talk and behave, but "this" while simply observing :roll: ). All this is already quite long stretches, but markedly in the last days as something very special.
Post by Михаил_ » Thu Oct 31, 2013 21:04
well the tablet by the way, what is provider in a network walk? maybe it's the fun of a single operator using which tablet? or tablet on the Wi-Fi geared ?
Макте
Post by Макте » Thu Oct 31, 2013 21:14
Михаил_ wrote:well the tablet by the way, what is provider in a network walk? maybe it's the fun of a single operator using which tablet? or tablet on the Wi-Fi geared ?
MTS. Tried via wifi and Rostelecom (through the past at the same time on a tablet, the site is not working and on the laptop everything is OK). Now, by the way, with writing tablet, under MTS, although five minutes ago had no access. Probably here's my "local" providers indulge. I was faced with the fact that the sites are blocked, although in official lists to ban them.
Аленка
Post by Аленка » Thu Oct 31, 2013 21:53
I also today was on restricted access, came out with a computer working, and the link was on the list of forbidden sites... an hour has gone - up. This glitch was not due to tablet, or provider.
Аленка
Post by Аленка » Thu Oct 31, 2013 22:14
actually I was looking at broadcast reviews, my runny nose stopped as suddenly as it had begun, which makes me very happy, but now a strange feeling in the area of the "third eye" as you tilt your head down in this place the pain is so strange, as if there is a stone wait to be thrown out, RUB the forehead, no pain, but it is necessary to bend - again oddities)) here was looking for one too, so it was... and then BAM - access restricted, the website is prohibited and credit lists give...
Макте
Post by Макте » Fri Nov 01, 2013 6:58
Аленка wrote:actually I was looking at broadcast reviews, my runny nose stopped as suddenly as it had begun, which makes me very happy, but now a strange feeling in the area of the "third eye" as you tilt your head down in this place the pain is so strange, as if there is a stone wait to be thrown out, RUB the forehead, no pain, but it is necessary to bend - again oddities)) here was looking for one too, so it was... and then BAM - access restricted, the website is prohibited and credit lists give...
Try a little to drink lemon juice (freshly squeezed, you can peel) four times a day half a Cup a day or much longer (just rinse your teeth after juice and soda water, for example), and Starry Wanderer Patrushev to listen to 8)
About the pain - I have a daily connection broadcast during very light Jogging lower back twisted so that the two minutes I was really shocked by such a sharp, prolonged pain. I have of course "extended" over all sorts of diseases, but this is something new. Knees again ache started (although a year ago I kind of healed). After a few days the tooth crumbled (but I do, in principle, expected).
Аленка
Post by Аленка » Fri Nov 01, 2013 9:43
Makte, thank you. Though it diluted with water, juice I mean, I doubt he could afford to clean... But I'll try anyway).
Макте
Post by Макте » Fri Nov 01, 2013 10:14
Аленка wrote:Makte, thank you. Though it diluted with water, juice I mean, I doubt he could afford to clean... But I'll try anyway).
Alenkawater just not worth it, including to drink water before and after. You can start with 50 grams to get used to. If we are really not talking that much to persist is not necessary - focus on your own feelings :)
львёнок
Been thanked: 5 times
Post by львёнок » Fri Nov 01, 2013 14:45
Макте wrote: Try a little to drink lemon juice (freshly squeezed, you can peel) four times a day half a Cup a day or much longer (just rinse your teeth after juice and soda water, for example)
and acid and soda in their break down tooth enamel, therefore, if for something to drink, it is better through a straw :wink:
With respect :)
Post by Михаил_ » Fri Nov 01, 2013 15:01
don't know where it erodes - I desire just ate a lemon :) well, cut slices and Yesh - he doesn't really sour :) well, not any more.... interesting to watch the reaction of others.
My wife taught :) I mean, I looked like she does with relish, literally, tried - cool :)
Just as hot peppers can is quite "mono" ... PS offtopic went :)
ПавелР
Post by ПавелР » Fri Nov 01, 2013 17:40
Please tell me where to read the description of the operation of the product series SP?
Thank you!
