Range. A new product in the social. the line.
ММ
Has thanked: 185 times
Been thanked: 40 times
Re: Spectrum. A new product in the social. the line.
Post by ММ » Tue Apr 14, 2015 1:23
Carried on the neck a couple of days matrix spectrum. There was a steady aversion to meat. And reluctance to have him at all. Before that neither AMB nor stream such effects were not given. :) Here's how it to understand? Like egregora meat did not work.And teams were not given.
Post by Михаил_ » Tue Apr 14, 2015 4:42
Yes, just needed another frequency from the operator and it was the last straw so to speak...
Петр.
Post by Петр. » Sat May 09, 2015 17:02
Storyboard of the spectrum.
Here https://yadi.sk/d/AVypOwOchnhDU
Галатея
Post by Галатея » Tue Jun 09, 2015 20:06
Hello Michael. I read the whole thread and in addition to reviews that range helps to fit into the society and work with egregors (though for me it is not clear how) for yourself didn't help. Could you briefly describe what else helps range (still social product)? May, for example, to help work interesting to find? I'm interested in the bracelet range - 4. And anyway, what would you advise to buy a bracelet or a better range of stream 5?
Post by Михаил_ » Tue Jun 09, 2015 20:53
1. Bracelet and translation complement each other, and they are somewhat different. I sometimes use them together, although usually without band (for me and so much worn), and the stream is always enabled. Well, more accurately it is sometimes off but it has long been the algorithms went to the level of assimilation (when I was prescribed it was the transition from the tried and tested ideas to structured practice and I took some time to soak up easy autopilot).
2. Can help in many ways, depend on You, as will apply. In other words "looking for work" he did not say, in most cases, although it is possible to transmit such a signal to society and maybe to get an answer useful, but in General the range probably requires a little more detailed control. Favor retrieves the operator, knowing in any case what society wants and drags it through the spectrum. Briefly, something like that.
Thank you.
Аксинья
Post by Аксинья » Sat Jun 13, 2015 21:14
I have not downloaded the storyboard . :?
Петр.
Post by Петр. » Fri Jul 10, 2015 18:28
Аксинья wrote:I Have not downloaded the storyboard . :?
Галатея
Post by Галатея » Wed Jul 15, 2015 1:37
If you can put the storyboard is also in pdf!!!
арте:м
Been thanked: 8 times
Post by арте:м » Wed Jul 15, 2015 3:14
Galateacan and in pdf
Галатея
Post by Галатея » Thu Jul 16, 2015 21:27
Spasibochki :wink:
Петр.
Post by Петр. » Wed Jul 22, 2015 22:08
Print range is better with source. You can see for yourself and compare that the difference is significant. (for those who understand)
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Thu Jan 28, 2016 22:14
Wife slipped on the probe 4 range - says the warm and hard enough!
Most of these effects have no...
Understood - I shouldn't have it in front of these to wear... looks Powerful probe :-)
ОлегЕ
Post by ОлегЕ » Fri Feb 12, 2016 15:17
Printed from the original, want to cut, glue blocks and thread your elastic. But there is a question-the order of the storyboard have to comply with? or not critical...
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Fri Feb 12, 2016 16:09
I think this is not important.
ОлегЕ
Post by ОлегЕ » Fri Feb 12, 2016 16:22
Thank You Vladimir! Someone tell me more....
Петр.
Post by Петр. » Fri Feb 12, 2016 20:41
ОлегЕ wrote:Printed from the original, want to cut, glue blocks and thread your elastic. But there is a question-the order of the storyboard have to comply with? or not critical...
The order of the storyboard is only in 1 cell that is clearly visible in the graphical editor at maximum zoom. All the other cells in this copy of the first. This option in the source was designed to be worn in the documents. Recommend doing dvuhstoronka a printout, and after it, is more dense laminate. It gives reinforcement and protects against wear. As for your revision, try it! But if it's a bracelet, can be done differently.
ОлегЕ
Post by ОлегЕ » Sat Feb 13, 2016 3:18
Peter, what would you recommend,I want the wristband to be done.Thank you! :)
Петр.
Post by Петр. » Sat Feb 13, 2016 4:26
Oleg to print on plastics and to the workpiece under a bracelet, for ease of Assembly.
Card from source works well through the eyes, access is much faster if the lack of effect in the passive wearing, plus well trained own skill without devices. :)
ОлегЕ
Post by ОлегЕ » Sat Feb 13, 2016 16:22
Петр. wrote:Oleg to print on plastics and to the workpiece under a bracelet, for ease of Assembly.
All printed and calaminarian two sides of the thick plastic that was in the cabin. I understand that in one cell raskazano all 22 minutes of video?(~1300 fps).Schliet 5-10 pieces and pour the epoxy in each cell of the matrix is already registered. Boom to try :) .
Post by Михаил_ » Wed Feb 17, 2016 22:05
I would recommend all the same just to "expose" the product is a projector of a video frame.... Now there are sooooo cheap projectors (need laser) with a price of anywhere from 200 dollars or below.
here the first search on herbest gave 80 dollars with bad resolution and best of about 200
http://www.gearbest.com/projector/pp_193475.html
t/e/ need a projector with a lamp (they are big usually) and compact - they are all laser diodes.
The laser facilitates the creation of conditions typical to run certain resonant processes in the world, although this is not the only and not the most effective way.
Патрик
Has thanked: 2 times
Been thanked: 5 times
Post by Патрик » Thu Feb 18, 2016 17:34
:shock: :shock: That is, charging with laptop and lenses are ineffective ??? "This is when the image from the laptop through the lens is on the product ?????? :cry: :(
Post by Михаил_ » Thu Feb 18, 2016 20:58
the perversion of what :) Yes, you can just the matrix screen thing to believe will be more effective than lens come up. The projector will obviously give much better result, although a few years ago when we used in the production of this technique some time there, except the projector was a whole abnormal area, but then I tested without it and on a weak projector - seminar free satisfied people, got strong (though there was AMB not a spectra if I remember correctly).
Lenses just do not need :) there is not in the picture business and in the process, it is only through a magnifying glass separate.
Патрик
Post by Патрик » Thu Feb 18, 2016 23:11
okay, thanks for the reply :)
Been thanked: 10 times
Post by Мастер 108 » Sat Feb 20, 2016 18:13
Михаил_ wrote:Lens doesn't need :) there is not in the picture business and in the process, it is only through a magnifying glass separate.
And lens the projector lens is not separate process?
Post by Михаил_ » Fri Mar 18, 2016 23:26
And then the lens :) no, of course :) everything will be OK with the process.... there output still laser irradiation and this leads to the features of the process.
