Strange anomalies
Константин.
Been thanked: 2 times
Re: Strange anomalies
Post by Константин. » Fri Nov 29, 2013 11:04
I have the same watch on a regular basis.
Open my eyes - darkness. but the flash was accurate.)
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Nov 29, 2013 12:57
КСС wrote:Friends, a question for you: when you go to bed and close my eyes, there are flashes outside, i.e. not inside you what is happening (in my head, mind), and it is outside you sent instant seconds a bright flash (while your eyes are closed)?
I was already so irradiated, that is when just go to sleep at night, and that's when I close my eyes - the outside is very bright flash of white. Like it's some invisible technique does. So about 5-7 times.
What could it be?
Consult an eye specialist and a neurologist, as may occur nevrologicheskoe problems and what to do with eyes, but with the lens of the eye.Flash can be a light in the eyes in glaucoma primary , the lights in glutaminova visible by day in people with early stage cataracts . But a lot of things. Maybe it's not your case , but still....
Post by Михаил_ » Fri Nov 29, 2013 13:12
this is not the case
Post by ЛИЛИЯ-Р » Fri Nov 29, 2013 13:41
Михаил_ wrote:this is not the case
I wonder then , what is it? I have the spillage of pigment in the crystalline lens there is a light spot and, after closing the eyes for a few seconds and remains a light spot, then goes off. But there are such flashes , I also did not notice the time , but nothing so strange is not connected. Although the window in the sky often seen , even tried to take a picture, but flash why even the camera is not reflected in the photo. Just watched somewhere a little less than a month ago a went to the window and there is orange color soft hangs like the moon but covered by some sort of cloud is not dense . The light from this ball was the cone up and down. I tried to understand the moon it's because that it is actually and the colors are often other and not so close and the light from it never saw. While looking to the left appeared the same and so began to tighten cloud is not dense and also up and down the light cone. I stood and tried to understand the glitches of this or that still is. Right then disappeared and appeared on the same level but behind the left globe. It looked like two huge eyes. Two moons orange is too much. Realized that you have to take pictures of, but until the camera took while the camera is turned on , both the "eye" is gone. And then quickly dissipated these clouds , covering the balls, literally in a couple seconds. Look I think if the moon ( and to assume that I have double vision))))), but now the clouds disperse and the moon rises. The clouds dispersed , and there is nothing :shock: :? Look out the window away , the moon is there in the side of the blue , as always . I was confused not so much the appearance of these balls , as the light from them. Because literally the day before I went to work and saw in the same place in the sky some lights and point-increasing, as if approaching.In the sky shining like flames , it also made the frame. Wanted to photograph , came out in the photo-the moon and the two lights, almost in a line. From the moon a blue cross of light , from lights orange. There is a photo on my phone so far. So I thought that the moon is so light and so taper to Shine should not. Light is usually in the photo in the cross is reflected , but not direct and under an angle of 45 degrees. Such are the observations. Or rather one of them.<
Константин.
Post by Константин. » Fri Nov 29, 2013 13:43
Of. Medicine can not sleep!!! :-)
Владер
Post by Владер » Fri Nov 29, 2013 14:21
ЛИЛИЯ-Р wrote: Look out the window away , the moon is there in the side of the blue , as always .
Damn, and I have always yellow :shock:
Post by bofara » Fri Nov 29, 2013 14:22
When you come home after work - it's too late, after about 00.00 hours. Then do something and begin to read the forum here or other information.. it Turns out that to 1-2 hours a night a sort of consciousness is in another 'plane' and just before bed are other 'perception'. So - last night I realized himself as :shock: call Leo /known to some here the magician/ talking to him /remember, almost all the details of the conversation and his reaction to my call/. By the way, I chose as the language of communication is Russian, and my Russian is not easy to communicate in real time.. it Turns out that I :shock: asked for it /i.e., call/ them and, if I understand correctly, the bilateral relationship was, ie, it's possible to 'build' consciousness, or easier - a glitch, but was very real /his reaction to my call was very believable/..
I etim magician in this life no nothing to do, sometimes I read his open forum, also watch the video on YouTube and all..
Etim status /call/ can work out, although I don't just spontaneously come out-turns..
Post by ЛИЛИЯ-Р » Fri Nov 29, 2013 15:14
Is not blue (but now it's been a long time like this), even red , it's a good point. Sometimes even with a halo is different, both in Sri Lanka have seen , that is certainly wonderful,but such a moon and even with their searchlights, I would call it , and even double))))Well, just with deep hangover can only be seen .))))But as dry as the leaf was , and it was not quite night, somewhere around 22 hours, I do not remember.
ВикторРусс
Post by ВикторРусс » Fri Nov 29, 2013 17:08
ЛИЛИЯ-Р wrote:covered what cloud is not dense . The light from this ball was the cone up and down. I tried to understand the moon it's because that it is actually and the colors are often other and not so close and the light from it never saw. While looking to the left appeared the same and so began to tighten cloud is not dense and also up and down the light cone
that you describe an observation of the flight of the UFO, there is an old book "UFOs in Voronezh" there are many similar eyewitness accounts.
КСС
Post by КСС » Fri Nov 29, 2013 17:35
Not this :)
Michael, THIS information is not voiced?
Post by Михаил_ » Fri Nov 29, 2013 21:57
too many options - I don't know, I don't want to sound not correct.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Sat Nov 30, 2013 23:58
Noticed (more than once) a rather strange and not very nice feature.
If you go and very busy some of my thoughts and aggressive drunk trying to approach, I bring out something that shifts from priblizhayuscheysya drunk faster just some chakra just below the navel to the left, and then the other (somewhere from the solar plexus to the navel), right (actually one continuous movement)
The drunk stops, rubs his eyes and quietly away.
Moreover, the consciousness in this area seems generally not involved... (it thinks it's white and fluffy :) )
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Sun Dec 01, 2013 16:33
I (drunk), usually funnel runoff is drained. It is necessary, whether that zatestit this method)) if possible, of course.
Макте
Post by Макте » Sun Dec 01, 2013 16:46
What could it be?
I have several times had. And I sleep in the mask on the eyes. Flash appeared in the dark and "broke through" in tightly pressed against the edge of the mask and not through the mask to sleep (in the room-then all is darkness tmusa even during the day - very thick curtains). That is, for some it vision or neuralgia I write off can not (although, to be honest, for neuralgia in my case, there are some suspicions). Of course there is just the chance of some sleepy glitches...
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Sun Dec 01, 2013 17:31
I'm also sleeping in a dark room in the mask for eyes. sometimes it happens that before my eyes(occupies the whole field of view) there is a carpet with fringe and she moves like the breeze. or flickering with a crunch. this in the eyes of the white-light-yellow-grey moving picture. Then I n her "dive" headfirst. Can continue to do in the dream what you want :) although it is better not to do it :(
Макте
Post by Макте » Sun Dec 01, 2013 17:33
Нетрезвый Сурдопереводчик wrote:I'm also sleeping in a dark room in the mask for eyes. sometimes it happens that before my eyes(occupies the whole field of view) there is a carpet with fringe and she moves like the breeze. or flickering with a crunch. this in the eyes of the white-light-yellow-grey moving picture. Then I n her "dive" headfirst. Can continue to do in the dream what you want :) although it is better not to do it :(
Well, it's the technician of the WTO and their ilk. Better to do it as often as possible :) IMHO. Here, in principle, can be any "picture" for such experiments. But flash me yet puts an impasse.
ВикторРусс
Post by ВикторРусс » Sun Dec 01, 2013 17:37
maybe this type of photo flash? someone commits the change :)
Макте
Post by Макте » Sun Dec 01, 2013 18:36
ВикторРусс wrote:maybe this type of photo flash? someone commits the change :)
:lol:
Better that then be neuralgia or visual glitches than paranoia 8)
Immediately I remembered the story about the girl (can't remember where I read), which at every flash of lightning stopped, looked at the sky and smiled - said that God was taking her photo.
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Sun Dec 01, 2013 18:48
Yeah, fuck these invisible "men in black". Still unclear what they erase, or, conversely, added. :evil:
Post by Михаил_ » Sun Dec 01, 2013 20:58
bofara wrote:When you come home after work - it's too late, after about 00.00 hours. Then do something and begin to read the forum here or other information.. it Turns out that to 1-2 hours a night a sort of consciousness is in another 'plane' and just before bed are other 'perception'. So - last night I realized himself as :shock: call Leo /known to some here the magician/ talking to him /remember, almost all the details of the conversation and his reaction to my call/. By the way, I chose as the language of communication is Russian, and my Russian is not easy to communicate in real time.. it Turns out that I :shock: asked for it /i.e., call/ them and, if I understand correctly, the bilateral relationship was, ie, it's possible to 'build' consciousness, or easier - a glitch, but was very real /his reaction to my call was very believable/..
there is some binding You to the structure (a long time) so there is nothing surprising (outside of the programmed action).
Post by bofara » Sun Dec 01, 2013 21:56
Yes, there are spells.. Well that's normal, we have almost the whole nation was told as a child-read books then the author, who has works /adult/, which mentioned Avadon, Avenir, etc., which are the product of a version adapted for kids.
But I don't notice /of course you can and it is, as You wrote/ programmed from outside the action - why do I programming in etim - Leo was parastatals a little bit, like: "who are you and what do you want?" and all /unless of course it was a real call, not a glitch/.
Легенда
Has thanked: 7 times
Been thanked: 9 times
Post by Легенда » Sun Dec 01, 2013 22:12
I'm here in the fall when the smartphone forum bracelets of life is opened. I now I always open the forum on your smartphone, feel some support and channel extension. Funny )))
Post by Михаил_ » Sun Dec 01, 2013 22:15
bofara wrote:Yes, there are spells.. Well that's normal, we have almost the whole nation was told as a child-read books then the author, who has works /adult/, which mentioned Avadon, Avenir, etc., which are the product of a version adapted for kids.
the action may not be programmed (for example on the contrary it may be well, for example the game of the subconscious to Omagh to show such a relationship).
In addition, as I understand it, Leo little (or not little?) aside from the General structure.
The twitching is apparently still there, but it may not be as programmed actions, and not as some direct manipulation
Post by bofara » Sun Dec 01, 2013 23:06
Михаил_ wrote:Twitching apparently still there, but it may not be as programmed actions, and not as some direct manipulation
Well, unless it is "some not direct manipulation" - I have a good mediumship manifests itself sings you and I'm looking forward greatly to the overall impact of the processes of this structure in the external world..
Of course, the baggage from past lives, in connection with the 'current structure' is - I remember as a child I had a strong 'vision' in the direction of magic, but rather the participation in certain rituals, mother is very scared when I was told that 'saw', and somehow managed to crush me in those things..
Владер
Post by Владер » Mon Dec 02, 2013 7:12
Yesterday was in the pine - grass still in full green.
But in the evening, apparently people in the habit of beginning to worry - "it is Time for winter to begin on December 1, after", and it was snowing.
Well, the explicit binding of the weather to social processes. :)
