G2.0AT - extension BJ on a cell phone.
Андрей Ермаков
- Has thanked: 3 times
- Been thanked: 15 times
OK, so all the same E. M. radiation is needed.
Re: G2.0AT - extension BJ on a cell phone.
The description clearly says that you need a collective communication device (laptop. phone, iPad with SIM card and so on, in short that in the network and emits a radio signal and has a battery) and most importantly - network!Андрей Ермаков wrote:OK, so all the same E. M. radiation is needed.
so something clearly
landline phone the old disk type without electronics too!
Андрей Ермаков
Okay. Neither of which is that it will be someone else's (not mine) device. Whose processes in this case will be supplied, mine or the owner?
The owner obviously. Well, if it is clearly defined. In some cases (where there is personally the owner) can be yours.
tell free version of a must-do on selfglue then to glue on the battery or is it enough to print out 2 pieces of paper and live one under the battery on the other battery
A homemade version is poorly suited for this purpose. Look for the discussion on the topic of Panacea.
was meant exactly G2.0AT free and not just a matrix panacea.
nenadal I'm in panaceia discussion about AT
can someone tell what the topic it was originally posted (the free version)and whether this forum or not but I took the source code with generator images and where they've been described I can not find, mainly across the comments what they are and how to glue them
It is clear that it is about at this same theme at
From this post viewtopic.php?p=94934#p94934 further.
Laid out was there on a few pages earlier and was intended primarily for generator
Well, if you still print on adhesive paper and then glue to smear and sculpt, as there is activation of the bondingХастред wrote:tell free version of a must-do on selfglue then to glue on the battery or is it enough to print out 2 pieces of paper and live one under the battery on the other battery
By chance (without my consent) to replace the old smart on the "stub". Stick at on the back cover, but forgot about the recommendation of Michael the third page: "First silver, then gold." Ie first stuck gold. Michael, is this critical or "everything will work as it should"? Thank you.
Will work.
Артем север
- Has thanked: 141 times
- Been thanked: 29 times
Bought at phone for 15,000 (two stickers, gold and silver), silver pasted side on the battery cover, Golden looks at the phone. Done all right? Both sticker directly on the battery.
How iPhone to glue them? Just on the back cover randomly or to each other? And who knows where is iPhone battery located in back (model 6 plus)?
Артем север wrote:how iPhone to glue them? Just on the back cover randomly or to each other? And who knows where is iPhone battery located in back (model 6 plus)?
both stickers on the outside(I mean on the back cover) next. First silver, then gold.
ИНОСТРАНКА
- Has thanked: 13 times
- Been thanked: 8 times
Tell pozh-La . If I take the test in the office 2.6 is the material of the bracelet and buy it at-is the norm. or is it still better to buy a BJ. At very need.
ИНОСТРАНКА
Thanks for the reply. Only you did not understand me a little. I just wanted to save. And take BJ paper,and at buy for 15 thousand rubles. And 30 I now expensive. Why ask such a question. Michael wrote that the presence of BJ definitely and then at.
- Has thanked: 1 time
- Been thanked: 10 times
Well, you can save
and yet — nothing stopping to make a homemade Panacea and you will be happy
ИНОСТРАНКА
MASTER 108 . Thank you.
Sit on the forum all consider. And I also came to the conclusion that I need to take the Panacea.
I'll try to make paper. I really need support.
Or buy the AT2 and BH a panacea. It will be like 15 times.
At the power plant obtained with the complex for "easy communication". A "hack" of the opponent, not so angry, but for the benefit of the business. If there is no BJ, what will nourish? A piece of paper? Buy 2.6 normal, then the AT2 or AT1 will go easier. Take your time.ИНОСТРАНКА wrote: Michael wrote that the presence of BJ definitely and then at.
ИНОСТРАНКА
Guys don't go to sleep
What I do is get confused. I think tomorrow to make the order . And just brains floating
. Please explain or where to see what - BH. like not met. And the meaning of this . Open a business associated with the consultations. I would like to quickly establish the flow of customers. And here is the thing thought to buy at. But as I wrote earlier, Michael recommends at only after purchasing and socks BJ.
ИНОСТРАНКА
The AT2 is also in the list
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
To complete the work required at ANY bracelet of life with the cell cloud is fine and free a Panacea. And commercial Panacea ebony (BH).
AND OS 2.2+. And 2.4. And improvised 2.1 from the video.
As they say, thousands of them!
About to take paper 2.6 - I don't think You quite understand correctly what the probes. You get a sampler free to use within a few days, and then he or he will break and You'll throw it away or not break, but still it NADO to throw out. It is NOT a means to save money. It is a means to decide the suitability of a particular product planned to purchase.
About free version 2.6 view here
Андрей Ермаков
You can even connect the simplest stream FRM (it is my free now only rent slot 450r/month) + there's still BJ is 2.2. Just for your case. Well, digital paper Panacea in the pocket to wear.
