Chamber! The doubts and reflections!
Пользователь
Post by Пользователь » Sun Oct 04, 2009 23:28
Жека3000
As such, the energy-the device no radiation, no EM radiation is not removed (like it is impossible). Know that the devices designed for such purposes. They work on another level and remove the negative information content of these radiations.
Svetlitsa is generally not aimed at the protection and on the normalization of the subtle fields of the human. And the strong aura she will be some protection.
Жека3000
Post by Жека3000 » Sun Oct 04, 2009 23:51
Пользователь wrote: heard it through the devices designed for such purposes.
Tell us a bit more about these devices! Or give a link where to read about them.
Жека3000
Post by Жека3000 » Sun Oct 04, 2009 23:55
Пользователь wrote:Svetlitsa is generally not aimed at the protection and on the normalization of the subtle fields of the human.
And the front room Window, after all, aimed at the normalization of space in the room, so I thought that maybe the radiation as it reduces. Because background radiation is a kind of pollution of space, though prostranstva on another level, a more "thick/touchable," but still.
Пользователь
Post by Пользователь » Mon Oct 05, 2009 0:02
Жека3000
The device that was used - Gamma 7N and BioProtect. But it's still individual. Most of the room, perhaps, to a certain extent will act the parlor Window, too, thought about her.
And then suddenly decided the background radiation to measure?
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 0:10
Yes, there were suspicions increased background. Moved recently and personally, I moved in a week where I began to feel tired all day after sleeping has become worse, and if getting enough sleep in the morning is the result of one terribly sleepy sometimes with a headache, woke up early on cheerful. And then got the dosimeter and decided to check, he showed a decent excess, but because the dosimeters deteriorate over time he can not be trusted and decided to call the professionals with a good detector. Tomorrow will be the result. But he has now said that the likely background and not from elevated source in General. He walks with headphones and the hiss is listening.
Пользователь
Post by Пользователь » Mon Oct 05, 2009 0:41
So in addition to radiation could still be EM radiation (for example, next to your bed at the neighbors is a CRT TV), or geopathic zones.
Post by Андрей Патрушев » Mon Oct 05, 2009 9:56
Granite gravel, part concrete, is a source of natural radiation. :shock: Factory JBI gravel must undergo dosimetric verification... :?
Андрей2009
Post by Андрей2009 » Mon Oct 05, 2009 13:20
Жека3000 wrote:Today conducted an experiment with water! Poured in 2 cups of water, one Cup left in the kitchen, the other moved into the room and put it on the Window sticker up to half an hour! In the end, trying alternately drank half the water from one half of a second, the difference is not felt at all no! Water water purified in the filter jug Aquaphor and after pranipatena. For purity of experiment try to give the person who did not know about the experiment, its conclusions have confirmed my feeling, there is no difference!
I, too, first thing I did - did an experiment. The water was cooler, the taste difference is not very noticeable (there was a slight metallic taste), but the smell is much more noticeable (again a metallic tint).
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 13:45
Андрей Патрушев wrote:Granite gravel, part concrete, is a source of natural radiation. Factory JBI gravel must undergo dosimetric verification...
Now new buildings constructed clear from what, but would be cheaper. Fonit and from the valve for example...
Today's transcript will determine...
Post by Шалтай Балтай » Mon Oct 05, 2009 13:46
why structured water should be different in taste from unstructured?
or what is the taste?
energetikam it above - Yes.
but this is only the GDV can show....
PS
I hope people will not be to the taste to try :-)
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 13:49
Андрей2009 wrote:I, too, first thing I did - did an experiment. The water was cooler, the taste difference is not very noticeable (there was a slight metallic taste), but the smell is much more noticeable (again a metallic tint).
In my case the taste if they differ, then so weak that almost elusive, within the error sensitivity of the receptors. The smell as well, although for a moment I felt the smell from the glass on the front Room stood, as if the water began to smell slightly superior, but after I wrote off a premonition because later times, when smelled, the difference is not felt. In any case, if the difference was at the level of receptors as it was elusive, perhaps molekulyarnom urine the difference is noticeable, but the microscope I have, and skills rarity with a microscope either.
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 13:52
Георгий_19 wrote:why structured water should be different in taste from unstructured?
PS
I'm not saying that it should be different or inadequate... people On the forum have done similar experiments, described them and result from them was the difference in taste of water. So I repeated this simple experiment and in my case the difference I felt... :?
Post by Шалтай Балтай » Mon Oct 05, 2009 15:30
PS
understand.
It's very personal, what can be done to give a taste of structured and no water, those who believe that will be able to distinguish one from the other. and see what happens.
By the way, his willingness to experiment,
I feel that I can feel the room (although those who drag - not feel), but you can try others, or a combination + placebo.
Very interesting, will work out or not :wiz
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 15:42
Георгий_19 wrote:This is a very personally thing to do, to give to taste structured and no water, those who believe that will be able to distinguish one from the other.
And where to get one who thinks so?:)
I degustation, Samel, etc. who you don't.
Tried not only me, the outsider is also not found differences. Of course, maybe I have the sensitivity of the taste buds is lower than in some people. It follows from this that the taste is different if it is not clearly! It is interesting to try on other products, such as milk, where the differences will be more obvious, to put a open bag in a warm place for the parlor and the other in another warm place, away more than 1.5 meters from the front room to check what will quickly turn sour.
I'm not going to conduct such an experiment because then you have to wear a parlor a week or two, but for me now the main experiment - changes in internal sensations and external relations subject to continuous wear of the drawing rooms.
Post by Шалтай Балтай » Mon Oct 05, 2009 15:47
Dimas??
Post by Dimas » Mon Oct 05, 2009 17:37
Георгий_19
Yes? :) Water need to take at least clean. Water is suitable,although I feel the difference even on Aquaphor passed through the filter.
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 17:41
Dimas wrote:the Water,although I feel the difference even on Aquaphor passed through the filter.
The difference between water and passed through Aquaphor I feel it too.
But purified water, prokipyachennuyu, poured two glasses, one in the Parlor half an hour, the second glass in another room is also a half hour(without a chamber of course), the difference to feel failed.
Post by Dimas » Mon Oct 05, 2009 17:55
Жека3000
the boiling gives the taste, which is then very difficult (if not impossible) for something to restore. Water is better to take and try unboiled...
слон
Post by слон » Mon Oct 05, 2009 20:51
I took not boiled. And experimented many times. Always clear, people who tried the water, guess which one is which. However, a month passed and neither I nor my household difference is not feel. Why is it so don't know...
Пользователь
Post by Пользователь » Mon Oct 05, 2009 21:05
Dimas wrote:Жека3000
Totally agree. That explains why not feel the difference.
Post by Dimas » Mon Oct 05, 2009 21:42
слон wrote:I took not boiled. And experimented many times. Always clear, people who tried the water, guess which one is which. However, a month passed and neither I nor my household difference is not feel. Why is it so don't know...
And the entire month You were drinking the water from the Chamber? Can pipiles already? :)
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 22:02
OK! The water is filtered but not boiled aquaform suitable? Now test, I will unsubscribe!
Half an hour is enough I think?
Жека3000
Post by Жека3000 » Mon Oct 05, 2009 23:24
So tested aquaform filtered water, unboiled. One stack stood in the front Room 58 minutes, the other is not standing in the parlor in the other room. The result is the same as with boiling, there is no difference, the taste of tap water remained in both glasses. I tried another 2 chelovik, all came to the same conclusion. :?
Post by Логик » Mon Oct 05, 2009 23:41
Жека3000,
Experiments with water, I put repeatedly. The taste has changed for the first time (noted I). In other experiments set out later, the water taste has not changed (and bleach like smell, and smells).
Жека3000
Post by Жека3000 » Tue Oct 06, 2009 0:05
Logik
I for some reason never changed(
And that's what I noticed: While the experiments were conducted,of course, the parlor was not with me and before that established more or less peaceful relationship with my mother over immediately... I do not know a coincidence or ... :?
