CD "Ultramesh"
And another question is the result of what what time of day it slushaesh?
Re: Disc "Ultramesh"
And mixermate how?избишка wrote:And I'm listening to the disc and the video course both in the headphones. So is it wrong?Андрей Патрушев wrote:For video disc you have to listen with headphones on the lowest volume, and courses with speakers.
video tutorial put it up and drive for a minimum of earshot
izbicka
I mean - what?
I mean - what?
The result depends on Your initial condition, the situation, Your setup for classes and other people.избишка wrote:And another question does the result of what what time of day it slushaesh?
It is possible and so...избишка wrote:on the turn player then the video
Tell me, what could happen, I bought the original disc "Ultramesh", everyone listened, but now in the track of "Star flight," the only thing binaural beats, and the sound disappeared. What to do and why this could happen?
What is it like?Муза wrote:were only minaralniye heartbeat, and the sound disappeared
SORRY FOR THE FALSE INFO, I MIXED UP 3 AND 4 TRACK((( )))).
Андрей Патрушев wrote:I would advise (as You learn) - in the morning the second track of the Star Wanderer, is a Massage of the Brain, and the Conductor is not to listen, or to set specific goals for study and then every three days. Training with bells to listen to not necessarily quite only if You are overwhelmed with emotions. The rest - all right.Оранжевое Сон-Це wrote:and Now for this disc is the theme![]()
And right questions to Andrei Patrushev: am I doing? I need one day to learn lots of new stuff (as otocenie do not own, for 6-8 hours ). I broke 2-3 of the block, with breaks between blocks 2-3 hours. Before each block - track 1 Training. Each unit is a 45-minute segments (track 2 Super Training) with breaks. Can you work with?
And at the end of the day - at bedtime - Integration (3 track). Or her after each block it is better to listen to?
Working with the disc for the first time, is it possible from such a load to take? Or just focus on feelings?
And the last question: is it possible to use such a scheme listen: morning Massage of the Brain, day - Ultramesh (if something is taught), the evening is the Conductor? Mosk boils?
Studying at the University and I want to try the combination drives "Ultramesh", "Massage brain" and InnerPulse sessions for better assimilation of the material (it seems to me that the simultaneous use of the disk "Ultramesh" sessions and "L" should give the best effect).
Please tell me which session of the "L" in combination with disk "Ultramesh" (2nd track of "Superbacana"), can be applied when reading the textbook(because mostly the training material is given in text format), i.e. without using points to svetistkhoveli (and whether session without glasses at all effective)?
I think to try the following scheme:
First go through the alpha course sessions or 15/15 21/21, and only then proceed to the training blocks.
I. in the Morning, after waking up:
"Star Flight" + session?
or
"Massage Brain" + session?
II. 1st block:
1. "Ultramesh", the 1st track "Preparing"+ L01
2. "Ultramesh", 2nd track "Superbacana"+ L n? (no points for printed text)
3. "Ultramesh", 3rd track "Integrator"+ L02
break
2nd unit:
2. "Ultramesh", 2nd track "Superbacana"+ L n? (without the glasses)
etc.
IV. In the evening, before bedtime:
"Healing. The Magical River" + session r02+S04 (for relaxation with a subsequent transition to sleep)<
Trabant
More is not better. Ultramag was designed for use without machine. In General, machine more effective than one sound.
Hello, Andrey! Thanks for the quick response.Андрей Патрушев wrote:Trabant
Please forgive me for the stupidity
1. at InnerPulse, with sessions L03,L04,L06 can be applied to any audio material
( for example,audio recording of lectures or audiokursy English, etc.), and if so, with what ?
2. With "Ultramega" successfully assimilated only audio ( in one of the replies You recommend to record lectures on tape or text material with the help of converters to translate audio ) or reading a conventional textbook effectively?
Trabant
1. With L03, you can listen (watch in special points) training material for memorization: foreign words, formulas, etc.), with the other sessions don't need is to set up a brain to study.
2. With ultramega successfully absorbed any educational materials.
Hello, Andrey.
Here's the question arose, maybe something similar already asked, but I don't found.
I need to learn a lot of material. You said for example "Star trek" have to listen to every two days. And what about "Superbacana" and "Integrator"? They also have every three days to listen to? Just as I thought, since it is the same exercise for the brain as Star trek... Or every day during training, but 15 in 15 days? Or every time sit down to study new material?
And what about the track "Star trek". After all, he kind of energizes the brain-energy laser (by the way quite active after listening to the felt, though to the last did not believe it could actually work). It turns out that the next two days, according to the rules of their gray matter should be left without a charging energy, and how then to start a "Superbacana" when you say that first in the morning must listen "Star trek". Especially if "Star trek" will not listen, then listening "Superbacana" start to fall asleep? How to be kind. Or I misunderstood something.
And more... "Star trek" Lasts 15 minutes, but he I understand a similar "Massage brain" which lasts 45 minutes. I don't understand why then they both need to listen in two days. It seemed to me that since "Star trek" lasts 15 minutes, so it can listen to every day, and if "massage brain" three times longer plays, that's it, and must every two days. hmm...
It is waiting for answer, thanks in advance
Sergeya
manual
manual
Even in this statement, and no such detailed description, thanks anywayАндрей Патрушев wrote:Sergeya
manual
Sergeya
What is missing?
What is missing?
You are of course sorry that I've accosted youАндрей Патрушев wrote:Sergeya
What is missing?
But that's not enough, a bit of a reality in which tracks how many days listen to
The fact that brain training, like training with the iron, I got it... supposedly we need to rest a couple of days. But then it turns out "Superbacana" is also not every day to listen to and star flight
Something I'm really confused.
What how long to exercise and how to relax during the day, I realized this. But as the days distribute?
I apologize again if bored
Sergeya
You can every day. Superbacana - when you do, taking breaks for 5 minutes, when the track is finished. Integrator - at the end of the study. Star flight in the morning.
Class, thank you very much for the replyАндрей Патрушев wrote:Sergeya
Hello, Andrey!
I would like to clarify - the track Star flight, you can listen every morning for several months or also on the scheme or 15/15 21/21?
And another question: is it possible to listen to the Integrator, even after training just before bed for relaxation? And over what time - in the same way?
