Man ... and his Personality...Universes
enough to cling to obscure any private tracker in the form of "what the hell is this happening to me". At first it's a tiny lead, but if to study it - it will unwind in the correct order and direction.
Re: Man ... and his Personality...Universes
is Yes...
but...seeing the dream....we can then forget...and then all of a sudden to remember!and begin to spin a story....we think vspomnyat....but in reality we just Mind draws pictures that all ended in a logical chain....
in principle, with all the memories...
for example-the memories of childhood ..from a person going?
so it's not about memories, they can not be trusted. They are often spoofed, and is the same. Just a man misunderstood and put the wrong picture memories, often replacing fiction... It was about the physiological sensations of the beacons. Only they are real and only they can catch and spin. The rest can just lead to samodurovu.but in reality we just Mind draws pictures that all ended in a logical chain....
Physiological indicators - any stiffness in the body, goose pimples, paresthesia, cold feeling, warmth, weightlessness, itching, tickling and so on... these are all manifestations of the electric current and it can be felt directly, but indirectly at first.
A simple exercise is to breathe in the center of the forehead and stretching to the bottom of the torso (of course nothing is breathed, but the man is as inhaled and stimulates need psychosomatics). This one exercise will increase the consciousness on the order with the time ))
but..understand...
I was confused-spun...
well...then the question-what is nausea?/of course I need to understand, but interesting options/
for example, yesterday...when I went to bed, I felt nausea...
Yes, maybe I spent a lot of time on the site...fatigue...but...I spent and more! max was tired...
then in the morning I feel the rise of forces that hasn't happened....
because it is now grounded much...and a lot of time at my forum, where defend the interests of Russia-i.e. the inclusion in the policy...
and I must say, I started fervently...much checking strong...and I must say, I lack the equanimity and self control))
with the *esoteric to communicate much easier...
Nausea, like melancholy, sadness, hopelessness, etc... It's just physiology. It all lies in the unconscious and so are unavailable to me as all. No one understands why. And this can pick up just talking on the forum, not even noticing.
To get it all from the unconscious is only one way - a physiological rise of the current from the crotch up, at least until the throat when it comes in the form of a lump. And all the longing, sadness and nausea are gone... It's just the electric current in the intestine, only very poorly. But it can be a simple way to convert, achieving a more comfortable state. This formed a vector of internal efforts from the bottom up (can be represented as a flow from the crotch to the top). At first, it's not going to happen, and then single-handedly, the question of the number of training.
Prayer, for example, is a vector of current and provides by itself. But you can directly control
I just *too much information...energy
had water to drink....infa is better *dissolves))
..and pumping the threads, Yes...it helps, especially when failures in the chakras/energy nodes/them useful...*breathe
even simple ..long exhale gives relief, removes tension
and the point wasn't to pray....and in that condition....some nostalgic emotion.....ease.....emotion
Oh..there was a time..when I distinctly wanted....pray.по. wrote:Prayer, for example, is a vector of current and provides by itself.
by itself it will not dissolve anything, the fact of the matter is exactly the opposite ))) Imagine a septic tank in which the water is filtered... there It settles and the bottom falls Il... And the bottom is unconscious, it is simply not visible, who knows what is out there... And if you don't call a regular plumber - all's well that Mr. and will be filled and then poured out. And the man seemed that he superathletes and all, but it will be what's inside... And felt the same way. And behave the same way. And be sure that everything is right and correct does not happen. The funny thing is that the more of that black sludge in the man - the more he is convinced that he is right that his exclusive secret knowledge that you can sell for big money ))) and sure, let's say a balloon will write "want to be rich", will do three times, spit over your left shoulder and you'll be rich. The degree of "confidence" then goes into fanaticism and continuous aggression.
So... in any case it is impossible to prevent siltation of the bottom of your well bad rude shock ))) And currents needed to drive through the body: the bottom - up, top - down. Then you get a small Taoist heavenly circle.
And the fact that the wells are silted... somehow there... sniffy. From which a person to shovel 5-10 years, proudly calling it "spiritual growth"
this is the most dangerous delusion
When a person is convinced that he is right
lunch)))and share ....
well, I....kind of like *at the table* come....))).по. wrote:by itself it will not dissolve anything, the fact of the matter is exactly the opposite ))) Imagine septic tank,
so first, you cannot be sure of anything, everything must be taken as probabilities. And to explore them, to try to understand how they are likely manifested. Not afraid of criticism, and happily work towards it, to listen and to draw conclusions.this is the most dangerous delusion
second of all, you need to look bipolar, with the two extreme poles in any coordinates. Watch so that it is clear and so and opposite, and no contradiction.
Usually the opposite - choose one point of view, one pole, and the second "silting" and then skewed in one or the other. But knowledge is a shared knowledge of the poles, the axis, not a point of view.
and imagine... If it every )) At a certain percentage or even all... And you say "realization"... the Realization that if such a result )))well, I....kind of like *at the table* come....)))
And it's not in joy... Criticism should not be dismissed, but to see how it fits in your model. If the arguments are strong and the model is not fit - what is there to be mad at anyone... Just correct model and the correct model will be found, including these arguments. And so, while there will be no contradictory fact
moved from the topic viewtopic.php?f=32&t=6468&p=175364#p175364
"He who knows others is perceptive, but to know yourself is enlightened.
Winning others is strong, but winning itself is the Almighty.
Tao Te Ching"
ie what's the point?in communion we show ourselves....while others show us what we have...it can be driven away in a corner...but it's there....and in time may go...and others are exaggerating to us ...*our...hidden quality =therefore, there is a Reaction.....us it hurts/how can they afford it, when I wouldn't presume/
___________________________________________________________________
and what happens when he deny it???
to you it also applies.....
and me....
______________________________________________________________<
Россомаха wrote:I casually Informed a lot of shit in other topics. His manner to me is extremely annoying.
poumnichat bit with the phrase:Финансист wrote:But pooblema his desire to look someone in the background someone in the absence of their own thoughts and ideas. Completely read and gleaned.
Tao Te Ching"
and more Better about yourself!.по. wrote:In addition, each person writes about themselves
Yes)))exactly ))) In other touches, and touches only what is unexamined in itself... But to accept it is impossible
and me....
<Финансист wrote:Read carefully the post. This imagines about himself knows that the accuser, in addition to this forum, got another two to three hundred people in the esoteric space. To identify abilities of the people to whom he appealed..по. wrote:. Personally spoke with many people in chat rooms and on Skype, at least hundreds, and probably 2-3 hundred... imagine each person checked, and tested me can withstand not everyone, probably evident by how everyone is trying to encourage the administration, realizing the weakness of his arguments.
But those who stand the test - they are really amazing people (in addition the fact that he survived). And never Shine, and don't invent things with folders level 80... There is quite something else...
Note his quote: "Check me stand every!!!" What kind of arrogance must be some pride to be had. Fucking ezoterichesky value!
And now check from me.
1. The purpose of validation abilities of hundreds of people?
— To identify these abilities from certain people?
— On the subject of whether there are such abilities at all?
But as he admits in the end of the post, that these abilities some people have and therefore the existence of paranormal abilities is available, in fact it makes no sense to find out the number of people possessing these abilities. If...
IF YOU DON'T DO THE JOB ANY STRUCTURE..
That is, it seems we are dealing with a Snitch and a provocateur.
2. This fucker while he does not possess any abilities. We can't see them. The reason for his accusatory behavior probably displayed right above. Maybe everything is easier. He is not capable of, so fiercely hates and envies those who possess abilities. Hence his incriminating/accusatory rage.
One word rogue, esoteric proletarian labour in its worst forms.
.по. wrote:if you are born of anger - people realized they were wrong ))) Because one part of his brain tells him one thing and the other another ))) the Contradiction gives rise to anger. When a person is fully adequate and knows he's right and sees no contradictions (this includes a complete understanding of the causes of others ' behavior) - he never gets angry. This is the basic, actually, is the criterion of correct understanding.and what happens when he deny it???
If others show contradictory arguments... So the picture of the world of man is not so correct, he understands it instantly, angry, but only on themselves, on their incorrect understanding. But think )))
any denial breeds resentment..thus understanding may not be...there is a reaction and there is a need to restore its position in the perspective-I'm good ..ie introduction about myself....по. wrote:if you are born of anger - people realized they were wrong )))
wise people do not argue...and nothing to prove to anyone.....
but alas...it's not about us)))
kompromentirovat most emotions....when people says that it is absolutely calm and balanced and he really believes in himself-for him it is true.....по. wrote:If others show contradictory arguments...
but the words, the momentum...to give as...
if the Mind is strong, trained , he does not allow it to track
__________________________________.по. wrote:if it were so... Then all the people kill each other ))) But it is not, then there is a positive mechanism even when a person is angry... What is he? Well, anger is a strong current in the sympathetic nervous system. You can say "fire", the action of which melted some neural connections, greatly overextended and overwhelmed... Maybe not exactly, but something like this... And when man reaches the highest boiling point by heating for a long time, such as year - he rushes in fury and anger at all 5 times a day... Inside - lava, which melted all the static belief that is very very good. Then lava will cool down and crystallize into something better... Better than the automatic reflexes of consciousness zombies: "touched-bite back." This stage is "lava" - it is inevitable for each person, someone in 15 years, someone 30, someone at 60. It cannot be avoided in any way - first "melt", then "crystal". But crystal may not be obtained, cooling must be very slow, and even "seed" should be... At this time the understanding is formed - a few years.any denial breeds resentment..thus understanding may not be...there is a reaction and there is a need to restore its position in the perspective-I'm good ..
<.по. wrote:emotions with words not related at all ))) This is only for fully reflexive machines are connected, and so to separate one from the other to know how many (not counting the passion). You can easily write obscenities, petrolina, and it is possible with anguish and emotions inside to write about self-development, and then to go out and shoot from hopelessness (remember yourself?). The honesty of the words (hypocrisy and showing off) can be detected only empathic. What man would not have written - it is still clear what happens if there is an empathy that words do not influence in any way ))kompromentirovat most emotions....when people says that it is absolutely calm and balanced and he really believes in himself-for him it is true....
I think the most direct way...and talk about used turns...which give a true relation, because we can't see non-verbal.по. wrote:emotions with words not related at all )))
certainly understandable.....and it is clear exactly what....the true condition at the moment....but again-with their own perception.....по. wrote:What man would not have written - it is still clear what happens if there is an empathy that words do not influence in any way ))
therefore, empathy is easier to confirm their own conclusions based on the analysis of the text/still I recall that in *it is why it is included and the subconscious mind, which produces..used those turnovers and phrases/
for the sake of objectivity we cannot say that M-theory is not yet confirmed anything, it's just pure mathematics about how "could be." And check out this math is impossible, yet such experiments is unavailable.
And so, I am a supporter of this theory, only in a slightly different form, as described in physics, but rather as Michio described poetically in the beginning. But there are other theories of everything, are also unprovable.
up to what time the twins are "very same", and the same conditions of development are still not perfectly identical, but simply because the attention of the twins is not controlled )Логия wrote:in the copying errors))))
even the identical twins....it seems to be when odinakovyh development contexts can be quite different, the only similarity percentage more...
so what little things accumulate, accumulate and after some time become very visible
here by the way interesting to consider the Siamese twins, they are also spatially fixed together
even from birth they have different character...Хорошо wrote:up to what time the twins are "very identical"
what do we know Dolly the sheep?
what went wrong?
eggs laid in each..still in embryonic form...
Dolly the Sheep (eng. Dolly 5 July 1996 — 14 February 2003) — the first cloned mammal, which was obtained by transplanting a somatic cell into the cytoplasm of the egg. The sheep Dolly was a genetic copy of the sheep donor cells.
The genetic information for the cloning process were taken from adult differentiated (somatic) cells, but not of sex (gametes) or stem. Source animal (prototype) at the time of cloning has already died. As part of its cells needed for the experiment was promptly frozen and stored in liquid nitrogen to preserve and pass on genetic material.
The experiment was set up by Ian Vilata (eng. Ian Wilmut) and Keith Campbell in Rosinska Institute (eng. Roslin Institute), in Scotland, near Edinburgh in 1996. The experiment is considered[by whom?] a breakthrough in technology, comparable with the splitting of the atom.
She Dolly became the most famous sheep in the history of science. She lived for 6.5 years and left 6 lambs. Dolly was euthanized in 2003 after an illness.
In 2006, about the life of Dolly and the fate of the experiment was filmed educational film[1].
As it became known later, no cloning was not, this statement was an article in Indendant, referring to Nature Genetics[14][15], which, in turn, one of the first reported success in cloning, and the fact that Dolly was cloned by removing the nucleus, but the genome is transmitted not only through the kernel, therefore, as shown by the test results of this experience, Dolly has two genetic mothers and a clone is not.<
it is currently possible to see if the "character" and not the fact that he was layered habits and stereotypes
of course the twins are originally different in nature, the time of birth decides, but very few of them
