Egregors
spinal fluid there... the Electrolyte actually. Which is electrified by current from the neuronal nuclei of the sacrum (yeah, the sacrum also has neurons, however in the most simplified form, but all start). Only it is liquid, there is apparently either not all the time, whether in the environment further raised some hormone, it is not very clear how you feel... But the rise is quite slow.
But then to you and cards in hands - "Aha! gotcha! not everyone knows! so wrong about everything!" ))
Re: Egregores
It when belt was punished and now is constantly feeling second body.Ольга Лагуза wrote:Where feel, not that any area where You have a concentration of energy?мимоходом wrote:as for the second body - so I feel you? ))![]()
Re: Egregores
It is not in my opinion, and for anatomical reference ))And it's your still brain washed.
There is a saying - Russian people wise after the event.
The idea is good. What is the back mind? This is the back brain. The dorsal part is the cerebellum, and in the thickness you'll channel Cellview water.
What is the cerebellum, what it consists of? And it consists of gray and white matter, is essentially a continuation of the spinal cord having the same structure.
And in the middle of the spinal cord is the Central canal (canalis centralis). This canal extends throughout the spinal cord, passing at the top into the cavity of the fourth ventricle. Downstairs, in the field of cerebral cone, the Central canal is expanded and enters the Canalis Sacralis
But what is the fourth ventricle? And the fourth ventricle as the time extends from the Central aqueduct, which is part of the back of the mind.
What we have in the end? And here is what we have: Kundalini (a hormone produced in the brain cone, the sacrum), moves along the canalis centralis of the spinal cord to the fourth ventricle of the brain, acting Cellview water, in the rear mind.
And, you know, I understand perfectly why you ask me ))) And deliberate rudeness - just a mask, well, that person does not drop. It's all so funny. As your test - attempts to enrage. I also these tests previously conducted excellent tests. If the person is broke and pissed off - so weak, even the hormonal system has not mastered.
Ольга Лагуза
- Has thanked: 22 times
- Been thanked: 7 times
Re: Egregores
Clairvoyance You are discussing let's see...мимоходом wrote: Well it is necessary to check your prediction.
In the spine there is liquid, let it be known, the liquid there is formed after a puncture or any other damage, in the form of condensation.
Re: Egregores
It initially was. I can have fun just.мимоходом wrote: But then to you and cards in hands - "Aha! gotcha! not everyone knows! so wrong about everything!" ))
Ольга Лагуза
Re: Egregores
Poor boyДжейсон wrote:It when the belt was punished and now is constantly feeling second body.
Re: Egregores
Are the doctors wrong? Or are you just not googled?In the spine is dry, let it be known, the liquid there is formed after a puncture or any other damage, in the form of condensation.
In the middle of the gray matter of the spinal cord is the narrow Central canal of the spinal cord, lined abandonnee cells and filled with cerebrospinal fluid
http://medbiol.ru/medbiol/mozg/00067b1b.htm
Well, here's another, about the liquid itself
Cerebrospinal fluid fills the ventricular system of the brain , the Central canal of the spinal cord and sub space. Cerebrospinal fluid formed by ultrafiltration across the choroid plexus from the blood of water and electrolytes. The bulk of cerebrospinal fluid formed in the lateral ventricles , a small quantity in the other ventricles containing the choroid plexus. The choroid plexus in the cavity of brain ventricles arise from the choroid , which pushes the epithelial tyre of the brain. Forms a complex consisting of thin-walled epithelium belonging to the brain, and within it a network of capillaries. The whole complex is a branched vascular plexus.
http://medbiol.ru/medbiol/mozg/00067dfd.htm
Re: Egregores
In what universe in the anatomical reference brain washed by the lymph?мимоходом wrote:It is not in my opinion, and for anatomical reference ))And it's your still brain washed.
Re: Egregores
In our ))) Just above I edited the comment with the answer to this question )))
Besides... In our brain, so much limfokinov... a lot. After all, according to him is the removal of the results of the work cells and the brain cells are working very hard
Re: Egregores
You know, this is all wrong.мимоходом wrote:a lot. After all, according to him is the removal of the results of the work cells and the brain cells are working very hard
Re: Egregores
I incidentally anatomy correctly imagined. And you all are wrong. You have in every post five mistakes and nonsense.
Re: Egregores
Revenge - such a sweet... mmm... I really hurt you with the Lama, that it is necessary to take revenge... But the feeling is sweet when it reaches the goal. And when it does not reaches in my chest this feeling of dissatisfaction arises... But I hope you have this all right ))
Re: Egregores
You love to lick his personality that are all around the same. You I never hurt and hurt could not. We had no contact. As you rightly pointed out I was, and you are nonsense. And my position has not changed and is unlikely to change, if you continue to post defamatory you texts.
Re: Egregores
I have no intention that your position has changed ))) Any position is good, otherwise the forum will just die ))
Someone buys the product of Michael and attending a zombie-webinars, someone spouts nonsense in the form of a citation of anatomical textbooks ))) This is normal. Most importantly have a choice
Re: Egregores
In all things, and not only in a poor knowledge of anatomy. All the nonsense just. Try to breed a fly with a tie.мимоходом wrote:, someone spouts nonsense in the form of a citation of anatomical textbooks )))
Re: Egregores
The attempt of course is good - to say "you're wrong about everything! In everything". Maybe some people then get upset and go cry in a corner, you never know. But I think it's manipulation at the level of the younger group of kindergarten. Funny, in a sense )))
Try to find some to refute the arguments - it touches stronger. After all, offends the truth and nothing but it... Won both of you grudge gushing... This, by the way, very good, clean kind, if not to hoard, but to pour out and tie ))
Ольга Лагуза
Re: Egregores
Doctors are people too, and therefore wrong.мимоходом wrote:Are doctors wrong? Or are you just not googled?
Re: Egregores
I mean they were a hundred years picking people, all the cerebrospinal fluid was discovered, and suddenly it turns out that you are wrong... How so.Doctors are people too, and therefore wrong.
Ольга Лагуза
Re: Egregores
Once again you are with yourself and about yourself...Here do not have the energy to save the s.... because then all through him and it turns out...мимоходом wrote:Won both of you grudge gushing...
Re: Egregores
People are funny ))) I Think that their emotions no one hears and as no one reads ))) Another funny thing is that his own emotion to trace the person may not being in it - and believes that it is not, and the condition that
Ольга Лагуза
Re: Egregores
I'm telling You that when they can get there, that is, by damage, there is formed a liquid, until there is not liquid. You are so surprised, and then medicine or science as a whole never made a mistake.мимоходом wrote:I mean they were a hundred years picking people, all the cerebrospinal fluid was discovered, and suddenly it turns out that you are wrong... How so.
Re: Egregores
Who will be offended by a wandering artist? Many times I have repeated that I am purple.мимоходом wrote: Won both of you grudge gushing...
But then resentment. What you Michael objectionable? Probably banned for nonsense? The air is spoiled in the vestibule?мимоходом wrote:Someone buys a products Michael and attending a zombie-webinars
Re: Egregores
Yes, not normal schizophrenic ))) well This is also a great talent - his schizophrenia to infect others and make this business. Is a successful businessman, someone has to teach Pinocchio not to hide their money in banks and cornersWhat you Michael objectionable?
