The CHEMISTRY of the body and not only
In the treatment of novocaine can't see the panacea. It is necessary to consider the compensatory capacity of the organism and to approach assignments carefully novocaine. The dosage of procaine should be individualized for each patient and it is considered as one of the means of complex therapy.
In the elderly novocaine appropriate to apply in combination with sulphate of magnesia, or with a complex of vitamins.
Romanian scientists have recently proposed a slightly different drug for the treatment of age — Gerovital or vitamin D3.
It is also used in injections 3 times a week. After 12 moves — break of 2-3 months and the course is repeated.
Recently in Kiev was held a conference convened by the Institute of gerontology and experimental pathology of the Academy of medical Sciences of the USSR. It covered issues of treatment of the phenomenon of premature aging with vitamins, hormones, procaine and other means. Paid particular attention to the fact that uncontrolled use of novocaine n" not give the expected results, but in some cases causes deterioration.
The main prevention of premature ageing were nutrition and active motor mode (physical culture, medical gymnastics).
Of great importance in the onset of premature old age have various diseases, so you need to be able to prevent disease in a timely manner, and if they appear, seek immediate medical attention.
Link some people that "once", "no time to observe a mode, to carry out preventive activities," baseless and harmful.
Only the use of complex methods of treatment and prevention in combination with a reasonably organized labor and rest, personal hygiene, adequate sleep and physical exercise, a balanced diet and careful attention to your nervous system may be the key to longevity.
The ability to prolong life is, first and foremost, the ability not to reduce it!
ru/preparaty-dlya-pozhilyx-lyudej/">http://www.longlifes.ru/preparaty-dlya-pozhilyx-lyudej/<
Александър
- Has thanked: 17 times
- Been thanked: 1 time
Re: CHEMICALS for the body and not only
Bold,thank you!
Maybe some of the other members of the forum correct? Please share with us!
do you know how inert the honey.the syringe to dlitelnogo contact with АСД2?
(I have the bottle with the syringe in the stopper in the syringe a bit ASD to better vozduhonosnye the contents of the bubble)
rubber, plastic and stainless steel do not react with ASD?
Александър
ZOMBIE, I think it is not very important, because taking away a certain amount of ASD with a syringe into the vial penetrate still air , the same amount approximately, how much was taken. I keep a syringe with a plastic cap to the needle wasn't dull, and the use of a syringe - based "one syringe 5 ml for one vial of ASD". Syringe not mine. Special damage after using saw. Something like that.
smarita what great chemistry Pikamilon
in the head disintegrates into Nikitenko and GABA... GABA kicks the pituitary gland into manufacturing GR... I think I should add to the evening diet
http://sportswiki.ru/GABA
http://ru.wikipedia.org/wiki/%CF%E8%EA% ... 8%EB%EE%ED
ЗОМБИ wrote:smarita what great chemistry Pikamilon
Zombies, well, tell me! You tried the nootropic Pikamilon?
Nootrop Phenotropil and You probyvali ?
http://ru.wikipedia.org/wiki/Фенотропил
On the recommendation of Andrey Patrushev I saw Phenotropil. I liked it - delicious
Moon
not tried, I am now hiding, chemistry and physics themselves are not loaded for several months, I decided to see the reaction of the carcass, and the health one, for example, without loads of joint and ligamentous apparatus was better... was to eat a normal diet without problems and the guts to become better... as long as... feedback needed... I'm so used not to ignore Tuscany signals, I frankly scored -- if it hurts, so be patient -- and this is not right... though the pain is different...
try it, you have inverse (so that there is a return line, ahead better look at what the effect will be) working fine...
nootropil pil after stresov... Phenotropil drinking illegally... the effect was the type of energy surge, but anxiety-irritability increased...
Александър
I want to ask the question, can who faced. After the use of sodium thiosulfate, no one raised blood pressure? I went with the ampoule of the thiosulfate powder (pure for analysis) - spread half a teaspoon on a glass of water and after an hour felt that I have increased pressure , we measured 150 by 100. And what's worse kept for 4 days
Perhaps, of course, the thiosulfate are not to blame, but I was no longer welcome.
Alexander
Boca pain?
Boca pain?
Александър
Andrew, actually sore lower back - it could be the kidneys, I have some kind of untreated infection, probably a kidney may be associated with hypertension . Now continue to drink ASD-2 , two times 2.5 ml. a day.Андрей Патрушев wrote:Alexander
Boca pain?
That's it-the kidneys.Александър wrote:Now continue to drink ASD-2 , two times 2.5 ml. a day.
When the kidneys ASD is a very bad choice.
Александър
Thank You, Andrew!Андрей Патрушев wrote:That's it-the kidneys.Александър wrote:Now continue to drink ASD-2 , two times 2.5 ml. a day.
Yes, on different sites write that it is necessary to use in conjunction with milk Thistle ,for example, to protect the liver.
And I have the dose reduced.
Tell me how often to do the cleaning of the thiosulfate. and since you drink it?
and then I drank 10 vials for 10 days, ampoules of 5 dice half an empty stomach half before bedtime. and I would say that there is some visible effect, perhaps just a little drink.
escho
can a overdose of ASD can cause such effect kidney or not?
escho
code drinking ASD a month ago started to hurt the kidneys, drink on 3 dice two times a day, decided that there is a foreground of the overdose and began to drink less, respectively, pain in the kidneys umenshilos, then decided a month Nepal to take a break before thiosulfate, pain in the kidneys is now rarely appears.Андрей Патрушев wrote:That's it-the kidneys.Александър wrote:Now continue to drink ASD-2 , two times 2.5 ml. a day.
Hatred
In ASD just a complete set of substances, a very bad influence on the kidneys. "Poison is the substance that makes only the dose".
I understand that this dose is strictly individual, and how it then to determine to begin again to drink with small doses and gradually increasing and wait kada back ache kidneys? I will osecurity youАндрей Патрушев wrote:Hatred
among friends there are people who a few decades drink ASD in decent doses (2-3 cubes 2 times a day, with breaks for 1-2 a weekend with breaks between courses of 20-30 days). No one has any problems with the kidneys including profile surveys at work is not discovered.
In my opinion rather problems arise because too many toxins in a short time is displayed and the load on their output falls including the kidneys (not only, and sometimes on the skin, one creepy-eating friend when cleaning during cancer skin just coated all - then passed naturally.
well, there are options for bad cleaning of product - you can drink Moscow (AVZ) but it's effect is weaker.
ACC. with a weak kidney or a large amount of slag IMHO should start with the drip doses and increase very gradually, when the first symptoms - take a break and reduce the dose. So in that case, "skin" such manifestations was the person when taking 10 drops of that in my vzgyald generally not sensitive dosage.
Usually in such cases (many products), the drug causes nausea, even in small quantities.
on ASD-question (site) is a commercial service calculation of individual schedule of intake, based on the experience of observing many receiving ASD for many years. I really never used, since none of the foreseeable environment was not a problem with an accepted schedule, but IMHO if there are problems and think that they are there, then you can use. They're a bunch of settings look.Хастред wrote: I understand that this dose is strictly individual, and how it then to determine to begin again to drink with small doses and gradually increasing and wait kada back ache kidneys? I will osecurity you
Board
I take a long time. Not a panacea, but it works reliably.
Good medicine Miramistin, and very versatile. I think it should be in every home medicine Cabinet.
Read:
- Side effects substance Chlorhexidine:
Dry and itchy skin, dermatitis, tack hands within 3-5 min, staining of teeth, deposition of Tartar, breach of taste (in the treatment of gingivitis).
- Side effects miramistina:
Rarely observed local reaction burning sensation, which alone passes for a short time (10-15 seconds). It does not require the discontinuation of the drug.
In addition:
Advantages Miramistina:
- high antimicrobial activity, at the same time acts on bacteria, fungi and viruses;
...a wide range of clinical applications: from the treatment of sunburn to the treatment of sexually transmitted diseases;
- Miramistin® reduces the resistance of microorganisms to antibiotics;
- stimulates a local immune response;
- has a pronounced anti-inflammatory action;
- effectively prevents infection of wounds and burns;
- has expressed hyperosmolar activity, resulting in wound inflammation relieves and absorbs the purulent exudate;
- does not damage granulation and viable skin cells, does not inhibit boundary epithelization;
- strengthens the processes of regeneration and reparative action in the wound;
- has pronounced detergent properties, which plays an important role in prevention activities.
- does not have a locally irritant and allergenic properties.
convenient and easy to use;
- without prescription.
In addition:
here:Андрей Патрушев wrote:Board
B. subtilis .. It was widespread across America and Europe from 1946 as an immunostimulating agent in the treatment of gut and urinary tract diseases such as Rotavirus and Shigella, but "denied" in popularity after the introduction of cheap antibiotics, despite causing less chance of allergic reaction and significantly lower toxicity to normal gut flora.B. subtilis ..It was marketed throughout America and Europe from 1946 as an immunostimulatory aid in the treatment of gut and urinary tract diseases such as Rotavirus and Shigella, but declined in popularity after the introduction of cheap consumer antibiotics, despite causing less chance of allergic reaction and significantly lower toxicity to normal gut flora.
PS Read the opinion of a certain Russian man who lives and work in the United States, and it so happened that I wrote some specific books, and when he /the author/ I read these books, perevedennye from English to Russian language found a serious error, until the contrary /the author, not me/.
Andrew, thank you!Андрей Патрушев wrote:Funny article...
The article is strong.
And the response inside confirms this.
The hands themselves(intuitively) reached for the soda!
And the head rejected this vector... for! It's soood! What??...
And here is the answer! ( see Article)
Believe in yourself.
Second day with Thiosulfate.
1 vial of water+ g 150-200 on zapivanie.
In the morning. Before meals.
The feeling that something powerful in the Body( around the body:-) ) start - works!
Interesting taste... not unpleasant, but...strange. no more.
Andrew, tell me, 10 vial= 10 days and a break?
How much of a break for a few days or 10 days?
Thank you.
Thank you.
