Orgone generator with their hands (SP). The FLAME
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Wed Jul 07, 2010 23:36
Swami Dopado
Judging by its extensive root system and the effect, very focused. :) And I know how such a device would be as easy linking. :)
Well I'm joking of course. :) az
Свами Доупаду
Post by Свами Доупаду » Wed Jul 07, 2010 23:47
МерКаБа wrote:Swami Dopado
And judging by the concentration of alkaloids ,undoubtedly the effect would be...if the smoke stuck its topper.. az az
Post by Guest » Thu Jul 08, 2010 12:40
ЗОМБИ wrote:brutal
need not track , a generator of electric oscillations, the higher the greater, i.e., perfect white noise, using headphones and white noise have rozowy noise, using the player and coil also have pink noise
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Thu Jul 08, 2010 12:42
magnet
Post by Guest » Thu Jul 08, 2010 13:35
МерКаБа wrote:Organogelator
maybe Svetlitsa super in organic , huh ?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Thu Jul 08, 2010 14:27
Guest wrote:and maybe Svetlitsa super in organic , huh ?
Pre-chopped grated... :)
Post by Guest » Thu Jul 08, 2010 15:00
Маг.нет wrote:just note, EXPENSIVE when no apiary. But if you add in the Mix... Possible interesting effects - energy and information-strong product.
about wax thought?
Post by Шалтай Балтай » Thu Jul 08, 2010 15:35
one thread with mordenai worked?
Morgan — oil varnish, amber. Used as adhesive base for foil coatings (gold leaf, silver-leaf or gilding).
373Алекс
Post by 373Алекс » Thu Jul 08, 2010 21:50
Экко wrote:how to check the operation of the device?
Known as-devices: http://www.heliognosis.com/specs.html
373Алекс
Post by 373Алекс » Thu Jul 08, 2010 21:54
Гость wrote:and maybe Svetlitsa super in organic , huh ?
Can be used not only copies of the parlor, but other resonant photo.
Вячеcлав
Post by Вячеcлав » Thu Jul 08, 2010 23:42
now, what about this device wrote Michael
http://www.mindmachine.ru/viewtopic.php?t=3255&start=25
Новик
Post by Новик » Thu Jul 08, 2010 23:50
In the forum created an idol :)
Вячеcлав
Post by Вячеcлав » Fri Jul 09, 2010 1:23
Yeah, after such a response the "all knowing" there was such impression :)
Post by Guest » Fri Jul 09, 2010 10:56
МерКаБа wrote:Vyacheslav
This device, personally for me, is also not credible.
Michael wrote the opinion, to listen or not, that's your business, you nobody does not impose anything.
absolutely true, but and fence, and decals :)
Post by Guest » Fri Jul 09, 2010 11:17
absolutely true, but and fence, and decals :) Merkaba you say that device is not credible, it's based on something?
Новик
Post by Новик » Fri Jul 09, 2010 11:21
Well the price of course he does not say so little :)
Post by Шалтай Балтай » Fri Jul 09, 2010 15:51
Вадим Перелыгин wrote:"Dyslexia is a partial specific violation reading process, due to the incompleteness (violation) higher mental functions and is manifested in repeating errors of resistant character."
Reason: Certain areas of the brain (the back part of the left middle temporal gyrus)these people are functionally less active than normal Structure of brain tissue also has in individuals with dyslexia differences from the norm. They showed areas of low density in the posterior part of the middle temporal gyrus on the left.
Sorry for the rude joke.
Accidentally ran
http://land-of-spirit.ru/board/80-1-0-447
Disease brilliant Dyslexia
The ability to read and write is considered mandatory for everyone. However, for some people, these simple actions - a real meal. They suffer from a rare disease. Dyslexia is the violation of process of reading, and dysgraphia - a violation letter. These violations are explained by the peculiarities of the structure of the brain, complicating the process of correlation of sounds and letters, writing and speech. In the world there are about from 5% to 15% of people with dyslexia and dysgraphia. Many great men suffered from this affliction, Winston Churchill, albert Einstein, Leonardo da Vinci, Hans Christian Andersen, Vladimir Mayakovsky, Soviet actor Nikolai Gritsenko. Among Hollywood celebrities, too many dyslexics. For Example, Tom Cruise. His "disease" does George W. Bush. Recently revealed an interesting fact: most people suffering from dyslexia – in the environment of rich people. For the study of British physicians 40% of the rich are unable to competently read and write.In the list of "patients" geniuses few of the Russian names, because we have dyslexia called ignorance and blamed everything on poor diligence of the student. Therefore, in our society it is not accepted to discuss this issue, even among public people.
his opinion must have Vadim.
But then so will someone else collect.........
By the way you present where does Dyslexia?<
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sun Jul 11, 2010 0:39
What is the material that does not boil?
Свами Доупаду
Post by Свами Доупаду » Sun Jul 11, 2010 21:57
ЛИЛИЯ-Р wrote:what is the material that does not boil?
Nescopeck.
Post by Михаил_ » Tue Jul 13, 2010 1:50
natural crystals look as in the photo Logic and Vice versa.... the crystals turned from solid material look too right, but inside contain a structure different from the one that turned from outside. In General, do not care, but natural and not processed will work much better (tested on programming them on the "mono" function).
All natural (not chiseled) - the deficit.
Вячеcлав
Post by Вячеcлав » Tue Jul 13, 2010 2:05
Michael_ what can you say about Brazilian Lemurian crystals here such
http://shop.ebay.com/lidosouvenirs/m.ht ... pos=&gbr=1
referring to their energy-information feature and whether it?
Post by Михаил_ » Tue Jul 13, 2010 3:14
Yes, these I like much more, they are certainly Lemurian to accelerate sales :) but in General, very similar to real crystals, not processed pieces of material.
you can simply define a leg chopped off and the crystal is not perfect, if you increase usually not visible to the evenness of the surface not from polishing but from the natural growth.
The reason that I drew attention to the banal. Important not attached to the piece of material artificially form, and the fact that he has grown as a crystal itself (the properties of a monolithic piece).
Ie choosing between beautiful and ugly processed raw, I would always chose the latter, even at the expense of size, shape and beauty.
Post by Шалтай Балтай » Tue Jul 13, 2010 10:29
Omniscient is back :lol:
The crystal cloud parameters.
Size - only one of them.
No one wants the diamond to fill? :-)
That is too small :-)
And who said that cutting is bad?
Read better source material than all x....
http://www.megabook.ru/Article.asp?AID=652005
Post by Шалтай Балтай » Tue Jul 13, 2010 17:15
oops
it seems we moved again.....
Кос
Post by Кос » Thu Jul 15, 2010 18:58
Guys! What are we Talking about? Someone explain, restless miteru? :)
