About the players, soundcards and other Goodies...
Sound
Yes, also going to order a sample, if you like, we will arrange...
Re: About the players, soundcards and other Goodies...
What do you think on this player http://www.sc-store.ru/sony/personal-au ... e464/gold/ if you transcode to WAV it goes, which I did not understand what "— a number of proprietary technologies to improve the playback quality and enhance bass." and how it will affect the effect of disk Patrushev?
Mirzadeh
And there's no WAV format.
And instead of technical characteristics - blah-blah-blah...
http://www.ret.ru/tov_inf.jsp?gid=786462 - more here, SOR
The truth about support of 20-20000hz anywhere in the net there is =(
Sound
Otpishite, please, how was it??? Very interesting!
Very soonАндрей Патрушев wrote:Sound
Closed the object had a very tight schedule.
In the box are 2 types of these devices. One of the types built in headphones in the near future. A second Jack for the speakers, but the speakers on the revision now, there is nowhere to listen. Sorry you are in Moscow, would give pleasure for the testing. Probably will reveal well on HiRISE... How are you doing with 24/192?
Poking around...Саунд wrote:How do you do with 24/192?
Today put Japanese super-tweeters in ear headphones. They are very compact, and large headphones. Went straight in bowls.Андрей Патрушев wrote:Sound
Sound. Became more accurately hear where the sounds. These sources of sound become denser and lokalizovannye. Appeared a volume and a clearer idea of what and where. The sound was not that more, and perception and feeling improved. Close my eyes and clearly see the picture what and where. The voice and music came to character and emotions. It's not the extra sounds, but rather to improve the perception of additional sensors information of the audible range. Noticed feeling vibration of sound waves. Hard to explain, but now I can hear like a vibrating sound wave is moving. Dive deeper into the music dives all over the body deeper.
Influence. I fell a month of practices, it is possible of course it will give a not quite clean result. But pay attention to one peculiarity. Turned On "Healing...". At the beginning of the head began to microfabricate... a bit like the feeling when the plane goes down sharply to a small high-frequency vibration. After 10 minutes, vibration is gone, but the feeling of lightness left in his head. It gradually spreads over the body. Let's see what will dream tonight.
A week to get them on different disks, view effect.
Frequencies above 14-16KHz person is rarely used and I think is atrofirovany sensors perception data ranges. Also with age most sit high frequencies. Not many people can hear above 14kHz. The children can hear 20kHz. Therefore, suggest the possibility of their training and maintenance to use a wider range of perception of the World. Bought echofon, for similar purposes.<
Sound
Thank you!
And the second set, as I understand it, - for the columns? Also very interesting, since air high fading fast...
Thank you!
True. But through the columns of the results will be much later. Perhaps they will need to put several sets of tweeters. Still other capacity and volume of the room. When will work pick-up artist, signАндрей Патрушев wrote:Sound
Thank you!
Made WAV EAC-ohms. Came this report: http://rghost.ru/35641800
Some mistakes. Included in your mp3 player (Direc F1958), with headphone-plugs (Nokia WH-205), not very good. The tone of voice is not as good as on a stationary DVD (BBK) upper classes "metal", the voice sharp, the bells barely audible and what is "artificial".
Actually a question to Andrei Patrushev and to the community.
Bought the discs .. poured them into Vav 44К/16/2 as actually advised on this forum.
Listen to NTS on Android in the ears the ear pieces from Philips. well, there is sound not the issue .. good or bad, useful or useless - I don't know, hence my first question.
How to use any devices to determine the desired effect is achieved or not? in other words how do I know that everything is working as it should?
And the second vopros if I listen to the files through a Bluetooth stereo headset the quality/usefulness will suffer?
forgive me for my suspiciousness. but as a man deprived of a musical ear, kill, I don't see no difference when playing the disc on a home theater no when playing wave files. nothing to do with proigryvaniya files in MP3 format.
Thanks in advance for your answers.
ElectroencephalographКЕНТАВР wrote:How to use any devices to determine the desired effect is achieved or not? in other words how do I know that everything is working as it should?
Well, the answer is of course worthy:)) .. not only that, to use Eeff need to learn almost professionally), and its price is depending on specifications and quality ranges from 12K up to 800K Baku. It is clear that to spend that kind of money Tomka for verification Oh how reluctant, and what is the technique?Астранавт wrote:Electroencephalograph
to take readings from the brain while listening? or to take readings from the device headphone output on the player? In any case, in order to learn correctly records on a specific device or not even removing evidence of EEPROM must at least know what these indicators to compare.
Question oduetse in force ).. how to understand that my Waw files on my equipment work with the desired effect?
While any disc and any track me act like otlichnyie sleeping pills) to sleep in the second minute of listening and Wake up at the end of the disc, the exception can be made for healing ) after the end of the drive I don't Wake up). Can this be considered an indication of the correct operation , provided that problems with sleep I had and not have?
In principle, it is possible. With large debts to relax the nervous system therefore responds to any rhythmical stimulation...КЕНТАВР wrote:While any disc and any track me act like otlichnyie sleeping pills) to sleep in the second minute of listening and Wake up at the end of the disc, the exception can be made for healing ) after the end of the drive I don't Wake up). Can this be considered an indication of the correct operation , provided that problems with sleep I had and not have?
I would like to clarify the principles of these terms in the "overflow" drive in WAV format with EAC program:
1. ONLY 'authentic' (secure) mode with no cache!
2. ONLY Microsoft PCM 44,100 kHz /16 bit Stereo.
In "overflow" mode of 'authentic' (secure) mode with no cache' there are sync issues and reading, a constant correction of errors, the process of encoding one track is 8 hours. I believe that the result from the transcode is not. Accordingly, the question is: is it possible to change mode of 'authentic' (secure) mode with no cache' to any other, without loss of quality? Is it possible to use other programs to transcode?
Thanks in advance to all the answers.
Eugene.In
If that does not work make a different.
If I understand You correctly, then this mode is not basic?Андрей Патрушев wrote:Eugene.In
Eugene.In
It is true, as, however, and the program itself.
Re:
Andrew, what do You think, has the sense to listen to your CDs on such HiFiMAN HE6 headphones (frequency response 8 - 65000 Hz) on the affected tract?Андрей Патрушев wrote:Don't knowСаунд wrote:and if you go further, that there is useful for 35кГц?And the technology is even 35кГц't play (only the Japanese have experimental designs).
By the way, on this path I first noticed significant the difference between copies and original discs.
Keeper
Some sense still there, since the linear range of these headphones is much better than the usual...
Decently you have on the disks of the high frequencies (as I understand it at least 15-20 kHz on the peaks), and these headphones are some of the best in their playing (many audiophiles even refuse them for this reason because listening to music becomes uncomfortable).
I love that you can listen to and buy missing in the collection of discs as the copies of high cut. And you want to go in the future, more advanced formats like Super Audio CD. However, CD is also very good on the relevant transport play.
In this sense, wanted to clarify more about the wheels Jeffrey Thompson, which are sold in the shop: this CD is factory-produced(like Amazone) ?
Does not matter to me.Кипер wrote:In this sense, wanted to clarify more about the wheels Jeffrey Thompson, which are sold in the shop: this CD is factory-produced(like Amazone) ?
And can phone to listen to? supports wav, lack of memory.
Aydar
Possible if headphones are.
