1. the easiest stabilizer - no friends, just paper.Логик wrote:Components hard to get. I don't one month were collected. Plus epoxy you have to request. It was easier to just find amethysts in the center of the stabilizer. For the longest time searched for a tray. Found Indian, made of stainless steel. With a diameter of 44cm.Михаил_ wrote:People make the stabilizers - they come in handy...![]()
True to the end do not understand how to fill. Need to stick stickers in this order, coat them with epoxy and after it dries, pour on top of the compound or can you just pour?
Michael, I've thought, what if to make images in foil laser crystal cabochons method? Will be made stabiliser or not?
2. druso quite well, in extreme case, you can either take a little or replace than others (Yes, even the stone from the river, in short, a natural breed, in an extreme case, and quartz (amethyst, they are twins), although of course correct Druse is very good.
3. components added to the resin in heterosexual candle or bees wax, paraffin. In Neutro earth from the nearest forest if there is no suitable clay. In NATO - one of these aroma can pink petals of the nearest. flower shop.(choose the most striking yet natural smell)
4. glue can and model, he just is prone to boiling and heating, it is impossible to pour a layer of more than 5mm it'll be different hot. It depends on the hardener... the way some additives into the epoxy can be catalysts of the process and stimulate boiling.
5. usually after the application of the bottom labels is fill in ONE step. Otherwise, you need another sticker and fill again. But even 5mm is enough to work as and paper works.
briefly - something like that.
By the way, instead of the resin in an extreme case can be filled for example with plaster, or more than.... options solid mixtures much, I have given a preferred recipe, but in a pinch, and for lack of better you can of course deviate from it, it would be better than nothing.<
