The cylinders and unimodularity... does It work?
Карил
Post by Карил » Wed May 27, 2009 13:53
How's measurements fit are you? :oops:
Post by Dimas » Wed May 27, 2009 14:03
Carilo
All measure up, the time will spread.
Карил
Post by Карил » Fri May 29, 2009 15:57
In light of the fact that the GDV changes from humidity hand, the temperature in the street/the room, from the mood and thoughts, or as aptly noted by Glan easily - shorter GDV anything can be. :( By the way the fit my hands are sweating, and the upper half of the body warmed up. If GDV is perceived as an increase in luminosity of the aura, how about the following experiment.
To drink a big Cup of sweet tea/coffee tat, also hands/body sweating and hot and probably more abruptly than the fit even. It is even possible that it will be possible to make a "conclusion" that coffee tat harmonize the aura. :wink:
Post by Dimas » Fri May 29, 2009 16:03
Carilo
there contrary,such razgermetizatsija field and chakra went,I almost went nuts,but the strange thing is that after 40 minutes, everything returned to normal and has become much better than before the wax cylinder!!!And while held-I felt a bit queasy(((at first I thought that Svetlitsa + cf this effect was given...but ASD said no.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Fri May 29, 2009 16:18
Dimas wrote:Carilo
If you are interested in measurements of dowsing , in General the same as :)
Measured myself.. use the fits given up to 12% damage to the subtle bodies on an energetic level. up to 50% of the changes of the information component of thin bodies (which is very surprising). Of these, 80% were positive and 20% negative.
on the thin bodies have changed the parameter "density" to decrease and "speed of rotation" upwards.
Violated , to some extent,( if I may say so) communication with the subconscious.
The infrequent use of fits, damage and the evil eye - can not be removed.. checked.
According to the authors of such abilities fit (removing hexes and evil eye), most likely to talk about the case of their constant use and probably - a long time.
For biolocational measurements (for me,I check almost every time), the safest posture is a - polarity. Posing a set of energy the body almost always gives a negative reaction( using a pendulum).
Post by Dimas » Fri May 29, 2009 16:24
Eugene Kosh
Wow...all very strange results,I did not expect that this is what the fits are...Eugene,and you swietlicki not checked?
Евгений Кош
Post by Евгений Кош » Fri May 29, 2009 16:33
Dimas wrote:Eugene Kosh
No did not check.
They were checking a device "Benefit"(it used to be called like a "tuning Fork"), although a couple of days.
But not details. Just "for the benefit of it to me" - the answer was no.
The other day,if you have time, again check.
Damage the subtle bodies recorded and third-party biolocatory that I reported that have used fits.
all gave the same data 8-12% damage to energy level. They also reported damage to relations with the PS.
But :)
in my experience the same negative thoughts are damage the relationship with the PS to 52% (that's what I have myself found) :)
Post by Dimas » Fri May 29, 2009 16:39
Eugene Kosh
If not a secret,what is the conclusion on the fit You've made for yourself,based on these studies?And what of SS?
Post by Dimas » Fri May 29, 2009 16:45
Carilo
By the way, not from GDV every sneeze changes can be do some changes in the testimony after anything,but...any explicit feature power remains even after several weeks if no effect on this indicator.
Евгений Кош
Post by Евгений Кош » Fri May 29, 2009 16:46
PS = the subconscious :)
Insights - use them only in POS polarity (UA almost always gives a positive reaction).
The set of energy every time check the reaction on the pendulum (suddenly when positive).
So if somewhere something hurts and you need a quick to help yourself, the positions of the polarity.
If you have time, then of course dowsing method to find out the cause and eliminate the launchers for the SS.
Quite normal work setup, the main thing with the SS to negotiate :)
of course this is considered at the level of the subtle bodies.
About physical injuries and need physical assistance (this lest you think that only some installations of PS you can edit and physics)
Post by Dimas » Fri May 29, 2009 16:50
I'll have to ask Kovtun what he thinks about all this...Sorry that it looks here 8)
Евгений Кош
Post by Евгений Кош » Fri May 29, 2009 16:55
Dimas wrote:I'll have to ask Kovtun what he thinks about all this...Sorry that it looks here 8)
I think he knows.
With biolokatsiya he communicates.
I can only say one thing, he will say that we should not "occasionally" to communicate with the TSF, and at first it is necessary to communicate tightly enough.
That's all going to be the answer.
And in addition is a personality reaction.
So I got it and the other can be completely different.
But the fact that the restructuring of the subtle bodies, and sometimes with raznymi ( early) results - he ought to know. Meshkov because biolocatory, she's seen and knows.
Post by Dimas » Fri May 29, 2009 17:00
Eugene Kosh
Yeah...that's the thing that I have from them always feeling different.Another day at the pleasant body of margulici running,and recently began to notice that sick, condition like if percatarse on the carousel...or I change or something,they interact...
Евгений Кош
Post by Евгений Кош » Fri May 29, 2009 17:02
I realized, later on you'll be.. Look what it is :)
Post by Dimas » Fri May 29, 2009 17:03
Eugene Kosh
OK!Thank you! az
Post by Guest » Fri May 29, 2009 17:19
Eugene
And what kind of poses polarity?
Карил
Post by Карил » Fri May 29, 2009 18:24
Well, definitely the main influence galvanische pair of zinc-copper. The fits give razgermetizatsii from stress, and when they are released the body from joy relaxes. It turns out some training the type of rod.
I now became more and more interesting as the tea with something sweet on GDV impact. :)
Post by Dimas » Fri May 29, 2009 18:27
Carilo
Well come and check it out! :wink:
Карил
Post by Карил » Fri May 29, 2009 18:52
Yes, I remember, I remember... :oops:
On interview, do not call something :( and just like that it is a pity to ride the time (cut from Anderson on the other end of Moscow, almost), Oh and I now every penny counts eh...
Post by Guest » Fri May 29, 2009 23:23
Карил wrote:Dimas
I wonder how my memory serves me ,zinc in Ancient Egypt did not know and was not extracted . And why these cylinders are called the wheels of Pharaoh ?
Карил
Post by Карил » Sat May 30, 2009 11:53
The silver-gold but it was.
соник
Post by соник » Sun May 31, 2009 11:33
Yes, silver and gold they had. But strangely for conventional copper-zinc galvanic element otdvat big money. Is not it easier to buy ANY battery, take the two pins together and to enjoy the resulting energy?! In my opinion the use of these cylinders, both from goat milk. All built on the suggestibility of the subject. Scientific data on the effectiveness of these "devices" I have not found. I do not mean advertising touting manufacturers, and the opinion of independent experts. Ocherednaya thing for pumping money. Triggered widely known effect of "placebo"
Карил
Post by Карил » Sun May 31, 2009 13:15
sonic
The battery does not roll, because it will be the electric circuit and hence the current. Perhaps the action will not be worse or better - don't know, but the experiment does not want.
Fit create the electromotive force (EMF) or electrical potential in different hands, but the chains do not create, I think this is an important point.
About placebo you are mistaken. Try to put one cylinder under the back of the head another under the feet. When you have a throat is swollen then you will understand what fits the body quite specifically affected.
From fits my hands get dry so the scribe. Have hand cream to use or even a gesture. So the physical effect of the fits is obvious, and placebo on any question.
And about use is another question. I'm not an expert and not a doctor and studies have been conducted. So the following thoughts in not more than IMHO.
It is known that the body produces its own electricity (plus-minus, Yin-Yang). And it can be a violation. Or not enough is produced or somewhere more and somewhere less. And fit as an external source of EMF are trained by the internal generator. After all, the external electricity is a crazy thing, you have to strain to compensate. A lot of exercises - a set of forces, polarity, chakras and so on. As a result, the body better manage the internal flow of energy and distributes.
Partly this theory is confirmed by measurements of the GDV. First razgermetizatsija, and then activated the body leads to normal energy. But as the internal generators are Horny, the new "norm" the more high-energetic.
Карил
Post by Карил » Sun May 31, 2009 13:24
The fits are of course a lot, but think about it. Need to order from Germany copper pipe of high purity, cut and zavaliat. The mixture for the filling also need something izgotovit. Still need zinc to find (to buy) and to organize its own production of zinc cylinders. Kovtun wrote that zinc is very brittle metal and not so easy to do not breaking down the cylinders. For example, in the wands of Horus in zinc lead add! This metal poisoning is even possible. Kovtun claims that its zinc cylinders as clean as possible and contains no nasties like lead.
I guess all you can do it much cheaper. But most likely the demand is not too high. And I think the fit on the machine are made manually. Hence the high price.
Карил
Post by Карил » Sun May 31, 2009 13:30
By the way fit, front room, mindmachine it all the crutches. You need your energy to train. To practice qigong, Rei-Ki or Bronnikov. By the way I need partners. :wink:
