Advice from Andrei Patrushev
Hello! Tell pzhl,insomnia for many years. Wake up in the night(3-4hours) and not in one eye!!!! Prompt,pzhl,what program to use Navigator. Thank you
olgac
Hello.
And what were You doing?
https://cloud.mail.ru/public/pYPh/xw1KJvKFv
https://cloud.mail.ru/public/FFti/sCca9LbRs
Hello.
Hello, Andrey! Want to buy MM and Your drives. I have a diagnosis of somatoform disorder was the experience of treatment with tablets (in fits and starts, saw, threw).More than six months not taking drugs several times a one-time reception of Phenazepamum. Disturbed sensations (internal tremor, tingling, burning, numbness, etc.) What would you recommend to buy? Until quite don't understand it. And if you buy the Navigator, it is possible for him to listen to your CDs or need an extra player? Thank you!
PS don't want to go back to the pills (they did not treat.
derrick
Hello.
Start with the Guide and Healing 1(the magic river).
Hello.
Anything extra is not necessary - there is a built-in player.Дерика wrote:And if you buy the Navigator, it is possible for him to listen to your CDs or need an extra player?
Hello, Andrey! Thanks for the reply! I understand that while MM do not need to use? Or you discs every other day (day) and MM r session tonight? Clearly there is tension and high-strung nervous system (had a lot of stress in 2013, all year and in 2015 started all of this horror).
And, CDs to listen to without glasses? Sorry for so many questions, yet difficult to understand, are not faced with it again, eventually will understand: Thank you!
derrick
To listen glassesand without glasses.
So as You suggest, or if you think the load is too big (listen to yourself), the discs can play in a two at the third, and in the intervals to do with mindmachines.
Here is a useful code to examine:
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
Listen now cycles 15/15 2 Healing/Massage мозга2 (all morning).
Is it possible tonight to add the theta (lucid dreaming)? And if Yes, with whom?
Thank you.
Thank you.
Can.Владимир Ш. wrote:Can evening add theta (lucid dreaming)?
No difference.Владимир Ш. wrote: And if so, which one is better?
I understand that all preset VAF file in the Navigator ("endorphins","journey", "healing", etc.) audiostrobe works incorrectly and use points does not make sense?Андрей Патрушев wrote:alecks
All my flash drives with audiostrobe, as there are many high. In principle, it is possible to deal with points, if you get bored just listen neither to harm nor good will.
alecks
No, not right.
No, not right.
clear
then, please tell me which files audiostrobe adequate on the browser, not the flashing "just so" because "there's a lot of high"
healing 1
healing 2
endorphins 1
endorphins 2
massage of the brain 1
massage of the brain 2
journey through the inner worlds
theta meditation
solar wind
healing 1
healing 2
endorphins 1
endorphins 2
theta meditation
solar wind
alecks
healing 1 - There are
healing 2 - No
endorphins 1 - There are
endorphins 2 - No
massage of the brain 1 - No
massage of the brain 2 - No
journey through the inner worlds - Have
theta meditation - No
solar wind - Is
healing 2 - No
endorphins 2 - No
solar wind - Is
Hello, Andrey.
Broke the cable from the connector on the headphone SENNHEISER MX375.
Hard-soldered to your connector, wire thin silk threads and mixed up left - right, found after final Assembly (adhesive filled connector and the soldering).
Questions: 1. Impact-is it listening to Your CDs?
2. Fit whether they are for listening to Your CDs (the manufacturer claims a frequency response of 18 Hz to 22 kHz)?
3. You conducted tests of headphones?
mind
1. On some of them.
2. Yes.
3. I've got things to do.
1. On some of them.
2. Yes.
Which of Your drives will be affected by listening to reversed audio channels headphone?Андрей Патрушев wrote:min
1. On some of them.
There are such earphones with a "zero".
To be ready to replace the headphone when listening to these discs.
Thank you.
mind
To a greater extent on the massage of the brain 2. Endorphins 2, Healing 2; less on the Conductor.
Thank you.Андрей Патрушев wrote:min
The most popular ...
Will have to resolder, otherwise ...
Hello! Started listening to Healing and the conduit through the day at night ( otherwise not yet obtained). I use glasses, but have not figured out how to set them up (which of the four types of signals) to listen to these discs. Tell me, please.
derrick
Hello.
Hello.
Announce please all list.Дерика wrote:on which of the four types of signals
Hello! I use glasses, how they were configured by the manufacturer. In the settings there is color strict : the ranks, mono s, mono s, mono, random, K - z. - S. This is how I understand the color on the glasses. Which is better to install, while listening to these disks, what it depends on. Still there are four signal type on the glasses: rectangle,asymmetric sine, sine, bell. Or is it not for listening to CDs? Honestly, while the Chinese grammar . Or just listen to CDs and not to fool with points, as there it is?
And if you listen to another session, what are the best at this stage and given my somatoform disorder (with a bunch of bodily manifestations). Really want to get out of this shit.
Hello, again. Forgot to ask, when I listen, sometimes fall asleep and Wake up three hours later, and the disc has already been played several times. How to make after one listening, there was no longer the playback?
derrick
Hello.
For the colors, if you don't have any significant thoughts on this,
it is necessary to choose "author" - that is, those colors that are set by the author session.
For the shape signal should also choose A - the author's (as in sessions may be present, depending on the task, multiple waveforms), but when tired, it is possible to choose any variety.
But if You still didn't pull the trigger, and leave - by default there are "more settings".
"After the playing of the audio file or all files from a folder, the player will move to repeat playback, if a menu "Training" option "Cycle room" is set to "on", or will continue to reproduce only the audio session if this parameter is set to "off". "
Hello.
User guide:Дерика wrote:How to make after one listening, there was no longer the playback?
Thank you for such a quick and detailed answer. But the word "author" is only in the Training, (est.color and fill.color), and Your CDs are in the Audio section.Gate., and there's no "A"and there is a gate type and color of the gate, and I don't remember how it was originally, and the husband of Navigator in the hands of the spit, and something clicked, and remember that any questions. You could not tell what were Your original Settings?
And what advise session from machine to add to the Guide and Healed? Or while to wait? Sorry to bother you.
