I2
- Has thanked: 1 time
- Been thanked: 182 times
I2
You can order I2. The Deposit 10 000 rbl. the Expectation of the order 10-30 days specified depending on the date of order.ВИТАЛИЙ ГИНЗБУРГ wrote: ↑Tue Dec 11, 2018 16:49Good day ! Which versions of the devices isn and ( I1 , I2 ) currently available to order ? And on what terms ( rate of payment and estimated delivery time) ?
I2
Michael, wrote You a PM, but apparently You do not read messages there. Looking for something for yourself, to clean the space for treatment. And for dogs, in particular "the evil eye" and to treat if necessary. If this device for my purposes? Or can advise something else
I2
Michael_Looking for something for yourself, for cleaning the area for treatment. And for dogs, in particular "the evil eye" and to treat if necessary. If this device for my purposes? Or can advise something else
I2
A free and easy option (for space and dogs) - matrix home cure / treatment through the generator images/home photos.
I2 is probably ideal for such purposes, but the device is very expensive and I would recommend it only to those who used and uses other products and capabilities, and understand why he is such a tool. Well, praise him (2) I can, but there are easier options including free You have tried them?
I2
Michael Good evening. Question 2: I want to buy, and today dealers are in MM talking about the professional version with enhanced input. Do I understand correctly that this is for connecting a separately sold emitters Eshek? And what else changes compared to the standard is in the PRO version? And you can read more about Eshkah 1,2,? Thank You
I2
at the moment, the E-NIS is only E5, the price, if I remember correctly 65t, he is the most powerful of these, to the procurement and manufacturing process is quite long, two months or more. Think can remove all mladshye E from sale.
I2
T2-Pro does not specifically require other emitters to work, it has an additional amplified output. Personal feelings of people are very different, there are those who feel "overweight" from low power I2 in the normal power mode "11" from 35 (highest), even if the device is simply located in the building (for example in the garage of the townhouse, under the bedroom diagonally, t/e quite far from the people and through several walls. There are those who want high power... sometimes it is combined within the same family (so my friend took 2 to work for this reason).
On T2-Pro has two options - normal and enhanced, can use the normal including weak capacities can be reinforced... Except this is a different power supply analog part with a high voltage, which makes even an ordinary yield more powerful (about 3-4 times relatively speaking).
In this model we do not put the battery into the device (too fast will drain), by the way, I think that in the near future, I would refuse on the availability of the battery in the device for many he is always in the socket, if you want to use a mobile, you can connect powerbank.
Thus, T2-Pro gives a greater range of capacities, to the second input you can also connect the emitters together to the first input, but not consistently. It turns out more flexible and more powerful (much). Once something like this. Equipped with the option "Pro" model emitters and do not have to it to purchase more powerful, at least immediately.
The Pro version is in a different performance, how many units we produced in a larger stationary body, but then was able to upihnut this functionality in a common housing, and now they are made in the model (just added one more plug), but used in smaller versions of the modules have disappeared from the market, so maybe come back later to increased housing as the purchased modules to be completed in stock.
I2
Michael, grateful for the detailed answer. Questions on И2ПРО:
How much approximately is affected, the increased power of the instrument to increase this flow in the space? All the neighbors arrive?
What is a safe distance from the better to put on night? (for example session sleep)
Read the forum and saw (quote below)just for Peter - is on the small sessional for 25T. which? And how you can use it to "warm fill"? And the truth is, well, sooooo true! Webinars and viewed again and again, but such example is not found. You can read more.
There are ready 2pcs additional in the sense they are all constructive to the issue and they can fairly quickly give rise. This is a small session and another one can be called "filler warm", by the way for Peter can be very important thing, in terms of the energy features of the Castle.
Michael_
Thank you.
I2
I2 in price only normal, it is possible to learn the value of I2 -Pro? The Internet has specific support for this model is? I just have the first two and very difficult to change or one reception or another, and the first - usually the Internet it. You have to completely thin out to second caught the network.
I2
Hello,
Thinking about purchasing a radiator. Can't find anywhere information, wherein the characteristics (modes at least) of each device and how they differ from each other. Please spread this information, so I can choose. What distinguishes the session from all the others? Read reviews, see mention of the program but can't figure out what specific model they are and whether they are available for other models. I would like to make the right choice. I would appreciate any clarifying information.
