Test products technology SEM.
Re: testing the products of technology SEM.
Good afternoon, all individually, chattering and reloading it is not required to operate neocolony, especially because You only have two, two can not match , and if matched then it just protects from these aspects, it Can also be that they are very harmoniously fit into Your integrated field and you have enough fluid, or the accumulation , transition of quantity into quality and you just need to observe yourself to track changes, as they necessarily are or will be, but once again the chatter and overload optional this is not a criterion of the work of neocolonial and one of the side time-related phenomena, passing under the appropriate changes of the integral field of the operator.Жанночка wrote:Auricollis I did all that, I have a Corsair + Intuition in the mode of power, wear for 2 weeks. And we wait, listen - well, nothing yet, not bounce, not Overdrive. I'm not sensitive? or not all right?
Regarding the marking of pendants who have a lot of them as an option: apply the highlighter on the back of the pendant is a label, then stick with transparent tape sticks well the marking is not erased pendant is not oxidized
The last time there was some sort of craving for silence not talk and all, not to speak not to write not to ask the question matured in the head as it is blown and it turns out the answer(not always of course but that is already being tracked) , not as a response more specifically and as is more often voiced by the one to whom he converted. An example in the forum thread Event Crosby asked what the pendant to give people from alcohol remember that Achim wrote that gave my test Corsair relative to the drinker, even wanted to write to ask Achim, and Achim here in my post in the thread test articles about him and mentioned
Somewhere in some thread I read, but now with the move can not find that will be tested Pendants on 2 levels. Can I still before the second level
But really want to watch in comparison. How to get into the group testing?
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
NVPmainly for testing neocolonial II level are invited to participate in the testing of level I, but for some reason exceptions were made... it is individually solved in PM
and when 1 have tested NVP level not yet bornАура wrote:mainly for testing neocolonial II level are invited to participate in testing level I
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
As I understand it, and perceive the second level of GAAP will help me to better understand what the......... approximately..... 'stopped-frozen Creek' or 'cold fire', or....... 'liquid stone' about...
Or ..... uh... 'euthanized pieces of sin'...
I.e., in fact, quite abstract from the point of view of the first level concepts...
- Иван Славов
After a couple of days to go pick up the parcel with ноокулон2 to the post office.Ира wrote:Achim, are you taking part in the test?
Yet ноокулон2 to me felt some 'things' with "time" and "life-death" as abstract and practical concepts/. I would be very interested in working in this direction.
Aura
You could say, the perception in all individual. Different levels of GAIP is a different matrix laws. We must understand that the integral field of GAIP to some extent the conventional concept. Like any structural component, SP GEEP can be viewed from the perspective of difference or the position of formation of the single. It's like the faces of crystals or dimensions - the view is quite different, but he does not need to determine the differences and associations of perceptions, that is, the formation of three-dimensional vision = perception of the program-level. You can even be tracked software component, although at a different level will have completely different qualities and names, but a single process defined by the system of the Balance+. That is, to approach the perception of the levels are not abstract, but practically, it is necessary to deal with this function.Ахим wrote:As I understand it, and perceive the second level of GAAP will help me better understand.... quite abstract from the point of view of the first level concepts...
Aura, can you please tell how to understand that it is time to start working with the pendant level 2?
It seems to me that in addition to testing of the pendants you can test operators)
I have a pendant Master. Judging by the description, for my purposes it fits best.
Do I need to buy 6 more pendants and start to wear them? If so, what? How long to wear them? Or is it possible to start work from the 2nd level?
And you can not detail about the Wizard. I think about it, but I would like some personal assessment. Thanks, if you can leave your comments)))АндрейСу wrote:I Have a pendant Master.
It's hard for me to write about any specific changes, since it is difficult to understand due to which they occurred. Any the event, something changed in my life, probably did not happen.Доктор М wrote:And you can not detail about the Wizard. I think about it, but I would like some personal assessment. Thanks, if you can leave your comments)))АндрейСу wrote:I Have a pendant Master.
I think I began to understand better some of the processes in the flow and processing of information, improved understanding of how to achieve "mastery" in a variety of activities. Sometimes they even manage to notice that a direction has moved to a new level "skill". At the same time, to be honest, I don't know how to choose the direction of further development.
But only whether this influence of the pendant or anything else - read this molding (especially messages Aura), reading various books, the job of the energy of the workshop are difficult to define.
The only noticeable effect - if I'm sleeping in the pendant, the dreams more stringent, sometimes even closer to the cruel, if without the pendant (even if it is just lying near) normal good dreams. I don't know why it happens, but many times checked and all the time the same effect.
The greatest samurai and the Great sword Master Miyamoto Musashi....directly and said, " Learning the art of the professions of carpenter or farmer or Builder, are most afraid that I will help..along the way . and thereby deprived of the opportunity of full development.."АндрейСу wrote: improved understanding of how to achieve "mastery" in a variety of activities.
if there is a BRM nookular be superfluous?Аура wrote:That is, the qualitative development of Brow, that is not just feedback, but if it is possible to achieve stable results, the operator masters the 2+ level at once, if not 3+. But could this not all, nookular in this way a more consistent and simple tool.
Аура wrote:and this is also possible with the position of a Warrior, a Sage or Priest.
it is also a program like this?
- Иван Славов
But the Sage, I would add, and Sorcerer, but this is only possible their own individual interpretation...
"Energobalans"...Аура wrote: I am giving away one piece of information, because time is so special it's how to treat it, everyone decides for himself. You can agree or disagree, respond or not and in any case it will be right for everyone.
Of our planet long enough have made a landfill power station. If not a concentration camp. We have been deprived of rebirth. What Buddhists say about the rebirth of the shower, no longer applies to many living on our planet, because that was the rebirth of the soul, you need to have something to be reborn. If there is nothing that original energy that was given at birth, and selected, merging into a single “Energobalans”. This energoblok seers perceive as a gray mass (it is also well-Castaneda in his books described). That's all the rebirth ended. The point is that the original energy (without being attached to terms of probation you can call it a Soul) requires appropriate density, not to be dissolved in mass of grey after death, and it's not so hard to do, if you understand one time, but no one teaches it. And on the contrary learn how to liquefy with the release of energy, that is, how to be a Perfect Battery. With this purpose, the information space of the Earth is filled with virtual programs, which purpose one – not to give the man for his short life span to understand what was happening, to encourage maximum emission in the near-earth space of energy in life. This is done very simply, I'll give you an analogy for those who all the previous posts not read... at the program level we perceive reality is nothing more than an illusion, the picture on the screen, the pixels is an analogue of space, i.e. space does not exist by itself, it is also the only program glowing or dead pixels – this is what we perceive as physical reality. A character that moves on the monitor, it is also the movement of the luminous pixels – our physical body, the existence of which is also determined by performance of the corresponding program. Is Programmer, conditionally correlate with human consciousness, or the built-in control program. From the settings of this program (of thought patterns and filters of perception) depends on what is happening on the screen.
In my humble opinion, part of the message of the Aura, quoted above - a provocation, a kind of test of the commitment of the forum to virtual programs, their receptivity to them. Explain why you think so. Last night when the moon rocked "big boat" from psychic workshop model in boots and mini skirt. What am I? Sensations from the process of rocking - gorgeous, who did know
I think the post Aura's not just about that, the energy of the land originally for other purposes less thinking and more in line with your described outfit. that is, for thoughts of him need to go to another floor, you can compare the understanding of the different chakras. A General class run skirt shoes Chikatilo energy of the earth good man
I suppose it's from the fact that all messages of the Aura multi-level and "magical"Милая wrote:In my humble opinion, part of the message of the Aura, quoted above - a provocation, a kind of test of the commitment of the forum to virtual programs, their receptivity to them.
Hmm, I like it and did not come to mind to subside in the pendant, well, I just do it in the way)) I sleep in a bandana - great! Dreams bright and positive. interesting, will test pendants at night...АндрейСу wrote:the Only noticeable effect - if I'm sleeping in the pendant, the dreams more stringent, sometimes even closer to the cruel, if without the pendant (even if it is just lying near) normal good dreams. I don't know why it happens, but many times checked and all the time the same effect
