Variety of crystal may be any, each has its own characteristics.операторпси wrote:Hello everyone! I have a question: is it necessary rauchtopaz need? I want to kill myself no, we're not in the sale, and the order will be brought only after the 20th day, and now only very large in the presence or chipped. Can quartz different? I saw another rock crystal with fluorite, but it is also the size didn't fit (sorry).
Bioresonance modulators
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Aura
Re: Bioresonance modulators.
Will work for any crystal, even without an antenna. But if we are talking about the modulator and the operation of the whole chain from OS to GAAP, there are certain requirements for crystals, though some are from jewelry. For example, the volume of the crystal (not to be confused with size), or the symmetry defined by the relative position of the faces. But most important, the primary property in the selection of crystals for BRM is its field. Crystal is not just a structure, but also the energy characteristics of the space, where he grew up. We can say that in the growth process of the crystal absorbs all the characteristics of the space in which ROS (which are especially strong are the crystals in the growth process without contact with the surface). The most suitable for BRM are crystals formed near the peaks of Energometall of the Earth.нева wrote:..I Think that any quartz...will work..
I just two days after buying I decided to check it out, and sent the intention that the money spent returnedАура wrote:Often the first the intention inherent in the BRM quickly and works well, because often is "to check" and does not want it-promise. And when the operator learns to get the first response, then immediately turns on a wishlist, or simply human greed, and intention begins to include "want, want..." Correctly formulated intention is a condition when there is, what is desired has already been achieved.
And that quickly, for several. days
And then I started to want. I should have more... want a million...
With the phone too was a glitch. My phone reads the time from the network, i.e., the time\date in the menu there.
I turn on the phone to check the time. There 9:35. Takes about 10 minutes - I again look time. There 9:35.
Had to watch another accurate time source. There 9:35.
Very similar to the responseоуаакун wrote:With the phone too was a glitch. My phone reads the time from the network, i.e., the time\date in the menu there.I turn on the phone to check the time. There 9:35. Takes about 10 minutes - I again look time. There 9:35.Had to watch another accurate time source. There 9:35.
You have Rauch, perhaps?оуаакун wrote:I was just two days after buying I decided to check it out, and sent the intention that the money spent has returned And so quickly, within several. days . And I had the extra money for a 2 BRM. 10 days.
Aura
Basically, the BRM crystals possess a positive organization structure. You can call BRM "booster thoughts", but was empirically revealed different sensitivity of the different crystals to positive and negative aspects.лексветер wrote:bad negative thoughts are very much hurt with BRM, his Bram that is, to strengthen, good, bad, but the truth is, there are different types of stones and different they work, some neutralize the negative, reinforce the positive etc., etc., a lot depends on what BRM is assembled.
Aura
How is the tablet connected to the Internet?Кирил wrote:Hello. Question to the developer. Please tell me, is it possible to use BRM on the tablet, because with him, spend more time and I think the attunement with him more than the phone?
I recommend to ask your question to the developers of BRM on the forum. However, I still don't know who to address it so I will write just in case, here) I'm interested in whether the smoky quartz do not glue to the phone, and just carry it with you?
I'm the first one two put. Rauch and amethyst. Then decided the amethyst into another phone to stick.снорк wrote:Very similar to the responseоуаакун wrote:With the phone too was a glitch. My phone reads the time from the network, i.e., the time\date in the menu there.I turn on the phone to check the time. There 9:35. Takes about 10 minutes - I again look time. There 9:35.Had to watch another accurate time source. There 9:35.Like "your time has come."
But now I think that may be the first time I did the right thing and it was not necessary to glue.
- операторпси
- Been thanked: 3 times
What's the point ? With the same success you are buying the crystal in the shop "World of stone" and carry it with you.Ирис wrote:I recommend to ask your question to the developers of BRM on the forum. However, I still don't know who to address it so I will write just in case, here) I'm interested in whether the smoky quartz do not glue to the phone, and just carry it with you?
I had worn one on the phone are in good contact with the crystal...then bought another tube..and stuck there too, so the first so offended that in the same hour old phone died.. even though the tube was quite new..оуаакун wrote:I'm first on one phone or two stuck. Rauch and amethyst. Then decided the amethyst into another phone to stick.
Wi fi is always enabledАура wrote:How is the tablet connected to the Internet?Кирил wrote:Hello. Question to the developer. Please tell me, is it possible to use BRM on the tablet, because with him, spend more time and I think the attunement with him more than the phone?
Well I have not offendedнева wrote:I had worn one on the phone are in good contact with the crystal...then bought another tube..and stuck there too, so the first so offended that in the same hour old phone died.. even though the tube was quite new..оуаакун wrote:I'm first on one phone or two stuck. Rauch and amethyst. Then decided the amethyst into another phone to stick.
But the second phone has become more convenient to put under the pillow (the screen is not rastavitsa). Dreams do not remember any dream, but the images and different shapes floating before my eyes as in a kaleidoscope.
Today include phone time, it's 9:35
. This time it was the exact time GMT. Two phones started to show time simultaneously.
операторпси wrote:What's the point ? With the same success you are buying the crystal in the shop "World of stone" and carry it with you.Ирис wrote:I recommend to ask your question to the developers of BRM on the forum. However, I still don't know who to address it so I will write just in case, here) I'm interested in whether the smoky quartz do not glue to the phone, and just carry it with you?
1. There is enough of it to put under the pillow for one night or continue until the activation will not feel?
2. Is it possible to apply over the phone cover?
3. What phone is it for me to glue, if I have two, one is occasionally used for calls (I do not basically talk on the phone it turns out), the second active use for communication in networks and the Internet, but they say it is even less (number of other areas in which I am 1-2раз per month)?
- операторпси
Iris I have a question:
the crystal in BRM encapsulated or just one fee?
- операторпси
You also have to be manual?Ирис wrote:Thank you)) but I have a few more such stupid questions
1. Under the pillow is for the lazy, and under the pillow glued to the phone.
2. In my opinion there is no difference - field capture is still more than a meter
3. I also rarely call, but sit on the Internet 18 hours, so put on the phone with the Internet
Aura
The wi-fi frequency higher than that of the phone. The antenna field of BRM is designed to work with mobile gadgets. On the tablet, it will work, but not as effective.Кирил wrote:Using wi fi, always on
AuraАура wrote:The wi-fi frequency higher than that of the phone. The antenna field of BRM is designed to work with mobile gadgets. On the tablet, it will work, but not as effective.Кирил wrote:Using wi fi, always on
please comment on the situation:
The quartz glued to the gadget for 3G
The bridge on the tablet with wi-fi
Amethyst - phone frequencies 453-467,5 MHz
Whether I did or overcomplicated?
The response is, funny situations increased intuition increased.
That you have now pinned, right?операторпси wrote:iris I have also a question:the crystal in BRM encapsulated or just one fee?
and regarding the user: to put under the pillow of BRM You can call the method for the lazy, and the manual says that this is the best activation method, considering the maximum of his work with hour to 7. You tell me to put it already pasted on the phone, and Vladimir or someone responds on the soap, with an exclamation point recommended in the beginning to activate, and then on the phone glue. I'm really quite confused
Wolverinethe concept of a "meaningful" are different) It's not a magic wand that waved and g-PA...so the term "true" is not very appropriate here...explain that with this device need to work. Yes, and I understand that the modulators here 2 months for sale...meaningful change, a person needs to be ready. I personally have over a month of working with BRM a lot has changed, although most of the time was spent on the attunement, the actual results have recently appeared. First, their self-perception has changed - a better intuition, higher awareness, energy has become more time to sleep was less to go. Well, all sorts of material things, like money almost out of nowhere, and cars. Yes, and occur in all sorts of situations, and lately everything is very well composed, like everything conceived in my favor. Recently, for example, before going to the car, the phone rang, and only the hand touched the phone, it's like a flash the realization that this trip is necessary very gently and carefully led. Indeed, if not for my gamerprofile behaviour on the road, crashed into the right side one...mm..bad man in Beha)) And significant or not, everyone decides for himself.)
I somehow came to the conclusion that if their own "power" and skills are missing, and without BRM you can to their essential purposes to walk. By the way, after 2 months of wearing much became calmer in their desires. And when dealing with him (BRM) put just the task application properties - Parking, need meetings, quickly look for something...Россомаха wrote:anyone has to pass something meaningful?
But this time, just 10 days ago, there was a significant event for me, which looked highly unlikely before, but very desirable. And related facts talked about what to expect of this event had even indefinitely. Specially I this event is not planned with BRM on this topic is not talked, but maybe he calculated. Parking I have exactly what happens - always find a convenient place that's not planning, only the overall message.
