Panacea or product "P"
MAG.no, as they say - we are alive not dead men
Too bad you have no faith in miracles, which still have a place to be. But about panacea Building will need to have a look. Thanks for the replies.
Re: .Panacea or product "P"
I have faith in a miracle all right, we're close, but the miracle often individually..... Objectivity does not negate the possibility of a miracle.....
Unfulfilled and unreasonable expectations often disappoint, I believed-believed, but the miracle is still no, "promised the Korean".....
Sincerely, MAG.no
(quote from this thread)Михаил_ wrote:Well actually it is not so
I hasten to disappoint the public, then the public is not disappointed myself
Sincerely, MAG.no
It is impossible so to speak.Витал wrote:.... I would like to ask developers of "Panacea home" and "Youth", give them something of such flows and about the fact that the house and the youth have different firmware and they have different objectives it is clear, but what is better to take Home or Youth , I never received( I would like specifics, took the Youth, will have you and or it, took House will lead to this effect, or rather just clean the space, etc) thanks.
Ie and the Panacea-the house and the Panacea-young, fulfill your program according to the description and its features. Of course, the description is narrowed from the multidimensional picture of reality. And the real work of these products is wider. But the result of their work depends on the context. I.e. those operating conditions in which it takes place. You cannot just say that it will happen in your specific case the use of these products. They'll do it. In the framework of the description and a few more. Brushed and harmonisierung house, plus the connection of these structures to the operator increases positive events. It is a fact. Whether you are implementing this is shown by the events visible in the background of what has already been for You personally? I do not know. But the work "home" visible, judging by the fact that many come for additional sets (well, because there are large houses, offices and so on, not always one you can do).
Youth affects your cocoon and your algorithms of interaction with the world. Ie in some way changes the context for the manifestation of the positive trends, or rather that part of it which is You.
Moreover, the area of its manifestation is unique.
So this is a completely different product to compare that affect the whole. And in your case more important - is only correct You may be seen.Maybe nothing
Hello!
I have a desire for each link wide bracelet Panacea ebony stick nakleechka Panacea VIP Youth.
I have a bracelet a Panacea. And I want to paste both bracelet nakleechek Panacea VIP youth.
Should I do that?
Thanks in advance for the answer.
Should I do that?
The range of the bracelet is wider than a particular case - focused "tuning" the Panacea for Youth, and Litera VIP for most of the performance of other media that focused on "settings", which is to be worn on themselves enough and they provided precise localization for
embed. Therefore likely to get a programming Panacea for not regular, ie, and effectiveness of the Panacea of Youth not much added (and may even interfere with the regular activities of the system elements) and bracelet Panacea will not be complete..... "oreida".
I think once.....
Sincerely, MAG.no
I think once.....
Sincerely, MAG.no
Константин.
- Been thanked: 2 times
I would put on the bracelet stickers Panacea. (not a youth). This is exactly significantly will increase the bracelets.
But these stickers are slightly larger than the link bracelet. will act region. and Stickers have a little cut.
there is no such stickers. You were dreaming.Moon wrote:Hello!
Should I do that?
VIP is done individually for a person.
To use the photo demo VIP thus for constant wear - no need. It is not personalised and therefore can be unexpected consequences that are not needed.
Addition. Complete panayatou, stickers work, complete with the main carrier ( the card or plate keychain in case of VIP version.) yourself stickers palamalaguti in all trim levels the same. Are conventionally driven from the cards or records. so the owners of vipmodel them and on the bracelet. The main thing that the overdose was not. At first I thought about copying a matrix vipdemo, that it is not necessary - it has a temporary personalization.
Hello!
I pasted each link into two broad bracelets Panacea for personal nakleechki youth VIP.
Sleep in these bracelets. Do not feel Overdrive.
I want to know: can top these nakleechek(personal nakleechek youth VIP) stick the stickers panacea.
Ie on each link is covering the personal label youth VIP top want to stick the sticker panacea
Is it worth doing?
Or is it better to buy two more wide bracelet Panacea and pasted each link label is the panacea?
Or is it still possible?
I already pasted
Thanks in advance!
Is it worth doing?
I already pasted
Thanks in advance!
Went! (Are unable to edit with the iPad )
I already pasted personal VIP youth paste on top of the sticker Panacea,
and in addition acquire two wide bracelet panacea and paste them nakleechek a panacea.
Thanks in advance!
Thanks in advance!
- ВладимирРева
I'm certainly not a Pro but I think it would be already too much one another five times to glue,BJ works for the max depending on your will.And protects as you do so BJ a panacea, why are there stickers more....I could be wrong but better buy other bracelets clean with a track cleaning and stick sticker....
Stickers on the bracelet Panacea Panacea enhance the bracelet significantly !
It is waiting for the response Michael!
1. Reinforce the fact.
2. Yes, it can be done.
3. In the system "panatest", as with all the older versions of the BZ (2.x, 3.0) and youngest too, is important (one of the main points) listen to the desires in behavior, nutrition, physical exercise and so on.
ie if you want a brighter effects - listen to more of itself, it will create a chain of self-empowerment effects.
Thank you very much for the answer!
ЗОЛОТАЯ РЫБКА
Hello everyone! My brain is still trying to stick at anything that is discussed on this forum
but disabling logic intuitively feel loyalty to all that is happening
Michael, do you know when you receive the programmer and what is it all about? How it will look and how much cost
- Has thanked: 1 time
- Been thanked: 10 times
Fish, it is better to begin not with the programmer, and BJ 2.0 and/ or 2.1
ЗОЛОТАЯ РЫБКА
Master 108, thanks for the advice! I just feel the need to Cure, so I want to start with her. I have no way to buy all of the modifications unfortunately, and bracelets with rings I don't wear....
Hope to talk will not
Well then read the forum further. As you read you will find the answers to all your questions. Programmer, yet he is only in development, respectively its functionality and appearance not yet been fully determined, and information about the programmer you are unlikely to be useful.ЗОЛОТАЯ РЫБКА wrote:... do not tell me when you receive the programmer and what is it all about? How it will look and how much cost
ЗОЛОТАЯ РЫБКА
Thank You, Druid!
no, he just designed and appearance defined, although some supplements is also true in the process, his publication restrains only the quantum of time to assemble the first batch.
but for novice user it is not particularly necessary, you need 2.0 and 2.1.
And "bracelets do not wear" - so take a map transfer. But it is better to wear.... i.e. I wasn't wearing any. So what?
ЗОЛОТАЯ РЫБКА
Michael, thanks for the comment
I don't know why but it pulls to the Cure... ie. do I understand correctly that the programmer need advanced user, but for a beginner only needs a bracelet version 2.0 or 2.1?
ЗОЛОТАЯ РЫБКА wrote:drawn to the Panacea
Once You are drawn to the Panacea, then it is good to listen to... yourself. Only if you start with a Panacea - it is necessary more accurately. First familiarize yourself VERY well with info, and then...ЗОЛОТАЯ РЫБКА wrote:for the beginner requires only a bracelet version 2.0 or 2.1?
Especially if you want You /via a digital matrix,
This is an example of a 'digital switch' with the means at hand.
I was also very drawn to the Panacea. However, I still reviled some of the time 2.0 and 2.1, but pulled so very specifically. So I also think that you should listen to yourself. By the way, may be better to start with a Panacea Lite
Владмосква
- Been thanked: 7 times
Michael, in the presence of the pendant N does it make sense in the future to get P-a bracelets or not (to be scarce space on hand to take)?
Konstantin wrote that the pendant in his(personal) feeling is ~30 P-bracelets.
I personally do not hurry, master 2.1, this question is for the future + answer other users will be useful.
