Orgone generator with their hands (SP). The FLAME
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Thu Jul 01, 2010 11:23
People where You just deduct it
in my opinion it is a little old....
what makes you think that all of this still work?
and what is the effectiveness of what you are saying.
Well rested You knots of wind, and who said that it will give the desired effect?
here I placed some accents, for those who like to read:
http://www.wizzersworkshop.com/Modern_O ... /M_O_5.pdf
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Thu Jul 01, 2010 13:24
Михаил_ wrote: And now the tricky question - why do Radionics stikipad has a color and a transfer pair is also similar in color? and what's it made of ? :)
I have no Radionics, but I would venture to suggest that from clay :)
Михаил_ wrote: I've had the opportunity to talk with ASD at the event where we randomly pulled.... and listen to some of his explanations.
It's the least the following frequency and other principles. What in esoterics is called space principles, or "matrix" as a movie.
With the Parlor, indeed, all is not easy as it may seem. I realized this only after a year of wearing.
Post by Михаил_ » Thu Jul 01, 2010 13:46
Mmm when in the office MM probe Radionics the first thing that came to mind is to do ceramics and :?
close but not exactly.
As additional factors to consider that Welz is a family owned and ceramics home is not always convenient to do.... in addition, the annealing often erases the information (if not provided the entry during the heating-cooling), and he needs otherwise.
but in any case
http://ru.wikipedia.org/wiki/%D0%9A%D0% ... 0%BA%D0%B0
Новик
Post by Новик » Thu Jul 01, 2010 14:20
Michael_
If I understand correctly, the key point is that they mixed into the clay....
Some sort of mix of mineral grit?
Post by Михаил_ » Thu Jul 01, 2010 17:49
Key points three and they are all very, very simple.
1. clay, the words of Karl, it is something like things have structural connection with the entire biosphere (which is passing its life cycle in the form of elements has to stop the rot (soil) washed it with water. Ie is a direct projection of the life cycle and life energy of solid. (don't need to go any mineral crumbs!)
2.the key point in the mental program that links the same stick pad with a large brick generator, this is a mental program (the language of the SDA it will be called structure, but not in the sense that it explains Welz, i.e. the structure as the highest element of the world, PRINCIPLE).
You can say that Welz has created a prototype of the device detailing how it works and it's not a simple thought, but something more, that it binds stikipad generator ( in rad 5 there is even a wiring netuti, but stiked so vividly responds to the settings).
3. key time latest this the conditions in which you can prepare this with a stick pad or the generator. Remember that Welz talks about negative entropy. To do something contains the energy you need to have the energy (or the setting in which it is). Then you will think of, quite simply, there recently have done the same for charging BJ and wrote about it on my forum.
all....
well, no, there is a correct model of the device + electronic part - it is of course also important, but from the point of view of technology of manufacture of the molded part is all.
The rest concerns the construction of control algorithms and the type of pulses on the generator (which is also important, but about it I already said earlier, who needs - will find). The key word soliton.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Jul 01, 2010 23:08
Михаил_ wrote:don't need to go any mineral crumbs!
1. Individualization pair (bunch together) how implemented? Visible under the varnish a single insertion of a different composition.
2. The porosity of filler than could be caused by and what features it adds?
3. The rear of the couples are open from varnish, some of the principles for which properties.
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jul 01, 2010 23:27
I'm not talking about the Shuttle, I talked about the panel stick pad. The Shuttle looks like the thing that the relationship did indeed put the parts of the whole to its half, so the first blank (as building) and then it refilling.
As I understand it, the connection table and the connection transfer pairs are made on different principles and for good reason.
Post by Маг.нет » Thu Jul 01, 2010 23:33
Михаил_ wrote:Natural biocycle includes the mass of living organisms. It starts with the growth of plants under sun light and ends in the earth. And do not think like the human body, without water.
Two opposite funnel which you can "copy" locking? To get one, you need to have a close other? Or is it two points of the vector energy creates the flow?
Sincerely, MAG.no
Post by Михаил_ » Fri Jul 02, 2010 0:45
no, I'm not talking about it.... just have a, let say "pulse" of life on the planet, the type of rhythm conductor, the person is part of the Biosystems and if plants live by photosynthesis, the person - a secondary energy receiving it from the biosphere (man can't live without the biosphere - will not recharge).
Clay captures the whole cycle, with its huge species diversity. Well, maybe not all, but for the area.
Ie, not something to divide into two streams and record - everything is already locked in, you just need to chase the thread (to create the conditions for a stream) and get the excitement of this clay, will be environmentally friendly energy, it is a natural for living organisms.
Post by Маг.нет » Fri Jul 02, 2010 8:30
Михаил_ wrote:Clay captures the whole cycle
Clear... Thank You!
Sincerely, MAG.no
Вадим Перелыгин
Been thanked: 7 times
Post by Вадим Перелыгин » Fri Jul 02, 2010 12:33
I suggest to use SP, which design came up with another Koschei the immortal:
(there's water and sun and clay and roots funnel and the funnel of branches and the connection with the biosphere of the planet...)
In ecologically clean area (in the far far away Kingdom), in a protected area (so not soon cut down).
To choose a powerful wood (oak, cedar – giving energy, not spruce, alder,.. – take away energy).
Find the hole (higher up) or make a small hole.
Put it in its structural label (photo, hair, nails).
Plug the hole with a piece of the same wood and gloss over garden pitch.
It is desirable that nobody saw, and that some Ivan the fool (or not fool)...Although it is unlikely, if the warlock was honorable, he would have no one fool would not be touched. :lol:
Вадим Перелыгин
Post by Вадим Перелыгин » Fri Jul 02, 2010 12:44
Шалтай Балтай wrote:here, here I placed some accents, for those who like to read:
Dear Humpty Baltay, would You, as a specialist in English, to make a brief selection of the most important places of this document in Russian? I will be very grateful! az
Post by Маг.нет » Fri Jul 02, 2010 13:09
Вадим Перелыгин wrote:Put it in its structural label (photo, hair, nails).
There is a variant: pair number 44(transfer of energy) will cost 2000P.
An experiment similar to that described under evaluation. The answer for Mihailom if there need energy, what quality and intensity, use.
Sincerely, MAG.no
Post by Маг.нет » Fri Jul 02, 2010 19:40
REMINDER of the TEST the VORTEX DEVICE:
Eddy ray is, above all, danger.
There is no protection. Torsion beam easily penetrates through any matter. Conversely, this beam is a barrier to penetration of matter. The potential difference should clearly know!
In a strong vortex field is a powerful effect on the tissues of a living organism and its frequency can be resonant for its individual organs. Conversely, a weak torsion fields of a certain frequency of radiation can have a beneficial effect on a living creature or plant.
The following property of the torsion field memory.
This means that the room in which the experiments were conducted with WU (read SP), will be a long time to store this information. There will be no radiation or chemical contamination, but the use of this room for a long time will not be so dangerous as during the experiments (if during the experiments launched destructive resonance).
The flow of the torsion radiation. This property, along with the pervasive ability of that radiation is stored not only in the research room, but also spreads through the neighborhood.
A bolt of lightning at the vortex beam has a very high probability. And the sad cases on this subject abound.
Sent into the air a ray immediately rips a hole in the ionosphere, it destroys the ozone layer.
Vortex radiation disrupts the operation of various radio - and television devices creates interference to the flight of aircraft and space devices.
The drain of a vortex beam into the ground – causing unknown effects on soil, and all living energy body of the planet.
Vortex effect on the water, can lead to the destruction of the cells of a living organism. There are almost all water. It all depends on the proximity of frequency of rotation of the vortex to its dangerous subsonic resonant frequency.
For monitoring the surrounding space, I have lived in the area of operation of the devices is a small flower of Aloe.
Began to give "kids"... Good "feedback".
Sincerely, MAG.no<
Post by Маг.нет » Fri Jul 02, 2010 19:49
Stream quality matters...
As the resonances broadcast...
Nowhere to hide, no escape.
The memory stores the resonance to 40 days.
Sincerely, MAG.no
Post by Михаил_ » Fri Jul 02, 2010 21:59
1. Don't know what's up with the warlock :) (if we remember, he, too, SP on gold did, judging by the text :) ), but I would advise 100raz is very good to think before something to stick into the tree like a direct link to the hair and blood.
You need to have very good health and is proper diet like the raw food diet. Why? because any inflammatory process + recharge this way (which is not promptly SHUT down) can be a problem .... very serious, if not fatal. Well, you need to understand that the person and the tree are not the same and there are several different frequencies of energy.
2. On the transmitter that the transfer pair is not yet had time to look closely, but I don't see it in any case as a super or just a useful conduit of energy, more as a reference to an interesting place.
Ie man is "image and likeness" it has all the planetary energy. If there will be some death in man, how will off the disease, to die unwanted cells? The balance should be in everything, there is no perfect energy channel, which would be the solution to all questions and problems. So when we speak about a essential signal - it has frequency, but the man just wider band of life energy. It has a lot of qualities.
Increased feeding one energy without the ability to disable is not good.
I.e. for us, the inhabitants of the civilization of cities, the influx of vitality an important and allows you to recover, to regenerate, discover and recover your true potential and more. But everything should be in moderation and without frills.
3. direct link via hair and blood will give a stronger impact than the transfer pair if the energy source is very strong, but it will be unswitched impact.
Transfer pair will give a signal more powerful than just a simple page communication "Karl" like half of the stone, because it contains "active" algorithm, but the receiver is relatively small (in the case of blood, the reception starts to go on the level of resonance with the genome of this person is the guard)
Вадим Перелыгин
Post by Вадим Перелыгин » Sat Jul 03, 2010 22:46
Михаил_ wrote:don't know what's up with the warlock. (if we remember, he, too, SP on gold did, judging by the text"
No not so! "There the king Koschey over with gold languishes!" And SP it is described in the tale "the frog Princess". Baba Yaga said:
"...his death at the end of a needle (bone his no regret for the structural connection of the blood), the needle is in the egg (perfect form), Egg in a duck (frequency of birds), a duck in a hare (frequency of mammals), the hare sits in a stone chest (frequency crystal) and the chest stands on a high oak (frequency of the plant world), and the oak tree Koshchei the deathless as its eyes protects." So don't just in the hollow, and in the trunk, to which the worm-gnawed bark not. But broke the Prince at the needle end, Koschei had to die.
It's better to use the smaller SP and only be enabled when there is an urgent need, not forgetting that this is still a "crutch"! :)
Вячеcлав
Post by Вячеcлав » Sun Jul 04, 2010 23:02
I read the whole thread. Very interested. Thank you all for supporting this topic.
Want to create something similar, but more why we tend not SP audio input, and input for connecting the adapter. Adapter for Radionics, with the ability to increase or decrease power. Is this possible and what can be difficult?
Post by Шалтай Балтай » Mon Jul 05, 2010 10:34
Вячеcлав wrote:Adapter for Radionics
To be honest I do not quite understand what kind of adapter it is. Explain more please - think about this.
Вячеcлав
Post by Вячеcлав » Mon Jul 05, 2010 18:32
Yes, not absolutely correctly expressed. This refers to the power reduction and power increase (from 1.5 to 9 volts).
Been thanked: 182 times
Post by Андрей Кабанков » Mon Jul 05, 2010 20:27
Vyacheslav
It is assumed that through the input of energy from SP modulated by certain frequencies or your statements,recorded audio,allowing you to get some results from this.
Вячеcлав
Post by Вячеcлав » Mon Jul 05, 2010 20:42
Yes, Andrew, I understand. The idea I have to use SP as organogelator.
Post by Guest » Tue Jul 06, 2010 12:33
True, but to SP worked optional connection of a player (although the effects appear interesting), and plugging in the power supply it is possible to achieve more power. But maybe I'm wrong.
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Tue Jul 06, 2010 17:04
and the work - only sensations.
well, you see for yourself that it works? what are your feelings?[/quote]
Свами Доупаду
Post by Свами Доупаду » Wed Jul 07, 2010 23:23
Вадим Перелыгин wrote: Parsley, like many plants, cone-shaped roots(funnel) concentrates the energy of the earth and tops(inverted funnel) concentrates the energy of the cosmos in his body.
Is it possible at least to use HEMP ?
Is it sufficiently concentrates the energy?
