Advice from Andrei Patrushev
Maxim
No.
No.
Andrew, good day.
Checked out your mp3 file to the other player, and he lost his normal, left channel to left ear, right in right, while and the machine and the first player playing the left channel in both ears.
Don't know why. It turns out, time machine this audio file plays, and then the rest of the files it can play. It turns out that the audition turns out a mess?
Maybe there are some ways to test more precisely the location of the channels? I just don't understand mixed up in the machine channels or mixed up, or they messed up and one channel for another two goes. To diagnose something.
In fact, so, but in machine the main light, not sound, so not much worry. The case most likely in incompatibility of plugs (tolerances). I've encountered this frequently (sometimes the eye can see, even if applied to each other).МаксимМ wrote:it Turns out, time machine this audio file plays, and then the rest of the files it can play. It turns out that the audition turns out a mess?
By the way, if the right channel plays fine, the left ear will just monaurally beats, that is, the right hemisphere will be slightly more effectively be stimulated....
Okay session. But with disks it is not so.but in machine the main light, not sound, so not much worry.
And these plugs you can somehow change it, or even possible in any way to fix this thing?
Maxim
For discs same thing - if the right channel plays fine, then nothing wrong with that.
To change, of course, possible, but a lot of fuss and guarantee will be lost.
Andrew, and if you change the firmware I have is of 1.16. It may not be the case?
Listened to the Conductor on the machine in the place where the text is on two channels, channels play in the left and right separately, i.e., the left channel sound only in one ear. Channels, of course, confused, but the important thing is that each channel sounds only in one ear. It turns out that everything is fine? Or is it not an indicator?Checked out your mp3 file to the other player, and he lost his normal, left channel to left ear, right in right, while and the machine and the first player playing the left channel in both ears.
It hardly...МаксимМ wrote:Andrew, and if you change the firmware I have is of 1.16. It may not be the case?
Yes, everything is fine.МаксимМ wrote:it Turns out that everything is fine? Or is it not an indicator?
Sadly, but I have the "Navigator" is the same: the phrase "the Left channel" sound in both the headphone and the "Right channel" sound in the left earphoneМаксимМ wrote:Tried on the machine and on the player. The phrase "left channel" for some reason and typed and the player sounds in both ears, and "right channel" on the player fine on the machine messed up.In any case, check this
The computer - fine.
Just in case even the file in Audition'e checked - correct file!
Sair,Maxim
It is necessary to Alexey, in the relevant subject about the Navigator report.
Andrew! Question. My daughter's almost 15. She's practicing ballet. Professionally i.e. almost Every day and a lot. The question arose with its growth. Heredity. Can't go anywhere. I read that healing 2 promotes growth. She naturally experience any psychoacoustics. 1. If she is 15 years start with healing 2?
2. Realistic expectations that it will grow more than nature has? And is it harmful?
3. I still wanted to give her the morning star traveler the second track, for school. Is it possible to combine them to her? Not much there will be for a teenager without psychoacoustic experience?
Thanks for the replies
Dmitry
Dmitry
I will soon do a pause with the conductor. Whether this pause to switch immediately to other disks? For example, a pause of 15 days. In the 15 days to take the course the star wanderer. Or still give the brain a rest from psychoacoustics entirely?
Thank you
Dmitry
Thank you
Dmitry
Yes, other drives without interruption. As for the rest - do You feel. In my opinion, breaks useful.митек wrote:I will soon do a pause with the handler. Whether this pause to switch immediately to other disks? For example, a pause of 15 days. In the 15 days to take the course the star wanderer. Or still give the brain a rest from psychoacoustics entirely?
MiTek
In 15 years it is unlikely we can say about the success in increasing growth, but it's worth a try. In addition, if not limited to audio while doing exercises. The exercise is simple: before going to sleep hanging on the bar (on door, etc.), but to descend carefully, without compressive loads on the spine, and literally koryachkah follow straight to bed (well, on hand consider).
Yes, it is possible to do it in the morning. And Исцеление2 you can do in two days on the third listen.митек wrote:I still wanted to give her the morning star traveler the second track, for school. Is it possible to combine them to her? Not much there will be for a teenager without psychoacoustic experience?
Andrew! I have the whole forum have already read and then I realized that I do not quite understand the difference between ZS and "healing." They have one goal (even fits the description). Or there are nuances?
Is there any sense other than the information interests, immediately after the "healing" to listen to ZS? This is also the alpha and the impact it seems, as I understand it.
I would like now to emphasize on improving concentration and memory, and the speed of response and efficiency.
If the meaning is to listen only to track 2 ZS in the morning?
Or all ZS in the evening?
Or all of the ZS 2 ZS the track in the morning?
Or the first three tracks (as stimuliruyushie) in the morning and 4. for the relaxation in the evening?
MiTek
Well, Star traveler focus on the development of memory, attention and fine motor skills, and healing, respectively, as (very specific), the most favorable for self-healing and a quick stay. Everything else (in the description) for these programs - the effects of. Both of these programs (plus three more) combines a Massage of the Brain.
The most favorable time to work with all of my audio programs - from 16 to 18 hours.
For a quick "refreshing the head" and setting the status is enough to do in the morning with the second track of the Star Wanderer.
Between listening to audio programs and sessions Masin at least 3 hours.
Is it possible with the aid of a drive to encourage the person to path of self-development?
I'm talking about people who are far from the ideas of self-development, of zhivushih in the "conclusions" of their prejudices, fears and beliefs.
Those who do not like themselves and are afraid to even think about what a should do. As she thought about the lesson itself immediately evokes a strong sense of guilt.
Those who are hiding from your feelings for this has dissapeared as a rule the pain (childhood traumas).
Those with nesbalansirovannoi self-esteem, with all vytekayuschimi.
I did this. I managed from this vicious circle to break. I'm on the way. It was not Negro.
I would like people to this realization. But they have fierce resistance.
And the more sensibility in me that I find it difficult to find a common language.
To escape and save 1000. Doesn't work.
MiTek
"Love can not be"...
Алексей Крячко__
- Been thanked: 17 times
Good day to all ! Audio playback is through a separate audio codec with its "iron" software, in which to get impossible. Switching "Lefty-righty" only affects the sound and light in a session because it plays the main software tool.
Alex and the channels are reversed only audio or both at the sessions too?the audio Playback is through a separate audio codec
my mother and wife both (I'm trying to convince them to listen to ”healing“) talking about the fact that they interfere with the headphone wire. And they are unable to sleep/relax. This suggests the need to control?
