Bracelets Life
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: The Bracelets Of Life
Post by Бисо » Sat Apr 01, 2017 16:51
There are advantages if the bracelet becomes more solid - width somewhere between 30-35 mm. Something like this: http://wellery.ru/derevyannye-braslety/ ... jki-vbr559
Or crispy this bracelet: https://www.etsy.com/listing/240703325/ ... e_active_7
And this as an option: https://www.etsy.com/listing/244623330/ ... _active_11
Post by Михаил_ » Mon Apr 24, 2017 2:03
Massiveness, as rightly noted, sometimes better. If there is much (human fit).
Валера Ворон
Post by Валера Ворон » Wed Apr 26, 2017 17:10
Good time!Michael tell me if Panacea Lite download smartphone file the letter will be some action?
Has thanked: 5 times
Been thanked: 16 times
Post by Вячеслав. » Sat Sep 09, 2017 10:36
Recepit atom... :) With my good friend ) have bother on the subject of what to use in his case as home-made.To use BJ, and since applying the move solved some problems :) indefinitely which deeply was sideways... there are certainly individuals extracting and transforming these structures into something constructive... ) but something tells us that they are not insured by disappointment.Slightly podrazumevaju,BJ and others _ deep reach certain levels was. the cocoon is placed and optimally embed / transformerait that over time will become more comprehensible form :?
Post by Вячеслав. » Mon Nov 06, 2017 15:52
The post below is mine ) thanks to the developer for 1.0 walendy modules"Pill"...Some negligence at the very first attempt to do something podobnoe nitcholas have on the ACC. result.And this is the fundamental hmm. thing... and to some extent the parent process) until the entry on the subject is teething, etc. in the overall process sdelka painful.
Now this is what happened,the thing is well vstraivayas in Kokan and in the interior of the garment.Turned out the plastic and gently presses ahead... not only all outside animals :) but it also prevents from getting into ballnik (rasadnik) Bazil :) I will continue to watch.
there is still the question appeared,it is possible to transfer items for example loved ones.
Post by Михаил_ » Tue Nov 14, 2017 21:46
Валера Ворон wrote:Good time!Michael tell me if Panacea Lite download smartphone file the letter will be some action?
Alpha version of a panacea is a button call the process of "charging" or more correctly overwrite the properties of the object. Easier and better (if you want to have a smartphone as an object of panacea) to put the letters on the lid temporarily (you can then erase) or even mental. The file will work too tak je if it be borne in mind. T/e the thing is not the finding of the letters on the object or in its memory and in the process start using them. As a response to the call of certain changes. As a direct analogy, when we get a phone call is the result from pressing the call button and she initiated the process phone and cellular network, and not from the fact that the phone recorded in a notebook the device - it can be put to memory from the keyboard to dial.... something like that.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Sat Dec 16, 2017 15:28
Obvious question. What kind of wood are now made bracelets? Before ebony bracelets were black, now brown bracelets.
Post by Вячеслав. » Sun Dec 17, 2017 9:38
Hello.
Need to clarify... :) and to the fullest extent you can answer.
Paradoxes -paradoxes ) to wear version 1.0 focused on module -"Tablet" you have to be really healthy :) written lot of energy eating this conventionally BJ,because I use dosed.
In fact, by performing simple recommendations for example a printout FRM to wear a few hours and otkladyvat if it is printed )).It disciplinarum,well, no one responsible over-the-shoulder looks,himself a Profesional.
And a little dessert :) to Slovo about is it possible to copy items from other people.To this question too on the practical side... suggested to a friend to wear with me.He enthusiastically agreed ),when I work for my thing, and I felt such a positive space.... that slightly stunned.Rather, I myself tested,I then wanted to copy to a media (to share) but wanted to quickly pick up rinse under running water.And keep your things in a 8)
Post by Михаил_ » Tue Dec 19, 2017 23:14
Vyacheslav :)
1.Most modules bracelets, working in the framework of the energy, which is the operator, which can be upgraded in different ways, which are themselves BJ :) If a module You personally perceived energy intensive, this is normal, but this is a personal perception according to personal energy levels and the tasks that receives the call module. T/e if there is "a lot left" - so there is something to work with.
2. In principle, all versions of BJ is wonderful self-cleaning that the first versions of that older, another issue is that to offer a friend can have an extra home-made, not tuned to your personal energy, because, as documented, the switching from one operator to another, takes some time, and removing the BJ to give BJ not clean (not in the sense of your personal energy, but in terms of the initial setting). Only recently with my tried OS 2.2+ with that on it, and returned in a minute with words that is overload :) However, the transfer of the BZ are quite normal, a common operation, without negative consequences for anyone. You just have to understand the nuances.
Post by Михаил_ » Tue Dec 19, 2017 23:41
Петрос wrote:the obvious question. What kind of wood are now made bracelets? Before ebony bracelets were black, now brown bracelets.
Trite answer, given many times over the years.
For bracelets purchased from the same supplier of the same wood "ebony" and "Blackwood", according to the availability. Depending on the party it can be pure black, black with white (almost white) streaks, temnokorichnevoj, temnokorichnevoj with small lighter streaks. Depends not only on the specific subtype
( https://ru.wikipedia.org/wiki/%D0%AD%D0 ... 0%B2%D0%BE )
but just from the party, introduced at the moment. As-or to affect this is not technically possible, but is in fact not necessary, it's all wood of the same type, dense, does not require coating, as socks with years preserve the color/look (well, except that is overwritten to a more polished look usually). That's exactly me now 7 bracelets of different "eras" of production, after the socks all look the same almost, although there are those that sickly black, there is brown.
Black wood is rare.
Also, as I have written many times, the links containing the wormhole, never to be rejected. Among the cabinetmakers, wood contains natural wormholes (look like pinned with a needle thin hole inside the link) is even more valuable as it provides different carved products for more flavor. Theoretically, they can be easily salivahana (masked) womadelaide thick polishes, but we don't use these in the manufacture of links. Rejection of the tree with wormholes would lead to polluting the treatment of rare wood species, and in addition there would be the question of how to estimate the cost of links, which in the most cheap BJ is considerable. All the links go into production. The presence of a wormhole on a particular BJ is not considered and will not be considered a marriage, I feel sorry for nature in the first place and it is not possible to say in a particular "stick" of a tree there will be 2% or 50% - it happens differently, and when you select a piece of wood is not visible, it comes in wax even color before cutting into separate boards not up to the end obvious, under the wax, it looks almost black.
At different points in time, we have also released bracelets and other options are valuable species, such as snake wood (snakewood), they way I liked in quality, unfortunately there is even harder than ebony, is usually a "log" contains a lot of wide cracks (characteristic of the breed) and marriage leave large pieces of wood in advance it is impossible to tell how many will turn out from a piece of wood bracelets or other items.
Manufacture of bracelets long been automated, standardized, and reduced to some internal quality parameters. The only criterion of rejection - visible cracks after production (or chipped parts.
Please note that we do not use any coatings (mastics/impregnation), as the years have shown that without them and the tree serves perfectly for years and no reactions to it from people. The Chinese manufacturers have ready-made bracelets made of black wood on sale on aliexpress/the eBay, but to identify where there are fake and where the real tree is extremely difficult. Wood can be impregnated paint. Too smooth perfect color in the photo at the extremely low price suggests that the majority of suppliers is so, for below-market global cost of a tree it can't be :) (it should be understood that when the manufacturing process goes into a lot of sawdust/crop, even with perfect cutting of wood).
I also want to see that ebony is not completely "nepomucenum" and long exposure to water will give a dark tree SAP (which provide color) in the water a little bit. I remembered that someone soaked the bracelets in a glass of water, asked what kind of water color - we used wood suppliers are absolutely sure, they "painted" don't sell, and it would not have looked like this. About something like that.
Overall, although the actual BJ from ebony, with all the range of products, we have a small piece of products and their production is carefully controlled and standardized process in which quality is paramount.
The type of wood in this process remains the same, because the number of valuable varieties has its own positive influence and energy of such wood feels just if not "charged" a stick of wood to sawing on the links to hold in the hand.
So it turns out that in fact the charging systems are combined BJ natural properties of wood.
It was the analysis and study of these combinations led to the production of a limited batch of bracelets from snakewood for example.<
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Wed Dec 20, 2017 0:53
By the way, the strongest and most powerful bracelets that I bought was light wood ( the name of the wood unfortunately do not know :? ). There were 4 pieces It was BJ 2.1 six months later, I got the socks began to ispolnyatsya small desires. But then broke the elastic. Replaced it with thread, but it is impossible to wear. I understand bright wood works more effective than any Abenov.
Post by Михаил_ » Wed Dec 20, 2017 4:06
this is a 2.4 probably and I think wood here not and :) just every bracelet has its own specifics, especially with regard to a particular operator and its capabilities, probably You 2.4 somehow better (especially in this quantity).
Replace the thread on a normal do not see any problems, there is even a whole topic about it, or take 1mm elastic thread ( in Russia for example is sold in a network "the Needle" as far as I remember, well, or anywhere where there are products, "Gamma"), or spandex, just to pass more difficult, you have several threads together to fold, but is much longer. Most of my bracelets changed your thread 2-3 times, it is from a couple of years or more, and sometimes likes to break, just in time for the performance of the maximum (as You write - fulfilled desires ). You may want to try 2.4 in broadcasts, for example in stereo, if that's the case.
Астероид
Has thanked: 22 times
Post by Астероид » Wed Dec 20, 2017 8:48
MMI bought thread "Gamma", but now bought https://ru.aliexpress.com/item/45-100M- ... 0.0.rxr2A5
more than double the length of and delivery to mail.
same - termopoliuretan
A Needle or Gamma is not everywhere.
Мартин
Been thanked: 58 times
Post by Мартин » Wed Dec 20, 2017 20:32
I have the same rubber as on the original bracelets, but also to link them I can not, under any circumstances. Would be to find a specialist.
Астероид
Post by Астероид » Wed Dec 20, 2017 21:36
Martinto turn )( X - need to fix for example the bottom part of the thread - so they do not unravel and tighten harder. Even an ordinary node. The main thing is pulled so that the string was lengthened in certain more stressed areas.
Мартин
Post by Мартин » Thu Dec 21, 2017 20:58
Астероид wrote:Martinto turn )( X - need to fix for example the bottom part of the thread - so they do not unravel and tighten harder. Even an ordinary node. The main thing is pulled so that the string was lengthened in certain more stressed areas.
That is, if start is pulled, the thread is stretched and it is a mess.
Астероид
Post by Астероид » Thu Dec 21, 2017 21:29
try to not pull so much and only a small portion of the skin. First, begin to stretch out tense spots and then with further increasing of the time of stretching, it stretches all. Well, again, it partly comes back. If not - then or thread thinner or wrong at all.
ММ
Post by ММ » Fri Dec 22, 2017 1:23
Михаил_ wrote:this is a 2.4 probably and I think wood here not and :) just every bracelet has its own specifics, especially with regard to a particular operator and its capabilities, probably You 2.4 somehow better (especially in this quantity).
I mean BJ 2.1 have become known as the 2.4? Not to mix.
Бисо
Post by Бисо » Sat Dec 23, 2017 0:52
ММ wrote:IN the sense of BJ 2.1 have become known as the 2.4? Not to mix.
Yes. I can't remember whether bracelets 2.2 or not (now there are only 2.2 OS+ (altenately+stoppage)). The latest version is 2.4.
Post by Михаил_ » Sat Dec 23, 2017 1:04
Yes, it is, is long gone, not only 2.1, but in 2.2, replaced by newer and more powerful version of the 2.4, and there is (from what it was 2.2) version with reinforced security properties 2.2 OS+, which, in some aspects stronger, but more expensive. It uses the basis of 2.2 and additions.
2.2 is still available as a card transfer that gives the flexibility to choose the subject-the carrier of the signal 2.2, and ready to end the bracelet - only 2.4.
Also 2.2, and 2.4 are available in the BROADCASTS, that gives you even greater flexibility and efficiency of use (although of course at the time, in contrast to physical products).
Владмосква
Been thanked: 7 times
Post by Владмосква » Sat Dec 23, 2017 12:11
Version "2.4 OS+" is in the plans?
Post by Михаил_ » Sun Dec 24, 2017 23:26
For OS 2.2+ 2.2 for optimum use, do not have these versions, the combination is optimal now.
Z.Blishar
Post by Z.Blishar » Tue Feb 27, 2018 16:31
Michael,
I would like to clarify about the BZ 2.9, Mousavi forum is nowhere to be found "TTH", only the commercial version 2.91 and all...
Post by Михаил_ » Tue Mar 13, 2018 6:16
Answered in the next branch for the first time 2.9 remember as a modifier of a cure in the not-pakazany mode (now the panacea many people seem to have a soft safe toy, and when just appeared, many people have asked how to make it factor softer and closer to the regular BJ). A wonderful mix of the base 2.x - a useful thing.
Артемка
Has thanked: 61 times
Post by Артемка » Thu May 03, 2018 2:45
Hello.
I feel that its time for me to speak about use of the BZ 2.2 OS+
The experience of wearing three weeks. When I brought it to the courier and I began to unpack, then straight his hands were shaking, maybe because she was afraid of him, didn't know what to expect. Wearing on his left hand (on the right as it is less comfortable to wear), nothing much felt. In the early days, began to change the mode of the day, began to sleep in the sun and less hours, although this is possible also thanks to the free broadcasts. Now the truth is the rhythm of the sleep lost, all the same, but sleeping significantly less, even in a few hours.. Soon to try the modules of climate control and search for that 100% I have earned. When looking for the right thing, then when you activate 'search' immediately had an idea where it is and lo and behold, the thing has been found. Climate control helped to cool the tired parts of the body, which was hot, immediately felt as heat soluble.
Increased energy a bit, in the early days even much, but then apparently used to. By the way vampirism from other people was less to be felt (I'm more frequently a donor than a vampire:). Early communication with some people was squandered to the specific discomfort to put it mildly, and BJ communicate easily, however after say goodbye to the person, you feel a surge of energy. I understand my alternator has become more powerful, and calmly pulls the load, and after shutdown a power surge occurs in the body in the upward direction (just like in all email.network))) and then the energy is aligned. In principle, you know that vampirism is only possible with the consent of the donor, so there's even stop magic will not help because all that happens voluntarily. But do not have a mental switch in this area and the modules 'spacesuit' and 'tube' in this situation does not help. Believe that technology quantummagic will help me learn how to fully control his energy.
The matrix of panacea by the way gives more energy, but this energy does not heal, but at the same time with the rise of tone, strengthen and nerve terminals and hyperactivity that I have. Probably because it is homemade, well, the operator is still not at that level. :)
Do not get tired to thank the Creator of Michael in this BZ (OS 2.2+) and for all other technologies!
I like that until even very worried about his BJ)), once again don't want to remove, so as not to stretch, although when I go to shower, then take off, not to wet. How to remove, feel weak, and after the return of BJ at hand, the weakness goes away, but not as quickly as it comes.
I hope my review will be useful, especially for beginners. Good luck to everyone and kudos to overpower a lot of letters. :)<
