Advice from Andrei Patrushev
zdrasvuyte.
for your disks need large headphones that cover the ear? with a conventional disk drive on a laptop can play the discs?
headphones which diaphon frequencies have to lose? I mean what you write, for example 20Hz or above-the box with headphones
Not necessarilyбурислава wrote:for your drives need large headphones that cover the ear?
20Hz - 20kHzбурислава wrote:headphones which diaphon frequencies have to lose?
If the output signal corresponds to 20Hz - 20kHz or greater range.бурислава wrote:with a conventional disk drive on a laptop can play the discs?
MM
There were several comments from adults with cerebral palsy. When doing a guide and a Healing 1 spasticity decreased, but through a very painful period with increased...
- Алексей Чипак
Hi Andrew.
I can't go into a trance. Myself I am anxious, can't relax the head.What can you advise may exercise any ?
Alex Chipak
TRANS thin "thing"... When You are riding the bus, in the Elevator, dream is all kinds of trance. The TRANS can be forced to happen, he just need to allow...
Simple exercises - progressive relaxation, for example.
Andrei Patrushev Good afternoon. Tell me pregnant women can your CDs to listen to?
The preamble is this: the girl starts to leave the bones of the pelvis, and it hurts, and pain interfere with sleep. Only a couple of months not sleeping. Massage of the pelvis can not be done.
I thought, maybe distract her from the pain of rhythms, such as a Conductor in the same, or Endorphins.
But not provoke anything?
Hello.Странникс wrote:But not provoke anything?
Not be. It is better to do with Healing. In addition to pain relief, this program contributes to the normal sleep.
Good day!
using the Navigator for about three weeks at night listening to the healing, in the morning conductor. Last week I noticed that the shoulders are constantly aching in the area of the top of the blades, or rather, not sick but as if there is a constant, unpleasant, slightly painful tension, at first paid vnmanie, I thought maybe with the weather something's wrong... but a week passed, nothing has changed, began to think what this might be, for Navigator thought at the last turn, but more to sin than that. The last couple of days, during the sessions, stopped using points - only headphones, but painful tension of the back does not pass, I went for a massage, massage therapists say that there are no spasms, no.
I wanted to ask, given the vast database of experimental
how much is it normally, this is related and whether this is something to do. Thanks for the answer!
alecks
You see, when You dive into the alpha state, your relationship with your body recovers and starts to hurt what hurts.
Many people find themselves in constant stress block the signals of the body that eventually results in various diseases. Problems in the cervical-shoulder girdle, usually associated with the computer, rather, with the fact that You spend too much time with him.
If You do not reduce the load, or develop a special set of exercises for yourself, then with high probability it can lead You to hypertension...
Good day, Andrew.
Have a question - how better to listen to CDs for best effect. It is desirable to lie down, close your eyes and relax or you can do some things that do not require intellectual work, a walk in nature, etc. Or with different disks different?
Thanks for the reply.
El
In most cases it is best to listen to lying down and try to relax your body.
There was one question - I have the system hasaya Aliyev "Key", does it make sense to listen to CDs in the ideomotor condition of the TRANS? Or better on the classics - lie back and relax?
El
It's a little different condition, so it is better lying down.
Hi Andrew!!! Please tell me you can drive lucid dreaming't listen to 45 minutes and 15-20 minutes ? Not it will affect the quality of the lessons? Thanks in advance for the answer.
Rudik
Can.
Can.
Expert
Night is for sleep.
Night is for sleep.
Expert
It is possible and so.
Andrewplease , could You advise how the author of so many techniques and also, as I recently found out a former smoker.
I have chronic problem - I can not fully stop Smoking! This is really bothering me to live, to be honest, on the long "horizon".
The background briefly is that I smoke somewhere between 22 years, a little less than 10 years already. Never before have not tried tobacco, began to smoke, as probably all of this stupidity, in connection with social
social circle in which were many smokers.
By and large throwing I consciously and "thoroughly" somewhere 4 times. Every time I read this A. Carr, "Easy way to quit Smoking".
Also tried pharmacy pill "Tabacs", but then I didn't like the desire to smoke is almost not decreased, and the effects were.
Nicotine patch not yuzal because few of my friends could use them to throw and besides, physical cravings and so I'm able to overcome when I feel like it.
Carr's book good help to calm nerves and give confidence to the stage of physical discomfort, sometimes referred to as nicotine "breaking". Without it, of course, had more to suffer.
The results in the end - managed to quit for a period of 2 to a maximum of 6 months (just this last attempt lasted from the summer of last year to January this year somewhere).
And in General, after 2-3 weeks of mild withdrawal symptoms, I feel fine, Oh cigarettes, thought not often, and the smaller, the more time passed.
Alas, the end of me or the book or something else we haven't yet - every time I relapsed again after 2 - 6 months.
And throw a really want, the more that interfere with the active sport I love!
The reason for the disruption, how I can diagnose, more psychological. This recurring sense of boredom, monotony, tedium of life, no expectations of any significant joys or pleasures that await in the reward for work, etc.
From home to work, in traffic jams, when many hours of standing, sedentary work often until late in the evening, and then the traffic back home (in traffic especially because of boredom and is not possible in any way to stretch your body want to smoke).
As if there's no outlet, which would be "switched". So when that's enough for a long time I never smoke, I ask myself, "is that if you remove the obvious health and aesthetic considerations, why did you actually not smoke?".
Even when everything and at work and around the house did you want what is feeling of celebration and float why is that a fucking cigarette, though, pepper is clear
like smoke, you feel even worse!
Of course, again, when already a physical "craving" has passed such moments are increasingly rare, but they are still not completely disappear.
Tried Shumovsky CD "No Smoke" preinstalled in the "Navigator". Listened to somewhere in time 10 regularly, the special effects are not noticed.
A. Carr 5-6 times already to read not
In the end, right now, a week or two I smoke, then a week somewhere or five days and then not smoke again for a new one. Some sort of bad infinity!
Can you advise anything to help from their experience or with MM or discs of some sort?!
Of course, I understand that to remotely to treat nicotine addiction - it is a thankless task, but still.
Sorry that someone else's theme interfering, but I note that Carr says is correct about the monster in the stomach. You need to work only with it, at least stimulus, at least psychologically. This dinosaur is just not going anywhere (the same problem)
