Ring. Flame
My personal feeling is... the intake of energy without the ability to compensate for something.It's not stab attempt to understand.Something technical education a plus practice/practice that a Deposit
truth.Whoever invented it clearly didn't want to listen to the opinions of others
IMHO
- Шалтай Балтай
Re: The Ring. Flame
It is, as I understand, Your answer for "opentoken Harpa Ukraine"?
PS
If it is possible without familiarity, I would appreciate it
ZZY
rights flame
PS
ZZY
rights flame
Re: The Ring. Flame
Vyacheslav
Look further,needles are made for acupuncture,very similar to kuwaki, with the tip of the needle in the outside.Coincidence?I think not,there are left-handed needle and pravonarushenii needle.Acupuncture has healed millions of people.If there was a fence,we knew it would.is the intake of energy without the ability to compensate for
Re: The Ring. Flame
From Humpty:
Removed because:
good luck
Removed because:
- Lie
- tallerova
- Poking
- Rudeness
Re: The Ring. Flame
Information on Kovalam have?searched did not find,I would be very grateful if you share), purpose,interest 4 four coiled.Please give information,you can PM or here.
- Шалтай Балтай
Re: The Ring. Flame
If it's me - IMHO, acupuncture - offs. If you are looking for a General that we must not look at the twist and length. I have little faith that the needles are made by the sacred standards.Гуфест wrote:Look on,needles are made for acupuncture,very similar to kuwaki, with the tip of the needle in the outside.Coincidence?I think not,there are left-handed needle and pravonarushenii needle.Acupuncture has healed millions of people.If there was a fence,we knew it would.
- Шалтай Балтай
Re: The Ring. Flame
If it's me then:Гуфест wrote:Information on Kovalam have?searched did not find,I would be very grateful if you share), purpose,interest 4 four coiled.Please give information,you can PM or here.
Bring sorry - did not understand.
Re: The Ring. Flame
I agree.If he had kept sacred measurements,it would have changed treatment ,only for the better.I hardly believe that the needles are made by the sacred standards
About four turn of kuvak any section and size, are interested in the sacred or magical purpose ,what is this kuvak exerts its action?how does it affect a person?
Please take a look at the fractals lab ,there is also a question))
- Шалтай Балтай
Re: The Ring. Flame
First, let's define the terminology.Гуфест wrote:About four turn of kuvak any section and size
If I understand correctly, the "four turn" means 4-wire. Or something else?
apologies - no dataГуфест wrote:About four turn of kuvak any section and size, are interested in the sacred or magical purpose ,what is this kuvak exerts its action?how does it affect a person?
- Шалтай Балтай
Re: The Ring. Flame
By the way, very interesting idea!Гуфест wrote:If kept sacred measurements,it would have changed treatment ,only for the better.
Even VERY and VERY interesting! Pinned separately!
respect!
Re: The Ring. Flame
Round - way will be around the ring around the cylinder when there is a winding spiral spiral just four turnover has an interest. The number of ribs is a separate issue.I would send a photo of your manufacturing kuweka spiral in four turns,but on those reasons while you can't,maybe later."turn four" means 4-wire
- Шалтай Балтай
Re: The Ring. Flame
Uh.... If I guess correctly, then You have a spiral Kovaka has 4 turns. Or in Your terms - four spirals. So?Гуфест wrote:Revolution - the path will be around the ring around the cylinder when there is a winding spiral spiral just four turnover interest
- Шалтай Балтай
Re: The Ring. Flame
Oh yeah. and still some.Гуфест wrote:the Number of ribs is a separate issue
- Шалтай Балтай
Re: The Ring. Flame
OK, wait.Гуфест wrote:I would send a photo of your manufacturing kuweka spiral in four turns,but on those reasons while you can't,maybe later.
Re: The Ring. Flame
Acupuncture and used metal games with silver can serve as a conductor through the wire such as to connect auxiliary product that has been damaged from an injection of microtini and blood of the human body,will be charged defined by the parameters carried in human blood,to bring healing.The treatment process can go faster.interesting idea!
Re: The Ring. Flame
All right.) Kuvak with a spiral in four turns,which has a sacred purpose,how it affects a person?I'm talking about your product.If I guess correctly, then You have a spiral Kovaka has 4 turns. Or in Your terms - four spirals. So?
- Шалтай Балтай
Re: The Ring. Flame
Dear GuestГуфест wrote:Kuvak with a spiral in four turns,which has a sacred purpose,how it affects a person?I'm talking about your product.
in order:
- I don't do Kuwaki in 4 turns/coil, IMHO, is not enough. I would recommend 10-12 turns per knot, photos of the products you can see here: viewtopic.php?t=6181
- I have no evidence to believe that Kuvak in 4 turns has a sacred value and has some special influence on human beings.
- The same can be said about any other number of turns, whether it's 5, 6, 7, 8, 9, etc.
- The choice of coils of the product of Kuvak in my understanding is a more practical choice, ergonomics, rigidity, and ease of use and transportation, and has no rigid standards, in contrast to the Measurements of the product.
- I also have no data on that slim used a certain number of turns for the product of Aku-VAK, in his articles you can see for example here: http://www.slimspurling.com/light-life-technologyThe same can be said about other manufacturers.
- If You have any data for the selection of the number of turns for the product Kuvak and the desire to share them - you are welcome.
- Notice that along with Kuvak is the product Loop, there turns two times, two and a half more. Very effective product - would recommend.
- Шалтай Балтай
Re: The Ring. Flame
I repeat: Yes, it's a very interesting idea, the use of sacred standards for acupuncture.Гуфест wrote:Acupuncture and used metal games with silver can serve as a conductor through the wire such as to connect auxiliary product that has been damaged from an injection of microtini and blood of the human body,will be charged defined by the parameters carried in human blood,to bring healing.The treatment process can go faster.
Let me give a recommendation: if you are going to experiment, the Measurements need to take linear. I understand, Yes? Is NOT circular.
PS
blank verse
Code: Select all
Only
cost
squeal
Troll
at
the head
as
immediately
bonus
from
heavenly
the office
came
works
office
all
at
Chesnakov
!THANK you!
Re: The Ring. Flame
Thank you for the answers,I began to read a book ring of Sliema.
Re: The Ring. Flame
On the basis of allegations from the book that rings for everyone.The question arises,measures, Sacred,Forgotten,New, remain unchanged,and twist can be of any proportions and sections.And will it work here the principle of multiplicity like 1+1=2изделия will increase the potential.Sacred 523мм measure if this measure is multiplied by 2,3...and so on,is there any sacredness or 523х2=1046 whether it's the number of workers and is still sacred.Sacred: 523мм; 20.63 inch; 144Мгц │ Forgotten: 596мм; 23.49 inch; 177mm │ New: 733мм; 28.86 inch; 188Мгц
The answers have been found.
Re: The Ring. Flame
Canadian scientists have learned or have found the frequency for the growth of the new tooth frequency universal can regenerate a damaged tooth,ultrasound to approximately 20 kHz,a little less or more frequency approximation.All waiting for the release of ultrasonic devices on the market.You wish to experiment with aquacom at a specified frequency to grow teeth.
Re: TECHNOLOGY SLIM SPARLING
Who else will do it?A very good intention.Slim will be happy.I have the intention to finish the translation
This is very interesting,can share?I finished translation of the Book by cal Harrison
Please tell me how much inches of wire on the ring of Freedom and what kind of ring will suit for the driver of the car ,not to be tired and not get tired.
- Шалтай Балтай
Re: The Ring. Flame
viewtopic.php?f=60&t=6147Гуфест wrote:This is very interesting,can share?
