Test products technology SEM.
Re: testing the products of technology SEM.
Hello, I wear a pendant of the month, the metal part keeps going dark, almost black, maybe it's a property of the metal and whether this be so? Additionally, I wear a silver chain with a cross so vnutrennyaya side of the cross is also starting to get dark!!!!
Yes, it's a property of the metal , the oxidation from the interaction with the body and other metals, conventional chemistry. Also depends on the condition of the body, from whom these processes are less visible, nothing supernatural ,but everything supernatural eventually as naturally it all depends on our knowledge.ВладимирР wrote:Hello, I wear a pendant of the month, the metal part keeps going dark, almost black, maybe it's a property of the metal and whether this be so? Additionally, I wear a silver chain with a cross so vnutrennyaya side of the cross is also starting to get dark!!!!
Whether it is impossible in advance the description and one pair of triples most favorable combinations of pendants for simultaneous operation, according to the developers, part written but I would like "the whole list".Аура wrote:Julianit will be a package spec. programs Mental. Software everything is ready, the production processes need a week.
Баришпольц
The Corsair, a microcosm of intuition as an option...
So much for the combination...
Yes, there it is possible to experiment themselves, and their vision is, from the developers as simply as guidelines and for comparison, and then under itself to make
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Yes, the description will appear soon, first will be given introductory information in the subject the basics of energy-magic for understanding the operation of some special. packages Mental.Корвин wrote:can we advance description
Aura
All very individually. Recruitment neocolony should proceed from the current state of the integral field. Can result in some combination, but you have to understand that this is not some permanent the most successful combinations, and the practical result, which is obtained based on the similarity of the conditions of the operators living in Metropolitan areas and with similar current status of the integral field and not because of the compatibility of different specials. packages. All spec. packages as such, by themselves, are combined equally with each other, but as this scheme rests on concrete integral box, is another question.Корвин wrote:one of a pair of triples most favorable combinations of pendants for simultaneous operation, according to the developers, part written but I would like to "entire list"
Master+Microcosm
Corsair+Body
Mental+Clouds
Corsair+Mental
Armor+Microcosm
Armor+Intuition
Intuition+Microcosm
Microcosm+Body
Corsair+Armor
Master+Microcosm+Mental
Master+Microcosm+Intuition
Master+Microcosm+Clouds
Corsair+Body+Armor
Corsair+Body+Intuition
Corsair+Body+Mental
Corsair+Mental+Armor
Corsair+Mental+Microcosm
Mental+Clouds+Microcosm
Mental+Clouds+Intuition
Mental+Clouds+Master
Master+Microcosm+Mental+Intuition
Corsair+Body+Armor+Intuition
Corsair+Mental+Microcosm+Intuition
Mental+Clouds+Intuition+Body
A Microcosm Of The+Clouds+Body+Armor
Body+Clouds+Master+Intuition
Молодой но Седой
Aura.
4 wear the pendant at the same time for 3 weeks, last added Microcosms.
Master, Corsair, Armor, a microcosm of the regime in power.( switched a week ago. )
Weekend left to nature and just forgot to put them on. Three days without pendants.
I did not understand what was happening to me, but when I put them on Monday morning, as it began to move around faster. had a lot to do.
Question: This combination is not contradictory?
Thinking of adding Intuition.
When you see the Mental and its details?
There is no contradiction all pendants are combined with each other, the main thing that You have not had overload from the simultaneous use of a large number but it individually
Молодой но Седой
How overweight feel?
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
Perhaps this is when a lot of things all at once..)Молодой но Седой wrote: How overweight feel?
СтаниФилмТВ
Now Yes, many notice the acceleration of rhythms in society, someone believes that this is the result of an increase in amplitude at higher frequencies the Schumann, someone thinks that the information flow has accelerated, in any case not correspond to the accelerating rhythms, then you can gradually fall out of society. Neocolony apparently, it is quite modern technology that allows you to function more adequately in high rhythms of society.Молодой но Седой wrote:I did Not understand what was happening to me, but when I put them on Monday morning, as it began to move around faster. had a lot to do.
Aura
Contrary to the combinations no all individually.Молодой но Седой wrote:Question: is This not contradictory?
The speed change may be a manifestation of many factors, from the increase in the saturation reaction before smoothing natural system changes in GAAP. What he wrote Sterifilt takes place, but is a global trend, and various rhythmic movements in GAAP lead to the emergence of many such micro-processes, usually these rhythms have a duration from several days to several weeks. All neocolony consider these processes too. Our entire universe, as well as its information component is in constant movement and state of development (change), so the work of neocolonial is not stable according to the results, all results should be considered in the dynamics, understanding that can take place as a resonance with some waves and smoothing others.Молодой но Седой wrote:how it all began to move around faster. had a lot to do.
Aura
Main programmay of neocolony Mental:Молодой но Седой wrote:When you see the Mental and its details?
1. The filters of perception
2. Patterns of thinking
3. Attention
4. Concentration
5. Associative thinking
6. Cross-layer interaction
7. The palaces of memory
8. Sherlock
9. Analysis
10. SVS (Internal Synthesis)
A detailed description of each program will appear in the near future. Nookular Mental will appear in the office within 1-2 days.
аВАЛОН
can't panati , explain why Your team went to the violation of the known laws of the cosmos and the universe and You decided zarabatyvaet on etc. money if You are handed a free ie a gift, for a gift ?Аура wrote: Because of this, the detection of positive effects of any technology leads to its improvement, and isolation and technology SEMM, and kindly donated for use in our laboratoryis the integral. I must say that the car was given on certain conditions, and can be claimed by the owner and Creator of back at any time. That is, the production of pendants may be interrupted suddenly, but most likely this will not happen. The second condition, Shine only within certain limits.
Again, You have a significant overlap, this time the Mental and Master. But judging by the written, Master, after all will be better. Why? Maybe worth to add a couple of programs to Master and put it on a higher price instead of having to make another necklace? Or as required by marketing?Аура wrote:Main programmay of neocolony Mental:Молодой но Седой wrote:When you see the Mental and its details?
See what is the overlap? the base is all one , and the rest if you try one thing for another always to give you can t e for yourself to see that is to say the watermelon is a large gooseberry. In my opinion all pendants are gradually emerging -flowing into each other and properties and tactical objectives of their vzaimoperesekajushchiesja, so rude Korsar in some cases, or slightly worse armor (best defense is a good offense), but the means to achieve them are different, the strategic task of all pendants is one and as stated can be achieved through any pendant or without pendant at all .
Aura
You just have no understanding of the nature of money. Laws would be violated when people received these opportunities for free. Gratuity is customary cheese in a mousetrap virtual programs. Moreover, it is considered necessary the presence of a "price of the censor", in the case when a great opportunity=great responsibility for their use.аВАЛОН wrote:why Your team went to the violation of the known laws of the cosmos and the universe
If something where-that is distributed free of charge, "on trial," etc., it is necessary to understand that instead of necessarily something demands not money, but something equivalent...(for example, free Indians blankets handed out, who is familiar with the story), but this is a conversation about the nature of money.
I agree with Kevinom.
I would only add that everyone needs the pendants that he is interested to learn. I now Master quite interesting, because I am so in your case the Master
and here the Mental is likely to take.
And went to the forum because I noticed since yesterday, strong changes, namely the "Flow" of the Cloud again covers as the first time. Not with what it can not, just as with the acceleration of information flows.
Aura
If you have more than 3 pendants install their interface, and the effect of overload will not. Then the group can be consistently split.Корвин wrote:there is no Contradiction all pendants are combined with each other, the main thing that You have not had overload from the simultaneous use of a large number but it individually
what is it like? what to do?Аура wrote:If you have more than 3 pendants install their interface, and the effect of overload will not. Then the group can be consistently split.Корвин wrote:there is no Contradiction all pendants are combined with each other, the main thing that You have not had overload from the simultaneous use of a large number but it individually
You need to register in the automatic switching mode ноокулоновhttp://www.mindmachine.ru/forum/viewtopic.php?f=35&t=5836 and it's all done. The bounce in General can be from one pendant particularly in the mode of power. Someone can bounce and from ten to ignore if it and without the pendants in this state always lived (it I not about You)
AuraKorvin I did all that, I have a Corsair + Intuition in the mode of power, wear for 2 weeks. And we wait, listen - well, nothing yet, not bounce, not Overdrive. I'm not sensitive? or not all right?
