Small offtopic.
Re: Small off-topic.
Post by Михаил_ » Wed Sep 05, 2012 11:14
1. the ceiling and floor of a modern home well thecranium this thing to leak just a residual phenomenon, but very poorly.
2. the effect of (mutual) in the radio frequency range is much stronger, full of radiating appliances, not very well affect neighbors.
3. here the water in the basement (main pipe) due to low-speed but large mass, their influence is seeping through the house, complementing the pattern of geomagnetic networks and creating the anomalous zone. At the time, spent very carefully removing the figure of nets in the living room during repairs to the floor drew all the lines with a marker for whiteboard erasable. It so happened that the only suitable sleeping place in the room - somewhere in the middle of the window, i.e. anywhere actually(the picture was shot with a special device, therefore, of objectivity - I am sure). By the way the constant presence over the nodes of nets can develop cancer or a propensity for stroke, myocardial infarction. So to say - a classic.
Well I was filling shungite solved the problem. Under the sofa in the large bag laid flat. And now the panacea act. By the way the same way, you can isolate the tail from the turntable, placing, in its stationary position, above and under the matrix, not on the turntable, but on the floor-the ceiling.
However, the "wheels" are actually all eaten with the use of the system (if desired, the second printout to place on top).
maverik
Post by maverik » Tue Sep 11, 2012 15:59
If I can handle the Wheel with radiation, if the gravel in the concrete ground, in tens times exceeding the MPC (is just).
Thank you.
Post by Михаил_ » Tue Sep 11, 2012 19:30
the wheel is not a means of decontamination, and disposal method. So it eats out, and how much - depends on heaps of factors. I do not think it will greatly change the readings, although experimentally I have seen that, but in other cases.
maverik
Post by maverik » Tue Sep 11, 2012 20:36
And Boh with them .. with the devices.
People it will be easier? they live there.. and I wish not to die...
Rubble from Uralzoloto brand.. cheap and cheerful..
In the Urals with the atom at all.. nowhere to hide... Around Ekaterinburg, the in the about 20 existing, and dying reactors, and Beloyarka, and Novouralsk, and in the direction of Chelyaba at all.. time bomb...
To even think that you can protect yourself .. already the case.
Post by Михаил_ » Wed Sep 12, 2012 0:14
there are similar technologies but simple main such technology - the man himself.
Therefore, more efficient time to spend on the home.
wheel - try, nobody loses, no negative options are not seen as possible.
maverik
Post by maverik » Wed Sep 12, 2012 3:13
Will try.
Thank you.
Post by bofara » Mon Sep 24, 2012 16:31
Михаил_ wrote:gift 2 will be a bit later.
Please excuse the audacity :o if you can ask about the case of gift number 2 - the event has already taken place for example can be considered as a gift 2 the information in Ω about the one-time entrance to the CHI/ or transmitter of here or something completely different, interesting and useful? Thank you.
Post by Михаил_ » Mon Sep 24, 2012 19:00
no, I don't have time.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Sun Sep 30, 2012 5:07
Transferred to the topic :)
Michael_ wrote(a):
Good day, Michael. Parents just live on the first floor above the boiler, water pipes and all that. Maybe so father, when living in the city (summer cottage), periodically sick, were and strokes. Well, in General, everyone who lives in this apartment health can not boast, and their 4 guests. What can I do at a distance? I have IC, is the stabilizer, the energy channels u-2,u-3 use to strengthen the work of SK and stabilizer.
Michael_ wrote(a):
Yes, for example you can operateit space (matrix a panacea for example, if not physically, then mentally), and SC and the stabilizer to formulate the tasks to harmonize the space and energy in it and braking (stabilizer) harmful factors.
With SK you can clean the room (track cleaning) remotely.<
Владмосква
Been thanked: 7 times
Post by Владмосква » Mon Oct 01, 2012 17:12
Michael, for the Wheels if the following installation location:
1) Under the microwave;
2) Next to the WiFi router?
(1 and 2 basically the same because the frequency is about the same).
P. S. on another topic, Michael wrote that next to radioisotope fire detectors Wheel can NOT be placed.
Петрос
Post by Петрос » Mon Oct 01, 2012 17:24
Владмосква wrote: Posted: Mon Oct 01, 2012 3:12 pm
... 3) and the transformers?
Post by Михаил_ » Tue Oct 02, 2012 6:40
I wrote that specifically do not need. it is two big differences. in a place where it is already naturally there please.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Thu Oct 25, 2012 12:13
Question. Sacramenot and suspendet discs in the turntable Rinat strongly influences efficiency?
Question 2. How much increases the effect of sharpening disks?
Post by Михаил_ » Thu Oct 25, 2012 13:10
1. well, somehow... I think not very but a little (suspendet still forms a link with salepalm small)
2. much, Stoke forms.
Post by Воффка » Sat Oct 27, 2012 13:06
Michael_
Got it, thanks!
The grinding angle effect?
Another question. You said that a person is able to perceive the leash a small portion of the flow from the fan, if I give the command "wheel" to take 1% of the flow from the fan and to feed me, will it be less effective than if I tell you to give 50% or 100% flow for washing me? Or here the state of health of the body depends?
Post by Михаил_ » Sat Oct 27, 2012 13:53
1. Hugo sharpening - like flying saucers with the images :)
2. give the command to power optimally, what kind of mathematical abstraction with interest.
3. the condition of the body is affected and changed in real time in both directions. For example eat something not and have less to take.
Post by Воффка » Sun Oct 28, 2012 13:12
Michael_
Thank you very much for the answers! :o
Post by Воффка » Sun Oct 28, 2012 18:09
Michael_
Another question. How long hold the "charge" music vegetable matter such as dry grass, berries, seeds of plants? Let's say after 12 hours of hanging around helicopter, roughly by how much muski clears?
2. How long musky water?
3. When processing асд2 better handle the bottle with ASD or water will be diluted?
4. Does strengthen musci from the turntable properties of water and increases T1 water T1 properties music?
Post by Михаил_ » Sun Oct 28, 2012 19:04
no, that's not right
in fact, no such music is the code name of a dynamic process and not breathe on a special dust.
In short, none of these questions can't be answer and they do not make sense :) Depends on the whole. From a place of time the operator and other factors.
Probably correct to say how long will the local anomaly and whether it will be tied to the place or objects to which subjects better and dolgosrochnye.
But again, depends on the place, time, operator.
Rinat about muski will be considered a joke :) well, just so it was convenient to describe a narrow theory.
In General, we're not talking so much about particles as it is about consciousness (in some way). So You invited a "tour" to myself how long she will have to stay off You 5 minutes and maybe 1000 years? depends highly on You. Can generally will remain forever.
In General, this is a question for the operator. Ie in a normal world living and actively socialsense just these "m-particle" always in good number because they are part of the process of creation.
Well, something like that.
Perhaps the rest themselves.
Алекс С
Has thanked: 2 times
Post by Алекс С » Sun Oct 28, 2012 22:45
Michael, please advise:
There was a desire to visit some trasformatori boxes of his native city, in order to position the wheel.
Inside is not allowed. (A let, then the wheel will be removed)
Question: what is the distance of the transformer operates the wheel? May not bother to put on the roof transformer room, or meter from the transformer plus concrete floor of the booth will block all?
Post by Михаил_ » Mon Oct 29, 2012 0:43
on the roof
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Tue Oct 30, 2012 1:33
Got a question on ASD :) Started today to drink. Took Armavir, Your drink, Michael, the recommendations, and I still love this thing :oops: Smell is not perceived as unpleasant - Yes, very specific, but in some ways even funny. And the question is this: I started drinking immediately with one cube, and after two of today's techniques (plan 3-4 hours a day), I want to increase the dose. Is it worth it, or better say, the first 5 days to drink in Cuba, 2 days in, and already there to increase?
upd. Add disease I have, unless you count poor vision, i.e. more development than cure.
Post by Михаил_ » Tue Oct 30, 2012 1:44
well, to get a negative reaction from ASD is very difficult, want to increase. Just be prepared for the fact that food and things can go unexpected sudden change of preference.
Пианистка
Has thanked: 10 times
Post by Пианистка » Tue Oct 30, 2012 11:17
Drink АСД2 about 10 days, began to eat more - I'm hungry all the time, especially drawn to chocolate cakes, ice creams, buns, gained weight... :roll:
Андрей С.
Post by Андрей С. » Tue Oct 30, 2012 13:45
Михаил_ wrote:well, to get a negative reaction from ASD is very difficult, want to increase. Just be prepared for the fact that food and things can go unexpected sudden change of preference.
Well, broken preferences to me a thing usual, thanks to Your products, especially 3.0. Thank you, I will gradually increase today 1.5 cube :)
Пианистка wrote:Drink АСД2 about 10 days, began to eat more - I'm hungry all the time, especially drawn to chocolate cakes, ice creams, buns, gained weight... :roll:
I can assume that the body needs to gain weight and\or need more energy to recover, but habit is perceived as a signal is something that is considered to be high-calorie food. By the way, I now have diversified their almost raw food diet quality (this is key) dairy products and something else on the little things, and have no regrets.
updated 13.12.2012
I consider it necessary to add to the post information :) In General, my "dilution dairy product" ended in less than a month, and I went back to raw. And I want to add that after three weeks of drinking milk (albeit very good!) began to feel much worse. So "no regrets" it was said clearly lightly. Of course, I have no regrets, experience is experience, but the raw food diet steers, and milk no :)
