Strange anomalies
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Re: Strange anomalies
Post by МерКаБа » Sun Jul 28, 2013 22:25
These things in the photo called orbani. The book is not bad, where people from several cameras filmed and got interesting results. If I am not mistaken the book is called the Project orbs.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Mon Jul 29, 2013 17:20
Good day!
In General, write in this topic, because for most people it is a complete anomaly.
A month ago the wife found a benign tumor, but with active processes.
Did an ultrasound, took a sample... scheduled surgery for the second half of August...
Measures:
АСД2 first 0.5 ml 1 now ml - 2 times a day - 5 days administration - 2 day break.
BJ 2.1 BH all the time with him.
Remotely map 2.1, one bracelet AMB and a bunch of stationary massive panaceas (digital + video Epoxy and PVA) + wide panacea BH... (he remotely had projected it all...)
+ gave the keychain stop magic (commercial) for keys.
Another at the end remote processing in the photo area...
(Yes, took my swinging Range(juniper) - but the return promised - silnova he is for her...)
Also had complaints of nightmares in my sleep...(not like I even asked to reduce little effect...)
Tonight half an hour ago - did an ultrasound - nothing found...
In these pictures the sample do not take... (just now I do not know where to take...)
Wife says as in a fairy tale! (the first time such occurs)
A huge thanks from our whole family - Michael_ ! :o
Кимили
Has thanked: 6 times
Post by Кимили » Mon Jul 29, 2013 17:56
Bravo, Andreyko! you're the Creator! The Creator Of Your Own World!
Faith, Action!
for Its Powerful Treaty!!
thank you for the feedback!
thank you Michael!
another Creator!!
Post by АндрейКо » Mon Jul 29, 2013 23:45
Кимили wrote:Bravo, andreyko! you're the Creator! The Creator Of Your Own World!
Don't want to disappoint - but to be honest the problem is solved very slowly and are in many ways in the deep .OPE...
I wanted to convey the fact that this is possible!
Кимили
Post by Кимили » Tue Jul 30, 2013 1:23
the emphasis is on "Decide"!
that, so to speak, "slowly"- particular:)
feel how much time must the Universe+ your consciousness to build a New Contract - so it goes to the "solution"...
the focus of its attention to Solve.
good luck and success!
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Wed Jul 31, 2013 16:12
АндрейКо wrote:and a bunch of stationary massive panaceas (digital + video Epoxy and PVA)
andreykocould You just comment on that. Do You feel this homemade product, what is its composition and weight and maybe a few words of specificity.
Post by Михаил_ » Wed Jul 31, 2013 16:19
and try handles poorly?
Post by АндрейКо » Wed Jul 31, 2013 17:41
Алекс С wrote:andreyko, could You just comment on that. Do You feel this homemade product, what is its composition and weight and maybe a few words of specificity.
The epoxy used 150 grams + leaves digital panacea size 3-5 font (prepared solution - filled - immediately! has one box with the prepared digital panacea in number (3-5 mm between them in the solution) all this is wrapped a sheet of panacea and 2 nights under the video panacea2.avi - I have about 20 minutes to warm up was...
PVA for much longer...(4 items) weight 150g +150g +100g +70 C - on each layer cut a rectangle from the digital panaceas - all is a wrap-around sheet with matrices panaceas and below the video... the layer will dry in 1-2 days!!!
While curing all subjects (with PVA and epoxy) were 50 sheets digital panaceas (each sheet of A4 font size 3 rows digital panacea - probably more than two hundred times repeated)
currently, PVA would take the cover plastic from CD boxes, prepared slightly smaller squares with printouts of the digital panacea.
A layer of PVA - box to put in PVA (wrap a sheet outside with a matrix of panacea) - the video freezing. (if you take the tall, narrow dishes - a lot of the time it will take)
PVA used concentrated! (five times more than in stationery glue for sale)
Feel of course.
the effect of PVA and different Epoxy - if the epoxy is touching hand warm in the hand... and comes with PVA wife felt the processes in the lower back.(a more distributed effect).
How to remotely projected - can't explain - just give the team...
(and of course people should be aware of and feedback to give)
Алекс С
Post by Алекс С » Thu Aug 01, 2013 12:51
Thank you so much for your detailed reply!
Try to do stationary a panacea...
It is good that You feel and share your expertise.
Michael calls for an independent search for the answers to the questions, but how is this possible if thick-skinned?
I printed 300 sheets of standard for 9 images on each, took a picture and posted on a forum, so no one felt... Thrown out time and money, fortunately a small.
Tell me, how do you make the gap between the printouts?
Post by Михаил_ » Thu Aug 01, 2013 13:01
Yes, no matter thick-skinned or not.
it is necessary not only to do, but still head to think.
300 sheets standard 1 sheet reference about the same thing (by the way, on the topic of creepy amount of panacea I am also not sure that their number multiplies as proportional to the number, I think probably more important than the layers of glue.
The standard aktiviziruyutsya on the man, he is not the source of something, he is the corrector of the cocoon specific.
What do You think was supposed to feel from your photos?that's right - nothing.
And to work it worked, perhaps better than 1 sheet still :)
Post by АндрейКо » Thu Aug 01, 2013 13:03
Алекс С wrote:can you make the gap between the printouts?
in the Epoxy on the eye first, the one flush, then the other. (ballpoint pen old Stoke )
for PVA - like layer of dry - box the following listing and the layer pour...
Post by АндрейКо » Thu Aug 01, 2013 13:14
Михаил_ wrote:by the way, on the topic of creepy amount of panacea I am also not sure that their number multiplies as proportional to the number
But if you print filled: one sheet of A4 digital panaceas 5 scriptom and another A4 sheet 3 font - which font 3 ( c plenty of panaceas) hand feels stronger (or also hallucinations of a personal nature? - will check blind...)
Post by Михаил_ » Thu Aug 01, 2013 13:30
no, not really glitches.... but just if we are talking about the mass of panaceas, and the mass of adhesive, the one panacea this adhesive structures and also the idea is about the same as mass.
Ie where it shouldn't be a difference between the conventionally, there 5 leaves and 50yu, if it cures in volume composition.
Мариомар
Post by Мариомар » Wed Aug 14, 2013 15:07
Don't know where to write, probably still here, maybe for someone is common, but new to me.
My wife and I wear the bracelets already more than two years. I - BJ 2.6, it is 2.1 and 3.0 N. Made friends and acquaintances about 10 bracelets 1.0.
And this is noticed: in the last six months is not impossible to plan anything except dinner. One has only to build some plans: from the simplest, like going for a walk in the Gorky Park in a couple of days, to complex, such as trips abroad, the future of relations with clients and partners, business plans, new projects, as it happens purse chatter, the events, everything is flipped upside the head, and the plans fall apart sometimes filled with the exact opposite(( Even the simplest desire for something specific, type of clothing or equipment gets turned into some kind of adventure, and the result is not what expected. Before such was not... on the Contrary, cost to plan, to want, as everything worked out in the shortest possible time, particularly if want the two of us))
What can be the reason? Still want to rely on some implementation of goals and plans, in addition to an evening dinner :)
Post by Михаил_ » Wed Aug 14, 2013 15:18
don't know, many friends are all very well realized with the only difference that not made plans for specific details and plans not planned the details. I.e. the trend (about - you need this or aspire to it, or even just "I'm a little interested in this) and very quickly realized.
In General it seems that having many (including your 2.6) You are trying to plan something very specifically, entering into a state of disharmony with the world. The world is very very much really changed. All implemented easier, he is more pliable. But it became much more of a bounce by itself (everywhere) and it is not conducive to the implementation of strict plans, but if you have to strain on the accuracy of the timing and plans - all on hurrah implemented without pant. Here are some thoughts.
I.e., without respect to BJ (note many friends who don't know about BJ, I'm not an advertising agent push their ideas - do not impose anything), many have long noted that the specifics of plan a long time became difficult, simpler detailed plans not keep. This is the state of the world is simple.
Галкина
Post by Галкина » Wed Aug 14, 2013 15:31
Михаил_ wrote: many have long noted that the specifics of plan a long time became difficult, simpler detailed plans not keep. This is the state of the world is simple.
it exactly. And I have recently without specifics, the end result comes out much better and more favorable than when I had planned with the details.
Post by Михаил_ » Wed Aug 14, 2013 15:34
Still faster and often generally thought forgot, was without any action. Sometimes then think why the heck was it thinking now what to do and already implemented (I'm again, not talking about myself, I realize that I'm a bad example, but about friends and again, not having a BJ, so to speak, for the purity of the narrative).
Мариомар
Post by Мариомар » Wed Aug 14, 2013 15:36
This trend has long tracked and already different trying to plan, and without any reference to the deadlines and events, simply by setting the intention. It still does not work. Now just live each day trying to create, and do not want this as they say "Keep calm" :) Thanks for the food for thought, I will try to transform their own plans in the direction of flexibility and compactness. If not difficult, help with the wording, taking into account the new world
Post by Михаил_ » Sat Aug 24, 2013 18:59
A good story is close to fun with the "magical paranoia", which at times visit all of us : ) (when the world is confused about simple causes and no simple). Often true sometimes Vice versa.... when simply trying to explain what it is not.
Now baked a cake. Got the base from the oven, put all that is necessary, put the cake back left. After 10 minutes, come, open the oven... Hang out. No cake. Home alone! Gently close the oven. Open again. No. Remember all the signs of schizophrenia that I have ever known. Then the machine comes in: "Yo-yo play and give back. Auntie is very important." Just in case, leaving from the kitchen, so as not to interfere with... Come back, open the oven - NO! Why then go to the mirror... Like external changes any. Gain - spirit of the times - in Google "from the oven is missing cake." Know what you're doing something wrong. He tweaked her hand - the reaction is. Said, "Light! You're a grown, intelligent woman! Well, where did he go?" I thought about the neighbors, attracted by the smell of fresh baking. The balcony is open. Went out and looked. Guys are to get. Go back to the kitchen, in full mental disorder. Why remember the "x-files"... Imagine the aliens, eagerly munching my pie in his plate and starts to laugh... Drink a glass of water. Open the dishwasher to put an empty glass. From there in amazement looking at my cake... Doors close... And my vacation time, yeah...
С. Альбатрос
Post by С. Альбатрос » Sat Aug 24, 2013 19:07
:lol: :ay a classic of the genre :)
Post by Михаил_ » Sat Aug 24, 2013 19:21
I, by the way, just in the kitchen, regularly do around the coffee pot in the fridge put, or wireless mouse in the bread bin by accident. But since not bothered about this, they all (lost) usually do ago are (either by myself or someone else - hahahahaha).
Искатель
Has thanked: 3 times
Post by Искатель » Sat Aug 24, 2013 22:27
:lol: :lol: :lol:
Аленка
Post by Аленка » Sun Aug 25, 2013 1:09
Yeah, I after every guest the table was cleared and somehow the sugar bowl in refrigerator stuck. The whole evening was looking for, found the next day, when the milk reached... the Devils also asked to give, and ashamed to say even the guests thought that the reason my sugar bowl picked... like what... said it would... I would...)))) then feel guilty for even thinking it))))
С. Альбатрос
Post by С. Альбатрос » Sun Aug 25, 2013 1:16
Yeah, I have often, too, is rather constantly :) A friend also told me recently, came to visit a friend who opens the fridge, and there on the shelf, neatly, in a row: car keys, TV remote and cell phone :) And above all separate from food :lol: that is the logic in the actions of what once was :)
Аленка
Post by Аленка » Sun Aug 25, 2013 1:50
))))))))) :ay funny, when the phone in the fridge will ring)))) haha)) Oh, can't ...
