Post
by Михаил_ » Wed Mar 02, 2011 4:16
well damn... a question.
there is no direct mapping, well for example, if we assume that DS flat picture of several three-dimensional shapes at the same time...or flattened by applying a rigid external modulation (actually strukturirovana so it is a tree). By the way, and the indentation of the big questions. For example, the Templars were in the course of a Tarot deck with glyphs 15ба and was called the 14th Arcanum. What could it be? Our world, or rather the illusion in which we live, is constantly retarded relative to the normal flow of time, i.e., has the shift inhibiting (or lack of vitality).
Okay, done talking in riddles.
Creativity is more of the stabilizer, the balance of the principles of Homo-and heterosexual and it was not my idea.... the closest analogy is the balance of the elements, i.e., DS should be 17БА and development must be 14БА, if you make the curve of the projection. But really do not go out. Not done it.
And my field is just another simplified version, though I much closer. Based on my understanding of DS is the set of stretch marks slightly outside, but there are internal principles that are located in more or less working version on the field, would make it much more difficult, but it technically wasn't real.
Based on the principles of DS, you can simplistically say that all that is from the creativity to the right (if they turn up, will have analogy with air Arcana. Not sure that this explanation has become easier.
Moreover, it is not entirely accurate.
Still we can say that we are dealing with similar principles taken outside (DS) and inside (troncale).
Yes, ACC. creativity will be like a 2.7
