Bracelets Life
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Jun 24, 2010 17:50
Михаил_ wrote:symmetric configuration (two arms or two legs) I would recommend to wear some time
What a difference 2 or 3?
If 3 will be dressed like this: symmetrical legs, one hand alternately (periodically changing clothes) from one to another, will differ from 2?
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 24, 2010 18:39
the difference is that the ideal - all the limbs, will give greater intensity, in its symmetry.
3 if so, then Yes, it will differ from 2x.
Post by Маг.нет » Thu Jun 24, 2010 19:00
Михаил_ wrote:3 so, Yes, will be different from 2
1. What? if all the bracelets are the same. (or originally different mass, such as massive and the wristband).
2. if the third place together with one another, the imbalance mass, which differences will emerge. For example, the right of -1, -2 the left.
3. left -1 right -2.
Sincerely, MAG.no
Малыш
Post by Малыш » Thu Jun 24, 2010 20:44
Михаил_ wrote:Turkey Hello
will tell:)) along with links to resources about the bracelet:)))
Post by Михаил_ » Thu Jun 24, 2010 21:26
MAG.no -in General, 2.0 is supposed to work is balanced across the cell cloud. Really, especially as the body that something is not quite right, through a bracelet is a tangible flow of energy, then amplifying (paying attention), then slightly decreased.
Symmetric configuration (on position) a little better balance the body and speed up any process of regeneration of the cocoon.
Mass on version 2.0 of the effect is not strong, more contact area...
in General, when one bracelet or three in one place, the outlet works one arm or leg, from where all diverges. Well, it's a little abnormal operation mode of the body (which was invented the trick with the cell cloud as a source of powering, while the technology is cellular - universal, for all).
Therefore it is better three different places, then the imbalance will be minimal.
PS my friend highly recommends older version to try to raise up on the shoulders, then speaks to the actual body comes more than from the hand, in General it is probably something right, although this is not a perfect solution, because the bracelet on their "home" location along the channels, quickens slightly.
Post by Маг.нет » Sun Jun 27, 2010 8:55
Михаил_ wrote:MAG.no white will be only next Friday or after the weekend
Michael_ time is not yet known?
Sincerely, MAG.no
Post by Михаил_ » Sun Jun 27, 2010 17:39
Monday and Tuesday, links engrave, today will be covered, most likely tomorrow or the day after tomorrow will go to the office.
Ослик ИА-ИА
Post by Ослик ИА-ИА » Sun Jun 27, 2010 19:08
Bought a 2.0 wooden wristband. Don't feel anything, the second day began to crumble links. While I struggle with one, floor managers lost forever - stuck a piece of toothpick with glue gun - I hope the perversion of the energy situation will not happen ;)
PS: what is the Cell the cloud? Google gives links only to this forum ;)
Алекс11
Post by Алекс11 » Sun Jun 27, 2010 21:36
Hello! Going to take BJ 2-6 but do not know how best to proceed,I can order by mail,but in Moscow a month later,the opportunity is there, are there any advantages if I take in the office?
Been thanked: 182 times
Post by Андрей Кабанков » Sun Jun 27, 2010 21:46
An advantage of purchasing office in that you don't have to pay shipping and you can see and choose from those what is the disadvantage of waiting for this month :)
Алекс11
Post by Алекс11 » Sun Jun 27, 2010 22:02
Thanks Andrew! Then I will choose the office because it is important that he came to hand and not much slack
Post by Михаил_ » Sun Jun 27, 2010 22:48
Ослик ИА-ИА wrote:I Bought a 2.0 wooden wristband. Don't feel anything, the second day began to crumble links. While I struggle with one, floor managers lost forever - stuck a piece of toothpick with glue gun - I hope the perversion of the energy situation will not happen ;)
The wooden wristlets there is one plus and one minus.
Plus the fact that it is lightweight and thin. For example, when working with papers at the table, a thick bracelet prevents on hand.
The downside is that the links are unreliable. They cannot be wet and maybe in the summer they can burst from sweat(?), although I have this has never happened before. From the party of 100, about 10 were thrown out after the winter frosts (stored in an unheated room), but sometimes convenience overrides the cons, I wear them very often.
In the office You will replace (I asked for change in all such cases), take more massive, since there is one such experiment. Though the destruction of links may be associated not with a bug, and work directly with the BJ (sometimes breaks).
As for sensitivity, it is individually.
Cell cloud is the energy structure used in technology BJ 2.0, consists of many micro-elements, i.e., has a complex and stable structure.
More details can be found on the forum (that my).
Post by Михаил_ » Sun Jun 27, 2010 22:51
Алекс11 wrote:Thanks Andrew! Then I will choose the office because it is important that he came to hand and not much slack
Bracelets consist of 11-12 units, if necessary can be shortened (in the office or on your own), but the resolution is always, of course, one link.
Colors currently available are in the picture somewhere above. It is possible to visit the office to select the color and pick out the right size, though there is another plus to visiting the office. Big.
You can focus on feelings and to choose the most comfortable option. Even from the same stone they are all a bit individual, that is.
Post by Андрей Кабанков » Mon Jun 28, 2010 9:55
In the office appeared first bracelet of larch handmade.Version 2.5. The price was 30000 RUB.
Post by Маг.нет » Mon Jun 28, 2010 18:43
Михаил_ wrote:Monday-Tuesday, links engrave, today will be covered, most likely tomorrow or the day after tomorrow will go to the office.
Michael_ You in the office expecting a gift.
Sincerely, MAG.no
Post by Михаил_ » Mon Jun 28, 2010 23:23
Yeah, thanks... but the links are transferred must be transferred on Wednesday morning. Unforeseen force majeure.
Regarding the bracelet with the photo above. Now we'll do 2.5.-2.7 at the same time, the long-promised construction.
The fundamental difference:
-very large capacity.
-very solid links solid wood (larch) growing in the ecologically clean and energetically strong place (the Baikal shore).
These bracelets are to a greater extent artifact to use of the time, not for day wear.
Version 2.5-2.6 will be the price of 30, 2.7-2.8 45.... i.e. the same difference as on the "younger" their counterparts.
version with a "coating" (2.6-2.8) these links are made so that the coating may not be easy and not simply destroyed, although of course the eternal objects does not happen.... Links suspicious look from the point of view of possible cracking or knots are rejected at the manufacturing stage. We expect that the bracelets are sometimes passed through a powerful interaction, such that sometimes torn apart to be completely intact and not damaged the metal.
If the usual 2.5-2.8 coating is applied to the surface of the link, in this case, the link is a special recess, to half the thickness of the material, it does not reduce the strength of the link to which is applied the coating material.
After making ALL the bracelets in this series are activated, increasing the power of the bracelet.
Post by Маг.нет » Tue Jun 29, 2010 10:00
Михаил_ wrote:here's links are transferred must be transferred on Wednesday morning. Unforeseen force majeure.
This unforeseen force majeure... :) ALL THE TIME! ...and place...
Payment made, awaiting shipment according to availability.
A personal request, just make the choice of having 2.5, 2.7, according to Your feelings and no visible manufacturing defects, according to the order made.
Sincerely, MAG.no
Ослик ИА-ИА
Post by Ослик ИА-ИА » Tue Jun 29, 2010 11:38
Михаил_ wrote:the wooden wristlets there is one plus and one minus.... They cannot be wet and maybe in the summer they can burst from sweat(?)
So sweat is currently rife ;)
Михаил_ wrote:In the office You will replace (I asked for change in all such cases), take more massive, since there is one such experiment. Though the destruction of links may be associated not with a bug, and work directly with the BJ (sometimes breaks).
Thanks for the offer, the bracelet I like - do not want to change. Will wear be careful and wait for the manifestations.
PS: once just to stupor wanted to remove, pressed as really insane, but I think it's just from constant wear.
Upd: 01.07.10 first results!!! Yesterday suddenly wanted to change the bracelet on the right arm, which was done. Today on the left hand, where the bracelet was discovered prickly heat!
Малыш
Post by Малыш » Fri Jul 02, 2010 16:45
and how to combine bracelets versions single zero and a double zero when worn simultaneously, one on each arm one version and one for each foot with the other version?
Post by Михаил_ » Fri Jul 02, 2010 20:04
Eeyore - basically, after I saw the bracelet 2.6 with charred coating... I can believe that sometimes the sweat is not only a consequence of sweat, but also intensive work BJ, all of this is very simple tool to remove the bracelet and move it to the place socks sometimes (slightly above, slightly below).
Baby - the perfect combination, when there was actually a 2.0 and dragged on a lot 1.0 (some power is not enough, people are different). just know how 2.0 will unite into a single system, and not 1.0, but still work in a symbiosis.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Fri Jul 02, 2010 23:00
Michael, please tell me whether I should continue to wear bracelets on the legs, if the pain begins in the knees and she does not pass. Sometimes weaker, sometimes stronger. Very difficult to rise if, say, shoelaces tied, need support. Age can be considered young.
The fact that I have lost communication with the ground, bad work of the lower centers, life at the top. (This is even reflected in the figure). So you want to purge channels from the feet, as part of the problem, connected, apparently, with that. BJ 1.0, wear for 2 months.
Can be still something will advise, for me it's a problem I don't know how to solve it.
And one more question, not quite in the topic )) I started to Wake up in the morning, after the coma, some dreams do not remember how deep the pit fell. Hard to get up in the head, and not physiologically (like sleep). Condition is very strange, lay low, don't know where I was, how I got here, where he was head heavy, fail. Then another roll for about 15 minutes, get up, wash my face and as a cucumber. Less than 9 hours, can't sleep, I feel bad start. After the SP started.
Post by Михаил_ » Sat Jul 03, 2010 0:26
About SP I have already said - there is a serious danger of a too strong identification (or link) with the crystal, it changes a person. However, there may be other reasons.
For example work with the same channels of the legs can theoretically give strange effects.
About the bracelets on his feet - to take them on for some time, then dosing. (put on some). While I have been in pain with the legs, it took almost three months, sometimes ached terribly, but it was a feeling of rightness of what is happening. But I was almost in the right channels, they just all have terribly little work.
One of the options of self-help in this sense-to walk in nature (if in a city, find a Park) barefoot. Regardless of the season. I went barefoot in the snow far enough (up to kilometers), the cold is not felt, though it was before the advent of the BZ. I mean, that one of the reasons of failure of the channels of the legs - insulating midsole. If they make conductive would be much better.
МерКаБа
Post by МерКаБа » Sat Jul 03, 2010 2:12
Михаил_ wrote: One of the options of self-help in this sense-to walk in nature (if in a city, find a Park) barefoot.
This is intuitively felt and more recently, trying to walk barefoot on the ground, like crazy, starting to feel the happiness of the world.
Ослик ИА-ИА
Post by Ослик ИА-ИА » Sat Jul 03, 2010 21:13
And what kind of wood 2.0 wrist brace? Interesting smells. It's watered or something?
Малыш
Post by Малыш » Sun Jul 04, 2010 4:51
the arrival of solar turets on the way in which bought two bracelet 2.0 and both wear for about a month my cats sleeping near me, the cat and used to hang out and the cat no . and now that the night cat NAP means on the chair, the cat on the hard floor and before that with pillows only kicks you to drive away ..... :)))
night not sleepy at all , too as it is not really sleep... so don't sleep!
