СК1М
Post by Михаил_ » Wed Jul 14, 2010 2:53
Воффка wrote:Michael_
Ie, I take a container of water and just starting to think about what I care about(and probably at the same time worrying), so I think 10 minutes, then put on the BCC and a minimum of 4 hours drinking? Or need to come up with a solution, and not just think that?
How much of this water time will keep the structure?
What is the maximum amount you can charge at a time (if I for example charge the water in the tub(iron), and then go to flop)?
As the rechargeable capacity of water will affect the charging time?
Gets whether any properties of the container in which the water is charged?
1. all right.
2. the decision to invent is not necessary (it limits choice)
3. for the UK you need to think about enabling THIS mode.
4. water, if it is not to shake, not to warm and not to put in the sun will keep the structure at least daily.
5. the volume - pot, bottle or something else that is placed on the stage of SK, then pour into the tub, only water in it to make a cool (not above 35 degrees).
but still partially to drink. SIP enough.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Thu Jul 15, 2010 9:48
Michael_
Hello Michael! I apologize for some meticulous, but I want clear for myself to understand.
1.Is it true? The essence of the work on resolution of problematic situations with water charging is that I'm holding (does it need to look at it?) a container of water emotionally immersed in some unpleasant feelings associated with the problem situation and about 10 minutes in all colors worried. Then put water in the UK, give him a simple command to "charge the water" after a specified time drink.
2. What if in that state of experience I will make some arbitrary figure (does it need to look at the new picture?) and put it in the UK?
3. What if, as this experience I will write an arbitrary phoneme and serve it in the UK?
4. Can and should (and do we need all these points when working with SK?) whether paragraphs 2 and 3 be combined with item 1?
Post by Михаил_ » Thu Jul 15, 2010 11:27
These are different modes of operation - phoneme and picture are good when You know which method of solution to choose and formulate precisely the goal.
work with water and the situation is when writing something that is not always the goal (the problem :) ) it does not need fixing, except on the water, because it is replaceable.
the operation mode of SK - charging to work with the situation.
Post by Воффка » Thu Jul 15, 2010 11:45
Michael_
I.e. on the first point, all right?
But if I don't know workarounds, but I know the goal (let's say it's some kind of financial benefit) will need to reflect like this purpose I already have the pattern and/or phoneme?
How important the emotional state of the creation of such a figure\phonemes?
Post by Михаил_ » Thu Jul 15, 2010 21:48
1. paragraph 1 all right, emotion is not very important, important engagement for the task to be solved.
2. not to be confused charging the water with other types of work.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Jul 16, 2010 18:03
HF-hat to SK, really "manifesting" themselves feeling a thing. I do not want to let go... However, while for 10-15 minutes trying, are recharged somewhere for 30-40 minutes. This is the first impression. Interesting as I've known, this "noise", now I understand that this RF is called. Constantly in this state hard, although it is rather facilitated (minimal sense of body weight), from the earth "pulls".
Sincerely, MAG☂no
Post by Воффка » Fri Jul 16, 2010 19:56
Рираха wrote:
Михаил_ wrote: 4. water can be charged for order. Moreover, a possible double cycle. Take a small container of water and thinking about the task (situation, health problem) keep the water in the tank in the hands of a few minutes (up to 10). Then put on the stage for 4 hours.
Then you can drink at once or portions. the corrective structure of the water will go into a cocoon in a very effective way and the effect is quite strong.
Michael,
1. "thinking about the problem to be solved" - that it is better to think of a specific goal visualize to feel or "it would be good that this problem is resolved" (especially if you don't know the solution)?
2. "double-loop" means that at this time, on audio, too, is something associated with the target situation?
3. How often should I do a water if the goal is not for one day?
Михаил_ wrote:Siraha
1. a specific goal without a way forward.
2. Yes
3. from a couple times a week to daily
Something is not clear. I put on charge the water I give SK the corresponding command, and can record audio input from the phoneme in which the invested that the problem is already solved. The direction of course of thought is correct?
Post by Михаил_ » Sat Jul 17, 2010 1:31
the entry serves the rest of the time, when not charged with water. These are two different modes...
Post by Воффка » Sat Jul 17, 2010 11:21
Michael_
Clear. Understood. Thank you for your patience! But the messages Riahi a few confused me for a while.
Michael, tell me, when I'm in the UK use mode the gain of the bracelets as they are amplified? Let me one bracelet 2.0, when the amplification regime in the UK it will be like two(three, four...) bracelet or as a 2.5 or something different?
Post by Михаил_ » Sat Jul 17, 2010 12:06
As a greater number (or more power) 2.0 a slight bias between 2.6-2.7
In General, all 2юх cooperate together, then SK will behave as the bracelet, but since it is not human-something a little weaker, but because it is very solid, it is decently stronger, it is more than 1-2-3 2.0, but if had to choose, I would choose the 2.0 on the hand, the foot, because it is a more intimate contact with you (physical), if not choose, and to heap very nice addition.
Post by Воффка » Tue Jul 20, 2010 14:38
Michael_
Hello Michael! Tell me, how far from the equipment you need to have SK to her did not too, that with Your watch? :)
Can I with arbitrarily long distances mentally to switch operation modes of the UK?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Tue Jul 20, 2010 19:34
Michael_,
СК1м, in the copy mode, can carry properties with photos for a real object located at the object table?
Post by Михаил_ » Wed Jul 21, 2010 1:06
Can. Generally it is very flexible, ask the program the cell is fine adjusted basis, the difference with the usual thought-form in an extremely high durability and density of the impacts.
Ie if you think that you want to transfer, and the effects dissipated after a short time. Thought for a long time - went a little better, but soon everything was erased. Dragged myself in RF mode long posts and energoproektami - turned out even better :) but still faded quickly. Then cells SK read according to the basic program of your task and mode of work - and they are not erased. But sometimes in passive mode switching, especially in elementary programs where fuzzy set parameters, but in the UK the basic "firmware" is less wise.
Ie in principle by the use of KO BJ 2.0 and its the same in the UK you can build a very interesting and quite "dense" things are very quality work and even to separate them from the main device (or TO) translating into Avtonom.
What am I? In basic mode, the copier assumes the focus operator that is allocated from the copied object (i.e. what quality or value we are interested in). And this setting is rather flexible, but well recorded. The main thing for itself to formulate correctly.
Post by Воффка » Wed Jul 21, 2010 20:03
Michael_
Hello Michael! Tell me, what modes of operation of IC primarily prohibited for a person with tumors(what kind of tumor do not know)? What modes of operation except "capsule" in this case can I use? Very interested in first of all is it possible in this case to use the cleaning of the cocoon of negative thought forms?
Post by Михаил_ » Thu Jul 22, 2010 15:24
just don't use SK as a generator to recharge the body.
tumors can grow in vital energy, because feed on the energy in the human range of frequencies.
all other modes can be used.
Post by Маг.нет » Thu Jul 22, 2010 17:22
Michael_, I'm sorry for the indelicate question, what "size" Your personal SK (if it is possible to compare) and some interesting "gadgets" are being tested?
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jul 22, 2010 18:12
I have a personal SK made in a clay vessel of about 3 liters in size (tureen :) was )
Size not always is key. But this is not the only such device to use, there are other...
in the testing of active amplifier to the SC, which in combination will have a number of unique f-functions as a standalone device.
in testing some other things.... :)
Новик
Post by Новик » Thu Jul 22, 2010 20:43
The program would be under SK would wait :oops:
Post by Михаил_ » Thu Jul 22, 2010 20:56
will the program... soon.
Post by Воффка » Fri Jul 23, 2010 21:04
Michael_
Michael there the above question about the distance of placement of appliances from the UK please answer.
Post by Михаил_ » Sat Jul 24, 2010 17:36
Well, move aside a foot or two... In principle, the distances here do not work in the classic sense, but when objects get too close, they bond occurs at the "territorial" basis.
I've recently mystery people was thinking about distance and energy channels. It seems to still guess :)
Post by Воффка » Mon Jul 26, 2010 13:16
Michael_
Hello Michael! Tell me, can I being in different rooms in the UK to enable scrapers from negative thought forms in the room which are, as it were, through itself(i.e. I will be playing the role of repeater)? How will this affect the efficiency in comparison if SK himself was in the room?
Post by Михаил_ » Mon Jul 26, 2010 14:46
Will greatly depend on personal abilities. In principle, Yes, you can. And better mental device to specify another room, figuratively representing that his working cell a cloud - a kind of energy-informational structure around the device, appears in the room where necessary. Efficiency will still be lower. Pretty decent.
But somehow it will work.
The reason is that on the one hand the distances are not important.
On the other direct contact creates a very strong attunement. (in this case space) and as a result - stronger, more "solid" impact.
But sometimes this method may be better than nothing.
The operator is strongly aligned with the appliance, so it is a good alternative, but the power required for cleaning small and not through themselves, not everyone is going to miss it (well, not straight through, but in the area itself).
try it, tell then.
Post by Воффка » Mon Jul 26, 2010 20:28
Michael_
I will try, but before that, ask :) How will depend on the capacity of the volume of the room or from being in the room with negative-minded people or how many negative people just all the time I was in this room?
I'm not fully understand how to measure (at least approximately) contamination of premises in this respect and what parameters it is measured and consequently how large are the energy costs of cleaning? Do I understand that cleaning is the saturation of the RF energy of some volume?
PS You said that the parasite can change host i.e. one (or several) of such entities can stay in the room (if they are there for some reason like it) after a visit to their carrier?
Post by Логик » Wed Jul 28, 2010 23:28
Michael,
when working with СК1м and RF module photos and drawings to lay down on the stage and from above to impose an RF module, or to lay down already on top of the Sam module, lugasi on the object table?
Does the RF module when infopresse?
