Radionic devices Karl Welz.
Generators of bio-energy (orgone)
Новик
Post by Новик » Sat Mar 13, 2010 23:24
No, well hope that is what they appear :)
PS.
And I already ripen morally for purchase....
Ванька-встанька
Post by Ванька-встанька » Sun Mar 14, 2010 11:33
Well, as they say hope dies last. :). I myself seriously thinking about buying a model more than 2400 RAD - 5 RAD, for example: what to do with one hand that you can't do five :wink:
Question Andrew Kabankova. Do You plan to expand the range of Radionics and if you plan, then when? Demand is quite stable, I think you can already think about the expansion of the :)
Been thanked: 182 times
Post by Андрей Кабанков » Sun Mar 14, 2010 11:52
While there are these 2 models,through a few months of rest.This is due to a number of organizational issues for contract deliveries.More powerful devices can be ordered now,the delivery time is 20 days.
Post by Михаил_ » Mon Mar 15, 2010 5:13
рыжая wrote:Michael, when you write "its normal potential" you mean, I'm conventionally "red" required three hours of instrument RAD2400 to get possession of additional energy, allowing to solve a problem, say, finding the right person to me? "It is easier to develop a sensory" You once wrote in another post and not here "about the consciousness of the user. Ie, if the consciousness is drawn, and little energy" And if the sensation developed but free energy is still not enough? Or it does not happen
Most city dwellers even just transport and other factors of anthropogenic city eat a lot of energy, and it can certainly be little. But I do not believe that in this case we are talking about quantity, I would say that most likely, we are talking about the right quality combined with the task.
Ie, I certainly agree with the contour of a Lily.
But as a practitioner, I have to note that the energy is different. And to characterize it as "good" or "delicious" or "Golden color" and so on, it is not an objective parameter. For different tasks need different. In order for the tumor to suppress this need, which in other cases will not use, and indeed the body in harmonious balance, and the excess of something - not good.
For the regeneration of the physics of the body need some frequencies for consciousness - other. To work in harmony - all cocooned in fine.
Here's the flu - you can go through the "down temperature" and is a certain quality of energy, and you can go through - on the contrary, to stimulate the body to kill the disease, the temperature will jump, but that will pass. This is a different quality. The terminology "orgone" under quality for free choice, but because she's ... odd, the most she fits the energy of life, but also that there are frequency levels (different ones) and the excess of it, not always and not to any place good. In the case of some tumors is not good.
In the case of pumping at the frequency of Shumen, I suspect the interface improved the consciousness of the planet. Ie "call" to find your friend easier reached at the address and were processed by the universe :) the most effective way. THE same would have happened with more energy in the upper levels, though perhaps on a different algorithm, but You would have noticed, probably, some physiological effects. Certainly consciousness is also podpisala....
In other words, I would not make any conclusions about how many hours of operation of the device and your consciousness to complete the work and such matches more often because it's not just the "battery stuck" it's a combination of factors.
In the ideal state of the harmonious person at all frequencies, in the case of the[SPAM]development of any individual abilities, is that he's a little.... hmm... skewed, for example, consciousness, works worse physics, and sometimes Vice versa - worse physics of consciousness... is Not good both.
And the effect came, probably it is due to better attunement with the external world, for quality changes energy usually need some time and if washing is harmoniously, the body will start to eat first, then giving part of consciousness. But exactly how the device works I don't know in detail. I would have assumed that all the forces of man and that man is powerless without the device (restored), but if there is something that helps this - and to use such useful.... moreover, the opposite factors (destructive) - a lot.
Ie if "useful junk" obviously leads to the incorporation and / or regeneration of their ability, it is very to use it correctly, because later the level will start without any outside assistance...<
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Mon Mar 15, 2010 12:15
рыжая wrote:And if the sensor technology is developed but free energy is still not enough? Or it does not happen
IMHO - it happens
This took the device.
IMHO - works.
рыжая wrote:attribute this to radionica. Coincidence, you say? Or a pattern?
Orgone energy is directed by intention.
The trend is not required.
Apparently You "have stanilova" maybe subconsciously in search of the person
ЛИЛИЯ-Р wrote:whole body filled instantly
This is the tide quickly
Filled - after 3 weeks (21 days?)
ЛИЛИЯ-Р wrote:We are in a mega ocean of energy or energies. Man as receiver and transmitter
Yes and no
The city is destroying the structure.
It is to be understood.
The energy here a lot, but it is mostly destructive.
I strongly feel differently radionic when outside and when indoors/underground.
Although after 3 weeks it's less. Used. :-)
All of the above - IMHO.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Mar 15, 2010 13:51
Шалтай Балтай wrote:Energy here a lot, but it is mostly destructive.
Destructive removed the Svetlitsa Super.The PARLOR WINDOWS IN the PREMISES AND on the phone Way.
Personally checked :wink:
Post by Шалтай Балтай » Mon Mar 15, 2010 14:41
ЛИЛИЯ-Р wrote:Destructiveness is removed the Svetlitsa Super.The PARLOR WINDOWS IN the PREMISES AND on the phone Way.
Personally checked
I do not really want to develop this theme, but I think here it is a little deeper
Urban structures - preventinput the normal flow of energy.
It is clear that the location of the cities on the planet - not by accident.
Post by Михаил_ » Mon Mar 15, 2010 16:09
man is not only alive itself, but part of a larger living system....
different information, electronic, mind, psychological and other helpers can really solve the problem, but not remove it. The city cannot be made into natural habitat by any instrument, how good they are. You can compensate for the most serious distorting factors(not all and not immediately) completely or partially, but because it's all usually done by some artificial inserts between man and world, though the benefits of such compensation is, but the rose-colored glasses on this account is not appropriate. So, lyrical note.
олигарх
Has thanked: 10 times
Been thanked: 4 times
Post by олигарх » Mon Mar 15, 2010 16:29
Dear friends! if anyone has dealt with the Manifestation program please tell me how to use it in conjunction with RAD.or if there is a normal transfer instruction throw off please to me or to the forum.Thank you
Post by Шалтай Балтай » Mon Mar 15, 2010 16:35
Михаил_ wrote:the City cannot be made into natural habitat by any instrument
If You mean me I'm not.
Михаил_ wrote:Can compensate for the most serious distorting factors
+1
олигарх wrote:Dear friends! if anyone has dealt with the Manifestation program please tell me how to use it in conjunction with RAD.or if there is a normal transfer instruction throw off please to me or to the forum.Thank you
I use Manifestation
here is some material: http://www.mindmachine.ru/viewtopic.php?t=3116
What's your problem?
Post by Михаил_ » Mon Mar 15, 2010 16:43
No, not about You, it was a lyrical exercise plan.
бетмен
Post by бетмен » Mon Mar 15, 2010 21:05
has anyone tried using this device to win the lottery?
МДВ
Post by МДВ » Mon Mar 15, 2010 21:42
бетмен wrote:has anyone tried using this device to win the lottery?
Why do win the lottery? For money or interest? If for money, then to be honest I did so. Would put his photo and wrote the goal. I have a million roubles on R/C. turned out,,,,,, But if for the sake of interest. the purpose of this - I know how to trust your intuition. :)
МДВ
Post by МДВ » Mon Mar 15, 2010 22:01
Intuition has increased, guess the card and number. However at guessing, undermining, and waves, i.e. 5 times guess, but three times miss. Probably affects the feeling of joy.... :D And if you have an internal sense of confidence, courage, etc. and it turns out more really when organic included and washer to be in the pocket. But the cost to turn the appliance off, as much as I push and what sense fiction -it is impossible. Really is magic. And I used it (in magic) and believed not before, and in God did not believe because they were raised atheist. Communist parents.... And now do not believe in God.... Church, religion is for me -sect.
олигарх
Post by олигарх » Mon Mar 15, 2010 22:08
Шалтай Балтай wrote:what's your problem?
how to combine work program and RAD? thanks for the help.
МДВ
Post by МДВ » Mon Mar 15, 2010 22:50
And You have a RAD? And which program? They are all different. What's the problem? Specifically, please describe the situation.
Post by Шалтай Балтай » Tue Mar 16, 2010 11:32
олигарх wrote:how to combine work program and RAD? thanks for the help.
Here's how:
  • You should have two disks. One of the installation program, the other with the "link" (Cortina in JPeg format)
  • Set the Manifest from the first disk
  • Open the Manifest Pinko Press Start
  • Next, click pimpco 'Copy Trasfer' - It asks the second SD with Jpega - give it to him. It copies the picture to his folder. This is due to the fact that in the General case these "links" can be set. That's all, and copy. If You have one link - so copy only.
  • Next, I highly recommend to download a template use pimpco 'Load Operation' - choose what is closer to You
  • Hereinafter, the binding itself. Click pipko 'Load Transfer Image'. Load the image that you copied above.
  • I recommend to edit and save the template for yourself (include your name at the target, what you want in the trend).
  • And the last "most important thing". In the envelope with the CD where there was a link - needs to be a laminated piece of paper with the SAME image - it MUST be put on RADIONIC - TREND
  • Voila - Shake pimpco START
Read more here: http://www.akor.cc/manuals/english/manual.pdf
page 31 and further
следующий
Post by следующий » Tue Mar 16, 2010 13:54
Humpty Baltay
Thank you!
олигарх
Post by олигарх » Tue Mar 16, 2010 23:43
Шалтай Балтай wrote:# You must Have two drives. One of the installation program, the other with the "link" (Cortina in JPeg format)
# Set the Manifest from the first disk
# Open the Manifest Pinko Press Start
# Next, click pimpco 'Copy Trasfer' - It asks the second SD with Jpega - give it to him. It copies the picture to his folder. This is due to the fact that in the General case these "links" can be set. That's all, and copy. If You have one link - so copy only.
# Next, I highly recommend to download a template use pimpco 'Load Operation' - choose what is closer to You
# Further - binding itself. Click pipko 'Load Transfer Image'. Load the image that you copied above.
# I recommend to edit and save the template for yourself (include your name at the target, what you want in the trend).
# And the last "most important thing". In the envelope with the CD where there was a link - needs to be a laminated piece of paper with the SAME image - it MUST be put on RADIONIC - TREND
# Voila - Shake pimpco START
Thank you.
олигарх
Post by олигарх » Wed Mar 17, 2010 3:15
may be in the books Klaus J. Joehle "Money is Love Some Things are worth believing in"you will find good advice how to be rich.Like trying to explain to the author of the book,the main thing is to learn to focus on feeling the possession of money and to hold onto this feeling(balance,for example when riding a Bicycle).And how will you have money whether you win in a casino or they simply will fall as snow on the head doesn't matter.after the financial well-being will be pulled to a favorable series of events:increase your self-esteem,self-confidence, freedom of choice,increase your social level,in what aspects will change your perception of the world.Sorry if I did not intervene on the subject.I do not pursue the aim of imposing interests.
олигарх
Post by олигарх » Wed Mar 17, 2010 3:33
red
You are very charming! :o
Ванька-встанька
Post by Ванька-встанька » Wed Mar 17, 2010 18:27
The oligarch! You spoke on the subject (I mean the post about the book), but not quite right. Usually one or the other book with tips about Finance can bring money only to the author of this book (and the publisher). Radionic can help to attract the energy of money, which is one form of Qi energy, most likely. The money can only be earned! A little harder or a little easier, but only earn.
About lotteries is predosterezhenie on the website of Carl Weitz: do not attempt to use radionic to guarantee winning the lottery. Yes, the prize Fund is 50% of the cost of the tickets and one of you sometime get the jackpot, but the number of possible winning combinations radionic reduce not this a mere accident, that would not say.
In General, Carl picks up a slippery subject, of course. Magic, legal manoeuvres, profitable casino game - if it were true, such devices are simply not allowed to market stakeholders, not necessarily intelligence agencies, and even professional Association of bookmakers or casinos
Post by Андрей Кабанков » Wed Mar 17, 2010 18:43
For winning number combinations reduce not need.You need to be in the right place at the right time.For example in casino on the Planet Hollywood in Vegas when I was there,there was a device that could spin only the hotel guests free of charge once.Jackpot $ 2 million.Sooner or later he will fall,so we only need something that would at this point, the handle spun me.And there is already a huge number of options and chains of events that can lead me to the machine at the right time.
I think so.
Ванька-встанька
Post by Ванька-встанька » Wed Mar 17, 2010 19:02
Yes and no. The machine that You, Andrew, describe was more a gaming machine than a random number generator (lottery or roulette). And they work on specific programmes, which at the time was governed by a mandatory cut. Therefore, the machines were "cold" and "hot" respectively. "Hot" was considered one that long for a long time were not given the win and could such issue in any subsequent second.
And roulette and the lottery - they don't have a "heating",or thought it, every new spin or circulation is a blank slate, roughly speaking.
On many issues I fundamentally disagree with Carl Walzem, but in the matter of lotteries we were with him in solidarity :)
Post by Андрей Кабанков » Wed Mar 17, 2010 19:11
Well, the essence is to approach the apparatus at the moment when he is ready to give the win,and it is cold or hot does not matter.Here radionic and it may work in my opinion.Not on automatic,and on a combination of time-place-machine.
Let's say I bet on the roulette wheel is always clean 23.
To win I need to choose a table and make a bet in that moment,when you get 23.
The reason I can get in at the right time can be any,well, shoelaces were untied and I was late for half a minute.This here is the field of work Radionics,these are the little things, or chain of things that lead to the desired result.
