I'm shocked that it happens. Jackie Chan just resting...Алексей Кузнецов wrote:
Here is a vidio about such phenomena. All real.
http://www.solovevstyle.ab.ru/index.php ... &Itemid=61
Svetlitsa Blaga. The results of the application
Логик wrote:At the drawing rooms-the good was otslaivetsa protective layer.
следующий wrote:the same thing happened with my parlor.
Гость wrote:shamelessly pasted
This is unacceptable for a product claiming to be a little bit worthy!Гость wrote:Now began to do somewhat better ( less need to glue )
A manufacturer of goods is also not acceptable!АСД wrote:Judging by Your posts, You consider yourself a specialist in manufacturing technology of plastic cards. But there are observations: 1. Your Bank card must have been other conditions of wear compared to SB. 2. In Your card there are no additional layers like SB, so I made it for a different technology. Not every technology of manufacturing cards suitable for SB. We tried a few and a number of materials while staying on this. 3. In any technological process can be deviations from the norm. 4. For the future I advise you to avoid prolonged contact with the skin SAT. On the one hand the skin is too aggressive environment for cards, another for skin is also not good to have prolonged contact with plastic
The manufacturer needs to recall substandard products. All cards must be replaced with a new, certified! - This is my IMHO!
But there are legal moments! To my knowledge, all products LIK, the manufacturer gives a 2 year warranty!!!
Guest, I mean, I talked about the products of the whale, and also that this defect characteristic of all the multilayer cards, because the moisture of the body ( which wears away the stone ) - sweat penetrates between the layers naturally leads to their detachment. A chamber made IMHO no worse than today's Whales. But the manufacturer really ought to attend to the reference conditions in the user and provide ( for such a price ) their products protective case
Гость9
Tell me, and as far as SB water-resistant?
Met posts regarding the integrity of the SS corps and peaceful use of it in the water.
What about a layered SB case? Is it possible to wet, put it in the water? (for example, when diving, to properly rebuild their movement under water)
And another question manual. As you see, can seriously damage the hull of the products carrying them in the same pocket, holster, etc.? (well, there are all these microtrading, scratches, the peeling of the paint from the outer layer of SB, etc.)
It is clear that it is better for each items separate bag, but if they are, for example, three, as-that inconveniently turns out...
With respect.
With respect.
SB water-resistant and not afraid of water. When we developed the technology of making the Parlor of the first generation in systems card, to check the moisture resistance and laid them in the washing machine and washed for several hours. Everything was fine and card was not stratified. To our surprise after the release of their on sale rained complaints from users because of the constant contact with human skin within a few weeks began to peel off the laminate. SB made a few other technology and are more resistant to moisture. But prolonged direct contact with human skin (for several weeks) it is also contraindicated (even if only for hygienic reasons). Now we are preparing a new edition of the instructions for the SAT with limits prolonged contact with human skin.Гость9 wrote:Tell me, and as far as SB water-resistant?
With respect.
To carry multiple products in a single case is possible. Better if the case does not allow them to move freely relative to each other. Though minor scratches do not affect performance, only worsens the appearance with time.
Александр79
[/quote]
SB water-resistant and not afraid of water. When we developed the technology of making the Parlor of the first generation systems in the form of cards, to test the water and laid them in the washing machine and washed for several hours. Everything was fine and card was not stratified. To our surprise after the release of their on sale showered with claims from users, because of the constant contact with human skin within a few weeks began to peel off the laminate.[/quote]
To be honest the mind does not fit Your written. Anyone have the same?
Yes here all is clear!Александр79 wrote:Honestly, the mind does not fit Your written. Anyone have the same?
When testing the moisture of prohodna "on the knee", the results are. And neichego surprising in this. Manufacture of parlor piece rather than massovoe/industrial scale, hence the schools performed in the tests.
If we talk about the tests "for strength", it is necessary to hold them in the washing machine for a few hours and in an environment that is several times more aggressive than the environment of actual operation and accurately calculated according to the formula time. According to the principle of tests of paint coatings on cars in the salt fog.
P. S. the Principle given in the example is just an example for understanding, not a proposal to try the front room as well as experiencing the paintwork.
The concept of "knees" comfortable denouncing the label. I called in to the factory, where we did a Chamber in the form of cards and asked about the cost of the equipment. Said the whole complex - with digital printing, laminating, sintering, cutting, etc. (total 9 machines) is worth over $ 100,000. So all Your claims are talking about the weak representation of technological processes and equipment.Жека3000 wrote:Yes here all is clear!Александр79 wrote:Honestly, the mind does not fit Your written. Anyone have the same?
Else to raise the price of our products, creating testing facilities do not see the need. Overall, the number of complaints is very low. Defective product we replace. You, in particular, one of those who underwent replacement.
[/quote] the Concept of "knees" comfortable denouncing the label. I called in to the factory, where we did a Chamber in the form of cards and asked about the cost of the equipment. Said the whole complex - with digital printing, laminating, sintering, cutting, etc. (total 9 machines) is worth over $ 100,000. So all Your claims are talking about the weak representation of technological processes and equipment.
Else to raise the price of our products, creating testing facilities do not see the need. Overall, the number of complaints is very low. Defective product we replace. You, in particular, one of those who underwent replacement.[/quote]
This is not an expensive piece of equipment... In my experience sometimes you need to spend gooorazdo more money for equipment and QUALITY raw materials, hopping in the marriage? Finally a nightmare!!! (The wife of busines, so I know firsthand
Александр79
Yes! I confirm, the parlor With the ball replaced! Thank you!АСД wrote:You, in particular, one of those who underwent replacement.
But after, on the forum, I saw a message from You that such a marriage, marriage is not. While the gap in the recess for mounting of a chamber increases the risk of primocane! What does this mean?
It is not the equipment but the ability to work on it and the quality of the materials that made! Bunglers and the equipment for $1000 000 marriage ceremony done! (examples of inept use of equipment think the result makes no sense, all and so know them)АСД wrote:worth over $ 100,000.
Based on what I have visited many factories, print shops and exhibitions, I can assure You that the charade I have, though maybe not detailed!АСД wrote:So all Your claims are talking about the weak representation of technological processes and equipment.
More expensive wait! Maybe in the margin to be pressed down? To sell knowingly defective product is undignified at least!АСД wrote:Else raise the price of our products, creating testing facilities do not see the need.
I think that is not because they are not! Most likely because do not want to communicate, and some "sneeze" they are afraid of covers for them master.АСД wrote:the overall number of complaints is very low.
People.... I'm sorry, but I'm surprised to read ndtsat pages of text on the stratification of the cards and discussing what needed to be done to the manufacturer.
It would be better if they were not(the parlor)? for example due to the inability to purchase more expensive equipment? I think no better. This is a working moment, and then branch leaf-leaf
and all the discussion of the technology of gluing maps and their soaking.
Now review on the merits.
There are unaccounted factor that I know for sure. Not sure it works at the Parlor, but I think still Yes. And it can cause delamination. This kind of product, relatively speaking, be called "collision" between the person wearing and the outside world. As harmonisation (or any other damper), take contact with the energy-intensive processes in the world. Example.
I have seen the subject (not the parlor) which are information modulator, which was lying in the sun visor (his pocket) in the car of my friend. On the machine, outside the city, fell a tree (the wind toppled the old thick tree during squalls in a thunderstorm).
By car - a couple of scratches. The tree leaned branches of the crown in the land, and even more unlikely - in the top of shtaketin old fence(well anyway that the needle tip in the needle). Visually, from the outside, it looked as if the car skiff(the stem was laying on the roof). Actually damage was not(millimeters between the trunk and the roof of the car), though I had to work with a saw to get the car and not ripped off at check out.
The subject is in the sun visor (made of plastic) broke apart. Impact on it, as I understand, it could not be (there is nothing in the car is not crashed).
None of the witnesses was no doubt the reason why the car remained intact and in the cause of the break plastic parts (like glass into smithereens)
Assume that a chamber (or other similar device) all versions, experience in some degree the burden of the ongoing interaction with information structures. Since the rupture of the plastic in other areas is unlikely, the impact on the direction where the probability of a gap of max - layers. In case of their strengthening, I assume the Chamber will be more likely to get lost (do not replace will
Александр79
I shared my experience. Cited only one example, in the presence of hundreds of serious event affects the media, there are examples when exploding objects. These cases repeatedly described not only by me, if you look closely in the network. When this happens regularly, it becomes quite obvious that the relationship with the events and the fact not natural (to our logic, at least) destruction.
Just Svetlitsa very soft subject, more torn and broken various things that contains a tough program.
As for the "nonsense", I have long held to three principles, and it really helps in life:
1. to allow for the possibility (since I may not be a valid perception of the situation or may be not taken into account all the factors)
2. to assume that anything is possible. Even the most improbable things are possible among ordinary people, and not somewhere in the historical-fairy-tale or biblical treatises.
3. in the formation of the current position to rely on their own experience, not on the opinions of others, some authoritative to me, it would not have been (I can make exceptions when the experience is coming indirectly, as in the view - model analogy in the perception of what is happening).
In General in quantum-information world everything is possible
However, the above fact seems even on the basis of simple logic clear.
That is, some object, having an information structure that somehow interacts with You and with the chain of events. There is some danger, such as serious accidents, relatively speaking, an accident on the road.
On the one hand, this event is very energy-intensive (although hasn't happened yet, but in some situation this, for example, the situation is), with another - there is a kind of matrix, an artifact, something that tries to smooth out what is happening to this destructive event had not occurred.
At this moment, the resistance of the medium is large (if the event is probable), but it also triggers the artifact to a higher output (if, for example, is activated and the resistance force, which have caught). As a result, put, somewhere just swung the scales - the driver yanked the wheel and the accident did not take place. (or any other event, some small or external and invisible to us, we just usually never know they are not in sight), but through a structured item has a very powerful flow of information and energy, and "processing structure" is geared for the physics material of an object.
As a result, when the impact is removed, this is similar to the explosion or just sudden changes in tension in the area of our modulator. He destroys the physical media. Fragile items are destroyed more effectively (ceramics, stones, etc.). Plastic, wood, leather - extremely rare.
Personal observation of the people loss her or the sudden disappearance of objects also occurs.
Such cases I know a lot, including some with fairly close friends, when after a very very critical situation in life; he was lost at times to some, a talisman, sometimes homemade tried and tested - what kind of favorite subject, which is man himself "appointed" as guardian, and here he suddenly the house disappears and never is - nonsense... well, if not in the house at this point, strangers, children, animals, and then I have a full bulkhead in all, and most importantly, and events match the person, intuitively understands the relationship and he voiced it.
When this once - just say, put a tick.
When this happens many times during many years with different people, it's not even statistics, but just a visible natural phenomenon.
In other words - something is not harmonious. On the one hand the chain of events and on the other - all this is connected with the prehistory of (causal chains create a LOT) and intends to face at one point. Not necessarily physically, well, for example, the scandal at work.
The event takes place, everything goes naturally harmonious. But the potential of the two gears that are spinning out of phase somewhere needs to STAND out. So he stands out, totally natural way, the exact point that changed the trajectory of events. It is logical to nowhere.....
I repeat, this is not a theory, it's a lot of years of observations, personal (including family and friends) hundreds read such descriptions in a network about various modulators of hundreds. Throw it all somehow does not work.... and adequate replacement to explain the "coincidences" are seen.<
That thing is now like this is not done. But I gave an example to clarify the situation with the bundle. There is the classic mistake of not understanding. Once it happened so, that doesn't always mean protection will be equally effective. Don't be in a tree some branches or fence on the fence, maybe the probability to survive the machine would be equal to zero - would simply not be where to switch the situation. Or minor accidents on the road is good or bad? like bad, or else it would be big? and so and so.T.e. that once happened to you, doesn't mean that will always be so, especially if the driver (for example) begins to believe that it is protected and still do not care.Александр79 wrote:this is very interesting and clear. You will be so kind as to PM me the address where you throw that thing to get or see?
Why would we throw in private - there is ekonorm, which is occupied exactly the same.... I see no fundamental difference. Moreover, perhaps it is more powerful. At least it solves the problem these (as I understand it, may be wrong).An example was given to illustrate that this happens in a very visual way. It's just more bright than other, less notable events.
Александр79
Michael, I asked you to share about the subject, you described the case of a tree.
Another question, what do you do? What do you do? What has made in your life? Based on what you write must be interesting.
A terrible tale.
Chamber decide how and what will happen on the road, at home, at work... They know everything. They take over the world and all will be as in the matrix.
Just kidding of course. And we then why.
A terrible tale.
Sometimes Vice versa. The materialization of a long-vanished subjects.Михаил_ wrote:personal observation of the people loss her or the sudden disappearance of objects also occurs.
Yesterday in Krasnodar. Talked to Professor Savina Lydia Vasilievna. She now conducts research in the Krasnodar regional hospital in the interaction of the Parlor with patients with diabetes. She told of a recent incident that occurred with her patently, which began to use the Parlor. Let's call it Patent.
A few years ago N lost the copper ring that had a talisman or amulet. She was very proud and very sorry about the loss. A few days ago she was walking down the street and felt that she stirs something in my Shoe. She stopped, took off his Shoe, sock and saw that the second toe wearing the same long-lost ring.
She's the result of the application of Chamber sugar was normalized and she stopped using medicines, but the case with the ring I had made more of an impression than the sugar.
Our technology is some overlap with what Nikoly Nikolaevich Denisov, therefore, the spontaneous materialization or teleportation could explain his position. http://denisov-nn.narod.ru/
I was faced with the materialization of objects at desudava age.This case is remembered well.Being small loved to take apart different things,one of them was an old camera.Favorite toy was disassembled the lens from the camera,the other evening in the winter,it was already dark,surprised the girls in kindergarten ,showing through it the lights of the lanterns,and telling them that it's germs.And because of that I lost her.Was very disappointed on the way back from the kindergarten home and thought about it.And what was my surprise and joy when upon entering home, I found its glass lying on the table in the kitchen!
I wrote that repairing the product in the form of cards with epoxy glue. In the last edition I believe, that repaired in this way, the card must remain in the pouch, if worn on the body, as even a hardened epoxy adhesive in a hostile environment can be dangerous for health. I was just to clear my conscience.Жека3000 wrote:АСД wrote: and some "sneeze" they are afraid of covers for them master.
Glan
Here's to the night here without me, this topic surfaced
I take this opportunity to Express special thanks to Andrei Patrushev, for a "tip" in N.N. Denisov made some time ago here on the forum, in the discussion of the CD "Inner worlds", when the question is not whether then it is another drive with the intention of teleportation, he replied that this could be, just need to find the time to Denisov Seminary to go.
It is a separate serious issue, which should not clutter up this thread. I will say briefly here that.
At Denisov, since January this year, was I and several of my friends.
1. On the paid course vision they do give is thought out from different points of view, the methods of testing essential of view. 100% of the present work. I do not lack "vision"(I mean the situation before), but I can't say that it works perfectly. It works somehow.... so, the question I thought was relevant (and he's in the study).
Interesting points that many should hear. We were in a group of 5 people. 2E ran from the middle of the course, getting GREAT results and making sure that it is possible. Why run away nedouchivshihsya? realized that will not learn (so I believe), because it is not only the course, but continue - constantly and for a long time independent work to Refine the skill until perfected state.
At the end of training, I have what my colleagues assistant N. N. showed waste Sidhu is fluent reading with a blindfold (bandage + bag on his head), with arbitrary locations and arbitrary books.
This is of course not an end in itself is only an intermediate step, but it reasonably does not work else, and for good reason (which many are fond of different practices glitches read instead of a detailed and completely accurate data).
By the time demonstration showcasing all the rest in our group read part of a newspaper headline (capital letters) in Cyrillic but not in Russian (don't know the Bulgarian newspaper). Ie doubt on the subject and whether in her ear hidden microphone or selkies in a sling was not necessary, since we all already had their experience and skill, just not as high quality.
2. classes on teleportation of objects are held for those interested free of charge, although Denisov and recommends that you FIRST work out the perfect vision (setting the subject), but out of curiosity I still "see" it. There were 7 people. 3 from studying vision, 2nd invited a lady from our group of friends and 2 regulars of the club fees.
Ie 5 beginners.
Of 7 people the result I got 6 and one got the opposite result (the missing subject). Conditions of the experience delivered so that the error is very unlikely. Virtually eliminated. Teleport small coins before they are translated to the last, is written not only the amount but also the amount of each denomination (describe why below). However according to Denisov, the newcomers almost always work.(for the reason that the consciousness of self still does not resist, simply does not allow for the possibility that it is possible and does not "defense" for the reason that the first time he translates all the right attitude, and then have independent work). So.
Jokes from Denisova, so to tell stories about teleportation and the vagaries of the conflict model of the world and possibilities of consciousness.
- some, when it detects the appearance of "extra" subject, begins the real hysteria (collapses to the usual picture of the world).
- some changes in the number of coin retaining amounte a compromise of the conscious and subconscious, in terms of - the amount is the same. Only a detailed analysis of how much of what, allows you to detect the difference.
- some, not appear those items that are consciously ordered, and those are either "near" in meaning, or sit in the subconscious. So I got a completely wrong denominations of coins (like many), Denisov said that high school students had engaged in their first time fooling around with....condoms. Not on purpose.
- some effect extended to "after" classes.
Tune to the exact transfer of just the desired object is difficult, the example is the same pilinovsky wheel and any pilinovsky games. As I wrote in the wrong section, the subconscious is able to broadcast on psyleron EXACT replica of the reference signal (so the synctxt service determines what message to send). But we, to put it mildly are not always able to convince your subconscious to do the right (expected) effect and send conflicting signals (from the series "the wheel turn, but I don't believe you will turn" it to spin in the opposite expected direction). and so on.
After Denisov we tried the technique of teleportation in the group of 15 people, two it was that much worse than Denisova, because there is the beginners as it was broadcast (many years doing this) and then I (after a couple of their own samples - my level "complete newbie"
A third of those 15 after that for two weeks constantly appears everywhere coin of the value, that tried to teleport.
Recently, Denisov was one of our friend - two coins for the first time (on the vision of it before it went).
Why am I still so minutely painted. It is not only in Denisov. The stream States can be done not only by hands of the operator (in manual mode) and in General this is often not required, we have it all.
I have described everything in such detail to explain what possible "catch". This is not advertising, not a divorce, it does not take money for these classes, it makes no sense to someone tell stories etc.and etc.
All the examples that the above described ASD and Andrew - undoubtedly true.
The reason that we don't do all that in everyday practice everything and everywhere in the blocks created by the "official" picture a world where this possibility we have. The same Denisov, told me that when he switched from the topic of view on teleportation ( for the vision they have simply achieved all what he wanted), I began to notice everywhere spontaneous teleportation where people admit indirectly that opportunity through a loophole. For example she thought she was saying "brownie-brownie, hold-release" you can return the glasses in the bag and they're there, but before that she turned her standing at the cash register inside out there in addition to the purse, there was nothing....
These examples show that our household idea of what is possible and what is beyond reasonable and looks like nonsense, it limits us.
Ie, I brought them as an indicator of much more jokes than the separation or rupture of the items or their disappearance-appearance.<
By the way, the facts of spontaneous teleportation the native parlor - it is a really positive indicator of their work. Ie means in a cocoon removed some of the artificial blocks that prevent the manifestation of these possibilities.
From the position of modern physics, teleportation is possible, physicists just don't know how to implement it in the amount of more than one elementary particle, and our consciousness knows.
