Small offtopic.
Someone has a positive experience in the treatment of degenerative disc disease?
Complete cure, with restoration of the proper form and structure of the spine and the disappearance of the osteophytes?
Please share the information!
Re: Small off-topic.
You should start with a light warm-up arbekovskiy and combine it with the company possible options/means of influence on the state of the tissues, so the story goes that the same Nique, developing todikamp had big problems with back pain .... This is just one example, we are unlike Method, we live in the era of the Internet and can aggregate data and do not take one. A warm-up I first set because she is effective, and gives restoring mobility/circulation. Although the data on the same Todeco, saying that sometimes the tissue repair may be more important. I also heard evidence on the impact of technology Reich and other options the total work.
Collect to control a set of tests and the result with the removal of the diagnosis - not vskidku I do not remember exactly who did this, although back problems as a total factor total restoration took many.
thank, started for Norbekov.
where to find the camera of Reich, in Rostov-on-don, Krasnodar? the Internet is silent...
Александър
- Has thanked: 17 times
- Been thanked: 1 time
Alex. I don't know where to find the camera of Reich in Rostov, but Michael talked about a new electronic device, which is an analogue of the orgone accumulator. In addition, the instrument knows how much more
We made field tests of T2 with the correct chamber of the Reich (made by the method verified for the years of correct materials without use of aluminium and special harmonizing know-how).
The camera is not the same as T2, but the device the pros and the camera too. However in the current view camera is NOT siting in town! (no). So for example a well-known use cases in sanatoria/hospitals (centralized, there are.... the efficiency is high), but it's outside the city noise, in nature. In other words the camera can be set in a country house/cottage/in the village.
In the city you can bet if we make a slightly sovmestnuyu version with 2 version,where the city will be cleaned EMG could, otherwise, even the TV in the next room working gives an unpleasant and uncomfortable feelings in the camera!
however, due to the activation agny starting at all interesting effects - most of them hear the sound that normally can't see can't hear. Noise of HF band begins to penetrate into the auditory channel, it seems that the car is going, then the plane flies (many one effect, although the nearest riding machine was probably about 3km in the village apart from us experiencing the camera 3их - anyone! ) I'm quite sure that the "usual" noises are perceived by some of the phenomena going on the information level (conventionally and with humor - the car drove in the astral
Theoretically make a camera with "paging" static that will filter out the noise of the city - you can.
With 2 filters it so, but the effect from it has pros and cons in terms of comparison with camera. For compactness and efficiency - plus. The breadth of range - plus and minus. Camera gives a wide range and can be operated from the super-woofer (below Muladhara) to the HF range. And I2 can only do this by making the range of 2-4 chakras separate version. The most successful "touches the spot" and it fills all at the same time pushing info-noise of the city.
To combine in I2 all frequencies is technically difficult (although possible, but would be a semi-portable version).
The camera in "Valerino" version, collapsible, can be taken on the balcony or somewhere else on the boards put, although it makes sense in the used version. But the thing is not cheap, there materials 60-80T without the cost of running.
I2 will be about the same price range but in terms of final stoiomst and not the cost of materials. Although it is good to have this and that....
In terms of cheap homemade version - do in the country, not in town and without the use of aluminium/foam!!!!!! min cotton wool/stainless steel/stainless steel wool. The user will find in Valerinic the review for the study topic. Although not everything. The know-how of German, sorry, will remain so to speak where he's supposed to be (see know-how). But the work will be.
stainless steel wool, you can search Chinese. It is cheaper.<
People, in General, is a topic about children, but it is slightly wider - read carefully and repost who will fit.... enough problems... http://kolencev.livejournal.com/533589.html
Hello Michael. Advise that you can use to replenish energy in the body? Constantly feel lack of energy and sleep for 13 hours a day, I want to fix it. At me now is broadcast a Panacea (somewhere half a year already 5 mode), and wear your bracelet version 2.4. Maybe you need to add the gymnastics of Hermes, and the feeling that the energy just leave my body?
Michael, please tell me you something like "the Suit" (an improved version) are not going to release in the near future?
Hello. I want to buy a couple cards transfer, tell me how to keep the card after charging of objects (so they nothing more was charged)?
Hello,Галатея wrote:Hello. I want to buy a couple cards transfer, tell me how to keep the card after charging of objects (so they nothing more was charged)?
You asked this question here and got the answer: http://www.mindmachine.ru/forum/viewtop ... &start=625
Another question arose. A coating matrix applied to both sides of the sheet, mean the upper and lower part of the sheet?
No, enough with one, but if you want two by mistake will not be
Hello Michael. Could you give effective techniques for working with goals? Or to advise the author and the book where information about this subject to read?
Read the forum, there's plenty of information in the framework of free products (the same ALFAVIT homemade/commercial/VIP, the deck of the Cheshire cat together with a common theme solitaire Medici, SC/Stabilisator/Activator along with a discussion of the language of work/aspects/anchors etc/ Контекст2 and so on.... shorter discussions and tech - hosts, and there are plenty to combine and there is free and there is discussion of the correct wording. In short, the recommendation is to study the forums. Again (today the lady answered) PC as an amplifier of obviousness of a statement (can be done also free), all applicable for for more than.
Do not understand
what kind of assaults
All versions of PC that are in free access FULL. And they are mega effects in humans.
I was busy designers cocoon and activators (notice that and that is also free and super version is) because I didn't have time to upload videos from AMB and system for PCs, this requires digging in my laboratory computer hardware for taking them, and while I'm at the other end of the world....
No one's been deprived
available version PC more than working and they are quite FULL.
Here is a great freebie
If I did something it was only because virtually working around the clock and sometimes just do not have time to shove in your daily schedule. Regularly a lot of details/answers to questions/correspondences and much more including never born fine products simply pulls back on the principle of "Express". For example, in the last days of December I was forced to put in the status of urgent commercial activators and KK and I don't think you
people and then it is objectively necessary (not only in the form of DIY).
The PC will be. But patience has to be developed. You do where ever seen as much again as powerful and work artifacts in free homemade products ?
I even did a complete list can't remember....
Thank You, Michael!
To be honest I do not have time to digest new free products (Activator, designers, alphabet, ... the same solitaire, all is not yet done)
January is definitely the eyeballs will be
(and possibly February... for proper study and elaboration) Given the current situation in the country Your items are particularly relevant.
PC You so please, because this is a special product, not for nothing was stream PC 3 months is required before application to the club.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
АндрейКо wrote:same solitaire, all is not yet done
АндрейКо wrote:PC You so please, because this is a special product
-Have Pandora+PC /commercial/ and tried to sculpt the 'dot chain'Михаил_ wrote:available versions PC more than working and they are quite FULL.
Also made myself a crocheted bracelet with elastic* thread again and using the card for Pandora and the Pandora card+PC during tavazzani nodes /*stretch because when you stretch a bit- harvested resource in the node is released - I'm so laid during the creation of the bracelet and then banderovskie individuals embedded in nodes again nakupovat resource/.
In both cases when you add and action PC felt considerably strengthen this. And many, for one or another reason, prefer to use a homemade PC, so they want a stronger PC, I am not so simple... for freebies, and more.
Yes, I know that is not just for the freebies
well actually regarding the "sensitivity" of the commercial Pandora - it really is for those who work with a PC is more powerful, because there is a space of contact, for others it works not a bit weaker, but harder this contact to feel and consciously adjust accordingly more difficult. here is the same example with a photo in Peter... to which the operator who shot the photos seen in oochie as I worked the VIP Pandora with canals in the old cities of Europe, and the LM/buffer he pumped.
Michael,why this parasite generally there?Where he did come from,artificially planted?I want to know your enemy in the face,and know his weaknesses,to be able to stand up to him.Oh, how I like knowing that this parasite as a symbiote embedded in my body and mind and thoughts even perceive as your own.Михаил_ wrote:It is biological thing cohabiting with a person in one body and at the same time is able to mentally send him "thoughts" perceived as their own. and having a single consciousness "from above", similar but not identical system.Фиолет wrote:Михаил_ wrote:increase the flexibility of the world in this area, the probability of success will be a lot more, I think the anchor itself, and a picture of the world to put still - usually it most strongly resists as internal parasite. They rigidly follow in order to "Nini" and it is unknown who is stronger....
Michael,can you clarify about internal parasite?What do You mean?Mental programs?Or something else?There is the concept of "Guardian of the Threshold" and how much it interferes with a person alleged in each incarnation.
However, this is somewhat outside the reasonable topics of the forum. Seminarians are we talking about this and they are convinced purely experimental in its existence and the possibility of at least "prihlasit" its activity. By the way the shoutbox which stupidly and stubbornly fighting all sorts of the practice of stopping VD - partially (but not completely) from there. What is also there are lots of purely practical evidence. But people prefer to believe in fairy tales about the guardians, and consider themselves the masters of their bodies and minds, and those who give them the "esoteric knowledge" under different pretexts of "self-development" convenient to feed such nonsense and to believe in it sometimes convenient.
For the umpteenth time I will emphasize, does not make sense to talk about any "development" or "self-development" while the minimum are not included artificially selected gangster way functionality.
The theme of the parasite less fit the theme of "small off-topic" and partly overlaps with it, if you want about it that way.
The activity of this parasite can only mute or in the Arsenal of man there is something more powerful that will allow you to completely get rid of it or at least block?
And you can read more about the functionality of a man who gangster way selected.Include this functionality, and we say its pumping,well that is that muscle grew,giving her the load, in this analogy.
Intuitively understand what it was about,but still I would like specifics,so as not to distort the important info through the lens of their own beliefs and stereotypes.
It is not a simple curiosity,a desire to sort out the vital issues.Otherwise, really all efforts in vain samorazvitie.
Thank You Michael for the previous answer and for your attention.
The parasite is part of "the system" but not identical to it. Unfortunately today I only have limited time for very long answers. Judging by the fact that it represents Trichomonas/they are also the mycelium is the real cause of tissue aging and weight disorders, and the shape of the cells can mimic and even "dead" cells for the studies of the Bulgarian physicians have a debate devoid of the cell membrane (shell), due to the work of the same trichopolum, for example, which many use as a kind of prevention (for example in the micro-reading technique "lifeline"). The debate alive as soon as the body gets the nutrient medium.... if the environment is not to give, and give "bait" in the gastrointestinal tract or through the skin is excreted SLIME ( and remember than the throat treating your crippled ? sweet fatty milk for example - and it "IT is expectorated, and the throat becomes easier). in the body, creating uncomfortable conditions and facilitating the withdrawal of mucus can significantly weaken IT. And its influence. It will not weaken the impact on relatives and friends. They will replace
his twitching and other background inner beast, but the situation will change yet... in physiological terms it is the cause of improvements in a number of seriedade and this is not a conclusion of mucus (about which little is said in the topics sardenia) is the reason that other shit which comes out.
Bring the whole probably can, but hearing is better not to talk about.
Kseniya now or later will publish a set of links to critical reading, there is only a part of information, plus personal observations of our seminarians and their "experiments on myself", of course voluntary, just because of acquaintance with the subject of each decided for himself how to try to change the situation. All internal data showed that effective as a folk remedy, and much more.
Folk remedies:
- Ivany (but the secret of fermentation, the most effective version were destroyed twice! the current is not exactly informed willow and was considered the elixir of immortality and was twice strip the factory of its production - after the revolution and during WWII, look on YouTube there is a movie)
- cranberries (but don't eat much and it is not as effective, so cranberry is useful when the temperature of the disease, but doing it with even a drop of SUGAR, which feeds the parasite kills the value completely!).
is a very powerful tool, Pau-d'arco (Pau d'arco), in the form of dietary supplements-capsules, or BETTER in the form of chips of bark under the leaves. By the way that is it as far as I remember smoke shamans of the Amazon for "repelling bad spirits" before the shamanic ceremonies.
- ginger
- many types of hot peppers
- ASD (partial)
actually Vidalia mucus or when from acute or otherwise had a fever throughout the body and/or nose/eyes flowed bright the effect is just the fact that the parasite is affected.
But left a little complex analysis, it was in the beginning of the article the blogger Dmitry Mylnikov (cycle Pro Hydra) but in the end he gave a pullback likely under pressure from his own (the parasite I mean).
As I said I received from many dozens, probably even hundreds of people confirm this data and all of the pieces of scientific information and personal mental observation.
From what we cook, probably the best would be I2. Although many products are indirectly promoting. when you return to the mental control of the situation improving.
and the timing... don't know who but in view of mimicry in different forms and other features, apparently it is extremely high-tech development of some very advanced civilization, to throw in the worlds is in the doldrums. Or the result of the evolution of a being as a unified whole (like ant), one way or another - the essence of parasitic.
But on purely technical data, while the number of complexes in the world type of temple and other electrostatic machines (such as read blogger vladimir-pro - there with photos, analysis, evidence), worked - the voltage of static in the atmosphere was much higher than today and many types of therapy, not from the parasite but indirectly caused by it problems body, based just on this. Even in Japan the medical certified complex version worse than T2 and stupid (there 30kV between the head and the heels in the chandelier Chizhevskogo, who incidentally is about the same only too weakly efficient). T/e during the construction "medieval" buildings ( in quotes because in the history of the mess and believe the exact date is unknown) parasite could not work as of now, if there was instilled, perhaps not to all or was very weak.
Parasite benefits of the system, it makes people biorobots easily controlled, so they are in symbiosis. Some, such as Burislav Servest, I think that the system and the parasite is one thing, but to my knowledge it is not. The system was built some external people, and a parasite - a separate entity with slightly different interests.
About lost sposobnosti ? things like teleport or telepathy was not the result of a self-development as the norm. Read more this can be understood after familiarization with the topic of personal worlds.<
Folk remedies:
- ginger
- ASD (partial)
Not found more suitable topic
Today took place the webinar on the website webinar.ru
Maybe someone could go to him with wm8.1
The problem as I understand it that data the background no support for Adobe flash...
Maybe someone already won?
Please if you know the solution to share
(tried third party but so far without success)...
Time for me to tell a story
Stop/control VD, has always been for me a cherished goal to which I was unable to come. All attempts ended in either fatigue from prolonged concentration, or headache.
And once, I made my first Stabilizer
And for such things as stop/control VD, the stub was just a magic wand.
I put about 10-12 anchors on different aspects. Of course with fuses: "the most auspicious and harmonious way......."
And literally a month was almost unbelievable series of events.
1) First I came across the Council of Andrey Patrushev about the Sedona method and with the help of this method, you can achieve the desired conditions.
2) the Wife with children has left to his mother for a few weeks and the opportunity to practice was perfect.
3) With some fright, I decided to undergo fasting for Marv Ohanian. It's not really starvation, more diet. Just don't eat and drink every hour 250ml of the decoction of herbs with lemon juice and 2 tablespoons of honey.
All these days I relaxed, practiced Sedona, letting go of negative emotions. Technique to me this seemed a little stupid and not effective.
And on the 7th day of fasting I vzbrendili in the head sit down to meditate. As always, focus was hard, there were a bunch of left-wing thoughts, emotions. But at some point I decided to apply the Sedona meditation, focusing on the emotion and fully accept it. And as soon as I got it swept a wave of peace of mind. Then the next thought/emotion was again taken and transformed into a powerful wave of peace. So, I have a few minutes reached such a deep state of meditation that if you add up all the years of trying they collectively and some were not. I dissolved. Left only a sensitive awareness and bliss. After this meditation I stopped believing in God
Then it was interesting. It turned out that this method works and with open eyes
and absolutely not effortless. On the contrary, as soon as there is the slightest effort, it should immediately be let go. I realized that the key moment to stop VD is the lack of effort and full acceptance of the present moment.
Sedona method says that from the "freedom" we are separated by three desires: the desire to control (the most frequent in my experience), the desire for approval desire for security. When I moved from working with thoughts and emotions to the adoption/melting desires, the effect surpassed all expectations.
For 5 minutes while I walked from home to work, I was immersed to such an extent that they had to pass work and to go further, in order to enjoy fully the peace of mind and an incredibly blissful state.
Then I started to stop VD at work
Only sometimes there was a confusion with the speech, when I simply forgot how to talk
So much more to say about how it was magical, but that's not the point.
Lester Levenson gave us the Sedona method when he realized that the path to freedom lies through the acceptance and lack of effort, went into seclusion for 3 months in the hotel and almost never came out. Day and night, he was in a state of freedom, until this state became 100% permanent.
He was able to retire 3 months. And it gave the opportunity to reshape his brain to a completely different mode of consciousness. The regime of freedom.
I told the whole story, for a few questions that I'd like to ask Michael.
Initially the post above about the parasite that caused me a kind of protest. Because my personal opinion in this matter was somewhat different. All 3 desires of the human EGO separated us from freedom. And then I remembered that I have often wondered why this is the EGO and what it is all about. And here, I heard about the bandit software and puzzle may have developed.
However, it turns out, one can almost effortlessly be freed from the parasite? It is sufficient only to retire for a while. And what then happens with this parasite? Because in my case, the parasite came back, because I interrupted the practice, and at Leicester he died it turns out?
there is evidence that in option when meshing a certain parasite leaves the body (dies, almost teleports) as inanimate and not an interesting object, but may return.
there is also evidence that people are too interested in all sorts of States of rest and not work, from the field of Buddhism and his ilk, grow a new species of the parasite, able to think independently and not depend on a Central being, the uterus, going with their death (but not earlier) somewhere in other worlds....
Stop VD is good, never haven't worked on it and never (VD) not bothered, not see the talk, so nothing like to stop. Can it be called if it is artificially not to do - he immediately stops. Although the parasite infection is still alive, this just know, do not know on the level of control, but biologically alive.
When you stop VD's important to stay creatively manifested in the world, not to hang, then everything is OK.
While speech and interaction with others will not prevent to continue remains in stop mode for VD, though there are overlays that personal autopilot with the conversation and the interlocutor happy, but because of the low value to the conversation then I don't remember what it said then me (and them especially).
Directly stop VD not mean that the parasite is dead. And does not mean that control is acquired. And Sedona (method) is just a social stamp suitable for most; I know people are spared from the three "saganowski" desires
fully
Good mages. This does not mean that they are in some kind of super-state are, they simply have no social framework to keep a man in a cage (Sedona about it) and some of your creative goals and experiments. They are very active in all
and how to say never forget
they simply have, as if to say something... .the motivation of the demiurge and not socialinclusion biorobot. Im interested in the process
as a kind of game. On safety and control while out of the question, and approval, and a fortiori
And do not put the identity between the inner shoutbox and a parasite. It is from:
- admission motivational teams in the top podlucky
the parasite
when you stop VD and podlucky not going away (and NOT your OWN motivation it continues to come and be treated as our OWN and their desires).
and the parasite will not be obliged to go. At long zamykanie/isolation from the world he might run considering the body dead, but not the fact. And its manifestations is not only a shoutbox.
By the way the parasite is not only a serious biological problem in the body. There is, but it is most strongly influencing processes in the body. On the "magic" ability also strongly affects cell metabolism and the work of MAO, so they run when taking Mao-inhibitors for more power. But not only again, t/e/ cannot be considered a one-sided process. It's complicated and confusing.
the parasite
