Small offtopic.
Lily, Hey, you want some? will lie, fonit in the office)
Re: Small off-topic.
Alex. Its of good enough, the truth slowly stand .....put in a prominent place, maybe someone is interested,so get used to as it is a pity other people's works. Although a couple of books I had to burn - very bad literature , went on the occasion of such an approval , and began to read .....in General prakticheskie things by ditching all living things, and is filed under "sauce" and fluffy white mages.
- Has thanked: 1 time
- Been thanked: 182 times
But the basic is the Declaration of one of the teachings of the "true" and other malware.алекс. wrote:target destruction is somewhat different than in the 14 century.
nifiga do not mind: benefit from them for me personally, zero, in the same bog to get more there is no desire, and the apartment they distort.
in a prominent place to put this, too, has no desire - that these passers-by is bad for me?
the basis is not so much country, how many products influence of this doctrine on the person. which is the very doctrine is not relevant and does not want to have.
Burn is a very good option, you can still see the ashes in running water. Classics so to say
You can even further to say that the connection with the egregore of the destroy action, it will be a mini-ritual, then.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
At this level of my understanding I would call burning too primitive if properly done work - even burn, at least in the earth buried, at least for running water - the material artifacts already done its work and can even be neglected. Therefore, in the past century, except for 'burning knowledge', working skilled professionals have over the people themselves /the Inquisition is an example/.
Absolutely adequate operating procedure.
If the artifact is narrow and quite dangerous it there is no need the best way to save is to burn when he done their job.
If it is "agregately artifact" from this artifact, to books/paper symbol is also burning very well.
The magic of a well-known technique of human exposure is the lining of the artifact in the house, operates reliably, and to bypass defenses. In fact, and was used widely. Method in the Scandinavian epos is described repeatedly. But there is about magical things, but the things associated with the word, with which no conscious desire to communicate better at home to not store at all. Later they can connection with the egregore of a strong fixed, even if the person nafig not necessary. With all the ensuing consequences.
When I HAE disconnected I have in the house sausage people on this subject, no reason. Not even fans of Christian Agra. Couldn't understand what was going on, and then found the package with the religious souvenir and brochures that I gave someone, and I'm in the closet, it was abandoned. He was the source. When escaped, the circus had stopped. But there is all sorts of my friends were trying to present things from HAE , is very intense. But the lesson I took home and not dragged. Hmm, cool, aggregor tried to implement a classical scheme of communication via the lining paraphernalia. Finally everything stopped when found efficient procedure to finally pass out.
Positivity can be a relative concept. Well, an example: if you made an artifact (classically magical runes for example, BG shny) to clear the room from any negative influences and entities it is positive, in a strictly declared time. While there is muck and it cleans. And if you haven't already, strip the through holes of the owners of the apartment. Such thing should take and burn after work.
Like razor, do you have someone beautiful to do, but you can not, if there ear cut off for example.
ps But it's not about Besnik things we are talking of course. Although for example the same card N 0.5 it is recommended to burn if it becomes bad Really it would seem purely positive thing, but if too intense the work included, apparently someone is not very positive can be, if not to dispense use.
As for egregorial bindings are physical, so they can for the owner and positive in his conscious evaluation. While the person wishes to remain adept and functionary of Agra, the artifact provides a steady connection. And if the picture of the world differs from egregorial, the goal is the other, and a similar thing at home somewhere gathering dust, it would likewise be a connection to support. But the egregore will be run through the communication algorithms that would be modulating the human condition, sobytijnye the number of people popavshih in the "affected area" to return the lost sheep to the right path. Tough, clumsy. Is positivity the there for a person, and for the egregore quite justifiable procedure.
- Иван Славов
Gelios, thoughts material...
The state has the necessary institutional response (just as long as they do not climb in this area, although I'm more for REASONABLE REGULATION!), they are simply busy with his other work. There are a lot of good people by the way. Say for example in Canada, the process of such control is made more lively and interactive, described the man living there, he practices, and is familiar not by hearsay with the procedures for the recruitment of staff and functioning of the corresponding services.
And the State has in the Law a number of directives on combating various subversive activities.
If some literature is called "extremist" or in other way dangerous, it is not allowed to distribute.
Recently, the President brought out the list of officially magical (official representatives of the denominations, whose literature was part of the system they podagricomela assemblies for example). This is CORRECT!
And then wrote about Alex (about to burn") - is not literature, it is the carrier of the virus or the drug. And the text there has no value, it is possible with a strong desire even as Pushkin so to "execute" that actually "owner" zafonic....
So Lily wrote that hizbullahs good (gave the other to bite on ?
) such fonyaschih.
I remember very well how some guys almost 20 years ago put me on the table at a public event brochure which can be easily to glue the fins as arsenic, even in good health - can read not long
What does the true teachings ? this is pure "information technologies" - not only peace.
So my cousin, a good practitioner with great experience, for fun tried to "attemperate" one Levashova (thus the very late in some cases said some smart things like, not so crooked....just a one-sided Malek), so no avail - there is SUCH great handling, well he had a school that was, as I understand it, more internal, then it is "out of control".... It seems to me that if to speak about the complete annulment of influences are changing the Outlook and perception of people say no you don't, then at least use particularly harsh methods to "capture" the need to regulate and it is not the fires of the Inquisition and the natural mechanisms of protection against any type of TERRORISM. They are inevitable in a changing world.
It is obvious that self-help yourself like washing your hands after contact with dirty or rotten - appropriate.
You just need to understand that the text or photo or video can be just a carrier of the "virus" though not biological.
PS Andrew, I kindly request not to post in my branches message with a bunch of attachments topic in the form of pictures/cartoons and so on. Erase messages from the website owner always not convenient. I'm sorry. It's not a gazebo, yeah?
Михаил_ wrote:Here and Lily wrote that hizbullahs good (gave the other to bite on ? ) such fonyaschih.I remember very well how some guys almost 20 years ago put me on the table at a public event brochure which can be easily to glue the fins as arsenic, even in good health
Read carefully , I wrote about the books that I was not already interesting , and about those that could hurt someone, I destroyed-BURNED! They are really harmful , they are to glue the fins can the whole family (and chelovecheski in the face) , looking at what ambitious hands.
And I stand Krasilnikova , Medvedev, Louise hay, Just Kryon , and different in the key books. But a lot of things. What's available in any bookstore.
Sorry, actually read diagonally. Very loaded at this difficult time and the forum is how people need, but a residual phenomenon.
Unfortunately things are not less dangerous but more efficiently "in disguise".
If it is me - I'm not published, although he wrote in the message.Михаил_ wrote: PS Andrew, I kindly request not to post in my branches message with a bunch of attachments topic in the form of pictures/cartoons and so on. Erase messages from the website owner always not convenient. I'm sorry. It's not a gazebo, yeah?
No, just another
Everything is OK
I have a question. If a particular person is intensely in his life uses all sorts of elephants, pendants in the form of a eyes, icons on walls, and so forth - is the use of egregores?
That the majority of egregors in varying degrees, use people I know.
Just I live in an apartment where a lot of this. And while I felt that cool. Well, there is. But this morning I was inspired (maybe test stream) to remove the prominent places (but not destroy all that is not mine).
On the forum of the author of the broadcast this was discussed - about the fact that if there is a thing relating to egregor, it greatly affects everyone, no matter how you feel about this egregore.
actually:
1) Yes, could affect test stream (later I will describe why is it such a funny moment).
2) Yes, it affects many things, regardless of "prohlednete" your relationship, because it can contain elements-a program for automatic "gear" has in fact fix his gaze "passing by", and it is connected with the outflow of energy, and redistribution in General AREAS of PERCEPTION. Because the capture of attention - there is a filter on perception ....
Or you can say so(based on the positions of a number of egregorial or podagricomela systems) - why MAKE people happy - enough that he himself thought of himself as such.... In other words, if the seizure of the areas of perception and motivation (egregorial podlucky) is due to the fixation of the gaze on the SYMBOL associated with a specific egregor/school/movement/cult, then this is often enough to move the very motivation and perception of the world so that people felt like it was inside this community as comfortable as possible in relation to the feeling of being outside thereof.
And the surprises can be in unexpected places.
In such cases, I can advise operatsinnoy the box with the software of shielding (you can write in less than a couple of minutes) and to blame it fonyaschih...Астероид wrote: But this morning I was inspired (maybe test stream) to remove the prominent places (but not destroy all that is not mine).
You can read more about the program and the shielding in your performance?АндрейКо wrote:In such cases can advise operatsinnoy the box with the software of shielding (you can write in less than a couple of minutes) and to blame it fonyaschih...
On one such fonyaschih gregorianum subject for my experiment, I drew a matrix panacea, gave the command zablocie lasciviousness and format.
The item was dusty, I finger in the dust matrix was drawn. But to erase her, no one thought two years. In his premises any such option and inconspicuous.
I can say that a very successful experience, since the subject ceased to work for the intended purpose.
And that was a very old icon, which looks like mirotochit besides when the.
ps you can then without the box
Gelios, SPS. Sobssno, questions are asked in the context of Hae, because in the house there are all sorts of different icons, etc., the ratio of parallel, keep standing, but the four-soars, I feel that one of the "parallel" relationship in this case is not enough, there is an outflow and sickly. Looking for a solution. Hence, the issues. I will be glad to listen to all opinions
That's regarding the items in the house I have a very simple mind.
Quite long at one point I posobirat all religious items from his home and disposed of. And I think it's very useful. So to say the benefits are particularly visible became in consequence, when compared "before and after". Even if I had them on my cleaned out at zero, using the methods of mental work, the "magical infrastructure" on the gizmos eventually recovered. And to me the circus is tired. Well, because the objects themselves are these are "graphic keys" to the egregious, and stupid, for General use. The idea of it would not have recovered if it the head is not identified as a "cult object", and for this yourself need a head clean to very same perception every time I start the recovery. But worth it in my opinion not worth it.
ps so that matrix to draw it I'm not-his room is bothered. As for myself, I think the easier options are more appropriate.
To give someone is not an option was because it's my responsibility yourself for the fact that I had a hand in the introduction of the man in egy. needle.
