Bracelets Life
you can combine anything with anything, the question is in what order and how your condition inside...
- ПавелРозов
Re: The Bracelets Of Life
Prompt, and how to interact 2.2 OS+ from products of other manufacturers? Such as the FACE, Atlantis..
Why not check it out?
Yes way.ПавелРозов wrote:Tell me, and how it communicates OS 2.2+ with products from other manufacturers? Such as the FACE, Atlantis..
change You (2.2) and the context of the world around (fairing and stoppage) if the other product in this context continue to log that can normally work, then they will work properly. My products do not interact with these. That You interact with them.
You can stay in the "window" where you think or subconsciously feel such interaction is necessary and / or useful, or fall out of this window depends on You. From the product is not affected in any way.
Michael, less than a month wear BJ OS 2.2+, this time jingling bracelet acquired a concave shape, it is obvious the tree was shriveled and deformed
if the process continues, the links will simply break down, therefore the question: is it possible to replace with another bracelet (the best of Eben, if any) with my surcharge, or better quality of the workpiece.
I apologize if wrote not to that branch.
All parts are standard and the material one in the party for many months and usually one
If there is something happening - it is more individually yours.
Tree water - I bathe for hours in the sea and in the rivers, the lakes, too.
Broken links - not seen.
That's when the problem - then we'll see.
I only saw overload breakage (not a warranty case by the way).
Yes - all wood is purchased from a large supplier in the state of the standard moisture under the wax and usually from each "log" goes from 40 to 100 sets.
More complaints (besides your) that is not audible....
So if something's going on - I think it is your individual process.
Thought this was, thanks for the reply.
On the big Panacea is also slightly arched links out - a maximum of 1.5 mm when put on a flat surface. Then the process stopped - about 5 months after the beginning socks (though I wash with ASD, and with soda and flamed on the hand bracelet to redness...) of AMB at all surprising as remained intact... - after such mechanical effects (e.g. falling on the asphalt on his procarcinogen - only a few lines on the 1st link... the plastic would totally smashed...)НИККТО wrote:If something happens - it is more individually yours.
Нина Жемчуг
Michael, tell me, please. I bought 4 2.2 bracelet for mom that are trying to get out of egregore of diseases. How best to wear: 2 hands, 2 feet or better at the 2 on each hand? Is it possible for me to call on her bracelet module "Timer healer"?
Let me answer the question (though not Michael):Нина Жемчуг wrote:Michael, tell me, please. I bought 4 2.2 bracelet for mom that are trying to get out of egregore of diseases. How best to wear: 2 hands, 2 feet or better at the 2 on each hand? Is it possible for me to call on her bracelet module "Timer healer"?
Wearing best 2 on hands 2 on the feet (because it is unknown what state cocoon)
If it is too cool - I would start with worn on 2 hands.
If you gave mum bracelets, and can call on her wristband modules (I do), but mom should at least admit the possibility (to agree).
PS - this is just a personal opinion.
Нина Жемчуг
Thank you very much!АндрейКо wrote:Let me answer the question (though not Michael):Нина Жемчуг wrote:Michael, tell me, please. I bought 4 2.2 bracelet for mom that are trying to get out of egregore of diseases. How best to wear: 2 hands, 2 feet or better at the 2 on each hand? Is it possible for me to call on her bracelet module "Timer healer"?
Hello Michael. Tell me what you'll be BZ BJ 2.7-2.8? I realized that they both work with energy. The difference in the washing of the cocoon energy? BJ 2.7 energizes the whole cocoon, and BJ 2.8 only the upper chakras (I want all the chakras to positivity)? Some of these bracelets it is better to buy a novice user? My energy is weak so I think that it is better, but it does not can choose
With Respect
There is a whole separate issue the difference between the versions 2.7 and 2.8.
Beginner to start with 2.7.
Thank you
Michael the fact that I have several years of drink and antidepressants now because of them I have a severe drop in energy (the last six months just crawling). That's why I asked about the Bracelets Life 2.7 and 2.8. Branch about their differences read and came to the conclusion that I probably them together should be worn (uniform washing of the cocoon from the top and bottom). Can I wear these bracelets together? Will carry the roof completely? Maybe stream of these bracelets to take? Please tell me. Hurt yourself do not want, and in this state to live no strength. Maybe you will advise something else! I'll wait for the answer. With Respect
Galatea, I Think for You a great option: purchase the physical media a pair of 2.2, for example, on each hand, so to speak to have the feeling of being on TV/in a cocoon stream where without it)) It works ,as mentioned, from the inside of the cocoon and powerful enough. Do not jump to 2.7 and especially 2.8 (Michael mentioned that the 2.8 now it is better not to use for certain reasons). Not a fix energy as a priority, and the recovery of the body and the resulting processes) by the Way, you can try, even necessary, cleaning with sodium thiosulphate, well cleaned the body and eliminated chemicals deposited from the use of various drugs.
Galatea, 2.8 is washing the upper chakras for their active work. And if you have imbalances in you ( leveling which requires the use of anti-depressants) it is a high probability that it will be even worse. It's like nitro fill in an old battered car that tries capricious, not always working, not always goes there where it is necessary for the driver. In this case, the Buda? Yes, maybe you can very quickly get to where were going. but it's a risk and a chance at all to reach are not great, most likely will find yourself in a ditch. I think a similar analogy is exaggerated and with older bracelets. As well as all of your thoughts and feelings will begin to materialize? Yet be saved from depression anti depressants and then?
First I think you need to repair the car, adjust steering system, the brakes can be checked, the power supply system to upgrade, and then tune?
All purely my speculation and please excuse me and correct if I'm wrong.
Thank you all for the advice. What do you think, and if you take one bracelet 2.2 and Panacea will not harm yourself?
Galatea, I think this is what the doctor ordered.
Still stream well:)
Hello,
How can we apply BJ a man who has phantom pain from an amputated limb?
Amputation was two weeks ago. He's a young guy with a strong spirit and is a Panacea for 5 months. I gave him after the incident and БЖ1.0.
He had already ordered the unconscious mind to use all its capabilities
and all the possibilities of bracelet for getting rid of phantom pain.
Can we do more?
Thanks in advance.
Can we do more?
Thanks in advance.
process your photo through the generator
Elian, and what stream do you recommend? Michael please answer my question. With Respect
Your question has already answered everything, why again? take OS 2.2+ 2.2 or just 2.2 or a couple or a couple OS 2.2+ 2.2 or one and panacea - to choose from.
2.8 You do not need.
2.7 - not effective - You need to recover and just 2.7 you hit the threshold of your perception (it will also recover but not as active as 2.2 or panacea).
Streams are of the same name. It's kind of obvious....
Michael_ How the combined use of BJ and broadcasts with holotropic breathing (HD)-will they interfere with each other? And would recommend You to practice the XA?
