If the consciousness has changed, how the body has changed. As it looks? Reptilianos consciousness somehow manifested in the physical body?Аура wrote: ↑Sat Feb 09, 2019 1:25For example, in one of my trips to China happened to see a man, Chinese masters do not know exactly what practices...really extending my life to 209 years, but very specific ways, namely, by changing the frequency of cells on the frequency of reptiles. Of course, that consciousness changed accordingly, but the fact remains that people have lived 209 years and judging by the observations, to grow old and die is not going to.
The rejuvenation practice, and more practice
Our project started in two months ago. The results for the two months to sum up I will not let you down three in a month. Three months can already be seen as a cycle or part cycle will be seen.
Over the last week. As always, it was difficult. It is difficult to hold in the selected rhythm, but I try. Discipline is not enough, Yes. All week there are different symptoms of diseases of childhood, tonsillitis, otitis media, and a couple of not very pleasant conditions. The symptoms are mild, go for 2-3 days without treatment. It seems that all is purification. Continue to study anatomy systems of the body, stuck on the endocrine, working with the musculoskeletal system, spine, stomach. Physical condition in General is very uncomfortable, although nothing specifically annoying. Can, managed to bring the body out of balance? Work on.
And you can still recipes of energotaktika for tendons and muscles
Thanks for the great recipe Maki, lay capsules, found, drank and really had a greater impact in winter than in autumn. Already in kilograms you can take
Delilahlet's Protocol. Suddenly this is another puzzle game called "rejuvenation"
[/quote]
https://nestarenie.ru/bolezn-altsgeymera.html
Sweetheart this I say to You, Protocol on Alzheimer's.
[/quote]
Began tenth week. I'm confused. With the body still a lot of work to the cell must somehow "get" and the situation persistently sends to work with the brain. Examine information and promote almost simultaneously the body and the brain need to be, but as I can find the time and strength? I do not know. Looking for opportunities.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Oh, a change of perception of the consciousness registers at once. Perception depends on the consciousness, and as it is the person recorded, the change of perception is perceived clearly. But for others obvious but the effects change perception, there are certain actions and reactions, if any, the mere change of perception is perceived by others either not at all or logged in the inner circle PI and/or sensitive people as weak change.
Aura
Well done noticing. Rainbow, You have all the attention to the qualitative, from birth (not very noticeable) or developed. Anyway, good that noticed the long waited for someone to ask this question. Rejuvenation programs are loaded to the SP as well as other programs with the intention.
Aura
Of course. The behavior is the hmm reptilian) This was one example of the possibilities of consciousness as unusual and extreme influence of consciousness on the physical body, not a technique the topic in any case
To raise energy and securing it for long time , enough for two handfuls of wood ash to dissolve in the bath, can be a little more, depends on volume of the bath, In the cold time of the year once in 3 months to repeat, in a warm dostaochno once in six months. And no Smoking-snuff-pitino poison)))!
Aura
Capsules probably quite small in volume and expensive. If you have an interest to order in packages of 1 kg, you can throw in a personal Peruvian contacts who send anywhere in the world, but customs may have questions...
Aura
Muscle range of plant energy is much wider, practically every other known and available, like Goji berries, ginseng, shatavari, yohimbe fill the muscular system, tendons harder to feed externally, except that cat's claw can have a noticeable effect.
About cat's claw in the external power supply is also worth mentioning, look up information in the Internet to query it a lot, however, there is an important system of reception, that is just to drink as pills several times a week is not enough.
Capsules probably quite small in volume and expensive. If you have an interest to order in packs of 0,5 - 1 kg, you can throw in a personal Peruvian contacts who send anywhere in the world, but customs may have questions...
And what of the cage? In some way we can rejuvenate very simple and unpretentious ways, for example, burning lipofuscin - intracellular junk (already have method).
Also can rejuvenate almost the same method almost all the types of stem kolok. It is absolutely proven things and very easy practice - anyone can, without any tricks and preparations ))).
But really need to rejuvenate the matrix (intercellular space) . At a young matrix cells automatically young. And this was also proven true only in vitro.
Studies were conducted very serious on all these topics. The results are registered on a very serious level.
Here is the matrix we rejuvenate any methods can not yet. Can only your. Tricky. But did it to someone in practice? The big question. Indra Devi lived to be 102 years old (I'm talking about the documented proven cases of longevity). But it was already an old woman. Alas. Or are you the pioneers?
Well, thank you, skinte please.
Bought and thrown away (the expiration date was over)-I didn't know how to take).
Mack with a cat's claw to be connected together? (if so, in what proportions, and the receive circuit).
P. S. I'm sorry, so many questions. One thing the Internet, another recipe and recommendation (there is a certain "transfer" experience. Approximately came into my life mate (that's made with milk and honey and drink to this day), etc.
If you order from local only 1 kg Maca, then with shipping it gets up around 6 Tr (this is for those who mentally isn't ready for that price for the original), it is clear that the volume the price will change, but until the first trial package is not successful the customs of the Russian Federation, order no longer makes sense.
May be makes sense in parallel with the powder to order seeds and grow themselves.
Customs - probably better to order in the bulbs, though you can see what's in the box, with the powder exactly headaches can not be avoided.
In Novokuznetsk district sell 100 adapted for the middle band of seeds for 200p
"Growing poppies in South America, has spread widely since the time of the Conquest, however, had declined over time."
French Agency of sanitary security is worried about the possibility of keeping potential mutagenic components.
The farther into the forest, the closer got out.
Gotu Kola and Bacopa - very similar in its properties and appearance, so they are often confused, hence the name they have the same -"Brami", although the Botanical (Latin) names are different.
Used mainly as a tonic for the brain, suitable for rejuvenation.
It - is certainly a good rejuvenating effect.
I would add to these Indian herbs be sure Guduchi (aka Gila, aka Amrita / Amrut - "nectar of the gods") is a rejuvenating effect.
This also added to the Ashwagandha, Haritaki and Bibhitaki.
p.s. He consumed all of these Indian grass, and many others. Guduchi (Amrit) - for me, the most important of them.
God, is it as simple as
Two years in a row, I created the intention, wished, dreamed, etc that I had conditions for the development and here I read and could not believe my eyes, they are!!!
I imagined "ideal conditions", perhaps moving to Moscow for regular practices, etc. But it's like about 20 years ago-go to India and be enlightened-not brightened:) the Case for discipline and system:) need It and energy and at the software level. But I don't have a clue how to use discipline and system in the long term for linking the operator-program/energy -the result. But experience how to do-plenty
Can the system theme and discipline already announced? While the branch of GAIP read.
P. S. but maybe I'm rushing things.
LONWhen I read about the energy supply, remember that the strength of any of the plants energy is linked to the place of growth. Ie as I understand it is as resonance with the place of power or his product. I mean that to grow probably does not make sense.
I am familiar with this point of view.
In any case, buy seeds adapted..look..there is no way.
Later Maca tubers will try to order.
Interestingly, during this time, that I'm on it, I theoretically/non-verbal know/have learned to know how to use sexual energy for development, but the entrance to practice I is little available.
My conceptual field has expanded very much in recent times, unable to declare with understanding and awareness, but to actually take off and start to change yourself inside forces can not find.
You know, when the Aura says that we are in constant deficit of sexual energy
Found here clarifying remark as to get out of the loop:
Аура wrote: ↑Thu Mar 24, 2016 14:15Free energy - this is our reality as a person, which can be a gift or a burden, depending on that it either is embedded or burned. Stored energy as such is a natural resource for the programs to work VPU, but is unable to start the work of consciousness, but the work of consciousness leads to accumulation and increased free energy. Such is coiled a vicious cycle where the exception paths of burning - is the first step. Work free energy can also be called creative life and life in art.
I want to try to work on the level of consciousness. The consciousness of my I "agree" with the consciousness of the cells.
It is time to begin to work with consciousness. Yes, only ten weeks later, I was "ripe" for such work. What hurt me before, because I know I can. To be honest, I'm sorry to leave the comfortable picture of the world, which is now. It is a pity, to tears. What is now clear and stable. And what happens if things change? Who knows? I have lost many things and many on the road and sincerely afraid of losing what you have now and those who are close. It's the best thing in my life. I will change and if they change in no time, I lose it. Is it worth my eternal youth such losses? Think. And we continue.Аура wrote: ↑Thu Jan 31, 2019 22:48In purely intellectual perception the question arises, what could be easier, hang your photo in his youth, create a picture of the world of youth, and here we are young? But somehow this method has a very limited level of self-hypnosis because they are working models of interpretation. You can hang a picture, but to alter the model?
