RESONANCES - settings on Energy sources.
Lone everything is fine with me,at first hung for a day,asked yourself how to start?and then I covered a bad mood,asked myself to do it joyful mood,the head is clean and brisk,the next day the mood is good condition chipper.On the physical plane,first day stopped digestion,not a pleasant feeling,after which the stomach has restarted,I felt it was a toothache,gave him the command not to hurt that he is healthy,the tooth was held for 5 minutes.Really now you can manage,you want more awareness 1000-fold increase .
Re: testing the products of technology SEM.
So, on Monday, the feeling that the selected resonances were necessary in an environment where they can prove their worth. Mean a day off at home, it was hard to track a movement of energy and its effects (e.g., resonance Big BOS, the Sword of War or Apollo) , but at work today, such effects I with difficulty, but was able to note. These include a slightly higher awareness (despite the lack of sleep), confidence, self-control, steady state, a more pronounced manifestation of leadership.
Good morning everyone!
Body quietly today, no gravity, no sense of multidimensionality. Went to the first study.
Resonance “Icaros” - chose it's not a coincidence, it seemed that my heart closed, I can not forgive those who once hurt me or hurt, just move away or communicate only within the bounds of social decency. It is understood that all right with my heart. Everything works well, all right. The reaction suspension is a natural protective reaction. And nobody needs to forgive and accept what the human mind does not require it, and with consciousness, a controlled entity of the Inferno, really, it is better to contact seldom or no contact at all.
I really wanted to see the energy of "Ikaros", but it is understood that in such a tight event row, in which they now live, it will fail, you need a state of complete relaxation and immersion in itself, which at the moment is impossible for me.
Resonance “Icaros" can be disabled. All a good day.
Дмитрий Никитин
- Has thanked: 10 times
- Been thanked: 10 times
Greetings to all! Becomes easier. Apparently energy began to ripen. Oh, and the right was the Aura that the resonances are better not to be greedy. In the other as well as with all the other programs CHEM. The ideal option would be to try the resonances one by one. To take the "load" gradually.
I haven't had heartburn, and then every day... From which we can conclude that some of the resonances acidify the body. Power returning to me, but it seems in problematic areas of the body like the heaviness ( leaden) , which indicates a need to engage the neck, stomach
shoulders.
And yet I need to mute the resonance of "Change" maybe it's because of him I was so pressed.... Disconnect the pzhl.
Another question arose, why the outcry of "Naked" is called "Naked"?
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Дмитрий Никитин wrote:it seems that this set of resonances ( or some of them) are pushing to go beyond any established stereotypes, actions , habits. Push "beyond" is nice, but the strength to come out "for" still not enough. Not "ripe".
Most likely. Energy changes applies to "intelligent" energy, which of old was above. The energy Change does not as such pronounced qualities, is managed and directed by conscious intention change in different processes, so can be easy, provided of operating energy. Management (operating) energy Changes is by tracking and following. If the first is not a problem with the second is usually harder. The following mainly involves non-resistance, because the body (and brain) are in power saving mode, and changes suggest brain activity as a result of the restructuring of neural connections. In other words, the energy of change runs into blocks in the energy structure and trying to clean it, and the stronger the resistance, the stronger the block. Energy is important to the work required for vector movement called "development". For testing it would be interesting to learn to operate at least one intelligent energy. As mentioned above, if the resonance is not immediately stopped, not worth it to immediately switch to another. While switched, the resonance Changes to a two.Дмитрий Никитин wrote:And still I need to disable the resonance of "Change" maybe it's because of him I was so pressed.... Disconnect the pzhl.
There are semantic names resonances, and there is a vibration (sometimes coinciding with sense). The vibrational name is similar to the vibratory signature, in the audio encoding. In fact, the vibrational signature of the person can also be a personal mantra...but more on that later. In this case, "naked" this vibration, and semantic name. With vibration sound of the name (you can speak as loud and to myself) you can tune in to the energy source. The meaning is not "half-poluzmeya," and the ancient Sanskrit meaning - Spirit (later value - a thought in time). It was believed that a spiritual man is a man whose Naga (Spirit) is in the Body. Although in Hinduism, the serpent symbolizes the Kundalini energy, so it is possible both values are related, but not correctly interpreted now.<Дмитрий Никитин wrote:Another question arose, why the outcry of "Naked" is called "Naked"?
Aura
The fact that the programs and sources of energy - different things. The program works in the integral field of the operator, the chain software layer and energy - physical. That is, when I say "energy to work", then the PI operator must be an information resource. Of course, the division is conditional, for example, smart resonances are somewhere at the intersection between energy and software level.Анька wrote:Aura Good time of day! And neocolony II not planned replenishment of these prog? Very interested in names and reviews
Aura
Had the confirmation, the helmet is connected, on the C grade, the Creator, too.rel wrote:apparently, the "Helmet" so it works.. although the regime familiar.. like tvorcheskoi from, apparently, "Creator", aiming to manifest everywhere and in the rows reporting..)
Many are still at the first stage cleaned)rel wrote: Cleansing/tin is not observed
After You described the experiment and its theoretical justification,
it was interesting to know your vibrational signature as a mantra..
if possible, lift everything up 6) I'm still sensitive to wood)
but I'm talking about the movement of energies, etc. - if efficiency productivity..
something these things I noticeable, and very glad that it was only three!! you-hoo! it's cool)
Oh, there why somehow weaker and began to feel, after the 1st stage)on the C grade
Aura
Of course, energy must be invested. Channel energy bilateral, as pipe, and if one end of the "faucet open", the other end of the space (terms), where flow energies. By the way, the analogy of water and energy is not random, the behavior of water and flow of energy have a lot in common.Юрий ВК wrote:so on Monday, feeling that the selected resonances were necessary in an environment where they can prove their worth.
Aura
You have connected almost all of the resonances of thin and soft (maybe in consonance with available were selected), so you need to have a certain degree of "clean energy" for their perception. Yes, you can connect the Energy bath (in General, this resonance is better to connect in need for emergency cleaning, for example, in a conversation with the person that is caught, if you frequently use it stops working on a regular basis and it is recommended that a Black and tan Golden Ray) + Alf, I would still recommend something with a harder edge, Ishu, for example.Кира Алексеевна wrote:Ask the advice of an Aura, maybe to Wake up and usbdrive of spasm energies for 1-2 days to deliver Energy bath +Alf, and then to the softness of Jade massage and the Jade jewel???
Aura
Anatoli, connected Energy baths, the water of life and Elixir of success.
Why Ecstatic wasn't chosen?анатали wrote: Yes, about sweets want to explain a little bit.I am the first daughter gave birth at the age of 23,before birth weighed 50 kg,my height is 150 cm but after giving birth, I was weighing 70 kg and all.life with this weight,I was told that it's a hormonal imbalance that I just did,within reason.my mother was a ballet dancer and her daughter we also of course danced.after giving birth I gymnastics did,delaisi bare body is lifted,stop doing everything comes.I always eat a little,but tea all my life and drank a lot of sweet.everyone told me-get sweet and lose weight,but it's easy to say but hard to do.I'm still in my youth, once tasted,not drank sweet tea 2 days and then woke up at night and almost breaking,how I want sweet tea.then he said-what I am,take me like this.and here now I'm quitting sugar and I even with 1 spoon of sugar sweet,probably soon and it will be removed.for me it's like a fairy tale, and taste sensations from food increased
Aura
Sweetheart, turned the Gold light on the three-pointer, Ikaros turned off.
Event can influence. Some - indirectly, because the events of reality depend on what vibration we send out into the world, some energy work on the space level. The difference in the degree of influence of the seers perceive as different forms and channels of energy, speed, as different speeds of flow of the energies of different rhythms. In this respect, the resonances quite different effects in the event the plan than the products SAMM, so some users will need to switch the expected effects. Roughly speaking, if the program structure (transformerait) current reality as a set of vibrations, expand it, pushing the boundaries of consciousness, that energy is transferred into another world. In General, energy is tested in practice - all that relates to energy generally easy with a purely practical approach is very complicated when trying to theorize. Easier to feel the energy than to explain them.Милая wrote:I have a question, show something of the energy of the resonances on the event level? Do these energies to others? On what depends the degree/speed of manifestation or influence?
Aura
Some energy (JNA apparently) breaks the axle in your hand is very good, because in your hands you can build your whole body. Try to feel the brush, not as something separate from the body, and to feel the axis going through the shoulder of the brush, she goes out in middle finger. The right feeling you can get when You're holding tennis balls between finger and thumb - straining not brush too hard, but not relaxing completely (the feeling of "energy concentration").Лон wrote:hands.. recently noticed that often the reason their unconscious strain curve..there goes energy, tired hands - relax, straighten;
Hooked: Pleasing to the eye, Ecstatic, Jade jewel, Unconditional love, Macho, Apollo, hussar.
Aura
Crosby, rel, the level of all the connected resonances changed to 6.
Aura
You love to readrel wrote:After You described the experiment and its theoretical justification,
With the new "male" resonances became much brighter, whole, fun, smiling, optimistic!!!!
I used to have manifestations were characteristic of "Agartha" and its multi-dimensionality and the feeling of quicksand and "transformer vibration"* in my head , and now they were joined by "transformer vibration" down from the crotch to the navel, but the lower vibration is more similar in its frequency by a mosquito squeak, ie thinner and more often/higher.
More about yourself yet can not say anything:) view
but really was fun!!!!, to live as something more wanted))))
who is sad and bored, I highly recommend!!!
*under "transformer vibration" I understand rumble, sound, vibration.. as from transformer box)))
Thank you, very clearly felt the moment of switching, a powerful stream has passed through the top of her head and warmth spread throughout his body. Went Association with the first rays of sun at sunrise, maybe because of the nameАура wrote:Sweetheart, turned the Gold light on the three
Join rel, very interesting. And I wonder if testing to give these mantras, then their will?rel wrote:After You described the experiment and its theoretical justification,
Aura
Be sure to include it in testing. It is difficult to say, because even his voice in the recording that we perceive is not always as "your", though often he doesn't like than like.Милая wrote:And I wonder if testing to give these mantras, then their will?
Especially any sensations. Several times today the left palm burned and itched. Of the most noticeable sensations periodically burn the ears at all stages of testing, maybe it is my personal reaction to energy. At the event level, quiet and smooth. Ask AURA to connect you recommended resonances: Black tan, Golden Ray, Alf and Ishu.
Yes, it will be interesting to try to guess your mantra! =)
On the event level today began that something was wrong.. Although perhaps I "called" yesterday..<
подробнее :
In General.. I've been thinking here.. and regardless of staging or not, the protective set.. tomorrow he will go in search of him (there are a couple of possible options to do this) and also, he will write to his old friend.. Need to dot the is Without negativity and beating, (as I expect)) , but it would be necessary, exactly.
Excellent condition, night, it was a revelation what I want to do in the near future-to work with space.now autumn,and soon winter, the flu epidemic and acute respiratory infections in all cities will go.and then the children work in offices and come home from work,near invisible,as if worked on the site.further more,if there is to be harmonisation will continue to expand.but then it is necessary to connect the resonances of protection,and even with the flu-offensive in the interests of the pharmaceutical industry.Aura is asked to connect me to the resonances
Resonance “Hanukkah”
Resonance “Lunar Cloak”
Resonance “Diamond Color ”
The Resonance Of “Black Tan”
Resonance “Ecstatica”
The resonance of “Swan neck”
Yesterday worked all day with the energy of living water,loaded everything that was grocery.households said that the water tastes better,more sweet that, if
