ATTENTION Summer discounts.
Payroll office look
Re: ATTENTION Summer discounts.
It is - was at work alone in the office - opened a couple of Windows (the window it was snowing...)Маг.нет wrote:one of the distinct additional insulation from the external environment, according to several parameters, including temperature
Stopped a worker from a nearby office with a coat on. After 5 minutes there was a phrase - "there is even a fur coat (was coat
Color better to watch try - now outside black inside mainly black with enlightenment in brown (but I have a couple of links Panacea Shire.BH of similar wood look similar).
Another was to look at the sun - first through the tree trunk at a distance of 50 metres (I do not know these techniques - but watched it pulsating) - then just the sun. In this case, before or after there is a feeling that the upper part of the space (not the ground where I'm standing over it) is folded like a fan, and then turns around (had not noticed this.)
In addition to the temperature, "filter" and the redistribution of the directions of flows of air masses (drafts), this "filter cell" works well with some pollution of the environment, such as smoke, found out by chance when visiting the "Smoking room" where smoke is "overwhelming", there is a slight smell still felt, but the tar, nicotine and other carcinogens are very limited (this is very noticeable), as if in a capsule with clean air are, however, no special commands I have to give is not necessary and everything works "by default", though if you suddenly want to "snatch what haze" (for example for sensory evaluation of smoke and harm), then a "filter-isolator" in this suit is "obey" and to prevent the interaction (e.g. "scan") will not be much.
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
I really want the AMP on the second hand:)
To wear at the same time on both hands
Now, if there was the opportunity to buy me another AMP:)
Yet acquire a second you could just buy a wooden bracelet (max 150 rubles).Moon wrote:I want AMB to the second hand:)
and alternating between different units to make 2 bracelets.
Understand that the need of everyone is different, but I had enough (even too much at first...)
I ordered their AMV and 2.6 is still the AT2 and Keys and Doors. Long wanted to do, even the special key has long laid upMoon wrote:I want AMB to the second hand:)
Thanks for the advice! Maybe they think someone will use it.АндрейКо wrote:Yet acquire a second you could just buy a wooden bracelet (max 150 rubles).Moon wrote:I want AMB to the second hand:)
But I have rolls of gokuhi:) for my needs:)
Well, maybe I can live without the second:)
Although I would brighten up the expectation of the Communicator PC
So everything individually.
Simply, there are people who are prone to maximalism ...
Thank you very much big, Michael!!!
I'd also like to know:
You wrote :
5. 2 pads АТ5 = 30% discount
And this trim bracelet?
If it's the pad on the bracelet, then to me please wrap TWO pieces
two of the bracelet( the bracelet on each hand)
At 3.0 s++ can overlay at 5 to stick?
I have every 3.0 s++ nakleeno two pads 3.1 and one PC( the PC that You I have loaded)
In price АТ5 no.... And a brief description PTS, hints. Really want to order and waiting, waiting.
1. about ат5 - price ат5 55t for 1pc, two 30% discount
2. Moon, trim fat.
a little rough, size 30mm to 45mm oval.
a photo of the product - a little later... I have these ат5 equipment welled, so I half the night and half the day occupied not with what was going..... as always with a very powerful new products.
Ie, stuff that big, the stage in the BZ does not fit fit the phone cover double-sided tape or glue( you can glue on plastic cover for example). Its thickness is also a big... well, how else to make a powerful product? is about 4mm.
On a large phone like the iPhone can next two will be more powerful. Can the second on the lid of the laptop, the iPad.
2. Moon, trim fat.
it renderanno image ат5 without the final stage of charge and without compound in the recess, just to be performance.
Photos later..
https://docs.google.com/file/d/0B8yB1qL ... sp=sharing
Photos later..
Thank you.
The whole rear of the phone is shiny holograms technology at. Clearly, not hurt, because in one direction will work, i.e. for the benefit of me
. Top glue? --- (Well let me be the first one asking this vital question... or in a separate branch???)
and on the back cover or case (ibid) did not fit....
my apologies АТ5 office will go tomorrow and Wednesday, today's all that.... sold out.
Could not resist.Moon wrote:Thank you very much big, Michael!!!
In the movie 9 Rota is an episode. Marines talk about what they would do after the war in civilian life. Character actor Arthur Smolyaninova asks "Sparrow" (alias, the actor Chadov), what he would do, the type will roll the dice. After all, he had plenty of friends girls. The entire faculty of the virtually of them. What Sparrow said, "No, I Olga is." The affected hero Arthur said: "you will Debelius I will come to see this video. What a miracle is?"
To paraphrase Arthur says. I will be in Sochi, be sure to find and look at the moon. What a miracle is?"
ha ha ha
Yes, everything is fine with Alena
simply, it is changing rapidly and potenial there is the opportunity to use the product. Plus intuition plows well, here it is ат5 and read as "mast HEV" product. I'm Lily and so hardly took them (ат5 s after testing short.)
And although the forum may seem that it claims to be recordsmen on the use of local products (not only mine), but in fact there are other... more Packed users, just because of certain reasons are more (much) silent.
by the way. All who received bonus bracelets AMB can thank Moon. It made me think of such upgrades.
Subject to the following conditions, You can get the second bracelet of AMB for symmetry FREE.
Conditions:
- written a review on the forum about using the available bonus AMB
real Lichna need of the second AMB (family the closest direct link can be attributed to personal)
- after receiving the second AMB - story about how it changed his work (if using pairs, one person).
(of course the third clause is executed after receiving a pair).
Yes, and the bracelet is made of black wood, not from snakewood, plus there he was in the office immediately, but after processing the request and will be sent with any purchase (well, for Muscovites easier, you can pick yourself).
This option - a single (1 additional AMB per winner).
Conditions:
Initially it was planned to write in a personal, very much why I didn't want some moments to mention publicly... But really there is nothing in here that requires personal, which means it's some kind of psychological kink, and therefore publish here.Михаил_ wrote:Under the following conditions, You can get the second bracelet of AMB for symmetry FREE.
Conditions:
In General, I find it difficult to assess what the real personal need in this context. On the one hand, I do not pull on itself (at least consciously), some global processes, not the steering wheel some difficult cases do not possess any abilities... well, can't say I really missing something one AMB and should be exactly two, since, probably, I and the potential of the first well use if for a few percent. On the other hand... My main goal for the past time was restoring itself, but SBA has exacerbated it at times (this effect came a little late, so I wrote about it in my previous reviews). A simple example - I think that AMB has emboldened me what a couple of months ago, I could not think - I started a comprehensive restoration of view (I have -4.5/-5.5 right/left eye). The results are in, but want to, of course, stronger and faster. The plans I have just insane work to restore itself. I'm a little more than a year myself - and I think that achieved a lot, but I see that need to reach a much larger. And then, Yes, I believe that I have a personal need, as I am, in fact, live this process (self-healing) is, at the moment, my highest priority. From this point of view, the second AMB will be a huge help to me if You, Michael, finds the need justified.<
Thank You, Moon!Михаил_ wrote: All received bonus bracelets AMB can thank Moon. It made me think of such upgrades.
Remembering that I have Michael begged cheekily this wonderful bracelet, I just want to write about what is happening in my life. I began to feel DIFFERENTLY. Other words yet can not pick up.Михаил_ wrote:Under the following conditions, You can get the second bracelet of AMB for symmetry FREE.
Conditions:
I became very often to bear in ISS, and I started to cope, or rather, I was almost able to manage this process.
I feel that often become "energy light", and, at such moments, people around me perceive me 10-15 years younger than I am...
I began to clearly feel, when I carried out the harmful energy impact - and I learn to deal with it.
Also - I've become energetically charged and cleaned by nature, it's awesome feeling.
I became a different "sound". Returns the "sound" of my youth, when I worked in his beloved profession, and enjoyed it, and now "sound" became more deep, rich overtones. Sometimes I feel that not only the energy body, and physical - vibrates well to vibrate as it should.
Shortly before I got the SBA, I absolutely was unexpectedly offered a job, which I have never and could not imagine. The situation is complex and complicated, with pitfalls, and I really needed friendly support. I got it. Now, despite the fact that there are depressing moments, and it is moments and not extended periods, I feel calm, confident courage.
In early February, I had to undergo surgery, hemoglobin was low, offered a blood transfusion, I refused - didn't want me was someone else's blood
Now I am fasting, thinking that the carbohydrates will well, weight is holding steady, and sometimes even downward.
Maybe someone will seem ridiculous - but I started to clearly HEAR the answers to their questions. I largely perceive the World through sound and sounds, and is developing that?
If I want a second AMP? Yes, very. Do I need one? Yes, I can feel myself changing, changing, expanding my space, and I want it was the second SBA - as an anchor, balancing it, and at the same time provides the basis for development.
What is happening with me - I like it. Some works of Mikhail I consciously purchased for the benefit of themselves. Now I began to think about what you want the benefit around, to me the space was harmonized. My sense is that AMB is a very good harmonizer.
Thank You, Michael!<
Michaeland the ends of the gray background paper AMB should butt together? or it doesn't really matter, only the tape (in which to crush on this striped paper from AMB that was not torn), it would be possible to repeatedly remove the wear
Well vaasche, how to use, I need to explain it to those who I plan to give them for the test
and even if a gray piece of paper ruptured, AMB spoiled or he doesn't care, as holographic the label, right ?
With respect and appreciation
in all variants - do not care. you can even cut and stick with tape.
Ufff, but then I ask myself: Hey,Михаил_ wrote:in all variants - do not care. you can even cut and stick with tape.
we need to think first and then immediately to break up the stripes; schA, think, Michael "warms" in full for damage to his property, but I didn't, damn, well, stone, damn it, something just fell down
huge Spa-si-BA
, you see, and others muffs of old in favor of the go
With respect and great thanks
Michael, it's summer, and wearing four bracelets on bare arms and legs might cause some moral difficulties of the test. Under the terms of the project to give the opportunity during the day to shoot for an hour or two bangle method of cutting or should I not bother and just find other, less shy subjects?
it is possible, let leave at least 1pc.
I can confidently say that if you go over this with anyone but You don't need the shyness, the effect of wear will only increase - further work principle of cost, which frequently helps in ritual magic.
we are talking about something quite different - the question was testing AMB the paper version, which are 4 paper bracelet 1 day and not going (yet at least) to wear them in the future.
