Stabilizer.
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Mon Feb 14, 2011 0:13
Anti-theft need to anchor to prescribe? and then in the selected area..
Post by Михаил_ » Mon Feb 14, 2011 0:17
write on paper a program anti-theft using (for example) all three specified axis of the box.
Further this program as an algorithm, write on something like a pad under the anchor, and the anchor mount of the target group, a pad under the anchor let the anchor find a place on the field device.
Next (in my example 3) additional anchors list for "powering" program from the axes of the field.
Like this.
Малика
Post by Малика » Mon Feb 14, 2011 0:20
Thanks, the more "chewed", the only thing left to do :) . Thank You, Michael! Thank You, MAG.no!
Post by Михаил_ » Mon Feb 14, 2011 0:23
On Saturday we spent almost a "military" testing program "stoppage". I attacked a group of well-trained :) in terms of effects and sensation of people as a benchmark a simple stream of raw energy (in the positive range close to 2.7), after which they took turns holding brake the magic in his hands and remembered the method of interaction between the cocoon is peace. Then, they reproduced the program on myself and I tried to work again, the same powerful flow of energy. The result - the stream turned to the other side, as against a concrete wall, partially hitting me measurable impact.
More dangerous test you basically do not want, I have had enough. The expected side effect is confirmed, wearing stoppage becomes a "leader" to influence the picture of the world in the area of my mental stay (i.e., conditional where the processes associated with it are). The group was not one of his stabilizer except one person. Ie effect was observed on the pure audience and without stoppage in the field, only in her remnant and memory of the cocoon.
Post by Михаил_ » Mon Feb 14, 2011 0:25
the most likely further developments - we probably will release a "stoppage" in the form of a massive object (pendant or keychain) and it will be somewhat more expensive than plastic, but somewhat more powerful..... plastic production will develop this program.
Малика
Post by Малика » Mon Feb 14, 2011 0:26
Very interesting!! I will observe the effects when wearing the "stopmovie"
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Feb 14, 2011 0:31
I also started wearing 3 pieces StopMagic1-2, see...
Sincerely, MAG.no
Димонъ
Post by Димонъ » Tue Feb 15, 2011 4:44
Michael, a few questions.
1) Stoppage blocks external(other people, objects, etc.) Energo-informational effects on humans?
2) the Whole range of BZ(ск1м. bracelets and so on.) the operator does not fall under this block? (In particular Radionics SP-that is,third party).
3) you Can use without artifacts?( the magic, absolutely not in the subject) can result in the form of increased responsibility for personal picture of the world?
4) As I understand it, now stoprage available in the form of bonuses, and when will ( will it?) it is possible to purchase?
Thanks in advance.
Post by Михаил_ » Tue Feb 15, 2011 4:55
The end.
1. now stoprage available in the form of the program to the AVR on the prices such, these prices are extremely and just, until it stops low, as the stabilizer itself is expensive, and the price of stoppage individual have not been made, mostly on my laziness and the understanding that it is a piece for piece acquiring usually in contrast, for example, from the anchor, the stabilizer need a lot. When engraving stoppage is double service life of laser time (it has a double image caused).
So it was that the price of this program many times through the floor, even in the current simplified version.
2. I suspect that the bonus stoppage either already ended, or is about, ask in the office. On Saturday afternoon they were half distributed.
3. the man without the artifacts easily. Although it is possible that its effect will be slightly weaker, it is better to combine with at least бж2.0, the benefit is available, or in the very least, with a homemade 1.0, the benefit is quite simple to make.
4. the increased responsibility may not come, here need is a BJ. But some protection from the pressure of others - Yes.
5. Artifacts of the operator(which is physically on it)- will not get. SK - and others compatible too. Radionics can get SP too, but having BJ them, you can probably prescribe for themselves, using KO, but it is better to verify the results.
Ask The Magician.neta, it will be interesting to put full-scale experiments, and he's got the whole range of these devices I think there is :)
If radionic or SP broadcast your job, they may not fall under the restriction, but I'm not sure.
6. Yes, stoppage blocks external influence by encircling it, and this past looks pretty funny, as some Mebunnai space, which ago takes off some recoil (it's not a mirror, by definition, build a simple reflective and other trivial structures is costly and not fully reliable, usually breaks easily).
Димонъ
Post by Димонъ » Tue Feb 15, 2011 5:29
Michael. thanks for the replies. Looked at a branch on a diagonal,alas, much missed. It is necessary to carefully read. Thanks again.
Тоха
Post by Тоха » Tue Feb 15, 2011 13:16
On his website, Michael wrote about the stop the magic. Here is a quote "the placement of the bed will affect sleep, of course it will be, but will change your options in the dream.... dreams will be exclusively internal, as with the "tank" You'll lose sync with your external dreams."
It was interesting and I decided to try it. Put the sheet with stop magic under the pillow and wished a pleasant inner dreams. What can I say, inner dreams, not too much. Were in the shoes of the maniac and in the skin of his victims. It was not very pleasant but surprisingly slept well and recovered well, as the evening was in training.
A remarkable effect was seen then. When driving to work and on the job. I had less influence and cling to all sorts of minor irritants. Direct really less. Leaf Mandal left the house, but now decided to buy next month stop magic. A very interesting piece. It turns out distantsirovaniya from some of the cases look like on the side on top and not inside. Michael thank you very much. Loved it.
I think a couple of weeks to experiment very tight.
Just do not would like to stop magic axes would radionik. I'll try to experiment.
Post by Михаил_ » Tue Feb 15, 2011 13:52
to not minced radionic, you need to not just drove the flow of energy or something, and was part of the internal picture of the world, i.e., this process must be consciously allowed and not just the switch turned on.
Тоха
Post by Тоха » Tue Feb 15, 2011 15:32
Michael little clarification. If I formulate the problem on the integration of Radionics in my picture of the world and will instruct the SC to do it? Will it use? And about how quickly it will happen. Take a doubt that I can smell it(.
Post by Маг.нет » Tue Feb 15, 2011 15:37
Михаил_ wrote: will be interesting to put full-scale experiments, and he's got the whole range of these devices I think it is:)
Let's try:)
Тоха wrote: If I'm laying down a challenge to the integration of Radionics in my picture of the world and will instruct the SC to do it? Will it use? And about how quickly it will happen. Take a doubt that I can smell it(.
Easier integration it already has, it remains to specify the interaction and the avoidance of conflicts with the program "StopMagic1-2".
Sincerely, MAG.no
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue Feb 15, 2011 15:44
Michael ,it turns out that stop magic brakes all the bracelets and all the room and everything.Blocks the effect of all artefaktov? And not to Bekirova need to register mentally ? Where to stop the magic cartridge? Or what? :oops:
Post by Маг.нет » Tue Feb 15, 2011 15:47
Маг.нет wrote:Try:)
Rather check possible today that was it... just bones broke out of the blue, the ground from under the feet left... miraculously managed over the air to grab...
Sincerely, MAG.no
Post by Маг.нет » Tue Feb 15, 2011 15:51
ЛИЛИЯ-Р wrote:AND not to Bekirova need to register mentally ? Where to stop the magic cartridge? Or what?
With BJ simply - it's all the same... (different settings within the same system), so conflicts shouldn't be.
Sincerely, MAG.no
Post by Михаил_ » Tue Feb 15, 2011 16:04
ЛИЛИЯ-Р wrote:Michael ,it turns out that stop magic brakes all the bracelets and all the room and everything.Blocks the effect of all artefaktov? And not to Bekirova need to register mentally ? Where to stop the magic cartridge? Or what? :oops:
Bracelets, IC, isn, stabilizer - does not slow down, the rest can slow down if it's external to the operator.
I suspect that a Chamber is also not slow.
In General, all OUTGOING effects do not change. Incoming will be inhibited if it is not the integral action of the world, and someone's personal, no matter intentional or unintentional, and not even necessarily personally focused on You.
Малика
Post by Малика » Tue Feb 15, 2011 16:21
Inhibited only negative influence from the outside ?
Post by Михаил_ » Tue Feb 15, 2011 16:49
in nature, there is negative and positive is our subjective assessment. Any naturally. But it is happening from the other person (people) :) ie some of the planetary processes of course are not shielded. Just your picture of the world becomes the leader in this area, while others flow around her as if by.....
Малика
Post by Малика » Tue Feb 15, 2011 16:57
Thank you!
Post by Маг.нет » Tue Feb 15, 2011 20:45
Маг.нет wrote:Rather check possible today that was it... just bones broke out of the blue, the ground from under the feet left... miraculously managed over the air to grab...
Sincerely, MAG.no
With me today occurred a mysterious event that is possible in the context of "StopMagic1-2". At least I admit it.
Small digression. A few years ago finding a property transfer dynamics of external process (not dependent on I) the current process of life, began to study... Caught several Autonomous dynamic (almost live) processes, began to use them, let's move, as a resource that specifies the dynamics of development at the point of application. Just a mental call and put... as a motor. Noted high efficiency.
Today, firmly standing on his feet, alone for reflection on the current working process, once again deciding to use the "app dynamics", aroused-trailer-sent a pulse... a flash in the pan (surprise...). Decided to repeat it pressed harder, what happened until the end and did not understand. The feeling was such that real feeling your weight and the force of gravity is absolutely not felt the earth beneath my feet, as if it's not there, although disorientation in space, but load the vestibular apparatus is an attempt to equalize the balance and I flew to fall, knowing that you'll get hurt specifically (not frail at 90 kg on concrete floor), urgently began to try to remedy the situation. Slowed down time (a feeling that these couple of moments stretched subjectively somewhere in 20-30 seconds) and began to grab a foothold and wonder I felt air seal as a fulcrum and hooked rectified the situation (I think BJ has helped! at least it's the first thing that came to mind after landing. Yes, and "air seal" I'm not just felt but seen, as a kind of layered substance similar in appearance to the slice of ice is heterogeneous, with different density of the layers, but a great aggregate and gas as moving with different velocity layers). I landed in a unique position in prisyadku on the left leg, the right extended in the air to the right-back, the body is significantly tilted forward, hands placed as climbers, right-right-up, left left, brush condensed like something you hold, and NOT FALL! Just know (and feel) that repeat just can not, and if you try, it seems to balance in this position does not hold. As if over an invisible boulder. Imagine if someone saw it:)that would had to think:) what planet is this gymnast... After such a good landing, I noticed a slight pain and heat in the forehead, after 10 minutes they went without a trace, although I immediately came to my senses (or rather I was myself, the only time the flight felt differently). A unique lesson.
Again, do not want to "pull the ears" subject to compliance with certain instrumental resources and capabilities, will try later poryt deeper (eventually the print is quite bright - there is something to see), but is simply stating a fact and give a description. Yet honestly 100% do not know how to this event to be, what made him and why I needed it, but noted some "useful" consequences, if not a glitch, then I will watch their development. development in dynamics...
Sincerely, MAG.no "planet Earth":wink:<
Post by Михаил_ » Wed Feb 16, 2011 1:31
assume that the compensation of possible drop this one process (the subconscious is harnessed available resources in abundance), and initiation of loss of balance - a process... don't know exactly what, but in principle can be quite simply much to shift the focus on something external (this could be described as incomplete or just begun teleportation). So maybe just "tight" thinking....
Димонъ
Post by Димонъ » Wed Feb 16, 2011 4:41
Michael, Hello .
Received bonus stop magic, buy failed. Appeared questions.
1) if Prescribed in the cocoon( after extended wear) quality of stop magic? (similar to BJ?)
2) does stop the magic from past external influences on the operator, and if it works, something like: automatically or can give the mind set on cleaning personal energy from an accomplished influences? Or "history does not tolerate subjunctive mood," and what was, stop the magic will take it as a part of the personality of the operator? And to solve the problems of the past it is better to use BJ?
Thank you.
Post by Михаил_ » Wed Feb 16, 2011 5:32
1. experience occurs, then the quality can be the cause... but it will not be permanent and caused by weaker modulated object.
2. no, the past is not covered by the.
