And if this thing in the UKНовик wrote:Michael_
OK wait!
Someone!!! ETOGES Icurrent through the IC, wrote on a piece of paper and put the two leaf exactly was on the table....
PS.
I kick everything out from the UK ETOGES fucking ARTIFACT
Bracelets Life
Новик
well put with the fruit cake is exactly diametrical things... a fruit cake gives a low frequency (also required), but it gives the SK, but he gives a wide range of frequencies. And RF console gives you a high. (by the way Radionics do not give this component as a fruit cake, and also a wide range, but also differently)
But it is certainly possible with any entrance to achieve the same result. I.e. add at the bottom - something rises to the top. and Vice versa.
In the RF console is the most important thing is not just "exposure" Agni and the possibility of a stronger influence on themselves and on the world, but that it resonates with the world on a coherent wave, so to speak.... special. Well, sort of zone ... that I can not explain in words, like some kind of zone where everything is balanced and where you can move in any new direction. Such a fun signal of the biosphere.
Yes, I've asked another question in PM about the differences between the versions. I have this question now will answer then separately.
But as a whole. Better to go through the 2.7 because 2.8 is slightly extreme version. I think about her in the video said. Wearing the bracelet 2.8, slightly weaker than the current modification, I twisted on energy for a week or more. Powerful 2.7 (those now) did not yet exist. Ie need for a good start. This is most properly and smoothly. And 2.7+2.8 is the best combination I guess.
At the same time, you need to understand that most of all runs within the area of lower frequencies and they are consumed in commercial quantities.
- Вадим Перелыгин
- Been thanked: 7 times
Michael, what instrument do You measure the frequency of the radiation (what: agents, by using waves of Chronal field, Orgone energy) of "pies" SP, BZ, SK ? Or do You use psychic abilities all these measurements – the feeling subjectively-estimated?Михаил_ wrote: Kulichik gives a low frequency (also required), but it gives the SK, but he gives a wide range of frequencies. And RF console gives you a high. (by the way Radionics do not give this component as a fruit cake, and also a wide range, but also differently)
the device - body and mind. Sensations and measurements are absolutely exact and not approximate. More precisely nowhere. If I 4 + I, say that the particular construct gives the washing resp. frequency level (the level of energy in the chakras) and this occurs independently from each other, what kind of approximations can we talk? it is clearly seen how the frequency of the energy comes (if comes) and in what quantity and quality. It's easy to measure the instrument (in some cases it is), although the body works as a frequency Converter. If you apply a low frequency in excess of - get the support and the upper levels. If you apply high frequency, you can lower it down and there will be a LOT.
Here if nothing is submitted, and the cocoon to get to work in the high frequency regime, the immunity falls in the first place. Because when you convert to treble the amount of energy decreases. Ie little to energize the ajna, you need a car to eat off the body, and the body without the energy starts to hurt.
Anywhere there is nothing approximate. I have an array of measuring devices (electronic). But experience shows that their accuracy is always lower than the precision of consciousness.
In the presence of practice of course.
- Вадим Перелыгин
Excuse for meticulousness, but still. Are there independently of any scale and unit of measurement frequency of level, quantity and quality, except "I have got to Agni, and "not so sickly pins(well, in terms of physics)""?Михаил_ wrote:the measurements absolutely precise, not approximate. Too right
If you can, please put a reference to the scheme objective electronic measurement. Device.
Vadim, that's just "sickly pins" or "I got" nothing is measured. I understand You very well, at most there were once all the same questions. And passed gradually through the various options, until I realized that everything just is...
Generally, if You know, many diagnostic methods are designed so that in addition to "accurate" equipment, there are no less accurate diagnostician, from which fact it depends. For example with ultrasound and x-rays like this. Ie what was there and saw the man, he writes in the breakdown (the conclusion). Sometimes, two different people write different. Familiar?
There are several ways of measuring the frequency band.
1. Purely hardware. Scheme - any electro-sensor (simplest form, a milliammeter and a battery).
The mass of options. It is possible to measure Fizicheskie changes directly in the area of chakras. Indirectly, through the meridians (where the program does GDV-Kirlian chakra from the device, for example, available in the office of the MM).
You can take a non-contact sensor, measuring it changes the background (so did some people I know), you can take the sensor of the type Lira-100 measuring parameters of body tissue in the local area (so did Andrei Patrushev, when the measured bandwidth of the chakra, including the CD "solar wind".
I have, for these purposes, there are two extended device diagnostic method (Sujok EDO and Biopolis, removing extensive diagnosis on the points and gives a complete picture of the cocoon), there is also a GDV, but I'm downone use for several years.
The interesting thing is that I know how different people, with a fairly scientific approach to the case of rented frequency bands in different chakras, on good equipment. Results varied, although the rate is increasing from the bottom up the same.
In General, we can say that there are certain harmonic frequencies that resonate in a specific chakra. Therefore fit "such and such".
However, over time, using different equipment, gain experience. Experience, when it is conscious, it is always some associative connection. The signal from the outside and helpfully provided a conscious response. Actually, it happens the specialists ultrasound for example, when looking at pictures. I mean, You're not going to use a set of colored filters to set what color You suggest a paint for the walls in the store? You know and and so that red is red and green is green. Device can and deceive and your eyes in any way. When I run the same thing constantly, and read the signal as a vision, then to analyze its devices only begin to create popular materials, or for use diagnosis without a specialist (for example self-test those who can not count what you need yourself).
I know a lot of people who have worked with measuring the state of the chakras and was never a problem to use a direct area of compliance or points of the meridians. Everything works fine, this knowledge knows how many thousands of years. And measured all quite instrument, not only electroacupuncture. You can "thickness" of the cocoon at the right level. For example, the device IGA-1, but there should be a hand stuff to be able to use. True to the YOKE 1 is generally a single anecdote, then at leisure tell you.
Generally, when there is some energy impact, then it has sign (arrives or leaves), frequency band (the chakras that hurt) and kachestvo (in one strip can be of varying quality, on the deployed diagnostics this will go on raznym meridians !). Parameter quality or type of energy can not escape. In the same sujok this is reflected in the division for 6 energies, but can be applied to another system of analogies (e.g. same tree of life).
In addition, the signal can be someone already modulated. I.e. except frequency bands (the affected chakras), quality and direction, it can contain some shape information, e.g. the algorithm. Ie to You something came and began to "feed" You in the zone ... no matter what. And it turned out that it was a nice destructive (someone's conscious message for example). Now the question is. Can more or less accurately read by the device?
Yes they can, but not all options in detail.
For example in GDV, foreign a promise or an energy source (though the stone or is there the same SP) will obviously give the "tail", and alien thought-form will display a certain structure is likely. However it is easy to confuse. For example, with a sluggish current timeline, also having a structural formation (unevenly distributed energy).<
Generally, that person feels the flow of "something", or just some change in the external environment that affects it. No matter, Auntie to transport him tried privateraise or somewhere nature went
You can clearly track the level at which the body (literally, from and to on the increase) the signal passes, the rest will be indirect consequences. Ie, in one place, remove, everywhere begins to shrink replacing departing. Or Vice versa. Arrives. Also comes mediated changes.
Many perceive any premises itself, in the area of the potential difference (which can work often just in a new energy place) as something favorable, even if this person is not a positive.
Sometimes Vice versa, bright and strong place "in nature" is not suitable to a specific person, and the other at the time. I beheld such a situation the couple where the wife doesn't like(and causes a physical headache), husband - just super... and the problem is literally the difference in the mental organization of consciousness, i.e. there "Realit" it is the quality, although the energy coming and it seems to be "positive". In fact it is all very conditional.
I was shown a photo of the place where the cemetery is literally energy (source), but the difference is felt strongly. Locals go there as for the Holy water, although there is only cancer you have to send it.... and reset the mother-not-worry.
However, to this I would add that being aware of the possibility of an error of diagnosis, in all important cases, I use "independent experts", the sensitivity and fulfilled the vision which trust, and generally "tormented" questions a few people. Although 100из100 is "nothing", i.e., until their mistakes are not ran, but I was so calm.
Don't know if I answered Your question, but add like nothing.
- Вадим Перелыгин
Michael, thank you so much for your detailed reply and lots of ideas!
It would be nice to have a simple instrument to monitor, at least the simplest options of orgone energy. For example, she arrives or leaves specific area with pinpoint accuracy. At least to confirm their feelings.
Its sensitivity, perhaps, we can develop and train, it would be something to build on.
After all, the impact of electric current and voltage of a particular value for one person can feel for another, but also to the threshold boundary beyond which not to feel not possible!
Similarly here: "Alert! The cocoon is in danger!". Of course, there are many affecting factors: radiation, chemical, geopathic, electromagnetic, etc., but all of them anyway, first destroy the cocoon.
Well if BJ beep...
Do You have any plans to create a "device" with such properties for people insensitive (though not yet feel, the effect is, watch out!)
How do You feel about the Tablets to measure energy in units of "Bowie" and this concept (selection from the forum)
http://analitikmag.com/Magforum/viewtop ... highlight=
"Here are two convenient tablet to measure energy. They can be used to measure any energy level, and to determine how this energy is perceived by the body. You can use them for training, for example, by defining the energy at home, etc. Suggest not to start with them, and to train when you already have experience with the pendulum.
And what is the standard of the units of bovi? Or is it somewhere in the information field firmly "registered"?
Will other people when izmerenii in these units receive the same digital value.
When measuring the energy of the same object in units of bovi digital record will be the same in different people. Unit Bowie is no different from the same kilograms or degrees Celsius.
The standard Bowie is in the energy-information field and the subconscious mind uses it when measuring. Energy are different, many people are unable to work with the energies of certain levels, and they will not be able to determine their number, if you do not have access to them. Pendulum will not give an answer, if there is no access to information. If a person has no access to information, the pendulum will go in circles. And regarding the energy that man himself does not feel - just a pendulum and will help to determine its level. For example, if I feel a thread which is in the spectrum that it's hard for me to feel - I still can clearly measure its level, and the results will not differ from the person as a whole perceives this range. It depends on the question of the operator of the pendulum. When working with the tablet: "What is the level of energy (the object)? How many Bowie radiates in this place of power ? "Lack of access - the pendulum goes in a circle, if the pendulum gives a clear value, then the wrong answer this is the result of cockroaches in the head and skill level of the pendulum. With experience it will be overcome."
Sorry, that is not the topic of the thread, but very interesting to know.
Well if BJ beep...
negatively to the tablet. More precisely, any pendulum system is able to tell the truth, lie, and do both at a time. It can be fun intrapersonal, external the "left" signal and more. In General, this is no different from practicing personal sensitivity, because the device is still is the man.
It should be noted that the negative is imbalance. And so a person has great energy. In some quantity. Too rapid change can also be traumatic (see post Lilies on the effects of several from 2.6). I.e. if you imagine the human as a vessel with different liquids to pour or to pour only gradually, otherwise you can cause a leak, break pipes and damage the entire system...
A simple diagnosis can be performed either by reflex points (even just without the device, the imbalance in plus and minus will cause deviations in systems that are easy to detect).
And you can take aurikulyarnyy on the retina and there are very detailed descriptions. Changes there occur quickly and reflect including the state of afirca (diagnosticians said that on the retina seen the alleged disease is still physics not shown).
And quickly, in the online mode - well, it's a little more accurate. Electropuncture, Kirlian, really.There are too many factors. What is good to one is bad to another, but it is ALWAYS an experience, as long as it was not destructive to humans.
Again, the predominance of some specific energy can cause relevant changes in the mental, i.e. to change a person's character, style of thinking....
Well, let's say a person moves to a new place with a different energy. And the place is reasonably begins to influence him.
here came a question in PM.Hello Michael! Wanted to ask a few questions with B. J. If you can, please answer.
I have B. J. 2.6, and 2.7. B. J. 2.6 wear 2 weeks almost without lifting (even at night), B. J. 2.Wear 7 together with 2.6,but not always, at night, not wore even once.
2 weeks of use B. J. a situation in which I wanted to clarify.
So, during that time I had few times situation too strong (mine and other people's) emotional reaction. And diverse situations, and emotions both positive and negative, but in all cases, too strong emotions are not peculiar to me.
What is more typical at this moment throughout the body, "walking" some of the threads and threw the hot then cold. At first it manifested itself in a situation with negative emotions, and the situation now seems to have arisen out of nothing.
But then in a situation seemingly with positive emotions (invited to the prom) again the same thing. This just never happened. Barely doterpel until the end. The body as the chills,then hot, then cold, and very strained as against the transcendent sound and light.
In this regard, I wanted to clarify it can be connected with the action B. J. and if possible, how can we correct this condition?
Was wondering, can this condition be corrected with any of the modules B. J.?
Maybe what principles work, I have not considered?
In addition You have on the forum are modules on the health of the body "Kit" (I saved them), but also stated that there is an additional stack of modules on health and work with different organs of the body.
Where can you get them? In addition to "Kits" found nothing.
In this regard, could You send me or give the link to all the modules of the B. Zh. relevant to the health of the organism or the organism in emergency situations!
If any recovery methods are available in the UK or the modulator (I also purchased), can we at least tell how to use these devices for rehabilitation or solve the problems associated with health?
Maybe some options in this area is possible using the transfer couple?
I would be grateful if you can answer and explain questions.
I decided that the answer is useful to many.
1. 2.6 and 2.7 is really powerful. Everyone appreciates the potential. Really bad of course nothing to do with them, overloading yourself can arrange. And good or bad is impossible to determine for certain. The person receives a "kick" faster to accumulate some life experience, very fast flow of these processes leads to some inconsistency. And it is not always directly related to the personal problems of the person, sometimes that's what my colleagues calls "the reality shook up". So this was You without BJ, there was a certain incentive, the output is different. Between them and their life opportunities and destiny may very big difference.
It is impossible to measure true...
At some point, it sort of accumulates a breaking change. Surprised the world adjusts to the fact that there was "Ivan Ivanovich", capacity 1, there was a completely different person, with a personal capacity 10. This rebuilds the connections, events, energy events. Literally everything shakes and shake down into place. Sometimes there are strange quantum anomaly. Sometimes meaningless, but very strange. Ie, you may notice that the events might even proshlyh, there is something that is not perceived as natural, and do You remember podrugomu some other version.
Walking streams and other visual effects - the passage of a certain point of shaking or tension, along with possible testing of some personal blocks.
Here that can advise? to reduce the time work with older versions. In General it is possible to start in the weekend or dressing for the night (the effects of this social usually excluded). I.e. producing gradually getting used to new qualities.
However, I'm not sure that each such Council is adequate. The thing is that maybe someone and need a very quick change, I should know that?
As for the kit, then:
1. usually all need good starts offline.
2. all modules described in the thread with modules
3. in addition to the kit there is a normalization of the spleen and pancreas (if not confusing anything), a quick stop of the blood,regeneration, kill the disease, a tablet, cleaning of the blood.... can that forgot, but in the thread about the modules exactly all there.<
BJ often to cope with the imbalance, or will cause the arm pressure (heating, cold, tingling, underline) to feel that something is clearly happening). People went with the BJ for photo x-rays,wrote that the bracelet then another day in the active species has arrived(felt).Вадим Перелыгин wrote: Similarly here: "Alert! The cocoon is in danger!". Of course, there are many affecting factors: radiation, chemical, geopathic, electromagnetic, etc., but all of them anyway, first destroy the cocoon.
Well if BJ beep...
Михаил_ wrote:tingling
Drew attention to it. BJ 2.0. Periodically feel the "tingling" - "look around inside", often notice a source/cause, if it is not shown - look CAREFULLY! - comes clear understanding. (Diagnosis of external/internal system).Михаил_ wrote:bracelet then another day in the active species has arrived(felt).
"Virtual gift" is celebrated constantly. I wanted to compare BJ with/without failed "to remove BJ" even 3 days, though I didn't push it
Sincerely, MAG.no
1.Маг.нет wrote:Michael_, 2.7 and 2.8 without the reverse is not the best option for frequent use?Михаил_ wrote:2.7+2.8 is the best combination I guess.
2. using 2.7+2.8, 2.5 and 2.6 can be omitted?
3. using 2.7+2.8, 2.0 - increases the weight?
Sincerely, MAG.no
2.7 and 2.8 self-sufficient, but in General, it is best to first 2.7 and then 2.8, together or separately... you can of course just together, but.... then you need to dose it. Still vigorous combination. No need to arrange overload.
You can of course ignore 2.7, to take just 2.8. Moreover, I wrote here about the supply person with a severe injury of the spine 2.8- (a lightweight version 2.8 weaker in strength), say good effect (at least painkillers). Obviously, due to osim filling of cocoon with energy and repairing places of disorders that cause pain. However, in my opinion, the effects will be more harmonious and stronger in the application of the first 2.7 and after some adaptation time (well, at least a couple of weeks) 2.8.
3.
2.0 when all the older 2.x adjusts to them (looks like their activation).
2.
2.7, 2.8, 2.5 and 2.6 is of different quality. Perfect to dedicate to them a separate "mono" time. In addition, you can use 2.5 and 2.6 to 2.7 or 2.8 gain or as a means of emergency assistance. Ie if the quality is not worked out completely as a personal experience, but suddenly need (life situation) and a bracelet on the man (or handy), you can rebuild yourself on him.
Relatively speaking, if you wear at once 2.5+2.6+2.7+2.8 then you can call moneychest one of them by moving attention to how switch. And you can just, according to circumstances, to switch to the desired quality. For example, the need to break the impasse and find a new, creative solution can be a reason to use the "today" single 2.5
Using 2.7 can trigger breaking on the break, not noticing the obstacles (energy many of the obstacles that seem negligible, but in fact really is). a 2.8 by itself can cause a condition from which assessment of this situation is to say that everything is fine and do not need breaking
The need to solve something in a more forceful way to encourage others to accept their point of view, -2.6, and so on.
Of course I exaggerated the description very much. Moreover, different people and at different stages of development effects can be very different.
In addition, you can use polar versions (2.5 and 2.6 on different hands, Veronik wrote here about this and I regularly use). In General, a person left and right halves just pushed together...<
here's another question in PM for a second day of rest...after Reading about the difference natro and NATO, I came to the conclusion that 2.8. needs to improve ability to, roughly speaking, magic, ie mental effects on event-driven processes. And enhance good luck and good fortune. However, I do not quite understand from the same description, why do You always write that and 2.6. also enhances the influence on events, whereas this Homo, recorded in one of nacro points, and the goal of Homo - creating symmetry for balance and harmony of all things. And its main motivation is the need to limit the speed of changes occurring under the influence of the Hetero force. Ie Homo is the force of resistance to diversity. How can it inspire change?
The situation is very simple. Not change the principle of your "work" and the impact on the world, and mental attitude, experience, and attitude of the world to You.
Result series, I think of clear examples, some of which have already been used.
Regarding Homo.
1. Man, the carrier of the principles of the order, remain human beings, with the ability to make changes in the world. In "Chronicles" from Zelazny, Homo is shown as amber (not completely of course, but in some way, and that, like Puck, in tringale described as a pole that appeared in our world after pole of Chaos, which was something intermediate.... ie, the world existed before, but was a different version of "the Chronicles")
So, the representatives of the amber really affect the world... of Course it's an artistic example, but it illustrates the principle. Ie they, appealing to their pole, pole of order, changing the balance, making any changes.
2. Generally trenchline principles in the bracelets should not be taken overly literally. Tringale very good model, but the world is always more complex than any model.
3. The principle of mass, about which I have already spoken. 2.6 personal increases the mass of the object, associated with its history, the past. Makes the object immutable from the point of view of the deforming influences of the world (not of course of course, not completely, just that is a quality that begins to manifest more than usual). Inside the object has the same potential for change as before, but the world may have to bend weaker. Hence the change of status and relations of the external world, including its specific representatives to bearing 2.6. Ie people in 2.6 is slightly a Prince of amber, but it's not only opportunities but also responsibilities and headache - impact on the world through growing their own importance (other people's perception as more ancient or more massive object), and the growth potential of its mass. But mistakes in behavior lead to more serious consequences, and the growth of the area of responsibility forces you to think about a larger radius of their environment in a stabilizing, harmonious style. Then "on the horizon" around the stops to show a bounce weird.
A conscious change in the outside world is a normal thing for any person, even if he doesn't know about such possibility, then their actions and thoughts everyone has... their influence is always on different frequency bands.In this connection the question - if I already have a 2.5. and 2.6., what I should take if my problem strategically can be formulated as follows: increased luck and ability to influence the situation, while maintaining (and preferably gradual improvement) level of health and without any negative effects on my family. What better combination for the realization of that mission: 2.5+2.6+2.7 full. or 2.5.+2.6+2.8? Assuming of course that I truly understood what makes version 2.8
Therefore 2.7. and 2.8. these are different ways of influence.
You can say that 2.8 is better for the development of personal abilities it is because of vysokochastotnom. But this does not mean that it is better to influence on what is happening. Who can more be achieved? usually it is energichnye people. All the BZ increase this parameter then the "ceiling" of personal power. Above the ceiling is in process of finding a completely new experience. From this point of view, work with 2.as with the mono-qualities, enhance individual potential and personal power at the expense of gaining new experience and new algorithms for consciousness.
Between development versions better make some pause....
2.8 it is better to take knowing that the study of the upper energy levels, it is not only possible, but much greater than with other versions of side effects.... thought back not get caught.<
while buying office two bracelets version 2.0 held them on the fingers of the hand five minutes after asked to podoiti in a bag and on his left hand was wearing another bracelet 1.0 and spustilsja metro look where to go, in what direction?:))), after a minute realized cauda necessary:)))).
I wore these bracelets all three on the leg for approximately a week nothing special harm and is not noticed except drool a river flowed for the first few days but then piss off colds and coughs were such that as if torn like a hamster in half for a few days, the treatment of conventional drugs, but with one bracelet 2.0, the effects of a cold was a few more days.
here's a question:how to determine whether to disable the cellular cloud on my bracelets? and another question : after removing the bracelet on the spot wearing the phantom remains when regular wearing of bracelets on the limbs, respectively, should also be the phantom as I understand it , is it possible to achieve the amplification effects of it wearing bracelets and if you can then what?
PS now in Turkey, some residents of this country are keenly interested in what the hell is on her leg
Cellular cloud of course will not go away.
Three bracelets in one place - a kind of overload.
Cold and consequences a clear sign of too rapid adjustment.
From the phantoms increase effects will be only in a critical situation, at the nominal work 2.0 General almost everything goes through the cellular cloud. But the symmetric configuration (two arms or two legs) I would recommend to wear some time when availability.
Turkey Hello
Turkey Hello
