Answers to frequently asked questions about the Parlor
Ростислав
Re: Answers to frequently asked questions about the Parlor
Post by Ростислав » Sun Jan 03, 2016 14:07
Алсемо wrote:what would you expect the product and solko in the Foundation of a commercial building at 1000m.kV. to lay, that successful operation was, whether effective?
all depends on the direction in which you want to use the building - maybe easier then to paste window)) well and then put in the corners of the room super
and coin 5 rouble copper )) in each corner
ЕИК
Post by ЕИК » Mon Jan 11, 2016 0:43
Hello!!!
I have a question on the wearing of cards in the parlor. I wear them in the holder, which is a metal box covered with leather and one side closes with magnets. Due to the fact that I'm wearing a chamber in the holder, the effect is not impaired? And what better to wear?
Акела
Post by Акела » Mon Jan 11, 2016 11:00
ЕИК wrote:Hello!!!
A little metal box shields the electromagnetic field, but the interaction with the person working in the information structures, the iron didn't bother them.
Алессандро
Post by Алессандро » Mon Jan 18, 2016 4:45
I have a question - someone is a chamber on the rope on the neck? I have a SS in your wallet, and often forget about it
Post by ЛИЛИЯ-Р » Mon Jan 18, 2016 14:38
Alessandro Those who have Svetlitsa hole wear. But it in older versions and in the first round. You can sew a little bag and wear it on the neck. Anywhere she was with you.
Алессандро
Post by Алессандро » Tue Jan 19, 2016 4:58
I have a new version, where you can drill the hole without damaging the product?)
Акела
Post by Акела » Tue Jan 19, 2016 10:15
Алессандро wrote:I have a new version, where you can drill the hole without damaging the product?)
Look at the card using a bright light bulb, remember structure is located and drill where an empty seat. Do not disturb the structure, otherwise the room will lose its quality.
Post by ЛИЛИЯ-Р » Tue Jan 19, 2016 12:31
Alessandro Possible, but why drill? Still better than the Parlor to wear in case of long wear and contact with the body ,it can delaminate. And not very nice plastic wear to the body, underneath the body is not breathing, cover slsde layer. Well, then for you to decide)) the Torch phone, too, can enlighten and drill a little higher.
Ростислав
Post by Ростислав » Tue Jan 19, 2016 16:12
Here's a thing to buy and all problems will be solved))))
http://www.ebay.com/itm/Plastic-Clear-I ... SwaA5Wi1NB
but in the stationery such badges from 20 rubles to buy a choice
Гродно
Post by Гродно » Wed Jan 20, 2016 23:51
Ростислав wrote:Here's a thing to buy and all problems will be solved))))
Rostislav, if you are the thing purchased, could you tell me the thickness of how many cards it includes?
Ростислав
Post by Ростислав » Thu Jan 21, 2016 0:19
Гродно wrote:could you tell me the thickness of how many cards it includes?
I took in a stationery store - 30 rubles - I took two pieces in each pocket fits 2 cards and two pockets then hung on a single cord
well, you go and empirically determine which is better to get yourself a pockets better than the soft that was otherwise eventually burst and soft last a long time
убивашка
Post by убивашка » Tue Jan 26, 2016 18:17
friends, just accidentally broke the card "the chamber" into two parts.
Can I use this card?
what to do with it?
maybe leave only half with the sticker?
Акела
Post by Акела » Tue Jan 26, 2016 22:39
Super two pictures, look to the light if not touched it will not worked. Or if one is whole, one will work .
убивашка
Post by убивашка » Wed Jan 27, 2016 6:14
Акела wrote:super two pictures, look to the light if not touched it will not worked. Or if one is whole, one will work .
I do not understand what a lumen is?
there pictures is a Slavic symbol is painted in green-yellow-red color. On the face, in the middle of the white light beam, here it is I have two parts broken.
Акела
Post by Акела » Wed Jan 27, 2016 11:06
убивашка wrote:don't understand what clearance?
Then using a bright light to see the outlines of "pictures" which is located inside the card, if the break goes through the picture it is not working.
Post by ЛИЛИЯ-Р » Wed Jan 27, 2016 12:06
hit girl What is your parlor? Svetlitsa Super 2 structure if broke in half card, between the structures , it is just 2 halves to glue to the other map and everything. If the structure is broken , it only acquires a new one. Structure Slavic is a WAY , a symbol of harmony and prosperity, not only of the Slavs. Photos at PM lay out and see what there is not.
убивашка
Post by убивашка » Wed Jan 27, 2016 14:27
Akella, Lily: Thank you for your answers!
Enlightened over the lamp, I realized what kind of clearance was discussed. The rift was between geometric figures without referring to them.
Lily, glue the two halves to new map - why? Can I wear the two halves together with you? or glue them into one, adding in the floors?
убивашка
Post by убивашка » Wed Jan 27, 2016 14:33
Speaking of the Slavic character.
When I showed this card to the healer, he said,"heard a bell, but don't know where he is." This symbol should be located in the upper right corner.
Акела
Post by Акела » Wed Jan 27, 2016 14:58
убивашка wrote:speaking of the Slavic character.
And the healer cross Svarog, forehead top right corner is? :?
убивашка
Post by убивашка » Wed Jan 27, 2016 16:51
don't get the joke.
Post by ЛИЛИЯ-Р » Wed Jan 27, 2016 18:45
убивашка wrote:speaking of the Slavic character.When I showed this card to the healer, he said,"heard a bell, but don't know where he is." This symbol should be located in the upper right corner.
Is in the upper right corner , that's right, when viewed from the front side on the Room , just she'll be in that corner, but caused the turnover with the upper left corner. But the Room you are facing from yourself. Also all the Feng Shui)))) .
Пользователь
Post by Пользователь » Mon Feb 08, 2016 15:04
ЛИЛИЯ-Р wrote:But the Room you are facing from yourself.
Yes, that's not a fact. The parlor-"the crack" had to wear face to his, then new, like as not fundamentally become, recently heard also on summary of yourself. Where is the truth?
Post by ЛИЛИЯ-Р » Tue Feb 09, 2016 14:03
Do something about the roundels, as you put it , I wrote about the other side that gives a little different effect))))I Have it in one pocket and some Stora -bezraznitsy for me right now. It works . And the cards the same structure , but enhanced, at least for domes them to the rib place)))also works.
ММ
Post by ММ » Tue Feb 16, 2016 6:09
Can the chamber help against cerebral palsy? Or any other product LIK?
АСД
Post by АСД » Sun Feb 21, 2016 1:12
ММ wrote:Can the chamber help against cerebral palsy? Or any other product LIK?
Let me ask another question. What is considered using? If we assume full recovery of the child from cerebral palsy, the Chamber will not help. On the other hand usually children with cerebral palsy treatment, gymnastics, etc. the use of the Parlor will make these methods of rehabilitation are more successful. This conclusion can be done indirectly by considering the principles of operation of the Parlor, which on this site much has been said. This is what we say, and some scientific reports that are posted on this website.
Interaction studies of the Parlor with children with cerebral palsy we have not performed.
To improve rehabilitation programs I recommend to use Svetlitsa Super (and not only children but their parents as well).
