You have to consult with your doctor.сергелис wrote:hi, Andrey, tell me please, is it possible to use MM or discs , with M. diagnosis: Macroadenoma the pituitary gland.(the tumor is benign). Thank you.
Contraindications
- Contact:
- Contact:
A flickering light (the sound this is not observed) is strongly influenced in a negative way on individuals with cardiac arrhythmia (symptoms increases). Similarly, potential failures in the presence of a stimulant. Perhaps the body is starting to adjust, in addition to stimulant and rhythms no longer match... But because the consequences can be fatal, it is better not to experiment.БородаНелли wrote:'ve always wanted to know why contraindications leput this:
- Persons with pacemakers.
- Contact:
- Contact:
2nd track Star Wanderer or a Massage of the Brain (may be difficult for an elderly person). Initially, the noise will increase.Слепченко Сергей wrote:Dear Andrew here at my mother's loud noises in the head,and the doctors can't tell what it is,prescribe medication and they worse.What would you recommend?
- Contact:
- Contact:
I have a question: is it Possible to use mindmachine for reabelitatsii after an ischemic stroke, and the constant high pressure? Pressure try to reduce with the help of folk remedies, but it turns out poorly, most certainly the effects of the drugs. What advise, what mindmachine advise to buy? And what discs to begin with?
- Contact:
Hello.Владмир wrote:I Have a question: is it Possible to use mindmachine for reabelitatsii after an ischemic stroke, and the constant high pressure? Pressure try to reduce with the help of folk remedies, but it turns out poorly, most certainly the effects of the drugs. What advise, what mindmachine advise to buy? And what discs to begin with?
If there are no contraindications, you can. Fits any car with blue and red (blue) points.
Of disks Guide, Healing, Massage of the Brain.
- Contact:
Hello.
I had TBI in ' 95, the year the flu, which gave a complication: infernal headaches, didn't require any drugs. the attacks lasted 2-3 hours, was accompanied by strong muscle tone of the head (occipital region of the jaw). diagnosis: post-traumatic encephalopathy. after 4 years the seizures have changed - the pain went away, but fatigue, stress or hunger, lost consciousness (5-7 times per month)
Now fainting happen 1-2 times a year.
I used to fall asleep very late (2-4 am), and now at 10 already forces are not as sleepy, and generally after 18:00, feel very tired.
Tell me that all of this "richness" can I use a MM and your CDs?
Thanks in advance
Thanks in advance
Good day!
In 7 years, as a complication after suffering a bad flu (the temperature rose above 41 C.), appeared tick (concrete form with the passage of time "walking" - it could be twitching of the head, neck, hands, eye blinking, etc.), medical language it's called so - "generalized hyperkinesis" )
With age, to 30 years, "learned" (so to speak) to control these movements, arbitrarily relaxing - and, in principle, it works and ticks are practically invisible. Sometimes "get out", if you do not follow them, for example, under intense stress, all sorts of nervous situations, etc.)
BUT. epileptic seizures was never from the beginning of history with ticks; strobe effect stand absolutely fine (eg. many times did the EEG with hyperventilation, stimulation of the flashing light, etc.; video games, movies with flashing scenes, the sunlight between the trees, etc. - never any problems did not cause )), in transport not swayed ))
In short, is it possible to use MM or not? ))
- Contact:
Hello.Шумелька wrote:Hello.
Thanks in advance
Drives safely, but with the light carefully. If there is vzmozhnost somewhere to try.
- Contact:
Hello.Иван 1980 wrote:Good day!
I think it is possible.
Thank you. What drives would you recommend in my situation? (note absently, unable to focus when reading and in General for a long time on something, forget, high temper and fatigue)Андрей Патрушев wrote:Hello.Шумелька wrote:Hello.
I had TBI in ' 95, the year the flu, which gave a complication: infernal headaches, didn't require any drugs. pressurelow lasted 2-3 hours, was accompanied by strong muscle tone of the head (occipital region of the jaw). diagnosis: post-traumatic encephalopathy. after 4 years the seizures have changed - the pain went away, but fatigue, stress or hunger, lost consciousness (5-7 times per month)
Thanks in advance
- Contact:
- Contact:
please advice
Hello Andrew! Tell me, what kind of car do You recommend to buy? I want everything at once ( healing, memory, control emotions, etc.), somehow this train, if so where and how much it costs. And the roof of this car not going. And yet, I do not understand who makes these machines, craftsmen?
- Contact:
Re: ask for advice
Hello!Ариадна wrote:Hello Andrey! Tell me, what kind of car do You recommend to buy? I want everything at once ( healing, memory, control emotions, etc.), somehow this train, if so where and how much it costs. And the roof of this car not going. And yet, I do not understand who makes these machines, craftsmen?
You will approach any machine. Within 21 days of regular sessions, You will be able to improve memory and immunity and will be better able to manage their emotions. You can buy on this website, there are numerous methodological books (free) for all your partitions.
"When razbegayutsya walls, the roof goes"...
Machine do in the United States.
