Healing 3. New 2019 from Andrei Patrushev
Post by Андрей Патрушев » Thu Mar 14, 2019 14:37
derrickof course Healing 3, etc. are not forbidden, but according to your own words You have too many alpha waves in the frontal lobes, therefore, recommended MM2.
Дерика
Post by Дерика » Fri Mar 15, 2019 9:34
In the method TANK when considering indicators is considered good when closer to 100%. I was told just too bad that so few in the back and not raised, only once had 70%. I have a lot of sympathetic, I would parasimpatic to awaken and bring them to balance.
Дерика
Post by Дерика » Fri Mar 15, 2019 9:46
Immediately after Explorer Исцеление3 or take a break? I'm under the Conductor fell asleep almost with the beginning of the countdown and Wake up (float) sometimes, You hear a short time and fail again, sometimes only at the end, removed the headphones and glasses, and to bed, often right up in the morning. This progress in relation to sleep. And the dreams began to dream about my stressful story, which was apparently the trigger. I thought I let go of the situation, but now I understand that there is. Only now I understand that perhaps you begin to let go. And yet, Исцеление3 to listen to with glasses or not?
Post by Андрей Патрушев » Fri Mar 15, 2019 12:28
Дерика wrote: ↑
Can.
Дерика wrote: ↑
Of course, sunglasses.
Дерика
Post by Дерика » Fri Mar 15, 2019 13:59
Thank you
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Post by Иван Славов » Fri May 17, 2019 5:34
Владимир Никонов wrote: ↑
Fri Jan 18, 2019 17:06
we can recall that the ancient Egyptian priests healed many diseases through meditation on the Golden light. And obviously followed the concept of wave-particle duality, because the light from them was at the same time the flow of "hot Golden sand" made of tiny, not visible
Where can I read about it?
Post by Андрей Патрушев » Fri May 17, 2019 9:14
Иван Славов wrote: ↑
I still remember in old age. :oops: In my opinion, the book about Hermes Trismegistus.
