Need help to determine what it could be
сол
Has thanked: 14 times
Been thanked: 14 times
Re: Need help to determine what it could be
Post by сол » Fri Nov 03, 2017 18:01
what you see is what you write ))) Intimidate that man does not exist ))) This is black, though some kind of mask wear.
Igor...I'm very good...strange that you write about it!
directly wonder....
is "believing" and there is "know". As long as you believe - you just hope, imagine, dream, fantasize. When you know you have no options to dream, to fantasize and so on )))
Faith of knowledge is different because you can explain how exactly works your faith. What she achieved. What the mechanics. As connected with the facts.
This is as the dollar was formerly backed by gold, and then became unsecured nothing and began hyperinflation in the world )))
Here is your hyperinflation faith... On what it is based on what values? Never in all the time of intercourse did not see that you wrote about values. And never saw that you wrote about your experience. So you have no experience or values. That is the base for your faith. So your faith is just a fake, but rather copied. And your own - nothing.
Therefore, recommend you not to count on the next life and especially the last (which you do not remember and can not remember in principle). Because you believe in them with the sole purpose of hurry to escape, because you do not like to live. But with that intention nothing will come of it )))
Рита С
Has thanked: 4 times
Been thanked: 30 times
Post by Рита С » Fri Nov 03, 2017 18:37
Reincarnation is only for the advanced, the rest will dissolve into nothing :)
сол
Post by сол » Fri Nov 03, 2017 18:41
Reincarnation is only for those who have ))) But if anything its not - something to reincarnate? Complex biological gramophone playing other people's records and entirely of them? ))) .
Логия
Has thanked: 111 times
Been thanked: 47 times
Post by Логия » Fri Nov 03, 2017 23:39
сол wrote:what you see is what you write )))
och evident in the posts)))you are right frame))))
сол wrote:and Therefore recommend you not to count on the next life and especially the last (which you do not remember and can not remember in principle).
why do I need your advice???and even with the prediction ?I asked?))))
сол wrote:And if its not - something to reincarnate?
so you and your example do not believe in reincarnation?..OK)))
about the experience and values=can you say about the same thing...all copied from books and Internet.....and issued their own thoughts...
not good actually it is.....
the difference is that I know this...and you continue to reside in their own pomp and deslanoside...
it kills.....
The topic, sorry for flooding....PTS would like to speak....
сол
Post by сол » Fri Nov 03, 2017 23:51
it is not in faith, but in logic ))) If you have anything of his own, but there is just faith in someone else (copied beliefs) - what then to reincarnate? This one's convictions? )))
Your experience, thoughts and values it is not visible... Just a copier...
Логия
Post by Логия » Sat Nov 04, 2017 0:04
сол wrote:Your experiences, thoughts and values it is not visible..
so I say the same to you...not seen you my.nothing.......solid...ungrateful plagiarism..because you still manage to decry that's where the thoughts....
nothing...nothing more)))
сол
Post by сол » Sat Nov 04, 2017 0:04
it you often write... But it only seems to you ))) Because you never will be able to find the source from where I copied, because none of this, in principle, no on the Internet and in books in this combination)))
When it seems possible to cross, the obsession will be gone. (just kidding, not lost, because baptism is not a gesture, and such a special procedure, which is also not described anywhere. While it will not pass - so it will seem)
Логия
Post by Логия » Sat Nov 04, 2017 0:07
сол wrote:in Fact you will never be able to find the source from where I copied, because none of this, in principle, no on the Internet and in books in this combination)))
When it seems possible to cross, the obsession will be gone. (just kidding, not lost, because baptism is not a gesture, and such a special procedure, which is also not described anywhere)
Aha...and decided that the blanket pull..you are funny....and so small))))
what you broadcast I've ever met on the Internet many, many times....
how much longer can you be fooled?
сол
Post by сол » Sat Nov 04, 2017 0:08
the difference between "know" from the "seems" is that in the first case, people can confirm my words )))
So, give the source ))) Those places which seem similar - it will be very interesting.
But the answer is most likely "why, I have nothing to do"... This is "think" ))) And when it seems - to be baptized you need to... Fire, water and copper pipes )))
If you have all seen everywhere - decode the last phrase )))
Логия
Post by Логия » Sat Nov 04, 2017 0:10
mint water....goose bumps -- threads=it's all your evidence???or something else?
Логия
Post by Логия » Sat Nov 04, 2017 0:11
сол wrote:decipher the last sentence )
I read about it in your book..let's have another question
сол
Post by сол » Sat Nov 04, 2017 0:11
About copper pipes, I did not write ))) But I've got it... So give a breakdown ))) What are the copper pipes )))
Логия
Post by Логия » Sat Nov 04, 2017 0:12
otherwise, the iron pipe...and iron is a blood
сол
Post by сол » Sat Nov 04, 2017 0:13
no, look further ))) While the seem will not cease )))
Логия
Post by Логия » Sat Nov 04, 2017 0:14
my option right))))
I will add only the copper from someone defended themselves, precisely now I do not remember
сол
Post by сол » Sat Nov 04, 2017 0:16
Option two:
Option 1: to rest assured that your option is correct... And stay in his "it seems"
Option 2: you step across the threshold of pride, to admit that you something there was seeing things. And to get the correct answer ))
сол
Post by сол » Sat Nov 04, 2017 0:17
Can network search, I took out )))
Логия
Post by Логия » Sat Nov 04, 2017 0:18
сол wrote:Option 1: to rest assured that your option is correct... And stay in his "it seems"
well...you know...why not concepts and application?
I will add more=a lot of options...more than you can imagine....but the Mind prefers logical for him at the moment...
Логия
Post by Логия » Sat Nov 04, 2017 0:20
сол wrote:Can network to find, after all I took out )))
I have nothing to look=my answer is the most correct at the moment for you
сол
Post by сол » Sat Nov 04, 2017 0:20
it's not about what I know ))) And about that - do you have the most something different... Or just the insatiable madness of the brain, which is trying to copy and dump in a bunch without thinking... And knocking and lying in a heap under an oak secular, eating acorns to the blade Roots to undermine.
Логия
Post by Логия » Sat Nov 04, 2017 0:34
SolPTS clever and manly...compare me with a pig, even if not directly...
and so...so I would say, right...what a wag is....
this is a reaction to the apparently empty))))
there is a contact))
сол
Post by сол » Sat Nov 04, 2017 0:35
Well, first and foremost, this poem is about science... Which is very far away from you and the fruits of which you use... Like acorns my descriptions ))) But, judging by the way you touched it... is This true?
"it's hurting the tree",
Oak with her Raven says:
"If the roots are bare, it dry can."—
"Let them dry", said the Pig:
"Did what I was not worried;
It's the use I see little;
Although age was not either, no compassion;
Only acorns were used: I them grow fat".—
"Ungrateful!" you been charming Oak it here:
"When would up could raise you mug,
You have been seen,
What are these acorns grow on me."
Логия
Post by Логия » Sat Nov 04, 2017 0:37
сол wrote:And that - do you have the most something different..
so you have to define something in nothing, so can not see.....and I declare is not the first time-many have read and taken note.....a lot of this just counter people....
and you like were born from....adults and intelligent type))))
сол
Post by сол » Sat Nov 04, 2017 0:39
and you're like born once....adults and intelligent type))))
I was born just a very kind, sensitive and with an innate empathy. And long could not understand where I was, thinking that all such )))
But that's because I made all possible mistakes, broke everything, was wrong in everything and tried all the stages and steps... So I feel so good and understand your condition, and other )))
And smart I made myself like everything else... Through the efforts.
вотан
Has thanked: 94 times
Been thanked: 25 times
Post by вотан » Sat Nov 04, 2017 0:42
game interpreter.well, to anyone or anything to fuck....enough to grab his attention.anyhow little() gained a more impressive size( ).using the resources of the donor.all the same, people still, and the energy-informational essence.
