The Updated Navigator.
Thanks for the clarification.
Re: Updated Navigator.
So after they were in memory of the device (at least on my device) and You, on the contrary, wanted to free them from the memory of the device to missing firmware.Алексей Крячко__ wrote:All sessions that have been reworked for Pathfinder at the moment recorded in the memory of the device. They can certainly duplicate in files *.SES and write to the folder on the flash drive. But they do so in the device is, even if not written to this folder. And run these sessions takes place via the menu "Training"-> "Basic session". If it's necessary, then I will ask to record them on a memory card and view files.
Well, let it be in memory if only the device files *.SES reproduced. And new will be on the flash drive, for example, in the section "Library" place.
Healing in Pathfinder
Good day!
Yesterday I listened исцеление1 Andrei Patrushev on the Navigator.
At the end of the gate ends before the sound for a few minutes (not timed exactly).
I run through the Room. Gate? Maybe it's not right or mistake have crept in?
Well, che?митек wrote:At the end of the gate ends before the sound for a few minutes (not timed exactly).
So, for the record, no problem.Андрей Патрушев wrote:Well, che?митек wrote:At the end of the gate ends before the sound for a few minutes (not timed exactly).
Алексей Крячко__
I refused, because memory is enough. And in addition, in the Navigator 2 set of built-in sessions accompanied by a tooltip that says what kind of session and why don't need to see the user manual. When selecting files you can't do that.Андрей Патрушев wrote: So in fact they were so in memory of the device (at least on my device) and You, on the contrary, wanted to free them from the memory of the device to missing firmware.![]()
Navigator - fire, good body and head to give
If there is more backlight on the keys was all super.
I have a problem, when I try to run any of the CSP sessions, writes that invalid file and throws back to the menu. As from the start?
Loew
The Player/Combs.panel/session.csp/Enter
