New! Endorphins 2
Re: New! Endorphins 2
Post by Андрей Патрушев » Mon Oct 02, 2017 9:38
Владимир Р. wrote:was referring to this moment. If you listen to e-2 rate, what is the maximum gap you can do to maintain consistency?
What changed?
Владимир Р. wrote:If e-1 or e-2 to listen little by little (e.g., 15 min), but not fully, how little? You are always the first 15 min or 1 day the first 15 min, 2 day 15 and 30 min, 3-day, 30 to 45 min?
As you wish.
Владимир Р.
Has thanked: 22 times
Been thanked: 9 times
Post by Владимир Р. » Fri Oct 06, 2017 7:41
Андрей Патрушев wrote:Also to the connectivity classes (fitness, if you want) are maintained, one disk to listen to at least the third day.
If you listen to e-2 scheme 15-15-15, then apparently nothing will change. But if the scheme every 3 days in length, 63 days, what is the maximum gap you can do to maintain consistency? Is it possible to listen to the 4th or 5th day?
Post by Андрей Патрушев » Fri Oct 06, 2017 9:17
Владимир Р. wrote:And, if the scheme every 3 days in length, 63 days, what is the maximum gap you can do to maintain consistency?
No. In this scheme already laid down the maximum gap.
ЮрийСт
Post by ЮрийСт » Thu Nov 30, 2017 13:35
Good day,
Disk Endorphins-2 increases the concentration?
As far as I know, increases the concentration of dopamine, not endorphins (and serotonin), hence the question
Thank you
Post by Андрей Патрушев » Thu Nov 30, 2017 14:40
ЮрийСт wrote:Disk Endorphins-2 increases the concentration?
Not really, rather a curiosity.
Иулия
Has thanked: 8 times
Post by Иулия » Sun Dec 24, 2017 10:19
Hello! Faced with some strangeness when you start working with the "Endorphins-2" increases the level of aggression, there is a suspicion that a lot of energy and it is not consumed, to put it no where and out aggression, and this positive effect is not happening... What to do!? Go dig, run or to the gym,or can quit to work with this disk?
Post by Андрей Патрушев » Sun Dec 24, 2017 10:51
Julius
Hello.
Best to quit. :)
Эксперт
Has thanked: 3 times
Been thanked: 4 times
Post by Эксперт » Wed Mar 28, 2018 19:53
Not critical to listen to the beta-energy through the day?
Post by Андрей Патрушев » Wed Mar 28, 2018 21:05
Expert
And they themselves have understood, what asked? :)
Эксперт
Post by Эксперт » Wed Mar 28, 2018 22:09
I mean nothing if you listen to the endorphins-2 through the day?
Post by Андрей Патрушев » Wed Mar 28, 2018 23:33
Expert
Nothing. :)
Иностранец
New! Endorphins 2
Post by Иностранец » Mon Nov 19, 2018 2:55
Translation in English, if anyone is interested
___________________________________________________________________________________________________
"Endorphines-2"
This is the second audioprogram built on beta-waves (similar to Endorphines).
Unlike the Endorphines, this program has a unique frequency matrix that allows enhancement of user's own brain waves (attributed to particular listener) using the holophonic effect autofocus rather than imposing certain frequencies.
Like the Endorphines, this Endorphones-2 program is aimed to increase alert, energy and promote natural production of endorphines.
Compared to the previous version, the Endorphines-2 has enhanced effect on mental abilities (focus, short-term memory) due to use of higher frequencies.
Hence, this audioprogram is designed to create good mood, eliminate depression and increase learning abilities.
Like other audioprograms with high frequencies, this product can help to do the following:
• clear mental fog
• think faster than before
• improve short and long-term memory
• improve attention, focus
• improve multitasking
• widen the spectrum of audible frequencies
• eliminate sound hypersensitivity
• increase self-confidence, eliminate anxiety and baseless fears
• enhance fine motor skills and general ability to control the body (dancers, artists, carvers, jewelers, martial arts, machinery operators)
• enhance ability to learn and understand foreign languages
• clear tinnitus
The best effect can be achieved by using stereo headphones. The optimum schedule for listening series is one time per 3 days. It is important to make a break for not less than 3 weeks after 21 sessions. For ADHD is more advisable to use 15/15/15 schedule (15 days of listening, 15 days of break and 15 days of listening), since it has shown better effect. The 15/15/15 schedule can be extended up to 3 months.
Is it recommended to drink a class of clear water before and after the session.
Note: Since this program increases alert and energy, it is not recommended to be listened to in the evenings (at least not later than four hours before going to bed).
It is not recommended to listen to the whole program more than once per day. Is it possible to make several sessions of 5 to 10 minutes with a break of not less than 3 hrs between them. The total listening time should not be more than 45 minutes per day.
It is important to remember that if you are very tired or did not sleep for a while, the program will make a paradoxical effect, which is drowsiness and inhibited thinking.
The same effect (falling into sleep while listening) is observed with persons diagnosed with ADHD and diffuse axonal brain injury (DAI).
There is not direct correlation between loudness and efficiency, therefore please always choose volume level as comfortable for you.
Age limit! The listeners should be older than 14.
Sometimes (quite rarely) the listeners can have OOBE (out-of-body experience) when the mind leaves the body and observes it from outside. This is safe, even though unusual quote. Please stay calm and allow yourself to gain new experience. You'll return to your body as soon as you think about it and move.
This program is not intended to replace any medical treatment. It can have unpredictable effect if used along with alcohol, narcotics or psychoactive drugs. Under no circumstances you should be listening to the disk while driving or operating potentially dangerous machinery.
Duration is 25 minutes. AudioStrobe is not present.
Please send your feedback and questions to: patrua@mail.ru
Andrey Patrushev<
Любимая Элен
Has thanked: 9 times
New! Endorphins 2
Post by Любимая Элен » Wed Jun 19, 2019 15:05
Yesterday I listened for 15 minutes at work really cheered and inspired after lunch.
Today I start to listen in the morning - at some minute shut down and fell asleep.
There have this squeaking be? Has put, of course, to the minimal volume, but it is very annoying...
New! Endorphins 2
Post by Андрей Патрушев » Wed Jun 19, 2019 16:10
Darling Helenthere is nothing superfluous. :)
New! Endorphins 2
Post by Андрей Патрушев » Wed Jun 19, 2019 16:13
Alienenclose with Nikonov the partnership agreement and will post a link with description on your page - you can make a little money.
Любимая Элен
New! Endorphins 2
Post by Любимая Элен » Wed Jun 19, 2019 16:27
Андрей Патрушев wrote: ↑
I'm not against it, it's just a question-'ll just keep going even quieter sound.
