Integral TATTOO
LONfor this and need reset. After applying the code symbol basic prenatal and restart the basic facilities, everything will fall into place and come to an understanding. Or not. But with sensations and illusions will understand.
Ярго Морок
- Has thanked: 1 time
- Been thanked: 7 times
Re: IC TATTOO
Olga, and here it's the same and not pleasant - ..."the victim is always questioned and can't admit that she's the victim, as you have to recognize the inconsistency..."
Re: IC TATTOO
In this regard, the question arose, is particularly important for girls: how crystal tattoo will affect the emotional background?Ярго Морок wrote:the concept of "FEELING" in followed by the root NAME value - SCHU, feel, what significantly body. In this way, the substitution of the concept of Sense - more related to the interpretation of EVENTS at the level of the usual-imposed interpretation of a particular compilation of the release of hormones\neurotransmitters and the response of the Brain (limbic system) to certain stimuli.
Ярго Морок
Re: IC TATTOO
Incidentally, it is interesting that the first reset and output in NAV was after tweaking the program DE-concentration Patrushev. Here in the "spillage" passing over the river Styx for the first time felt a Sacred Horror of the aggregate composite Simbiotel\parasites of the program self-awareness "I".
Ярго Морок
Re: IC TATTOO
Difficult. The girls limbic system 6-five times more active male. And if it has energy and energize.... Better, of course, if there is support. Carries much.
Re: IC TATTOO
Ярго Морок wrote:Olga, and here it's the same and not pleasant - ..."the victim is always questioned and can't admit that she's the victim, as you have to recognize the inconsistency..."
Ярго Морок wrote:Here the people, too, not just gathered.
Re: IC TATTOO
Аура wrote:Sometimes the drive crystal tattoo does not notice the changes that happen to him, but for others it's obvious.
Apparently, everyone has a different reaction, depending on the customization possibilities, and essences.Ярго Морок wrote:Difficult. The girls limbic system 6-five times more active male. And if it has energy and energize.... Better, of course, if there is support. Carries much.
Ярго Морок
Re: IC TATTOO
therefore girls do that-thread the structural and weakly active Moon stone, Jasper,Jade. To begin with.ОльгаВВ wrote:Аура wrote:Sometimes the drive crystal tattoo does not notice the changes that happen to him, but for others it's obvious.Apparently, everyone has a different reaction, depending on the customization possibilities, and essences.Ярго Морок wrote:Difficult. The girls limbic system 6-five times more active male. And if it has energy and energize.... Better, of course, if there is support. Carries much.
I, for example , the body did not take Black agate, considering what the tattoo was already Rubin, Cheryl, Shungite and Quartz. But it interacts with the Thorium, Gold and Vermilion. It is impossible in a processor that draws only Android "to sew" XP full version. Gradually, gradually and in a timely manner.
Someone and Jasper and Quartz in the first phase for the structure is enough. As a symmetric crystal structure on which we can rely in resonace.
It's another mode of living. And children and to feed them has not been canceled. Although assotsialnost, of course, evolving. Leaving the time - out of the dependence on temporary programs.
Ярго Морок
Re: IC TATTOO
well, not all so tragic. There are bonuses. OBVIOUSLY becoming, and a way of transforming one stream of efforts at any choice (Health, Finance). Just switches ATTENTION from one to another. So and what is bad?If there is neither good nor bad? There is action and result.Лон wrote:Zeroing..application..the victim emotionally...the background...the cuckoo "normal" person will not carry? I have to work..raise children ... with people "normal" to chat..? A serious matter.
our BRAIN is any GENERATOR of the EVENT. And here is what it generates? or Who Generates? and that relies on the one who Generates?
Re: IC TATTOO
Is it possible at Your level to determine by looking at a person that it is preferable and where, mean tattoo, or still work going on sorting options?Ярго Морок wrote: assotsialnost Although, of course, evolving. Leaving the time - out of the dependence on temporary programs.
Ярго Морок
Re: IC TATTOO
Of course.
The energy matrix of primary. It dictates the geometry of the bones and the modes of visceral systems. Well, here, protocols of diagnostics - not only lazy doctor. I mean the availability of information. And if in the 91 year of the last century about the lymphatic drainage only may said, today's burst of openness allows you to learn very precise methods. If another 25 years to do it, eyes on the fingers sprout.
The selection there is someone to do in our time. Not here.
Ярго Морок
Re: IC TATTOO
Be honest with yourself and in front of You:
-Choice crystal essences, trust your feelings - understand, but very expensive to loop through trying the whole range
-How to distinguish the illusion of feelings of feelings - not understood (the Lunar root tried-but not sure where he was feeling, and what's not. Bad also can not say anything, believe that not in vain was.)[/quote]
And like as there are protocols selection "under the task". I just worked from a mineral or combination of minerals as needed. And it picked up the essence for payment nourishing body.
The lunar root - the correct use of the nebulizer. Not through the inhaler, namely the nebulizer. At the rate of 3 drops per 100 ml saline solution. Here then is a palpable result. Bronchopulmonary actively start to recover with all the...
Re: IC TATTOO
The idea was to start with jade, then beat on the lunar root. Well understood here, that was passed.Ярго Морок wrote: And like as there are protocols selection "under the task". I just worked from a mineral or combination of minerals as needed. And it picked up the essence for payment nourishing body.
To use a nebulizer -it is generally a revelation to me, sorry that this is a lunar root of this is not documented or classifiedЯрго Морок wrote: The lunar root - the correct use of the nebulizer. Not through the inhaler, namely the nebulizer. At the rate of 3 drops per 100 ml saline solution. Here then is a palpable result. Bronchopulmonary actively start to recover with all the...
Ярго Морок
Re: IC TATTOO
YES, no, no secret. Just empirically found. Following the Moon as Root...Well, a bit of alchemy Taoist immortal.Лон wrote:The idea was to start with jade, then beat on the lunar root. Well understood here, that was passed.Ярго Морок wrote: And like as there are protocols selection "under the task". I just worked from a mineral or combination of minerals as needed. And it picked up the essence for payment nourishing body.
To use a nebulizer -it is generally a revelation to me, sorry that this is a lunar root of this is not documented or classifiedЯрго Морок wrote: The lunar root - the correct use of the nebulizer. Not through the inhaler, namely the nebulizer. At the rate of 3 drops per 100 ml saline solution. Here then is a palpable result. Bronchopulmonary actively start to recover with all the...and therefore probably the most effective method of application.
About selection - if the problem was health - better with the Lunar root to start. Jade he is very alchemical - it must be able to interact.
which mineral is the most noticeable? But how ? And where in the body? What is its geometry? And the angle of twist if it is? So make a matrix map of feelings for each stone. That is, if the Purpose of such questioning is to raise stress in the Brain to develop the perceptibility of minerals (not all of them -crystals)
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
Re: IC TATTOO
Jack Sparrow, that's just not culturally..)Ярго Морок wrote: and we have imposed the belief that it is either the branding of Slaves and prostitutes - the Judeo-Christian version, either on shoulder blade men photos of Jack-of Vorobja stuff...strange resonace
Ярго Морок
Re: IC TATTOO
Sterifilt Yes, Yes...
I myself have several of Jack Sparrow problemilla - 2005 when partying among tattooists tightly, saw brutal lad - seems very fan of Depp. To the artistic quality no complaints - picture. But when you consider that even in Ayurvedic culture has a whole section of the diagnostic signatures of body you can imagine yourself Tovarisch program recorded on a subtle plane.
Ярго Морок
Re: IC TATTOO
Re: IC TATTOO
Interesting character, will reveal its meaning? What is there in it that means. Is full variations...
I would like to find a common language on the basis of this character, to complement the common understanding, and continue to discuss other characters, some of which I do not understand yet.
It would also be interesting if you would have posted a library of symbols with no explanation - it is interesting to watch, and then discuss.
Re: IC TATTOO
Interesting interpretation... a More complete version of the symbol is the logo of the group picnic
but this does not mean that a truncated symbol is wrong, as it is dynamically built, consistently, with a number of transformations in the process, from one line adding lines. Step by step. We can say as the stars on the epaulets and insignias )) is Possible and the application of inappropriate tattoos is not so correct...
The song is cool about stripes
СтаниФилмТВ
Re: IC TATTOO
.по. wrote: We can say as the stars on the epaulets and insignias )) is Possible and the application of inappropriate tattoos is not so correctly
For some I guess it would be interesting, all meridians to fill with points, and to sign each. Yoga may also not refuse, all of the Chakras and Kundalini.
if forgotten that it is always possible to look in the mirror )
СтаниФилмТВ
