Ring. Flame
As always! It should appear high-quality and useful information, as immediately swooped down brigade Basmachi and the subject begins to swing.
We can do without infomotor and wait continue for the purity and clarity of thought? Knowing the thoroughness and meticulousness of the construction, there is a lot more. Because different sizes and applications, etc.
Besides, personally, I two days it took to find the wire screen for the manufacture of the device Bertinelli, plus today found the copper wire for the manufacture of rings. Tomorrow is going to look, who to me is tied up and sapal. And you are worn out?
- Шалтай Балтай
Re: Workshop. Rings on the slim.
SavedСмелый wrote:As always! It should appear high-quality and useful information, as immediately swooped down brigade Basmachi and the subject begins to swing.
And che himself?
Hands are not imprisoned there. I'm more on the subject, to organize, to direct, etc.Шалтай Балтай wrote: And che himself? the point is not very tricky
By the way, there from slim about insects. So I today to an old friend who has an apiary. You supposedly said, in which the range of expected yields of honey. Well, in such limits. Okay, write down and offer him to make a ring to place in the apiary, and in the fall, remember the past, and weather conditions and the harvest and related factors.
It is interesting to me!
A totally different thing compare http://www.ksv.ru/%C8%F1%F1%EB%E5%E4%F3 ... R002.shtmlдругой wrote:is hoops Merovingia A. Naumkin.
Re: And what are we in the rings of a Tensor?
Many "ancient" "jewelry" have similar shapes, hilts of swords of all sorts are worth. Of the same shape. And obviously not in ukrashatelskih order
- Шалтай Балтай
Merovingians
you would go.....
okay, just kidding
against myrevenge do not have a niche, but said, IMHO the topic is very good. poorly prorabotano
Products slim 25 years, thousands of people around the world, North, South America, Europe, Africa
+ receive training as well around the world
I already spoke with Andrew, Catarina can to us to invite, let us learn to mind to reason
the technology looks perfect, go on u-tube, the cloud of material + twisted sage, i.e. Brain Besco
another thing is that all in English, well, I harnessed translate Maltz
https://duckduckgo.com/?q=lightlife+technology&t=h
merovingen still digging and digging
I can go look, while th ... then there is the case
you would go.....
okay, just kidding
Шалтай Балтай wrote:Merovingians
you would go.....![]()
okay, just kidding
Naumkin is very hard(IMHO) digs. A syllable from him God forbid
Share your impressions of the product.
- Шалтай Балтай
thank you for your question, AishaАиша wrote:Share impressions of the product.
BUT
this branch workshop, nothing more
reviews will create another branch that would not flame this
most likely it will happen after the presentation, if possible.
Humpty Baltay
I have a coin 3 rouble silver Bank of Russia a little more of this washer in diameter and to my sign of the zodiac it can be used?
talked to Alexander Bay (famous master of non-contact fight) , he told me that normal shoelaces tied on the head vnatyag, to relieve headaches. I do not attach any importance then ,as the topic of the conversation was ascontact . it turns out all works in varying degreesчернокнижник wrote:Yep, such a thing has long yuzayu))) Do yourself a Hoop size of the head, when "pressure" helps. "Golovnyak" is not just headaches, conditions are different - from a vague pressure to the left or right until quite distinct crackling in the back of his head. Works quickly, usually about five minutes is required. Some days, when raging "magnetic storms" or whatever the case, promotes clarity of perception. In my opinion the most useful of my toys. Enameled wire, about a millimeter in diameter, wrapped right. Size in no way by the standards, again on the head was measured. Brazed by the rules, but as it turned out, the soldering was hidden under heat shrink. In short, all is made crooked and askew, but still works! Later, puzzled, and just a piece of wire will work or what? It turned out - works. A bit less expressive, but it works. I simply jerked his head around and not even soldered. It is sometimes useful to be gouging in such matters, did not know how, the old me had not yet caught the eye, made intuitively. The performance of the wrap have confirmed home and casual companions. Helps even when the hangover of moderate severity, if the subject is not lying)))
- Шалтай Балтай
it is rather a thought-form is a little differentЮпитер wrote:Humpty Baltay
- Шалтай Балтай
Re: TECHNOLOGY SLIM SPARLING
So, I finished the translation of the part regarding rings
Further - nodes
This is a very interesting topic, but it applies more to healing, and because I intend to return to it later
If you have questions - ask, I will try to answer if I can
All the information, even basic, to issue on the forum pages is not possible
Some of the information I intend to give during the seminar, we hope for it. This should be in video format
seminar: viewtopic.php?f=57&t=6184
Further - nodes
Thank you! Already, a vast field for reflection and action.
I want to emphasize.
So very, all of this time and place.
Personally, I'm very happy!
- Шалтай Балтай
Hey!ЗОМБИ wrote:Humpty, hi
Hi Humpty. Long time no see)
I here's such a coil twisted at leisure, is very pleasant and powerful effect is felt. Those in the apartment to hang a few pieces and Feng Shui clearly improved))
- Шалтай Балтай
Good zdraveska, Merkaba
I look at the nodes since SP, Sliema seen, but at the time did not understand
Now, responded
Lujan, vail, Logan, Ryan, and so. Doug. All of your friends, but start looking and there are more questions than answers
Slim won
By the way I recommend Brian Besko, very competent people
Now, responded
Slim won
I read on their website - gorgeous! Right magic rings! Just a thought - perhaps the ring itself can be manufactured? Only here at the elbows not to understand what a measure is... well, diameter probably has a role. if you figure it out. those who are engaged in wicker yuvelirkoy, most likely would be able to do. Interesting topic. Thanks for opening the topic, a very necessary thing!
It seems that this is an extremely serious thing. As for the user, but the manufacturer really. Responsibility for the correctness of manufacturing, significantly higher than in the manufacture of just the rings.Шалтай Балтай wrote:especially 5D chamber, try to take...
But on the other hand, given your abilities, you can be sure that you do it right. Thing probably time-consuming, making the flow do not deliver. But you can copy to place in the office mindmachine and for a fee, willing to let cleaned.
- Шалтай Балтай
about the production of the questionСмелый wrote:It seems that this is an extremely serious thing. As for the user, but the manufacturer really. Responsibility for the correctness of manufacturing, significantly higher than in the manufacture of just the rings.Шалтай Балтай wrote:especially 5D chamber, try to take...
it is possible to connect and use. this is done through "spells" (meditation) + "harmonic" ring (don't know the details)
but the thought of competent
Like this?Шалтай Балтай wrote:about the production of the questionСмелый wrote:It seems that this is an extremely serious thing. As for the user, but the manufacturer really. Responsibility for the correctness of manufacturing, significantly higher than in the manufacture of just the rings.Шалтай Балтай wrote:especially 5D chamber, try to take...
- Шалтай Балтай
[youtube]http://www.youtube.com/watch?v=ZM8KSOp-X3A[/youtube]ММ wrote:[
Like this?Photo of where to connect?
Re: Ring Of Sliema. Strategy
A video or audio recording will be made? To missing can download. Pliz.
- Шалтай Балтай
Yes, this is one of the main intentions
